Dithering Implementation for Eink Display Panel
by Daiyu Ko, Freescale
  1. Dithering
a.          Dithering in digital image processing
Dithering is a technique used in computer graphics to create the illusion of color depth in images with a limited color palette (color quantization). In a dithered image, colors not available in the palette are approximated by a diffusion of colored pixels from within the available palette. The human eye perceives the diffusion as a mixture of the colors within it (see color vision). Dithered images, particularly those with relatively few colors, can often be distinguished by a characteristic graininess, or speckled appearance.
Figure 1. Original photo; note the smoothness in the detail
http://en.wikipedia.org/wiki/File:Dithering_example_undithered_web_palette.png
Figure 2.Original image using the web-safe color palette with no dithering applied. Note the large flat areas and loss of detail.
http://en.wikipedia.org/wiki/File:Dithering_example_dithered_web_palette.png
Figure 3.Original image using the web-safe color palette with Floyd–Steinberg dithering.
Note that even though the same palette is used, the application of dithering gives a better representation of the original
b.         Applications
Display hardware, including early computer video adapters and many modern LCDs used in mobile phonesand inexpensive digital cameras, show a much smaller color range than more advanced displays. One common application of dithering is to more accurately display graphics containing a greater range of colors than the hardware is capable of showing. For example, dithering might be used in order to display a photographic image containing millions of colors on video hardware that is only capable of showing 256 colors at a time. The 256 available colors would be used to generate a dithered approximation of the original image. Without dithering, the colors in the original image might simply be "rounded off" to the closest available color, resulting in a new image that is a poor representation of the original. Dithering takes advantage of the human eye's tendency to "mix" two colors in close proximity to one another.
For Eink panel, since it is grayscale image only, we can use the dithering algorism to reduce the grayscale level even to black/white only but still get better visual results.
c.          Algorithm
There are several algorithms designed to perform dithering. One of the earliest, and still one of the most popular, is the Floyd–Steinberg dithering algorithm, developed in 1975. One of the strengths of this algorithm is that it minimizes visual artifacts through an error-diffusion process; error-diffusion algorithms typically produce images that more closely represent the original than simpler dithering algorithms.
(Original)
Threshold
Bayer   (ordered)
            Example (Error-diffusion):
Error-diffusion dithering is a feedback process that diffuses the quantization error to neighboring pixels.
Floyd–Steinberg
Jarvis,   Judice & Ninke
Stucki
Error-diffusion dithering (continued):
      • Sierra dithering is based on Jarvis dithering, but it's faster while giving similar results.
      • Filter Lite is an algorithm by Sierra that is much simpler and faster than Floyd–Steinberg, while still yielding similar (according to Sierra, better) results.
      • Atkinson dithering, developed by Apple programmer Bill Atkinson, resembles Jarvis dithering and Sierra dithering, but it's faster. Another difference is that it doesn't diffuse the entire quantization error, but only three quarters. It tends to preserve detail well, but very light and dark areas may appear blown out.
Sierra
Sierra   Lite
Atkinson
     2.     Eink display panel characteristic
a.       Low resolution
Eink only has couple resolution modes for display
     DU                  (1bit, Black/White)
     GC4                (2bit, Gray scale)
     GC16              (4bit, Gray scale)
     A2                   (1bit, Black/White, fast update mode)
b.      Slow update time
For 800x600 panel size (per frame)
     DU                  300ms
                             GC4                450ms
                             GC16              600ms
                              A2                   125ms
3.       3.     Effect by doing dithering for Eink display panel
a.       Low resolution with better visual quality
By doing dithering to the original grayscale image, we can get better visual looking result. Even if the image becomes black and white image, with the dithering algorism, you will still get the feeling of grayscale image.
b.      Faster update with Eink’s animation waveform
Since the DU/A2 mode could update the Eink panel faster than grayscale mode, with dithering, we can get no only the better visual looking result, but also we can use DU/A2 fast update mode to show animation or even normal video files.
4.       4.     Our current dithering implementation
a.       Choose a simple and effective algorism
Considering Eink panel’s characteristics, we compared couple dithering algorism and decide to use Atkinson dithering algorism. It is simple and the result is better especially for Einkblack/white display case.
b.      Made a lot of optimization so that it will not affect update time too much
With the simplicity of the Atkinson dithering algorism, we can also put a lot of effort to do the optimization in order to reduce the dithering processing time and make it practical for actual use.
c.       Current algorism performance and result
Currently, with Atkinson dithering algorism, our processing time is about 70ms.
5.       5.     Availability
a.       We implemented both Y8->Y1 and Y8->Y4 dithering with the same dithering algorism.
b.      Implemented into our EPDC driver with i.MX6SL Linux 3.0.35 version release.
c.       Also implemented in our Video for Eink demo
6.       6.     References
a.       Part of dithering introduction from www.wikipedia.org
Labels (3)
Comments
Has this changed or improved in i.MX7?
Was the Atkinson sharpen filter enabled?
Superior Dithered Images with HyperDither
%3CLINGO-SUB%20id%3D%22lingo-sub-1100219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDithering%20Implementation%20for%20Eink%20Display%20Panel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-bidi-font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-bidi-font-size%3A%2012.0pt%3B%22%3EDithering%20I%3C%2FSPAN%3Emplementation%20for%20%3CSPAN%20class%3D%22SpellE%22%3EEink%20D%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellE%22%3E%3C%2FSPAN%3Eisplay%20Panel%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3Eby%20Daiyu%20%3CSPAN%20class%3D%22GramE%22%3EKo%2C%20Freescale%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3EDithering%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22MsoListParagraphCxSpLast%22%20style%3D%22margin-left%3A%2058.5pt%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-22.5pt%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EDithering%20in%20digital%20image%20processing%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-weight%3A%20bold%3B%22%3EDithering%20%3C%2FSPAN%3Eis%20a%20technique%20used%20in%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FComputer_graphics%22%20title%3D%22Computer%20graphics%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Ecomputer%20graphics%3C%2FSPAN%3E%3C%2FA%3E%20to%20create%20the%20illusion%20of%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FColor%22%20title%3D%22Color%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Ecolor%3C%2FSPAN%3E%3C%2FA%3E%20depth%20in%20images%20with%20a%20limited%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FColor_palette%22%20title%3D%22Color%20palette%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Ecolor%20palette%3C%2FSPAN%3E%3C%2FA%3E%20(%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FColor_quantization%22%20title%3D%22Color%20quantization%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Ecolor%20quantization%3C%2FSPAN%3E%3C%2FA%3E).%20In%20a%20dithered%20image%2C%20colors%20not%20available%20in%20the%20palette%20are%20approximated%20by%20a%20diffusion%20of%20colored%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FPixel%22%20title%3D%22Pixel%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Epixels%3C%2FSPAN%3E%3C%2FA%3E%20from%20within%20the%20available%20palette.%20The%20human%20eye%20perceives%20the%20diffusion%20as%20a%20mixture%20of%20the%20colors%20within%20it%20(see%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FColor_vision%22%20title%3D%22Color%20vision%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Ecolor%20vision%3C%2FSPAN%3E%3C%2FA%3E).%20Dithered%20images%2C%20particularly%20those%20with%20relatively%20few%20colors%2C%20can%20often%20be%20distinguished%20by%20a%20characteristic%20graininess%2C%20or%20speckled%20appearance.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20text-decoration%3A%20none%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig1.png%22%20style%3D%22width%3A%20227px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38591iEDF2CD7FAF4C3C60%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22fig1.png%22%20alt%3D%22fig1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efig1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20class%3D%22GramE%22%3EFigure%201.%3C%2FSPAN%3E%20Original%20photo%3B%20note%20the%20smoothness%20in%20the%20detail%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3ADithering_example_undithered_web_palette.png%22%20title%3D%22%22%20figure%3D%22%22%202.%3D%22%22%20original%3D%22%22%20image%3D%22%22%20using%3D%22%22%20the%3D%22%22%20web-safe%3D%22%22%20color%3D%22%22%20palette%3D%22%22%20with%3D%22%22%20no%3D%22%22%20dithering%3D%22%22%20applied.%3D%22%22%20note%3D%22%22%20the%3D%22%22%20large%3D%22%22%20flat%3D%22%22%20areas%3D%22%22%20and%3D%22%22%20loss%3D%22%22%20of%3D%22%22%20detail.%3D%22%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3ADithering_example_undithered_web_palette.png%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig2.png%22%20style%3D%22width%3A%20227px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38616iA297EAE9727A0B99%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22fig2.png%22%20alt%3D%22fig2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efig2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3EFigure%202.%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3EOriginal%20image%20using%20the%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWeb-safe_color_palette%22%20title%3D%22Web-safe%20color%20palette%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3Eweb-safe%20color%20palette%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20with%20no%20dithering%20applied.%20Note%20the%20large%20flat%20areas%20and%20loss%20of%20detail.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%200in%3B%20text-indent%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3ADithering_example_dithered_web_palette.png%22%20title%3D%22%22%20figure%3D%22%22%203.%3D%22%22%20original%3D%22%22%20image%3D%22%22%20using%3D%22%22%20the%3D%22%22%20web-safe%3D%22%22%20color%3D%22%22%20palette%3D%22%22%20with%3D%22%22%20floyd%3D%22%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3ADithering_example_dithered_web_palette.png%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%200in%3B%20text-indent%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig3.png%22%20style%3D%22width%3A%20227px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38655i611ED6D253A983BE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22fig3.png%22%20alt%3D%22fig3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efig3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3EFigure%203.%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20class%3D%22GramE%22%3EOriginal%20image%20using%20the%20web-safe%20color%20palette%20with%20%3CSPAN%20style%3D%22mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-font-family%3A%20SimSun%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFloyd%25E2%2580%2593Steinberg_dithering%22%20title%3D%22Floyd%E2%80%93Steinberg%20dithering%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EFloyd%E2%80%93Steinberg%20dithering%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E.%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3ENote%20that%20even%20though%20the%20same%20palette%20is%20used%2C%20the%20application%20of%20dithering%20gives%20a%20better%20representation%20of%20the%20original%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%2058.5pt%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-22.5pt%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Eb.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EApplications%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EDisplay%20hardware%2C%20including%20early%20computer%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FGraphics_card%22%20title%3D%22Graphics%20card%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Evideo%20adapters%3C%2FSPAN%3E%3C%2FA%3E%20and%20many%20modern%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FLiquid_crystal_display%22%20title%3D%22Liquid%20crystal%20display%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3ELCDs%3C%2FSPAN%3E%3C%2FA%3E%20used%20in%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FMobile_phone%22%20title%3D%22Mobile%20phone%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Emobile%20phones%3C%2FSPAN%3E%3C%2FA%3Eand%20inexpensive%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FDigital_camera%22%20title%3D%22Digital%20camera%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Edigital%20cameras%3C%2FSPAN%3E%3C%2FA%3E%2C%20show%20a%20much%20smaller%20color%20range%20than%20more%20advanced%20displays.%20One%20common%20application%20of%20dithering%20is%20to%20more%20accurately%20display%20graphics%20containing%20a%20greater%20range%20of%20colors%20than%20the%20hardware%20is%20capable%20of%20showing.%20For%20example%2C%20dithering%20might%20be%20used%20in%20order%20to%20display%20a%20photographic%20image%20containing%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FTruecolor%22%20title%3D%22Truecolor%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Emillions%20of%20colors%3C%2FSPAN%3E%3C%2FA%3E%20on%20video%20hardware%20that%20is%20only%20capable%20of%20showing%20256%20colors%20at%20a%20time.%20The%20256%20available%20colors%20would%20be%20used%20to%20generate%20a%20dithered%20approximation%20of%20the%20original%20image.%20Without%20dithering%2C%20the%20colors%20in%20the%20original%20image%20might%20simply%20be%20%22rounded%20off%22%20to%20the%20closest%20available%20color%2C%20resulting%20in%20a%20new%20image%20that%20is%20a%20poor%20representation%20of%20the%20original.%20Dithering%20takes%20advantage%20of%20the%20human%20eye's%20tendency%20to%20%22mix%22%20two%20colors%20in%20close%20proximity%20to%20one%20another.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EFor%20%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3E%20panel%2C%20since%20it%20is%20grayscale%20image%20only%2C%20we%20can%20use%20the%20dithering%20algorism%20to%20reduce%20the%20grayscale%20level%20even%20to%20black%2Fwhite%20only%20but%20still%20get%20better%20visual%20results.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpFirst%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%2058.5pt%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-22.5pt%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ec.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EAlgorith%3C%2FSPAN%3Em%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EThere%20are%20several%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FAlgorithm%22%20title%3D%22Algorithm%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Ealgorithms%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%20designed%20to%20perform%20dithering.%20One%20of%20the%20earliest%2C%20and%20still%20one%20of%20the%20most%20popular%2C%20is%20the%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFloyd%25E2%2580%2593Steinberg_dithering%22%20title%3D%22Floyd%E2%80%93Steinberg%20dithering%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3EFloyd%E2%80%93Steinberg%20dithering%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%20algorithm%2C%20developed%20in%201975.%20One%20of%20the%20strengths%20of%20this%20algorithm%20is%20that%20it%20minimizes%20visual%20artifacts%20through%20an%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FError_diffusion%22%20title%3D%22Error%20diffusion%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3Eerror-diffusion%3C%2FSPAN%3E%3C%2FA%3E%20%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3Eprocess%3B%20error-diffusion%20algorithms%20typically%20produce%20images%20that%20more%20closely%20represent%20the%20original%20than%20simpler%20dithering%20algorithms.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpLast%22%3E%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20class%3D%22MsoNormalTable%22%20height%3D%22222%22%20style%3D%22width%3A%20733px%3B%20height%3A%20269px%3B%20margin-left%3A%2039.7pt%3B%20mso-cellspacing%3A%201.5pt%3B%20mso-yfti-tbllook%3A%201184%3B%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A%200%3B%20mso-yfti-firstrow%3A%20yes%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E(Original)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3EThreshold%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3EBayer%26nbsp%3B%26nbsp%3B%20(ordered)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%201%3B%20mso-yfti-lastrow%3A%20yes%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_63_grijswaarden.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22original.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22original.gif%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38521iADE06E6F6FC493B2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22original.gif%22%20alt%3D%22original.gif%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eoriginal.gif%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_drempel.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22threshold.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22threshold.gif%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38694i14BAFD3B8D8F9212%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22threshold.gif%22%20alt%3D%22threshold.gif%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ethreshold.gif%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Bayer.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bayer.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bayer.gif%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37787iD0017B1DEF6ED172%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22bayer.gif%22%20alt%3D%22bayer.gif%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebayer.gif%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20class%3D%22MsoListParagraphCxSpFirst%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpLast%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EExample%20(Error-diffusion)%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20margin-left%3A%20.5in%3B%20line-height%3A%20normal%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20margin-left%3A%20.5in%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FError_diffusion%22%20title%3D%22Error%20diffusion%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%20mso-bidi-font-style%3A%20italic%3B%22%3EError-diffusion%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-font-style%3A%20italic%3B%22%3E%20dithering%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3Eis%20a%20feedback%20process%20that%20diffuses%20the%20quantization%20error%20to%20neighboring%20pixels.%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CUL%20style%3D%22list-style-type%3A%20circle%3B%22%3E%3CUL%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l1%20level2%20lfo3%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFloyd%25E2%2580%2593Steinberg_dithering%22%20title%3D%22Floyd%E2%80%93Steinberg%20dithering%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EFloyd%E2%80%93Steinberg%3C%2FSPAN%3E%20dithering%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20only%20diffuses%20the%20error%20to%20neighboring%20%3C%2FSPAN%3Epixels.%20This%20results%20in%20very%20fine-grained%20dithering.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l1%20level2%20lfo3%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fw%2Findex.php%3Ftitle%3DJarvis%2C_Judice%2C_and_Ninke_dithering%26amp%3Baction%3Dedit%26amp%3Bredlink%3D1%22%20title%3D%22Jarvis%2C%20Judice%2C%20and%20Ninke%20dithering%20(la%20pagina%20non%20esiste)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EJarvis%2C%20%3CSPAN%20class%3D%22SpellE%22%3EJudice%3C%2FSPAN%3E%2C%20and%20%3CSPAN%20class%3D%22SpellE%22%3ENinke%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellE%22%3E%3C%2FSPAN%3E%20dithering%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20diffuses%20the%20error%20also%20to%20%3C%2FSPAN%3Epixels%20one%20step%20further%20away.%20The%20dithering%20is%20coarser%2C%20but%20has%20fewer%20visual%20artifacts.%20It%20is%20slower%20than%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFloyd%25E2%2580%2593Steinberg_dithering%22%20title%3D%22Floyd%E2%80%93Steinberg%20dithering%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EFloyd%E2%80%93Steinberg%3C%2FSPAN%3E%20dithering%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20because%20it%20distributes%20errors%20%3C%2FSPAN%3Eamong%2012%20nearby%20pixels%20instead%20of%204%20nearby%20pixels%20for%20Floyd%E2%80%93Steinberg.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l1%20level2%20lfo3%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fw%2Findex.php%3Ftitle%3DStucki_dithering%26amp%3Baction%3Dedit%26amp%3Bredlink%3D1%22%20title%3D%22Stucki%20dithering%20(la%20pagina%20non%20esiste)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EStucki%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%20dithering%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20is%20based%20on%20the%20above%2C%20but%20is%20slightly%20faster.%20Its%20%3C%2FSPAN%3Eoutput%20tends%20to%20be%20clean%20and%20sharp.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3C%2FUL%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20class%3D%22MsoNormalTable%22%20height%3D%22269%22%20style%3D%22width%3A%20729px%3B%20height%3A%20266px%3B%20margin-left%3A%2043.45pt%3B%20mso-cellspacing%3A%201.5pt%3B%20mso-yfti-tbllook%3A%201184%3B%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A%200%3B%20mso-yfti-firstrow%3A%20yes%3B%20height%3A%2012.95pt%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2012.95pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3EFloyd%E2%80%93Steinberg%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2012.95pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3EJarvis%2C%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22SpellE%22%3EJudice%3C%2FSPAN%3E%20%26amp%3B%20%3CSPAN%20class%3D%22SpellE%22%3ENinke%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2012.95pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22SpellE%22%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3EStucki%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2012.95pt%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%201%3B%20mso-yfti-lastrow%3A%20yes%3B%20height%3A%2077.4pt%3B%22%3E%3CTD%20style%3D%22text-align%3A%20left%3B%20height%3A%2077.4pt%3B%20padding%3A%200.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Floyd-Steinberg.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22floyd.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22floyd.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37894iC2035B9022A52B1F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22floyd.png%22%20alt%3D%22floyd.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efloyd.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2077.4pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Jarvis%2C_Judice_%26amp%3B_Ninke.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jarvis.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jarvis.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37958i16D5984B8B10D7C2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22jarvis.png%22%20alt%3D%22jarvis.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ejarvis.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2077.4pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Stucki.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stucki.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stucki.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F11181iDF19376FE9416447%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stucki.png%22%20alt%3D%22stucki.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Estucki.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2077.4pt%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20margin-left%3A%20.5in%3B%20line-height%3A%20normal%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20margin-left%3A%20.5in%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3EError-diffusion%20dithering%20(continued)%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CUL%20style%3D%22list-style-type%3A%20circle%3B%22%3E%3CUL%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l3%20level2%20lfo4%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fw%2Findex.php%3Ftitle%3DSierra_dithering%26amp%3Baction%3Dedit%26amp%3Bredlink%3D1%22%20title%3D%22Sierra%20dithering%20(la%20pagina%20non%20esiste)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3ESierra%20dithering%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20is%20based%20on%20Jarvis%20dithering%2C%20but%20it's%20faster%20while%20giving%20similar%3C%2FSPAN%3E%20results.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l3%20level2%20lfo4%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3EFilter%20%3CSPAN%20class%3D%22SpellE%22%3ELite%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellE%22%3E%3C%2FSPAN%3E%20is%20an%20algorithm%20by%20Sierra%20that%20is%20much%20simpler%20and%20faster%20than%20Floyd%E2%80%93Steinberg%2C%20while%20still%20yielding%20similar%20(according%20to%20Sierra%2C%20better)%20results.%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l3%20level2%20lfo4%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fw%2Findex.php%3Ftitle%3DAtkinson_dithering%26amp%3Baction%3Dedit%26amp%3Bredlink%3D1%22%20title%3D%22Atkinson%20dithering%20(la%20pagina%20non%20esiste)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EAtkinson%20dithering%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%2C%20%3C%2FSPAN%3Edeveloped%20by%20Apple%20programmer%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FBill_Atkinson%22%20title%3D%22Bill%20Atkinson%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EBill%20Atkinson%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%2C%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3Eresembles%20Jarvis%20dithering%20and%20Sierra%20dithering%2C%20but%20it's%20faster.%20Another%20%3C%2FSPAN%3Edifference%20is%20that%20it%20doesn't%20diffuse%20the%20entire%20quantization%20error%2C%20but%20only%20three%20quarters.%20It%20tends%20to%20preserve%20detail%20well%2C%20but%20very%20light%20and%20dark%20areas%20may%20appear%20blown%20out.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3C%2FUL%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20class%3D%22MsoNormalTable%22%20height%3D%22269%22%20style%3D%22width%3A%20729px%3B%20height%3A%20267px%3B%20margin-left%3A%2043.45pt%3B%20mso-cellspacing%3A%201.5pt%3B%20mso-yfti-tbllook%3A%201184%3B%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A%200%3B%20mso-yfti-firstrow%3A%20yes%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3ESierra%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3ESierra%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22SpellE%22%3ELite%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3EAtkinson%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%201%3B%20mso-yfti-lastrow%3A%20yes%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Sierra.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sierra.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sierra.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F11340i3CE7EF6DB42A37DD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22sierra.png%22%20alt%3D%22sierra.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esierra.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Sierra's_Filter_Lite.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sierralite.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sierralite.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37983iE9366EDEC8FD5C5D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22sierralite.png%22%20alt%3D%22sierralite.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esierralite.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Atkinson.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atkinson.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atkinson.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38524i12D037F97D600E34%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22atkinson.png%22%20alt%3D%22atkinson.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eatkinson.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Eink%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3Edisplay%20panel%20characteristic%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3ELow%20resolution%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EEink%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3Eonly%20has%20couple%20resolution%20modes%20for%20display%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EDU%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(1bit%2C%20Black%2FWhite)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EGC4%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(2bit%2C%20Gray%20scale)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EGC16%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(4bit%2C%20Gray%20scale)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EA2%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(1bit%2C%20Black%2FWhite%2C%20fast%20update%20mode)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Eb.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3ESlow%20update%20time%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EFor%20800x600%20panel%20size%20(per%20frame)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DU%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E300ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EGC4%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E450ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20GC16%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E600ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20A2%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E125ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20.5in%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E3.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EEffect%20by%20doing%20dithering%20for%20%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3E%20display%20panel%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3ELow%20resolution%20with%20better%20visual%20quality%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EBy%20doing%20dithering%20to%20the%20original%20grayscale%20image%2C%20we%20can%20get%20better%20visual%20looking%20result.%20Even%20if%20the%20image%20becomes%20black%20and%20white%20image%2C%20with%20the%20dithering%20algorism%2C%20you%20will%20still%20get%20the%20feeling%20of%20grayscale%20image.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Eb.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EFaster%20update%20with%20%3CSPAN%20class%3D%22SpellE%22%3EEink%E2%80%99s%3C%2FSPAN%3E%20animation%20waveform%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3ESince%20the%20DU%2FA2%20mode%20could%20update%20the%20%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3E%20panel%20faster%20than%20grayscale%20mode%2C%20with%20dithering%2C%20we%20can%20get%20no%20only%20the%20better%20visual%20looking%20result%2C%20but%20also%20we%20can%20use%20DU%2FA2%20fast%20update%20mode%20to%20show%20animation%20or%20even%20normal%20video%20files.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E4.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EOur%20current%20dithering%20implementation%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EChoose%20a%20simple%20and%20effective%20algorism%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EConsidering%20%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3E%20panel%E2%80%99s%20characteristics%2C%20we%20compared%20couple%20dithering%20algorism%20and%20decide%20to%20use%20Atkinson%20dithering%20algorism.%20It%20is%20simple%20and%20the%20result%20is%20better%20especially%20for%20%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3Eblack%2Fwhite%20display%20case.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Eb.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EMade%20a%20lot%20of%20optimization%20so%20that%20it%20will%20not%20affect%20update%20time%20too%20much%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EWith%20the%20simplicity%20of%20the%20Atkinson%20dithering%20algorism%2C%20we%20can%20also%20put%20a%20lot%20of%20effort%20to%20do%20the%20optimization%20in%20order%20to%20reduce%20the%20dithering%20processing%20time%20and%20make%20it%20practical%20for%20actual%20use.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ec.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3ECurrent%20algorism%20performance%20and%20result%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3ECurrently%2C%20with%20Atkinson%20dithering%20algorism%2C%20our%20processing%20time%20is%20about%2070ms.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E5.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%205.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EAvailability%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EWe%20implemented%20both%20Y8-%26gt%3BY1%20and%20Y8-%26gt%3BY4%20dithering%20with%20the%20same%20dithering%20algorism.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Eb.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EImplemented%20into%20our%20EPDC%20driver%20with%20i.MX6SL%20Linux%203.0.35%20version%20release.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ec.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EAlso%20implemented%20in%20our%20Video%20for%20%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3E%20demo%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E6.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%206.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EReferences%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EPart%20of%20dithering%20introduction%20from%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.wikipedia.org%22%20target%3D%22test_blank%22%3Ewww.wikipedia.org%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGraphics%20%26amp%3B%20Display%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Dithering%20Implementation%20for%20Eink%20Display%20Panel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWas%20the%20Atkinson%20sharpen%20filter%20enabled%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Flowendmac.com%2Freviews%2F08rev%2Fhyperdither-1.2.html%22%20title%3D%22http%3A%2F%2Flowendmac.com%2Freviews%2F08rev%2Fhyperdither-1.2.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESuperior%20Dithered%20Images%20with%20HyperDither%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Dithering%20Implementation%20for%20Eink%20Display%20Panel%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHas%20this%20changed%20or%20improved%20in%20i.MX7%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-24-2012 11:13 AM
Updated by:
