Dithering Implementation for Eink Display Panel
by Daiyu Ko, Freescale
  1. Dithering
a.          Dithering in digital image processing
Dithering is a technique used in computer graphics to create the illusion of color depth in images with a limited color palette (color quantization). In a dithered image, colors not available in the palette are approximated by a diffusion of colored pixels from within the available palette. The human eye perceives the diffusion as a mixture of the colors within it (see color vision). Dithered images, particularly those with relatively few colors, can often be distinguished by a characteristic graininess, or speckled appearance.
Figure 1. Original photo; note the smoothness in the detail
http://en.wikipedia.org/wiki/File:Dithering_example_undithered_web_palette.png
Figure 2.Original image using the web-safe color palette with no dithering applied. Note the large flat areas and loss of detail.
http://en.wikipedia.org/wiki/File:Dithering_example_dithered_web_palette.png
Figure 3.Original image using the web-safe color palette with Floyd–Steinberg dithering.
Note that even though the same palette is used, the application of dithering gives a better representation of the original
b.         Applications
Display hardware, including early computer video adapters and many modern LCDs used in mobile phonesand inexpensive digital cameras, show a much smaller color range than more advanced displays. One common application of dithering is to more accurately display graphics containing a greater range of colors than the hardware is capable of showing. For example, dithering might be used in order to display a photographic image containing millions of colors on video hardware that is only capable of showing 256 colors at a time. The 256 available colors would be used to generate a dithered approximation of the original image. Without dithering, the colors in the original image might simply be "rounded off" to the closest available color, resulting in a new image that is a poor representation of the original. Dithering takes advantage of the human eye's tendency to "mix" two colors in close proximity to one another.
For Eink panel, since it is grayscale image only, we can use the dithering algorism to reduce the grayscale level even to black/white only but still get better visual results.
c.          Algorithm
There are several algorithms designed to perform dithering. One of the earliest, and still one of the most popular, is the Floyd–Steinberg dithering algorithm, developed in 1975. One of the strengths of this algorithm is that it minimizes visual artifacts through an error-diffusion process; error-diffusion algorithms typically produce images that more closely represent the original than simpler dithering algorithms.
(Original)
Threshold
Bayer   (ordered)
            Example (Error-diffusion):
Error-diffusion dithering is a feedback process that diffuses the quantization error to neighboring pixels.
Floyd–Steinberg
Jarvis,   Judice & Ninke
Stucki
Error-diffusion dithering (continued):
      • Sierra dithering is based on Jarvis dithering, but it's faster while giving similar results.
      • Filter Lite is an algorithm by Sierra that is much simpler and faster than Floyd–Steinberg, while still yielding similar (according to Sierra, better) results.
      • Atkinson dithering, developed by Apple programmer Bill Atkinson, resembles Jarvis dithering and Sierra dithering, but it's faster. Another difference is that it doesn't diffuse the entire quantization error, but only three quarters. It tends to preserve detail well, but very light and dark areas may appear blown out.
Sierra
Sierra   Lite
Atkinson
     2.     Eink display panel characteristic
a.       Low resolution
Eink only has couple resolution modes for display
     DU                  (1bit, Black/White)
     GC4                (2bit, Gray scale)
     GC16              (4bit, Gray scale)
     A2                   (1bit, Black/White, fast update mode)
b.      Slow update time
For 800x600 panel size (per frame)
     DU                  300ms
                             GC4                450ms
                             GC16              600ms
                              A2                   125ms
3.       3.     Effect by doing dithering for Eink display panel
a.       Low resolution with better visual quality
By doing dithering to the original grayscale image, we can get better visual looking result. Even if the image becomes black and white image, with the dithering algorism, you will still get the feeling of grayscale image.
b.      Faster update with Eink’s animation waveform
Since the DU/A2 mode could update the Eink panel faster than grayscale mode, with dithering, we can get no only the better visual looking result, but also we can use DU/A2 fast update mode to show animation or even normal video files.
4.       4.     Our current dithering implementation
a.       Choose a simple and effective algorism
Considering Eink panel’s characteristics, we compared couple dithering algorism and decide to use Atkinson dithering algorism. It is simple and the result is better especially for Einkblack/white display case.
b.      Made a lot of optimization so that it will not affect update time too much
With the simplicity of the Atkinson dithering algorism, we can also put a lot of effort to do the optimization in order to reduce the dithering processing time and make it practical for actual use.
c.       Current algorism performance and result
Currently, with Atkinson dithering algorism, our processing time is about 70ms.
5.       5.     Availability
a.       We implemented both Y8->Y1 and Y8->Y4 dithering with the same dithering algorism.
b.      Implemented into our EPDC driver with i.MX6SL Linux 3.0.35 version release.
c.       Also implemented in our Video for Eink demo
6.       6.     References
a.       Part of dithering introduction from www.wikipedia.org
ラベル(3)
タグ(1)
コメント
Has this changed or improved in i.MX7?
Was the Atkinson sharpen filter enabled?
Superior Dithered Images with HyperDither
%3CLINGO-SUB%20id%3D%22lingo-sub-1100219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEink%20Display%20Panel%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E5%AE%9F%E8%A3%85%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-bidi-font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22SpellE%22%3EEink%20D%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellE%22%3E%3C%2FSPAN%3E%20isplay%20Panel%E3%81%AE%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-bidi-font-size%3A%2012.0pt%3B%22%3E%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0I%20%E5%AE%9F%E8%A3%85%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3Eby%20%E3%83%80%E3%82%A4%E3%83%A6%E3%82%A6%20%3CSPAN%20class%3D%22GramE%22%3E%E3%83%BB%E3%82%B3%E3%83%BC%2C%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20class%3D%22MsoListParagraphCxSpLast%22%20style%3D%22margin-left%3A%2058.5pt%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-22.5pt%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E7%94%BB%E5%83%8F%E5%87%A6%E7%90%86%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-bidi-font-weight%3A%20bold%3B%22%3E%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%20%E3%81%AF%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FComputer_graphics%22%20title%3D%22%E3%82%B3%E3%83%B3%E3%82%B0%E3%83%A9%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FA%3E%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%89%8B%E6%B3%95%E3%81%A7%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FColor%22%20title%3D%22%E3%82%AB%E3%83%A9%E3%83%BC%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FA%3E%20%E3%81%8C%E9%99%90%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E7%94%BB%E5%83%8F%E3%81%AB%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FColor_palette%22%20title%3D%22%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20%E8%89%B2%3C%2FSPAN%3E%3C%2FA%3E%20%E6%B7%B1%E5%BA%A6%E3%81%AE%E9%8C%AF%E8%A6%9A%E3%82%92%E4%BD%9C%E3%82%8A%E5%87%BA%E3%81%99(%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FColor_quantization%22%20title%3D%22%E3%82%AB%E3%83%A9%E3%83%BC%E9%87%8F%E5%AD%90%E5%8C%96%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20%3C%2FSPAN%3E%3C%2FA%3E%E3%82%AB%E3%83%A9%E3%83%BC%E9%87%8F%E5%AD%90%E5%8C%96)%E3%81%9F%E3%82%81%E3%81%AE%E6%89%8B%E6%B3%95%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%81%A7%E3%81%AF%E3%80%81%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%E3%81%AB%E3%81%AA%E3%81%84%E8%89%B2%E3%81%AF%E3%80%81%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%E5%86%85%E3%81%8B%E3%82%89%E3%81%AE%E8%89%B2%E4%BB%98%E3%81%8D%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FPixel%22%20title%3D%22%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%3C%2FSPAN%3E%3C%2FA%3E%20%E3%81%AE%E6%8B%A1%E6%95%A3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%BF%91%E4%BC%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BA%BA%E9%96%93%E3%81%AE%E7%9B%AE%E3%81%AF%E3%80%81%E6%8B%A1%E6%95%A3%E3%82%92%E3%81%9D%E3%81%AE%E4%B8%AD%E3%81%AE%E8%89%B2%E3%81%AE%E6%B7%B7%E5%90%88%E7%89%A9%E3%81%A8%E3%81%97%E3%81%A6%E8%AA%8D%E8%AD%98%E3%81%97%E3%81%BE%E3%81%99(%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FColor_vision%22%20title%3D%22%E8%89%B2%E8%A6%9A%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%E8%89%B2%E8%A6%9A%3C%2FSPAN%3E%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%9F%E7%94%BB%E5%83%8F%E3%80%81%E7%89%B9%E3%81%AB%E8%89%B2%E3%81%8C%E6%AF%94%E8%BC%83%E7%9A%84%E5%B0%91%E3%81%AA%E3%81%84%E7%94%BB%E5%83%8F%E3%81%AF%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E7%89%B9%E5%BE%B4%E7%9A%84%E3%81%AA%E7%B2%92%E7%8A%B6%E6%80%A7%E3%82%84%E6%96%91%E7%82%B9%E3%81%AE%E3%81%82%E3%82%8B%E5%A4%96%E8%A6%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%8C%BA%E5%88%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20text-decoration%3A%20none%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig1.png%22%20style%3D%22width%3A%20227px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38591iEDF2CD7FAF4C3C60%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22fig1.png%22%20alt%3D%22fig1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efig1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20class%3D%22GramE%22%3E%E5%9B%B3%201.%3C%2FSPAN%3E%E5%85%83%E3%81%AE%E5%86%99%E7%9C%9F%3B%E7%B4%B0%E9%83%A8%E3%81%AE%E6%BB%91%E3%82%89%E3%81%8B%E3%81%95%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3ADithering_example_undithered_web_palette.png%22%20title%3D%22%E3%80%8C%E5%9B%B32.%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20Web%20%E3%82%BB%E3%83%BC%E3%83%95%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%85%83%E3%81%AE%E7%94%BB%E5%83%8F%E3%80%82%E5%A4%A7%E3%81%8D%E3%81%AA%E5%B9%B3%E3%82%89%E3%81%AA%E9%A0%98%E5%9F%9F%E3%81%A8%E8%A9%B3%E7%B4%B0%E3%81%AE%E6%90%8D%E5%A4%B1%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%80%8D%20%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3ADithering_example_undithered_web_palette.png%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig2.png%22%20style%3D%22width%3A%20227px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38616iA297EAE9727A0B99%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22fig2.png%22%20alt%3D%22fig2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efig2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E5%9B%B3%202.%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FWeb-safe_color_palette%22%20title%3D%22Web-safe%20color%20palette%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%20Web%20%E3%82%BB%E3%83%BC%E3%83%95%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%85%83%E3%81%AE%E7%94%BB%E5%83%8F%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20%E3%80%82%E5%A4%A7%E3%81%8D%E3%81%AA%E5%B9%B3%E5%9D%A6%E3%81%AA%E9%A0%98%E5%9F%9F%E3%81%A8%E8%A9%B3%E7%B4%B0%E3%81%AE%E6%90%8D%E5%A4%B1%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%200in%3B%20text-indent%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3ADithering_example_dithered_web_palette.png%22%20title%3D%22%E3%80%8C%E5%9B%B33.Web%20%E3%82%BB%E3%83%BC%E3%83%95%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%E3%81%A8%20Floyd%E2%80%93Steinberg%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E7%94%BB%E5%83%8F%E3%80%82%E5%90%8C%E3%81%98%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%81%8C%E3%82%88%E3%82%8A%E3%82%88%E3%81%8F%E8%A1%A8%E7%8F%BE%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3ADithering_example_dithered_web_palette.png%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%200in%3B%20text-indent%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22fig3.png%22%20style%3D%22width%3A%20227px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38655i611ED6D253A983BE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22fig3.png%22%20alt%3D%22fig3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efig3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E5%9B%B3%203.%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20class%3D%22GramE%22%3EWeb%20%E3%82%BB%E3%83%BC%E3%83%95%E3%82%AB%E3%83%A9%E3%83%BC%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%E3%81%A8%20%3CSPAN%20style%3D%22mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-font-family%3A%20SimSun%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFloyd%25E2%2580%2593Steinberg_dithering%22%20title%3D%22%E3%83%95%E3%83%AD%E3%82%A4%E3%83%89%E3%83%BB%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B0%E3%83%BB%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EFloyd%E2%80%93Steinberg%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E7%94%BB%E5%83%8F%E3%80%82%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-top%3A%202.25pt%3B%20margin-right%3A%200in%3B%20margin-bottom%3A%202.25pt%3B%20margin-left%3A%20.5in%3B%20line-height%3A%2015.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E5%90%8C%E3%81%98%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%81%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%85%83%E3%81%AE%E3%83%91%E3%83%AC%E3%83%83%E3%83%88%E3%81%8C%E3%82%88%E3%82%8A%E9%81%A9%E5%88%87%E3%81%AB%E8%A1%A8%E7%8F%BE%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraph%22%20style%3D%22margin-left%3A%2058.5pt%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-22.5pt%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Eb.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%E5%88%9D%E6%9C%9F%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FGraphics_card%22%20title%3D%22%E3%83%93%E3%83%87%E3%82%AA%E3%82%AB%E3%83%BC%E3%83%89%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20%E3%83%93%E3%83%87%E3%82%AA%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%3C%2FSPAN%3E%3C%2FA%3E%20%E3%82%84%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FMobile_phone%22%20title%3D%22%E6%90%BA%E5%B8%AF%E9%9B%BB%E8%A9%B1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20%E6%90%BA%E5%B8%AF%E9%9B%BB%E8%A9%B1%3C%2FSPAN%3E%3C%2FA%3E%20%E3%82%84%E5%AE%89%E4%BE%A1%E3%81%AA%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FDigital_camera%22%20title%3D%22%E3%83%87%E3%82%B8%E3%82%AB%E3%83%A1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E5%A4%9A%E3%81%8F%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FLiquid_crystal_display%22%20title%3D%22%E6%B6%B2%E6%99%B6%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20LCD%3C%2FSPAN%3E%3C%2FA%3E%20%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E3%82%88%E3%82%8A%E9%AB%98%E5%BA%A6%E3%81%AA%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%88%E3%82%8A%E3%82%82%E3%81%AF%E3%82%8B%E3%81%8B%E3%81%AB%E7%8B%AD%E3%81%84%E8%89%B2%E7%AF%84%E5%9B%B2%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E7%94%A8%E9%80%94%E3%81%AE%201%20%E3%81%A4%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%82%8B%E7%AF%84%E5%9B%B2%E3%82%88%E3%82%8A%E3%82%82%E5%BA%83%E3%81%84%E7%AF%84%E5%9B%B2%E3%81%AE%E8%89%B2%E3%82%92%E5%90%AB%E3%82%80%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E3%82%88%E3%82%8A%E6%AD%A3%E7%A2%BA%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E4%B8%80%E5%BA%A6%E3%81%AB%20256%20%E8%89%B2%E3%81%97%E3%81%8B%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%83%93%E3%83%87%E3%82%AA%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%20%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FTruecolor%22%20title%3D%22%E3%83%88%E3%82%A5%E3%83%AB%E3%83%BC%E3%82%AB%E3%83%A9%E3%83%BC%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%E3%80%81%E6%95%B0%E7%99%BE%E4%B8%87%E8%89%B2%E3%82%92%E5%90%AB%E3%82%80%3C%2FSPAN%3E%3C%2FA%3E%20%E5%86%99%E7%9C%9F%E7%94%BB%E5%83%8F%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20256%20%E8%89%B2%E3%81%AF%E3%80%81%E5%85%83%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E8%BF%91%E4%BC%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E8%A1%8C%E3%82%8F%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E5%85%83%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AE%E8%89%B2%E3%81%8C%E5%8D%98%E3%81%AB%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E6%9C%80%E3%82%82%E8%BF%91%E3%81%84%E8%89%B2%E3%81%AB%E3%80%8C%E4%B8%B8%E3%82%81%E3%82%89%E3%82%8C%E3%80%8D%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E7%94%BB%E5%83%8F%E3%81%8C%E5%85%83%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E8%A1%A8%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AF%E3%80%81%E4%BA%BA%E9%96%93%E3%81%AE%E7%9B%AE%E3%81%8C2%E3%81%A4%E3%81%AE%E8%89%B2%E3%82%92%E4%BA%92%E3%81%84%E3%81%AB%E8%BF%91%E6%8E%A5%E3%81%97%E3%81%A6%E3%80%8C%E6%B7%B7%E5%90%88%E3%80%8D%E3%81%99%E3%82%8B%E5%82%BE%E5%90%91%E3%82%92%E5%88%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3E%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E7%94%BB%E5%83%8F%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%AC%E3%83%99%E3%83%AB%E3%82%92%E9%BB%92%2F%E7%99%BD%E3%81%AE%E3%81%BF%E3%81%AB%E4%B8%8B%E3%81%92%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E8%A6%96%E8%A6%9A%E7%9A%84%E3%81%AA%E7%B5%90%E6%9E%9C%E3%81%8C%E5%90%91%E4%B8%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpFirst%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%2058.5pt%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-22.5pt%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ec.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%B9%3C%2FSPAN%3Em%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22padding-left%3A%2060px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FAlgorithm%22%20title%3D%22%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E3%82%82%E5%88%9D%E6%9C%9F%E3%81%AE%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E4%BB%8A%E3%81%A7%E3%82%82%E6%9C%80%E3%82%82%E4%BA%BA%E6%B0%97%E3%81%AE%E3%81%82%E3%82%8B%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AE1%E3%81%A4%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%201975%E5%B9%B4%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%9F%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFloyd%25E2%2580%2593Steinberg_dithering%22%20title%3D%22%E3%83%95%E3%83%AD%E3%82%A4%E3%83%89%E3%83%BB%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B0%E3%83%BB%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20Floyd%E2%80%93Steinberg%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AE%E9%95%B7%E6%89%80%E3%81%AE%201%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FError_diffusion%22%20title%3D%22Error%20diffusion%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20text-underline%3A%20none%3B%22%3E%20%E3%81%A4%E3%81%AF%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E6%8B%A1%E6%95%A3%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E8%A6%96%E8%A6%9A%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%95%E3%82%A1%E3%82%AF%E3%83%88%E3%82%92%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%20%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E6%8B%A1%E6%95%A3%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81%E5%8D%98%E7%B4%94%E3%81%AA%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%88%E3%82%8A%E3%82%82%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%81%AB%E8%BF%91%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpLast%22%3E%3C%2FP%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20class%3D%22MsoNormalTable%22%20height%3D%22222%22%20style%3D%22width%3A%20733px%3B%20height%3A%20269px%3B%20margin-left%3A%2039.7pt%3B%20mso-cellspacing%3A%201.5pt%3B%20mso-yfti-tbllook%3A%201184%3B%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A%200%3B%20mso-yfti-firstrow%3A%20yes%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E(%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3ETHRESHOLD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%E3%83%90%E3%82%A4%E3%82%A8%E3%83%AB(%E7%99%BA%E6%B3%A8%E6%B8%88%E3%81%BF)%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%201%3B%20mso-yfti-lastrow%3A%20yes%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_63_grijswaarden.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22original.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22original.gif%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38521iADE06E6F6FC493B2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22original.gif%22%20alt%3D%22original.gif%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eoriginal.gif%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_drempel.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22threshold.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22threshold.gif%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38694i14BAFD3B8D8F9212%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22threshold.gif%22%20alt%3D%22threshold.gif%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ethreshold.gif%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Bayer.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bayer.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bayer.gif%22%20style%3D%22width%3A%20180px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37787iD0017B1DEF6ED172%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22bayer.gif%22%20alt%3D%22bayer.gif%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebayer.gif%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20class%3D%22MsoListParagraphCxSpFirst%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpLast%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%E4%BE%8B(%E3%82%A8%E3%83%A9%E3%83%BC%E6%8B%A1%E6%95%A3)%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20margin-left%3A%20.5in%3B%20line-height%3A%20normal%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20margin-left%3A%20.5in%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FError_diffusion%22%20title%3D%22Error%20diffusion%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%20mso-bidi-font-style%3A%20italic%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%E6%8B%A1%E6%95%A3%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-font-style%3A%20italic%3B%22%3E%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E3%81%AF%E3%80%81%E9%87%8F%E5%AD%90%E5%8C%96%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E9%9A%A3%E6%8E%A5%E3%81%99%E3%82%8B%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%AB%E6%8B%A1%E6%95%A3%E3%81%99%E3%82%8B%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CUL%20style%3D%22list-style-type%3A%20circle%3B%22%3E%3CUL%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l1%20level2%20lfo3%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFloyd%25E2%2580%2593Steinberg_dithering%22%20title%3D%22%E3%83%95%E3%83%AD%E3%82%A4%E3%83%89%E3%83%BB%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B0%E3%83%BB%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EFloyd%E2%80%93Steinberg%3C%2FSPAN%3E%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FA%3E%E3%81%AF%E3%80%81%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E8%AA%A4%E5%B7%AE%E3%82%92%E9%9A%A3%E6%8E%A5%E3%81%99%E3%82%8B%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%AB%E5%88%86%E6%95%A3%E3%81%95%E3%81%9B%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%3C%2FSPAN%3E%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E3%81%8D%E3%82%81%E7%B4%B0%E3%81%8B%E3%81%AA%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l1%20level2%20lfo3%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fw%2Findex.php%3Ftitle%3DJarvis%2C_Judice%2C_and_Ninke_dithering%26amp%3Baction%3Dedit%26amp%3Bredlink%3D1%22%20title%3D%22Jarvis%2C%20Judice%2C%20and%20Ninke%20dithering%20(la%20pagina%20non%20esiste)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%93%E3%82%B9%E3%80%81%3CSPAN%20class%3D%22SpellE%22%3E%E3%82%B8%E3%83%A5%E3%83%87%E3%82%A3%E3%82%B9%3C%2FSPAN%3E%E3%80%81%3CSPAN%20class%3D%22SpellE%22%3E%E3%83%8B%E3%83%B3%E3%82%B1%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellE%22%3E%3C%2FSPAN%3E%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E3%81%AF%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E4%B8%80%E6%AD%A9%E9%9B%A2%E3%82%8C%E3%81%9F%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E3%81%AB%E3%82%82%E6%8B%A1%E6%95%A3%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AF%E7%B2%97%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E8%A6%96%E8%A6%9A%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%95%E3%82%A1%E3%82%AF%E3%83%88%E3%81%AF%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFloyd%25E2%2580%2593Steinberg_dithering%22%20title%3D%22%E3%83%95%E3%83%AD%E3%82%A4%E3%83%89%E3%83%BB%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B0%E3%83%BB%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EFloyd%E2%80%93Steinberg%3C%2FSPAN%3E%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FA%3E%E3%82%88%E3%82%8A%E3%82%82%E9%81%85%E3%81%8F%E3%80%81%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3EFloyd%E2%80%93Steinberg%20%E3%81%AE%204%20%E3%81%A4%E3%81%AE%E8%BF%91%E5%82%8D%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%2012%20%E3%81%AE%E8%BF%91%E5%82%8D%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E3%81%AB%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E8%AA%A4%E5%B7%AE%E3%82%92%E5%88%86%E6%95%A3%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l1%20level2%20lfo3%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fw%2Findex.php%3Ftitle%3DStucki_dithering%26amp%3Baction%3Dedit%26amp%3Bredlink%3D1%22%20title%3D%22Stucki%20dithering%20(la%20pagina%20non%20esiste)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3EStucki%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20%E3%81%AF%E4%B8%8A%E8%A8%98%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%8F%E3%81%9A%E3%81%8B%E3%81%AB%E9%AB%98%E9%80%9F%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%20%3C%2FSPAN%3E%E5%87%BA%E5%8A%9B%E3%81%AF%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%82%B7%E3%83%A3%E3%83%BC%E3%83%97%E3%81%AB%E3%81%AA%E3%82%8B%E5%82%BE%E5%90%91%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3C%2FUL%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20class%3D%22MsoNormalTable%22%20height%3D%22269%22%20style%3D%22width%3A%20729px%3B%20height%3A%20266px%3B%20margin-left%3A%2043.45pt%3B%20mso-cellspacing%3A%201.5pt%3B%20mso-yfti-tbllook%3A%201184%3B%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A%200%3B%20mso-yfti-firstrow%3A%20yes%3B%20height%3A%2012.95pt%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2012.95pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%E3%83%95%E3%83%AD%E3%82%A4%E3%83%89%E3%83%BB%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2012.95pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3EJarvis%2C%26nbsp%3B%26nbsp%3B%20%3CSPAN%20class%3D%22SpellE%22%3EJudice%3C%2FSPAN%3E%20%26amp%3B%20%3CSPAN%20class%3D%22SpellE%22%3ENinke%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2012.95pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22SpellE%22%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2012.95pt%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%201%3B%20mso-yfti-lastrow%3A%20yes%3B%20height%3A%2077.4pt%3B%22%3E%3CTD%20style%3D%22text-align%3A%20left%3B%20height%3A%2077.4pt%3B%20padding%3A%200.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Floyd-Steinberg.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22floyd.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22floyd.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37894iC2035B9022A52B1F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22floyd.png%22%20alt%3D%22floyd.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Efloyd.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2077.4pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Jarvis%2C_Judice_%26amp%3B_Ninke.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jarvis.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jarvis.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37958i16D5984B8B10D7C2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22jarvis.png%22%20alt%3D%22jarvis.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ejarvis.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2077.4pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Stucki.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stucki.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22stucki.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F11181iDF19376FE9416447%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22stucki.png%22%20alt%3D%22stucki.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Estucki.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%20height%3A%2077.4pt%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20margin-left%3A%20.5in%3B%20line-height%3A%20normal%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20margin-left%3A%20.5in%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%E3%82%A8%E3%83%A9%E3%83%BC%E6%8B%A1%E6%95%A3%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0(%E7%B6%9A%E3%81%8D)%3A%20%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CUL%20style%3D%22list-style-type%3A%20circle%3B%22%3E%3CUL%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l3%20level2%20lfo4%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fw%2Findex.php%3Ftitle%3DSierra_dithering%26amp%3Baction%3Dedit%26amp%3Bredlink%3D1%22%20title%3D%22Sierra%20dithering%20(la%20pagina%20non%20esiste)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3ESierra%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20%E3%81%AF%20Jarvis%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%90%8C%E6%A7%98%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E4%B8%80%E6%96%B9%E3%81%A7%E3%80%81%E3%82%88%E3%82%8A%E9%AB%98%E9%80%9F%3C%2FSPAN%3E%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l3%20level2%20lfo4%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3EFilter%20%3CSPAN%20class%3D%22SpellE%22%3ELite%3C%2FSPAN%3E%3CSPAN%20class%3D%22SpellE%22%3E%3C%2FSPAN%3E%20%E3%81%AF%E3%80%81Floyd%E2%80%93Steinberg%E3%82%88%E3%82%8A%E3%82%82%E3%81%AF%E3%82%8B%E3%81%8B%E3%81%AB%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E9%AB%98%E9%80%9F%E3%81%AASierra%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE(Sierra%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%82%88%E3%82%8A%E5%84%AA%E3%82%8C%E3%81%9F)%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20class%3D%22MsoNormal%22%20style%3D%22mso-margin-top-alt%3A%20auto%3B%20mso-margin-bottom-alt%3A%20auto%3B%20line-height%3A%20normal%3B%20mso-list%3A%20l3%20level2%20lfo4%3B%20tab-stops%3A%20list%201.0in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3C%2FSPAN%3EApple%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%20%E3%81%A7%E3%81%82%E3%82%8BBill%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FBill_Atkinson%22%20title%3D%22%E3%83%93%E3%83%AB%E3%83%BB%E3%82%A2%E3%83%88%E3%82%AD%E3%83%B3%E3%82%BD%E3%83%B3%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%20Atkinson%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%9F%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fw%2Findex.php%3Ftitle%3DAtkinson_dithering%26amp%3Baction%3Dedit%26amp%3Bredlink%3D1%22%20title%3D%22Atkinson%20dithering%20(la%20pagina%20non%20esiste)%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20text-underline%3A%20none%3B%22%3E%20Atkinson%20dithering%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20%E3%81%AF%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%20Jarvis%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A8Sierra%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E4%BC%BC%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%88%E3%82%8A%E9%AB%98%E9%80%9F%E3%81%A7%E3%81%99%E3%80%82%E3%82%82%E3%81%861%E3%81%A4%E3%81%AE%3C%2FSPAN%3E%20%E9%81%95%E3%81%84%E3%81%AF%E3%80%81%E9%87%8F%E5%AD%90%E5%8C%96%E8%AA%A4%E5%B7%AE%E5%85%A8%E4%BD%93%E3%82%92%E6%8B%A1%E6%95%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%814%E5%88%86%E3%81%AE3%E3%81%A0%E3%81%91%E6%8B%A1%E6%95%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%82%A3%E3%83%86%E3%83%BC%E3%83%AB%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E5%82%BE%E5%90%91%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E6%98%8E%E3%82%8B%E3%81%84%E9%A0%98%E5%9F%9F%E3%81%A8%E6%9A%97%E3%81%84%E9%A0%98%E5%9F%9F%E3%81%8C%E7%99%BD%E9%A3%9B%E3%81%B3%E3%81%97%E3%81%A6%E8%A6%8B%E3%81%88%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3C%2FUL%3E%3CTABLE%20border%3D%220%22%20cellpadding%3D%220%22%20class%3D%22MsoNormalTable%22%20height%3D%22269%22%20style%3D%22width%3A%20729px%3B%20height%3A%20267px%3B%20margin-left%3A%2043.45pt%3B%20mso-cellspacing%3A%201.5pt%3B%20mso-yfti-tbllook%3A%201184%3B%22%3E%3CTBODY%3E%3CTR%20style%3D%22mso-yfti-irow%3A%200%3B%20mso-yfti-firstrow%3A%20yes%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%E3%82%B7%E3%82%A8%E3%83%A9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%E3%82%B7%E3%82%A8%E3%83%A9%20%3CSPAN%20class%3D%22SpellE%22%3E%E3%83%A9%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20align%3D%22center%22%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%E3%82%A2%E3%83%88%E3%82%AD%E3%83%B3%E3%82%BD%E3%83%B3%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22mso-yfti-irow%3A%201%3B%20mso-yfti-lastrow%3A%20yes%3B%22%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Sierra.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sierra.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sierra.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F11340i3CE7EF6DB42A37DD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22sierra.png%22%20alt%3D%22sierra.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esierra.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Sierra's_Filter_Lite.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sierralite.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sierralite.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37983iE9366EDEC8FD5C5D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22sierralite.png%22%20alt%3D%22sierralite.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Esierralite.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%20.75pt%20.75pt%20.75pt%20.75pt%3B%22%3E%3CP%20class%3D%22MsoNormal%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20line-height%3A%20normal%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fen.wikipedia.org%2Fwiki%2FFile%3AMichelangelo's_David_-_Atkinson.png%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20text-decoration%3A%20none%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-language%3A%20EN-US%3B%20text-underline%3A%20none%3B%20mso-no-proof%3A%20yes%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atkinson.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atkinson.png%22%20style%3D%22width%3A%20182px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F38524i12D037F97D600E34%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22atkinson.png%22%20alt%3D%22atkinson.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eatkinson.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20class%3D%22MsoNormal%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%202.%20Eink%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E7%89%B9%E5%BE%B4%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E4%BD%8E%E8%A7%A3%E5%83%8F%E5%BA%A6%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3EEink%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E3%81%AB%E3%81%AF%E3%80%81%E8%A1%A8%E7%A4%BA%E7%94%A8%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C2%E3%81%A4%E3%81%97%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EDU%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(1%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%83%A2%E3%83%8E%E3%82%AF%E3%83%AD)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EGC4%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(2%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EGC16%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(4bit%E3%80%81%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EA2%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E(1%E3%83%93%E3%83%83%E3%83%88%E3%80%81%E3%83%A2%E3%83%8E%E3%82%AF%E3%83%AD%E3%80%81%E9%AB%98%E9%80%9F%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Eb.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E6%9B%B4%E6%96%B0%E6%99%82%E9%96%93%E3%81%8C%E9%81%85%E3%81%84%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E800x600%20%E3%83%91%E3%83%8D%E3%83%AB%20%E3%82%B5%E3%82%A4%E3%82%BA%20(%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%82%E3%81%9F%E3%82%8A)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20DU%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E300ms%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3EGC4%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E450%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EGC16%3CSPAN%20style%3D%22mso-tab-count%3A%202%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E600%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EA2%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22mso-tab-count%3A%201%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E125%E3%83%9F%E3%83%AA%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20.5in%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E3.%3C%2FSPAN%3E%203.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E3%82%88%E3%82%8B%E5%8A%B9%E6%9E%9C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E4%BD%8E%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%A7%E8%A6%96%E8%A6%9A%E5%93%81%E8%B3%AA%E3%81%AE%E5%90%91%E4%B8%8A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%E5%85%83%E3%81%AE%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E7%94%BB%E5%83%8F%E3%81%AB%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%82%88%E3%82%8A%E8%A6%96%E8%A6%9A%E7%9A%84%E3%81%AB%E8%A6%8B%E3%81%88%E3%82%8B%E7%B5%90%E6%9E%9C%E3%82%92%E5%BE%97%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F%E3%81%8C%E7%99%BD%E9%BB%92%E7%94%BB%E5%83%8F%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E7%94%BB%E5%83%8F%E3%81%AE%E6%84%9F%E8%A7%A6%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%3CSPAN%20class%3D%22SpellE%22%3Eb.Eink%E3%81%AE%3C%2FSPAN%3E%E3%82%A2%E3%83%8B%E3%83%A1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%B3%A2%E5%BD%A2%E3%81%AB%E3%82%88%E3%82%8B%E6%9B%B4%E6%96%B0%E3%81%AE%E9%AB%98%E9%80%9F%E5%8C%96%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3EDU%20%2F%20A2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B0%E3%83%AC%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%A2%E3%83%BC%E3%83%89%E3%82%88%E3%82%8A%E3%82%82%20%3CSPAN%20class%3D%22SpellE%22%3E%E9%AB%98%E9%80%9F%E3%81%ABEink%3C%2FSPAN%3E%20%E3%83%91%E3%83%8D%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%A6%8B%E6%A0%84%E3%81%88%E3%81%AE%E8%89%AF%E3%81%84%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81DU%20%2F%20A2%E9%AB%98%E9%80%9F%E6%9B%B4%E6%96%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A2%E3%83%8B%E3%83%A1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%84%E9%80%9A%E5%B8%B8%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E4.%3C%2FSPAN%3E%204.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AE%E5%AE%9F%E8%A3%85%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E5%8A%B9%E6%9E%9C%E7%9A%84%E3%81%AA%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20class%3D%22SpellE%22%3EEink%3C%2FSPAN%3E%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E7%89%B9%E6%80%A7%E3%82%92%E8%80%83%E6%85%AE%E3%81%97%E3%81%A6%E3%80%81%E3%82%AB%E3%83%83%E3%83%97%E3%83%AB%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%80%81Atkinson%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%B1%BA%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E7%B0%A1%E5%8D%98%E3%81%A7%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%20%3CSPAN%20class%3D%22SpellE%22%3E%E7%89%B9%E3%81%ABEink%3C%2FSPAN%3E%E3%81%AE%E9%BB%92%2F%E7%99%BD%E3%81%AE%E9%99%B3%E5%88%97%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%82%88%E3%82%8A%E8%89%AF%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%E6%9B%B4%E6%96%B0%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E6%99%82%E9%96%93%E3%81%AB%E3%81%82%E3%81%BE%E3%82%8A%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E6%9C%80%E9%81%A9%E5%8C%96%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%E3%82%A2%E3%83%88%E3%82%AD%E3%83%B3%E3%82%BD%E3%83%B3%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%95%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E5%87%A6%E7%90%86%E6%99%82%E9%96%93%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%97%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E5%AE%9F%E7%94%A8%E7%9A%84%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%9C%80%E9%81%A9%E5%8C%96%E3%82%92%E8%A1%8C%E3%81%86%E3%81%9F%E3%82%81%E3%81%AB%E5%A4%9A%E3%81%8F%E3%81%AE%E5%8A%AA%E5%8A%9B%E3%82%92%E6%89%95%E3%81%86%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ec.%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AE%E6%80%A7%E8%83%BD%E3%81%A8%E7%B5%90%E6%9E%9C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%E7%8F%BE%E5%9C%A8%E3%80%81Atkinson%20%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%A7%E3%81%AF%E3%80%81%E5%87%A6%E7%90%86%E6%99%82%E9%96%93%E3%81%AF%E7%B4%84%2070%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E5.%3C%2FSPAN%3E%205.%205.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E5%8F%AF%E7%94%A8%E6%80%A7%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3Ea.Y8%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E-%26gt%3BY1%E3%81%A8Y8-%26gt%3BY4%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E5%90%8C%E3%81%98%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%A7%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3Eb.i.MX6SL%20Linux%203.0.35%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7EPDC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%3CSPAN%20class%3D%22SpellE%22%3Ec.Eink%3C%2FSPAN%3E%E3%83%87%E3%83%A2%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%81%AB%E3%82%82%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level1%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E6.%3C%2FSPAN%3E%206.%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%E5%8F%82%E7%85%A7%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%3E%3C%2FP%3E%3CP%20class%3D%22MsoListParagraphCxSpMiddle%22%20style%3D%22margin-left%3A%201.0in%3B%20mso-add-space%3A%20auto%3B%20text-indent%3A%20-.25in%3B%20mso-list%3A%20l2%20level2%20lfo2%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%20color%3A%20%23000000%3B%20font-size%3A%2010pt%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-list%3A%20Ignore%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%20115%25%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.wikipedia.org%22%20target%3D%22test_blank%22%3Ea.www.wikipedia.org%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E5%B0%8E%E5%85%A5%E3%81%AE%E4%B8%80%E9%83%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6SL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Eink%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E5%AE%9F%E8%A3%85%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%A2%E3%83%88%E3%82%AD%E3%83%B3%E3%82%BD%E3%83%B3%E3%82%B7%E3%83%A3%E3%83%BC%E3%83%97%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Flowendmac.com%2Freviews%2F08rev%2Fhyperdither-1.2.html%22%20title%3D%22http%3A%2F%2Flowendmac.com%2Freviews%2F08rev%2Fhyperdither-1.2.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EHyperDither%E3%81%AB%E3%82%88%E3%82%8B%E5%84%AA%E3%82%8C%E3%81%9F%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E7%94%BB%E5%83%8F%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1100220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Eink%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B6%E3%83%AA%E3%83%B3%E3%82%B0%E5%AE%9F%E8%A3%85%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ei.MX7%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%BE%E3%81%9F%E3%81%AF%E6%94%B9%E5%96%84%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-24-2012 11:13 AM
更新者:
