Change the clocks according to the display (non-default resolution)
For the board imx8M Quad EVK running the Linux 4.14.78-1.0.0_ga version BSP, the resolutions 3840x2160,1920x1080, 1280x720, 720x480 are support in our default BSP. For the other resolutions how to make it work?
This patch used to do support for a non-default resolution on i.MX 8MQ EVK. Basically, the customer needs to change the clocks accordingly to the display requirements,  it to be used as a base to the display support.
Comments
Is there similar patch for imx8m mini 4.14.98? I m looking for non-CEA 1024x768 resolution via IMX-MIPI-HDMI. And I don't have any option like "use monitor with standard "cea_modes" resolution.". Thank you.
UPD:
Tried to add some cmdline args like mxc_hdmi.only_cea=0 allow_noncea=1 -- no result
evk_8mm:/ # cat /proc/cmdline
console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 init=/init androidboot.console=ttymxc1 androidboot.hardware=freescale cma=800M@0x400M-0xb80M androidboot.primary_display=imx-drm firmware_class.path=/ve
ndor/firmware transparent_hugepage=never androidboot.wificountrycode=CN androidboot.lcd_density=213 mxc_hdmi.only_cea=0 allow_noncea=1 androidboot.serialno=2***********d94a androidboot.btmacaddr=*********** androidboot.soc_type=imx8mm androidboot.boot_device_root=mmc
%3CLINGO-SUB%20id%3D%22lingo-sub-1108122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EChange%20the%20clocks%20according%20to%20the%20display%20(non-default%20resolution)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%22%3EFor%20the%20board%20imx8M%20Quad%20EVK%20running%20the%20Linux%204.14.78-1.0.0_ga%20version%20BSP%2C%20the%20resolutions%203840x2160%2C1920x1080%2C%201280x720%2C%20720x480%20are%20support%20in%20our%20default%20BSP.%20For%20the%20other%20resolutions%20how%20to%20make%20it%20work%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20patch%20used%20to%20do%20support%20for%20a%20non-default%20resolution%20on%20i.MX%208MQ%20EVK.%20Basically%2C%20the%20customer%20needs%20to%20change%20the%20clocks%20accordingly%20to%20the%20display%20requirements%2C%26nbsp%3B%20it%20to%20be%20used%20as%20a%20base%20to%20the%20display%20support.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1108122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Change%20the%20clocks%20according%20to%20the%20display%20(non-default%20resolution)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20there%20similar%20patch%20for%20imx8m%20mini%204.14.98%3F%20I%20m%20looking%20for%20non-CEA%201024x768%20resolution%20via%20IMX-MIPI-HDMI.%20And%20I%20don't%20have%20any%20option%20like%20%22%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F505648%22%20target%3D%22_blank%22%3Euse%20monitor%20with%20standard%20%22cea_modes%22%20resolution.%3C%2FA%3E%22.%20Thank%20you.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUPD%3A%3CBR%20%2F%3ETried%20to%20add%20some%20cmdline%20args%20like%26nbsp%3B%3CSTRONG%3Emxc_hdmi.only_cea%3D0%20allow_noncea%3D1%3C%2FSTRONG%3E%20--%20no%20result%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3Eevk_8mm%3A%2F%20%23%20cat%20%2Fproc%2Fcmdline%3C%2FSPAN%3E%3CBR%20%2F%3E%20console%3Dttymxc1%2C115200%20earlycon%3Dec_imx6q%2C0x30890000%2C115200%20init%3D%2Finit%20androidboot.console%3Dttymxc1%20androidboot.hardware%3Dfreescale%20cma%3D800M%400x400M-0xb80M%20androidboot.primary_display%3Dimx-drm%20firmware_class.path%3D%2Fve%3CBR%20%2F%3Endor%2Ffirmware%20transparent_hugepage%3Dnever%20androidboot.wificountrycode%3DCN%20androidboot.lcd_density%3D213%20mxc_hdmi.only_cea%3D0%20allow_noncea%3D1%26nbsp%3B%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%22%3Eandroidboot.serialno%3D2***********d94a%20androidboot.btmacaddr%3D***********%3C%2FSPAN%3E%26nbsp%3Bandroidboot.soc_type%3Dimx8mm%20androidboot.boot_device_root%3Dmmc%3C%2FSPAN%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20style%3D%22position%3A%20absolute%3B%20left%3A%20562px%3B%20top%3A%20107.385px%3B%22%3E%3CDIV%20class%3D%22gtx-trans-icon%22%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎09-26-2019 07:41 AM
Updated by:
