Basic Device Tree for the Udoo Board
  1. INTRODUCTION
  2. REQUIREMENTS
  3. DEVICE TREE
  4. BOOTING LINUX
1. INTRODUCTION
    This document explains how to use the yocto images and tailor the source code for a different board. The board used in this document is the Udoo board that features an iMX6Q. In this document U-Boot Migration Example the U-boot changes are covered and it must be followed before this one. The below steps will cover the next board changes:
  •     Ethernet PHY
  •     SD card
  •     Debug UART
2. REQUIREMENTS
  • A functional Yocto environment (Images generated for your target, core-image-minimal). The images generated must be chosen for the imx6q, which is the one explained in this document.
  • Toolchain. The meta-toolchain is used in this document.
  • L3.14.38 is used in this document.
  • Build Kernel using meta-toolchain
  • A SD card with the core-image-minimal image.
NOTE:
Follow the next training that explains in detail the steps to cover the requirements.
Yocto Training - HOME
3. DEVICE TREE
    In previous Linux versions 3.0.35 backwards, the kernel contained hardcoded structures in C language used for board and platform specific configurations. Thanks to the device tree, the same kernel image can be used for different boards and the description of the platform and board is defined in a different file. Therefore the same kernel used by the SABRE-SD or SABRE-AI board can be used for the Udoo board and only  a new Device Tree file has to be generated.
3.1 ADDING A NEW DEVICE TREE
After you have chosen the configuration of the corresponding board (imx_v7_defconfig), exported the needed environment variables like ARCH, CROSS_COMPILE; the new .dts file must be added.
    • In the linux source folder arch/arm/boot/dts create a file named imx6q-udoo-doc.dts. This is the .dts file that contains the hardware description.
$ touch imx6q-udoo-doc.dts
    • Add the new dts file in the Makefile found in arch/arm/boot/dts. The file must be inside the precomipler directive $(CONFIG_ARCH_MXC)
3.2 DEVICE TREE CONTENT
    • Using your prefered text editor, add the dts version at the top of the file
/dts-v1/;
    • There is already a dtsi file that describes  the imx6q device named imx6q.dtsi. Include this file in the new dts .
#include "imx6q.dtsi"
    • Add the root node, model and compatible property. The udoo,imx6q-udoo property does not exist in the DT_MACHINE structure, but fsl,imx6q does.
        model = "Udoo i.MX6 Quad Board";
        compatible = "udoo,imx6q-udoo", "fsl,imx6q";
    • Add the memory region.
memory{
          reg = <0x10000000 0x40000000>;
    • Add the pinctrl configurations for the nodes you want to add. UART2_TXD and UART2_RXD are the pins used for the serial debug console. The pin description must be placed in the iomuxc node.
&iomuxc{
     imx6q-udoo{
          pinctrl_uart2: uart2grp{
               fsl,pins = <
                         MX6QDL_PAD_EIM_D26__UART2_TX_DATA          0x1b0b1
                         MX6QDL_PAD_EIM_D27__UART2_RX_DATA          0x1b0b1
    • The RGMII connection and SD characteristics are the same as iMX6Q SABRE-SD .
pinctrl_usdhc3: usdhc3grp {
                        fsl,pins = <
                               MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059
                               MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059
                               MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059
                               MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059
                               MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059
                               MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059
pinctrl_enet: enetgrp {
                        fsl,pins = <
                               MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b0b0
                               MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b0b0
                               MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b0b0
                               MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b0b0
                               MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b0b0
                               MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b0b0
                               MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b0b0
                               MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b0b0
                               MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b0b0
                               MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b0b0
                               MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b0b0
                               MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b0b0
                               MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1b0b0
                               MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0
                               MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0
                               MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8
    • The fec, uart2 and usdhc3 nodes must be added. These nodes exist already in the imx6q.dtsi but the status property, pinctrl  among others must be added.
&fec {
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_enet>;
        phy-mode = "rgmii";
        status = "okay";
&uart2 {
        pinctrl-0 = <&pinctrl_uart2>;
        status = "okay";
&usdhc3 {
        pinctrl-0 = <&pinctrl_usdhc3>;
        non-removable;
        status = "okay";
    • Below is the simple dts file resulting from the above points.
/dts-v1/;
        compatible = "udoo,imx6q-udo", "fsl,imx6q";
        memory {
                reg = <0x10000000 0x80000000>;
&fec {
        phy-mode = "rgmii";
        status = "okay";
&uart2 {
        status = "okay";
&usdhc3 {
        non-removable;
        status = "okay";
&iomuxc {
        imx6q-udoo {
                        fsl,pins = <
                pinctrl_uart2: uart2grp {
                        fsl,pins = <
                        fsl,pins = <
3.3 COMPILING DEVICE TREE
Compiling the .dts will generate a .dtb file that is the binary file the kernel needs.
make ARCH=arm dtbs
A file named imx6q-udoo-doc.dtb is the file used by our board. It is found in  arch/arm/boot/dts folder. If you have a SD with a working image, place this file in the FAT partition. You may need to change the file name first, in this case for imx6q-udoo.dtb.
4. BOOTING THE IMAGE
After this you should have a simple and functional linux system. Just plug-in your SD card and power-up the board.
You should get an output in the serial console like the one below:
I hope you find this basic document helpful.
评论
thanks for the simple / clear information on device tree file.
after all steps i followed, i ran below make command. but i dont find dtb file.
make ARCH=arm dtbs
when i run "make ARCH=arm dtbs", i see below message in terminal window thats all.
rm -f /../*.dtb
%3CLINGO-SUB%20id%3D%22lingo-sub-1117118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUdoo%20%E6%9D%BF%E7%9A%84%E5%9F%BA%E6%9C%AC%E8%AE%BE%E5%A4%87%E6%A0%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117118%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3COL%3E%3CLI%3E%3CSTRONG%3E%E7%AE%80%E4%BB%8B%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E8%A6%81%E6%B1%82%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E8%AE%BE%E5%A4%87%E6%A0%91%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%90%AF%E5%8A%A8%20Linux%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%20%E5%BC%95%E8%A8%80%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E8%A7%A3%E9%87%8A%E4%BA%86%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20yocto%20%E5%9B%BE%E5%83%8F%E5%B9%B6%E4%B8%BA%E4%B8%8D%E5%90%8C%E7%9A%84%E4%B8%BB%E6%9D%BF%E5%AE%9A%E5%88%B6%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%E6%9C%AC%E6%96%87%E6%A1%A3%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E6%98%AF%E9%85%8D%E5%A4%87%20iMX6Q%20%E7%9A%84%20Udoo%20%E4%B8%BB%E6%9D%BF%E3%80%82%E6%9C%AC%E6%96%87%E6%A1%A3%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-328200%22%20target%3D%22_blank%22%3EU-Boot%20%E8%BF%81%E7%A7%BB%E7%A4%BA%E4%BE%8B%3C%2FA%3E%E6%B6%B5%E7%9B%96%E4%BA%86%20U-boot%20%E7%9A%84%E6%9B%B4%E6%94%B9%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%85%88%E9%81%B5%E5%BE%AA%E6%AD%A4%E6%9B%B4%E6%94%B9%E3%80%82%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E5%B0%86%E6%B6%B5%E7%9B%96%E4%B8%8B%E4%B8%80%E6%AC%A1%E8%91%A3%E4%BA%8B%E4%BC%9A%E5%8F%98%E5%8A%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BB%A5%E5%A4%AA%E7%BD%91PHY%3C%2FLI%3E%3CLI%3ESD%20%E5%8D%A1%3C%2FLI%3E%3CLI%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Debug%20UART%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%20%E8%A6%81%E6%B1%82%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%B8%80%E4%B8%AA%E5%8A%9F%E8%83%BD%E6%80%A7%E7%9A%84%20Yocto%20%E7%8E%AF%E5%A2%83%EF%BC%88%E4%B8%BA%E6%82%A8%E7%9A%84%E7%9B%AE%E6%A0%87%E7%94%9F%E6%88%90%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%8C%E6%A0%B8%E5%BF%83%E5%9B%BE%E5%83%8F%E6%9C%80%E5%B0%8F%EF%BC%89%E3%80%82%E5%BF%85%E9%A1%BB%E4%B8%BA%20imx6q%20%E9%80%89%E6%8B%A9%E7%94%9F%E6%88%90%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%8C%E8%BF%99%E6%98%AF%E6%9C%AC%E6%96%87%E6%A1%A3%E4%B8%AD%E8%A7%A3%E9%87%8A%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B7%A5%E5%85%B7%E9%93%BE%E3%80%82%E6%9C%AC%E6%96%87%E6%A1%A3%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BA%86%E5%85%83%E5%B7%A5%E5%85%B7%E9%93%BE%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E4%B8%AD%E4%BD%BF%E7%94%A8%20L3.14.38%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%E5%85%83%E5%B7%A5%E5%85%B7%E9%93%BE%E6%9E%84%E5%BB%BA%E5%86%85%E6%A0%B8%3C%2FLI%3E%3CLI%3E%E5%B8%A6%E6%9C%89%20core-image-minimal%20%E5%9B%BE%E5%83%8F%E7%9A%84%20SD%20%E5%8D%A1%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E6%8C%89%E7%85%A7%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%9F%B9%E8%AE%AD%E8%AF%A6%E7%BB%86%E8%A7%A3%E9%87%8A%E6%BB%A1%E8%B6%B3%E8%A6%81%E6%B1%82%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20%E5%9F%B9%E8%AE%AD%20-%20%E4%B8%BB%E9%A1%B5%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSTRONG%3E3.%E8%AE%BE%E5%A4%87%E6%A0%91%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%E5%9C%A8%E4%B9%8B%E5%89%8D%E7%9A%84%20Linux%20%E7%89%88%E6%9C%AC%203.0.35%20%E4%B8%AD%E5%90%91%E5%90%8E%EF%BC%8C%E5%86%85%E6%A0%B8%E5%8C%85%E5%90%AB%E7%94%A8%E4%BA%8E%E6%9D%BF%E5%92%8C%E5%B9%B3%E5%8F%B0%E7%89%B9%E5%AE%9A%E9%85%8D%E7%BD%AE%E7%9A%84%20C%20%E8%AF%AD%E8%A8%80%E7%A1%AC%E7%BC%96%E7%A0%81%E7%BB%93%E6%9E%84%E3%80%82%E7%94%B1%E4%BA%8E%E8%AE%BE%E5%A4%87%E6%A0%91%EF%BC%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%BA%8E%E4%B8%8D%E5%90%8C%E7%9A%84%E4%B8%BB%E6%9D%BF%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%B9%B3%E5%8F%B0%E5%92%8C%E4%B8%BB%E6%9D%BF%E7%9A%84%E6%8F%8F%E8%BF%B0%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AE%9A%E4%B9%89%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8CSABRE-SD%20%E6%88%96%20SABRE-AI%20%E6%9D%BF%E4%BD%BF%E7%94%A8%E7%9A%84%E7%9B%B8%E5%90%8C%E5%86%85%E6%A0%B8%E5%8F%AF%E7%94%A8%E4%BA%8E%20Udoo%20%E6%9D%BF%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AA%E9%9C%80%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20padding-left%3A%2030px%3B%22%3E%3CEM%3E%3CSTRONG%3E3.1%20%E6%B7%BB%E5%8A%A0%E6%96%B0%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%20%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20padding-left%3A%2030px%3B%22%3E%E9%80%89%E6%8B%A9%E7%9B%B8%E5%BA%94%E6%9D%BF%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%88imx_v7_defconfig%EF%BC%89%E5%90%8E%EF%BC%8C%E5%AF%BC%E5%87%BA%E6%89%80%E9%9C%80%E7%9A%84%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%EF%BC%8C%E5%A6%82ARCH%EF%BC%8CCROSS_COMPILE%EF%BC%9B%E6%96%B0%E7%9A%84.dts%E5%BF%85%E9%A1%BB%E6%B7%BB%E5%8A%A0%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%E5%9C%A8Linux%E6%BA%90%E6%96%87%E4%BB%B6%E5%A4%B9%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Earch%2Farm%2Fboot%2Fdts%E4%B8%AD%3CSPAN%20style%3D%22color%3A%20%23505050%3B%22%3E%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BAimx6q-udoo-doc.dts%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%E8%BF%99%E6%98%AF%E5%8C%85%E5%90%AB%E7%A1%AC%E4%BB%B6%E6%8F%8F%E8%BF%B0%E7%9A%84.dts%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14532394817515309%20jive_text_macro%22%20data-renderedposition%3D%22874.5999755859375_8_1231_16%22%20jivemacro_uid%3D%22_14532394817515309%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%24%20touch%20%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3Eimx6q-udoo-doc.dts%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%E5%9C%A8%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Earch%2Farm%2Fboot%2Fdts%20%E7%9B%AE%E5%BD%95%E4%B8%8B%E7%9A%84%20Makefile%20%E4%B8%AD%E6%B7%BB%E5%8A%A0%E6%96%B0%E7%9A%84%20dts%20%E6%96%87%E4%BB%B6%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%80%82%E8%AF%A5%E6%96%87%E4%BB%B6%E5%BF%85%E9%A1%BB%E4%BD%8D%E4%BA%8E%E9%A2%84%E7%BC%96%E8%AF%91%E5%99%A8%E6%8C%87%E4%BB%A4%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3E%24(CONFIG_ARCH_MXC)%3C%2FSPAN%3E%E5%86%85%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20228px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F52136i507A12BDB35CFFD5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%23303030%3B%22%3E%3CEM%3E%3CSTRONG%3E3.2%20%E8%AE%BE%E5%A4%87%E6%A0%91%E5%86%85%E5%AE%B9%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E4%BD%BF%E7%94%A8%E6%82%A8%E5%96%9C%E6%AC%A2%E7%9A%84%E6%96%87%E6%9C%AC%E7%BC%96%E8%BE%91%E5%99%A8%EF%BC%8C%E5%9C%A8%E6%96%87%E4%BB%B6%E9%A1%B6%E9%83%A8%E6%B7%BB%E5%8A%A0%20dts%20%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14532394899718169%20jive_text_macro%22%20data-renderedposition%3D%221129_8_1231_16%22%20jivemacro_uid%3D%22_14532394899718169%22%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%2Fdts-v1%2F%3B%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%E5%B7%B2%E7%BB%8F%E6%9C%89%E4%B8%80%E4%B8%AA%E6%8F%8F%E8%BF%B0%20imx6q%20%E8%AE%BE%E5%A4%87%E7%9A%84%20dtsi%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%90%8D%E4%B8%BA%20imx6q.dtsi%E3%80%82%E5%B0%86%E6%AD%A4%E6%96%87%E4%BB%B6%E5%8C%85%E5%90%AB%E5%9C%A8%E6%96%B0%E7%9A%84%20dts%20%E4%B8%AD%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14533091749113643%20jive_text_macro%22%20data-renderedposition%3D%221192.5999755859375_8_1231_16%22%20jivemacro_uid%3D%22_14533091749113643%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%23%E5%8C%85%E6%8B%AC%E2%80%9Cimx6q.dtsi%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%E6%B7%BB%E5%8A%A0%E6%A0%B9%E8%8A%82%E7%82%B9%E3%80%81%E6%A8%A1%E5%9E%8B%E5%92%8C%E5%85%BC%E5%AE%B9%E5%B1%9E%E6%80%A7%E3%80%82udoo%2Cimx6q-udoo%20%E5%B1%9E%E6%80%A7%E5%9C%A8%20DT_MACHINE%20%E7%BB%93%E6%9E%84%E4%B8%AD%E4%B8%8D%E5%AD%98%E5%9C%A8%EF%BC%8C%E4%BD%86%20fsl%2Cimx6q%20%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14533094074101286%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%221256.199951171875_8_1231_120%22%20jivemacro_uid%3D%22_14533094074101286%22%3E%3C%2FPRE%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2019.0pt%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%2F%20%7B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%20.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2019.0pt%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E5%9E%8B%E5%8F%B7%20%3D%20%E2%80%9C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2019.0pt%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3EUdoo%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2019.0pt%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ei.MX6%20%E5%9B%9B%E6%A0%B8%E4%B8%BB%E6%9D%BF%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%20.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2019.0pt%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20compatible%20%3D%20%22udoo%2Cimx6q-udoo%22%2C%20%22fsl%2Cimx6q%22%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%20.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2019.0pt%3B%20font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%E6%B7%BB%E5%8A%A0%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14533099442604447%22%20data-renderedposition%3D%221423.5833740234375_8_1231_48%22%20jivemacro_uid%3D%22_14533099442604447%22%3E%3CP%3Ememory%7B%3C%2FP%3E%3CP%3Ereg%20%3D%20%26lt%3B0x10000000%200x40000000%26gt%3B%3B%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3E%E4%B8%BA%E6%82%A8%E6%83%B3%E8%A6%81%E6%B7%BB%E5%8A%A0%E7%9A%84%E8%8A%82%E7%82%B9%E6%B7%BB%E5%8A%A0%20pinctrl%20%E9%85%8D%E7%BD%AE%E3%80%82UART2_TXD%20%E5%92%8C%20UART2_RXD%20%E6%98%AF%E7%94%A8%E4%BA%8E%E4%B8%B2%E8%A1%8C%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%E5%8F%B0%E7%9A%84%E5%BC%95%E8%84%9A%E3%80%82%E5%BC%95%E8%84%9A%E6%8F%8F%E8%BF%B0%E5%BF%85%E9%A1%BB%E6%94%BE%E5%9C%A8iomuxc%E8%8A%82%E7%82%B9%E4%B8%AD%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20564px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F52645i4FEB8EFFE912D066%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20645px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F52712i1902633178B276D8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14533107779722760%20jive_text_macro%22%20data-renderedposition%3D%222127.183349609375_8_1231_161%22%20jivemacro_uid%3D%22_14533107779722760%22%3E%3CP%3E%26amp%3Biomuxc%7B%3C%2FP%3E%3CP%3Eimx6q-udoo%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pinctrl_uart2%3A%20uart2grp%7B%3C%2FP%3E%3CP%3Efsl%EF%BC%8C%E5%BC%95%E8%84%9A%3D%26lt%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_EIM_D26__UART2_TX_DATA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b1%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_EIM_D27__UART2_RX_%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3EDATA%3C%2FSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b1%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3ERGMII%20%E8%BF%9E%E6%8E%A5%E5%92%8C%20SD%20%E7%89%B9%E6%80%A7%E4%B8%8E%20iMX6Q%20SABRE-SD%20%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20739px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F21790i9E47E5D326A2B3E0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20994px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F276i8A9D344A33541A0A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_1453313155796486%22%20data-renderedposition%3D%222986.283447265625_8_1231_212%22%20jivemacro_uid%3D%22_1453313155796486%22%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3Epinctrl_usdhc3%3A%20usdhc3grp%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efsl%EF%BC%8C%E5%BC%95%E8%84%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D%26lt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3EMX6QDL_PAD_SD3_CMD__SD3_CMD%200x17059%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_SD3_CLK__SD3_CLK%200x10059%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3EMX6QDL_PAD_SD3_DAT0__SD3_DATA0%200x17059%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3EMX6QDL_PAD_SD3_DAT1__SD3_DATA1%200x17059%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3EMX6QDL_PAD_SD3_DAT2__SD3_DATA2%200x17059%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3EMX6QDL_PAD_SD3_DAT3__SD3_DATA3%200x17059%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F21910i805A7AE590986CCE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F21801i3F069EC4D6BFFF62%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14533132870909658%20jive_text_macro%22%20data-renderedposition%3D%223885.333251953125_8_1231_430%22%20jivemacro_uid%3D%22_14533132870909658%22%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epinctrl_enet%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3A%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Eenetgrp%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efsl%EF%BC%8C%E5%BC%95%E8%84%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3D%26lt%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3EMX6QDL_PAD_RGMII_RXC__RGMII_RXC%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_RD0__RGMII_RD0%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_RD1__RGMII_RD1%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_RD2__RGMII_RD2%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_RD3__RGMII_RD3%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3EMX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL%200x1b0b0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TXC__RGMII_TXC%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TD0__RGMII_TD0%200x1b0b0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TD1__RGMII_TD1%200x1b0b0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TD2__RGMII_TD2%200x1b0b0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TD3__RGMII_TD3%200x1b0b0%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3EMX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_ENET_MDIO__ENET_MDIO%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_ENET_MDC__ENET_MDC%200x1b0b0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_GPIO_16__ENET_REF_CLK%200x4001b0a8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26gt%3B%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CUL%3E%3CUL%3E%3CLI%3E%E5%BF%85%E9%A1%BB%E6%B7%BB%E5%8A%A0%20fec%E3%80%81uart2%20%E5%92%8C%20usdhc3%20%E8%8A%82%E7%82%B9%E3%80%82%E8%BF%99%E4%BA%9B%E8%8A%82%E7%82%B9%E5%B7%B2%E7%BB%8F%E5%AD%98%E5%9C%A8%E4%BA%8E%20imx6q.dtsi%20%E4%B8%AD%EF%BC%8C%E4%BD%86%E5%BF%85%E9%A1%BB%E6%B7%BB%E5%8A%A0%E7%8A%B6%E6%80%81%E5%B1%9E%E6%80%A7%E3%80%81pinctrl%20%E7%AD%89%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14533141017594949%20jive_text_macro%22%20data-renderedposition%3D%224368.4833984375_8_1231_473%22%20jivemacro_uid%3D%22_14533141017594949%22%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%20.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Efec%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%20%7B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epinctrl%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E-names%20%3D%E2%80%9C%E9%BB%98%E8%AE%A4%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epinctrl_enet%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%26gt%3B%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ephy%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E6%A8%A1%E5%BC%8F%3D%E2%80%9C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Ergmii%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%7D%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26amp%3Buart2%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epinctrl%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E-names%20%3D%E2%80%9C%E9%BB%98%E8%AE%A4%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart2%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%7D%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26amp%3Busdhc3%20%7B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3Epinctrl%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%22%3E-names%20%3D%E2%80%9C%E9%BB%98%E8%AE%A4%E2%80%9D%EF%BC%9B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3%26gt%3B%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20non-removable%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20status%20%3D%20%22okay%22%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20black%3B%20font-size%3A%208pt%3B%22%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.31pt%3B%20margin-bottom%3A%200.56pt%3B%20padding-left%3A%2034.2px%3B%20text-indent%3A%20-0.19in%3B%20text-align%3A%20left%3B%22%3E%3C%2FP%3E%3C%2FPRE%3E%3CUL%3E%3CUL%3E%3CLI%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%A0%B9%E6%8D%AE%E4%BB%A5%E4%B8%8A%E5%87%A0%E7%82%B9%E5%BE%97%E5%87%BA%E7%9A%84%E7%AE%80%E5%8D%95%E7%9A%84%20dts%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_1453321903255517%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%224888.83349609375_8_1231_1280%22%20jivemacro_uid%3D%22_1453321903255517%22%3E%3CP%3E%2Fdts-v1%2F%3B%3C%2FP%3E%3CP%3E%23%E5%8C%85%E6%8B%AC%E2%80%9Cimx6q.dtsi%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%20%7B%3C%2FP%3E%3CP%3E%E5%9E%8B%E5%8F%B7%20%3D%20%E2%80%9CUdoo%20i.MX6%20%E5%9B%9B%E6%A0%B8%E4%B8%BB%E6%9D%BF%E2%80%9D%EF%BC%9B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20compatible%20%3D%20%22udoo%2Cimx6q-udo%22%2C%20%22fsl%2Cimx6q%22%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AE%B0%E5%BF%86%20%7B%3C%2FP%3E%3CP%3Ereg%20%3D%20%26lt%3B0x10000000%200x80000000%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26amp%3Bfec%20%7B%3C%2FP%3E%3CP%3Epinctrl%20%E5%90%8D%E7%A7%B0%20%3D%20%E2%80%9C%E9%BB%98%E8%AE%A4%E2%80%9D%EF%BC%9B%3C%2FP%3E%3CP%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_enet%26gt%3B%3B%3C%2FP%3E%3CP%3Ephy%E6%A8%A1%E5%BC%8F%3D%E2%80%9Crgmii%E2%80%9D%EF%BC%9B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20status%20%3D%20%22okay%22%3B%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26amp%3Buart2%20%7B%3C%2FP%3E%3CP%3Epinctrl%20%E5%90%8D%E7%A7%B0%20%3D%20%E2%80%9C%E9%BB%98%E8%AE%A4%E2%80%9D%EF%BC%9B%3C%2FP%3E%3CP%3Epinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart2%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20status%20%3D%20%22okay%22%3B%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26amp%3Busdhc3%20%7B%3C%2FP%3E%3CP%3Epinctrl%20%E5%90%8D%E7%A7%B0%20%3D%20%E2%80%9C%E9%BB%98%E8%AE%A4%E2%80%9D%EF%BC%9B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_usdhc3%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20non-removable%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20status%20%3D%20%22okay%22%3B%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26amp%3Biomuxc%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q-udoo%20%7B%3C%2FP%3E%3CP%3Epinctrl_enet%3A%20enetgrp%7B%3C%2FP%3E%3CP%3Efsl%EF%BC%8C%E5%BC%95%E8%84%9A%3D%26lt%3B%3C%2FP%3E%3CP%3EMX6QDL_PAD_RGMII_RXC__RGMII_RXC%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_RD0__RGMII_RD0%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_RD1__RGMII_RD1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_RD2__RGMII_RD2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_RD3__RGMII_RD3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3EMX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TXC__RGMII_TXC%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TD0__RGMII_TD0%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TD1__RGMII_TD1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TD2__RGMII_TD2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_RGMII_TD3__RGMII_TD3%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3EMX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_ENET_MDIO__ENET_MDIO%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_ENET_MDC__ENET_MDC%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b0%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_GPIO_16__ENET_REF_CLK%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x4001b0a8%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epinctrl_uart2%3A%20uart2grp%7B%3C%2FP%3E%3CP%3Efsl%EF%BC%8C%E5%BC%95%E8%84%9A%3D%26lt%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_EIM_D26__UART2_TX_DATA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b1%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_EIM_D27__UART2_RX_DATA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x1b0b1%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pinctrl_usdhc3%3A%20usdhc3grp%20%7B%3C%2FP%3E%3CP%3Efsl%EF%BC%8C%E5%BC%95%E8%84%9A%3D%26lt%3B%3C%2FP%3E%3CP%3EMX6QDL_PAD_SD3_CMD__SD3_CMD%200x17059%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_SD3_CLK__SD3_CLK%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x10059%3C%2FP%3E%3CP%3EMX6QDL_PAD_SD3_DAT0__SD3_DATA0%200x17059%3C%2FP%3E%3CP%3EMX6QDL_PAD_SD3_DAT1__SD3_DATA1%200x17059%3C%2FP%3E%3CP%3EMX6QDL_PAD_SD3_DAT2__SD3_DATA2%200x17059%3C%2FP%3E%3CP%3EMX6QDL_PAD_SD3_DAT3__SD3_DATA3%200x17059%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CEM%3E%3CSTRONG%3E3.3%20%E7%BC%96%E8%AF%91%E8%AE%BE%E5%A4%87%E6%A0%91%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E7%BC%96%E8%AF%91.dts%E5%B0%86%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%20.dtb%E6%96%87%E4%BB%B6%E6%98%AF%E5%86%85%E6%A0%B8%E6%89%80%E9%9C%80%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14533236016623935%22%20data-renderedposition%3D%226273.83349609375_8_1231_16%22%20jivemacro_uid%3D%22_14533236016623935%22%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E4%BD%BF%20ARCH%3Darm%20dtbs%3C%2FP%3E%3C%2FPRE%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E5%90%8D%E4%B8%BA%20imx6q-udoo-doc.dtb%20%E7%9A%84%E6%96%87%E4%BB%B6%E6%98%AF%E6%88%91%E4%BB%AC%E4%B8%BB%E6%9D%BF%E4%BD%BF%E7%94%A8%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%E5%AE%83%E4%BD%8D%E4%BA%8E%3CSPAN%20style%3D%22color%3A%20%232873ee%3B%22%3Earch%2Farm%2Fboot%2Fdts%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%20SD%20%E5%8D%A1%E4%B8%8A%E6%9C%89%E5%8F%AF%E7%94%A8%E7%9A%84%E9%95%9C%E5%83%8F%EF%BC%8C%E8%AF%B7%E5%B0%86%E6%AD%A4%E6%96%87%E4%BB%B6%E6%94%BE%E5%85%A5%20FAT%20%E5%88%86%E5%8C%BA%E3%80%82%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%85%88%E6%9B%B4%E6%94%B9%E6%96%87%E4%BB%B6%E5%90%8D%EF%BC%8C%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%E4%B8%BA%20imx6q-udoo.dtb%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E4.%20%E5%90%AF%E5%8A%A8%E9%95%9C%E5%83%8F%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E6%AD%A4%E5%90%8E%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E6%8B%A5%E6%9C%89%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E4%B8%94%E5%8A%9F%E8%83%BD%E9%BD%90%E5%85%A8%E7%9A%84%20Linux%20%E7%B3%BB%E7%BB%9F%E3%80%82%E5%8F%AA%E9%9C%80%E6%8F%92%E5%85%A5%20SD%20%E5%8D%A1%E5%B9%B6%E5%90%AF%E5%8A%A8%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%8D%B3%E5%8F%AF%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E6%82%A8%E5%BA%94%E8%AF%A5%E5%9C%A8%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E8%8E%B7%E5%BE%97%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E7%9A%84%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F54339iB4B4B6430251B0D2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E8%BF%99%E4%BB%BD%E5%9F%BA%E6%9C%AC%E6%96%87%E6%A1%A3%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AUdoo%20%E6%9D%BF%E7%9A%84%E5%9F%BA%E6%9C%AC%E8%AE%BE%E5%A4%87%E6%A0%91%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E8%AE%BE%E5%A4%87%E6%A0%91%E6%96%87%E4%BB%B6%E7%9A%84%E7%AE%80%E5%8D%95%2F%E6%B8%85%E6%99%B0%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%8C%E6%88%90%E6%89%80%E6%9C%89%E6%AD%A5%E9%AA%A4%E5%90%8E%EF%BC%8C%E6%88%91%E8%BF%90%E8%A1%8C%E4%BA%86%E4%B8%8B%E9%9D%A2%E7%9A%84%20make%20%E5%91%BD%E4%BB%A4%E3%80%82%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%20dtb%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%BF%20ARCH%3Darm%20dtbs%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%E2%80%9Cmake%20ARCH%3Darm%20dtbs%E2%80%9D%E6%97%B6%EF%BC%8C%E6%88%91%E5%9C%A8%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%E4%B8%AD%E7%9C%8B%E5%88%B0%E4%BB%A5%E4%B8%8B%E6%B6%88%E6%81%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Erm%20-f%20%2F..%2F*.dtb%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:34 AM
更新人:
