Deploying the eIQ Sample Apps to an i.MX8 board
After setting up an Yocto build environment as described in the L4.19.35_1.0.0 BSP Yocto Project User's Guide, apply the attached patch to the meta-fsl-bsp-release layer:
<yocto_dir>/sources/meta-fsl-bsp-release$ git am eiq-sample-apps-Add-recipe.patch
To include the applications in the image, add the following line to local.conf:
IMAGE_INSTALL_append += "eiq-sample-apps"
This will include all applications from the eIQ Sample Apps repository to the built image.
タグ(2)
添付
コメント
Hello:
           I encounter a error when applied the attached patch.
ERROR: Nothing RPROVIDES 'eiq-sample-apps' (but /home/duxy/fsl-arm-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-sdk/dynamic-layers/qt5-layer/recipes-fsl/images/fsl-image-qt5.bb RDEPENDS on or otherwise requires it)
NOTE: Runtime target 'eiq-sample-apps' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['eiq-sample-apps']
ERROR: Required build target 'fsl-image-qt5' has no buildable providers.
Missing or unbuildable dependency chain was: ['fsl-image-qt5', 'eiq-sample-apps']
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
      how to resolve it?    Before applied the patch, I have compiled the eIQ image successfully.
Hi coindu‌,
Could you please confirm that the patch was successfully applied? Does the eiq-sample-apps folder exists in meta-fsl-bsp-release/imx/meta-ml/recipes-apps/eiq-sample-apps? What BSP release are you using?
Thanks!
Vanessa
fsl-arm-yocto-bsp/sources/meta-fsl-bsp-release$ git log
commit 7a67a5a9f8bb31a50bf6704d6383957c8264c656
Author: Vanessa Maegima <[email protected]>
Date: Tue Oct 1 16:07:22 2019 -0300
eiq-sample-apps: Add recipe
Recipe to deploy all eiq_sample_apps to an iMX8* board.
Signed-off-by: Vanessa Maegima <[email protected]>
commit 8eeb420fad668b733ab95b460895e1c337c66b25
Author: Neena Busireddy <[email protected]>
Date: Fri May 3 10:50:12 2019 -0500
vkmark: Use SHA in SRCREV instead of AUTOREV
Signed-off-by: Neena Busireddy <[email protected]>
I reference 《UM11226.pdf》 to set the environment
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_machinelearning.xml
$: EULA=1 MACHINE=imx8mqevk DISTRO=fsl-imx-xwayland source ./fsl-setup-release.sh -b build-xwayland $: echo "BBLAYERS += \" \${BSPDIR}/sources/meta-imx-machinelearning \"" >> conf/bblayers.conf
meta-imx-machinelearning/recipes-libraries/tensorflow/tensorflow_1.12.0.bb  modify
COMPATIBLE_MACHINE = "(imx8qm|imx8mq|imx8mm)"
bitbake fsl-image-qt5
Could you please modify the COMPATIBLE_MACHINE in the eiq_sample_apps recipe as you did for TensorFlow and let me know how it goes?
My patch applies on top of a newer release L4.19.35 but let's try to make this work on L4.14.98
It do not work to modify COMPATIBLE_MACHINE.
It doesn't matter, I still compile according to the documentation
Please try adding the following line to conf/bblayers.conf:
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-ml "
The Yocto Project User's Guide say that eIQ is integrated in meta-eiq, but this layer doesn't exist.
There is a meta-ml: is ti the same thing?
Philippe
Hi philippemidol-monnet‌,
Yes, you are correct. I will ask for this to be updated.
Thanks for reporting.
Vanessa
%3CLINGO-SUB%20id%3D%22lingo-sub-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEeIQ%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%80%8EL4.19.35_1.0.0%20BSP%20Yocto%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%BA%20%E3%82%AC%E3%82%A4%E3%83%89%E3%80%8F%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%20Yocto%20%E3%83%93%E3%83%AB%E3%83%89%E7%92%B0%E5%A2%83%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%20%3CSTRONG%3Emeta-fsl-bsp-release%3C%2FSTRONG%3E%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CYOCTO_DIR%3E%2Fsources%2Fmeta-fsl-bsp-release%24%20git%20am%20eiq-sample-apps-Add-recipe.patch%3C%2FYOCTO_DIR%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%20%3CSTRONG%3Elocal.conf%3C%2FSTRONG%3E%20%E3%81%AB%E6%AC%A1%E3%81%AE%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EIMAGE_INSTALL_append%20%2B%3D%20%22eiq-sample-apps%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EeIQ%20Sample%20Apps%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%BE%E3%81%A7%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEeIQ%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fphilippemidol-monnet%22%20target%3D%22_blank%22%3Ephilippemidol-monnet%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E4%BE%9D%E9%A0%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EVanessa%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEeIQ%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EYocto%20Project%20User's%20Guide%E3%81%AB%E3%81%AF%E3%80%81eIQ%E3%81%AFmeta-eiq%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Emeta-ml%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3Ati%E3%81%AF%E5%90%8C%E3%81%98%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%95%E3%82%A3%E3%83%AA%E3%83%83%E3%83%97%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEeIQ%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CEM%3Econf%2Fbblayers.conf%3C%2FEM%3E%20%E3%81%AB%E6%AC%A1%E3%81%AE%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EBBLAYERS%20%2B%3D%20%22%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-ml%20%22%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEeIQ%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECOMPATIBLE_MACHINE%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEeIQ%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Efsl-arm-yocto-bsp%2Fsources%2Fmeta-fsl-bsp-release%24%20git%20log%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%207a67a5a9f8bb31a50bf6704d6383957c8264c656%3CBR%20%2F%3E%3CSPAN%3E%E8%91%97%E8%80%85%3A%E3%83%B4%E3%82%A1%E3%83%8D%E3%83%83%E3%82%B5%E3%83%BB%E3%83%9E%E3%82%A8%E3%82%AE%E3%83%9E%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Avanessa.maegima%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evanessa.maegima%40nxp.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%E6%97%A5%E4%BB%98%3A%20Tue%20Oct%201%2016%3A07%3A22%202019%20-0300%3C%2FP%3E%3CP%3Eeiq-sample-apps%3A%20%E3%83%AC%E3%82%B7%E3%83%94%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEeiq_sample_apps%E3%82%92iMX8%20*%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%E3%81%99%E3%82%8B%E3%83%AC%E3%82%B7%E3%83%94%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%AA%E3%83%95%3A%E3%83%B4%E3%82%A1%E3%83%8D%E3%83%83%E3%82%B5%E3%83%BB%E3%83%9E%E3%82%A8%E3%82%AE%E3%83%9E%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Avanessa.maegima%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evanessa.maegima%40nxp.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%208eeb420fad668b733ab95b460895e1c337c66b25%3CBR%20%2F%3E%3CSPAN%3E%E8%91%97%E8%80%85%3A%20Neena%20Busireddy%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aneenareddy.busireddy%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eneenareddy.busireddy%40nxp.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%E6%97%A5%E6%99%82%3A2019%E5%B9%B45%E6%9C%883%E6%97%A5(%E9%87%91)10%3A50%3A12%20-0500%3C%2FP%3E%3CP%3Evkmark%3A%20SRCREV%20%E3%81%A7%20AUTOREV%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SHA%20%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E7%BD%B2%E5%90%8D%E8%80%85%3A%E3%83%8B%E3%83%BC%E3%83%8A%E3%83%BB%E3%83%93%E3%83%A5%E3%82%B7%E3%83%AC%E3%83%87%E3%82%A3%20%26lt%3B%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aneenareddy.busireddy%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eneenareddy.busireddy%40nxp.com%3C%2FA%3E%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20869px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F95238iE5ABE8016CEE8D42%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%80%8AUM11226.pdf%E3%80%8B%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E7%92%B0%E5%A2%83%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%3C%2FP%3E%3CPRE%20style%3D%22color%3A%20%2324292e%3B%20background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3Erepo%20init%20-u%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23990073%3B%22%3Ehttps%3A%3C%2FSPAN%3E%2F%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23009926%3B%22%3E%2Fsource.codeaurora.org%2Fexternal%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23009926%3B%22%3E%2Fimx%2Fimx-manifest%3C%2FSPAN%3E-b%20imx-linux-sumo%20-m%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3Eimx-4.14%3C%2FSPAN%3E%20%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E98%3C%2FSPAN%3E%E3%81%8B%E3%82%89%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E2.0%3C%2FSPAN%3E%E3%80%82%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E0_%3C%2FSPAN%3Emachinelearning.xml%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22color%3A%20%2324292e%3B%20background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3E%24%3A%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3EEULA%3C%2FSPAN%3E%3D1%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3EMACHINE%3C%2FSPAN%3E%3Dimx8mqevk%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3EDISTRO%3C%2FSPAN%3E%3Dfsl-imx-xwayland%20source%20.%2Ffsl-setup-release.sh%20-b%20build-xwayland%20%24%3A%20echo%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23dd1144%3B%22%3E%22BBLAYERS%20%2B%3D%20%5C%22%20%5C%24%7BBSPDIR%7D%2Fsources%2Fmeta-imx-machinelearning%20%5C%22%22%3C%2FSPAN%3E%20%26gt%3B%26gt%3B%20conf%2Fbblayers.conf%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2324292e%3B%22%3Emeta-imx-machinelearning%2Frecipes-libraries%2Ftensorflow%2Ftensorflow_1.12.0.bb%20%E4%BF%AE%E6%AD%A3%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20style%3D%22background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%3ECOMPATIBLE_MACHINE%3C%2FSPAN%3E%20%3D%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23dd1144%3B%22%3E%22(imx8qm%7Cimx8mq%7Cimx8mm)%22%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2324292e%3B%22%3Ebitbake%20fsl-image-qt5%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEeIQ%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fcoindu%22%20target%3D%22_blank%22%3Ecoindu%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3Feiq-sample-apps%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AF%20%3CEM%3Emeta-fsl-bsp-release%2Fimx%2Fmeta-ml%2Frecipes-apps%2Feiq-sample-apps%3C%2FEM%3E%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A9%E3%81%AEBSP%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3EVanessa%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%B8%E3%81%AEeIQ%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%E4%BD%95%E3%82%82%20'eiq-sample-apps'%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%88%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%20%2Fhome%2Fduxy%2Ffsl-arm-yocto-bsp%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-sdk%2Fdynamic-layers%2Fqt5-layer%2Frecipes-fsl%2Fimages%2Ffsl-image-qt5.bb%20RDEPENDS%20on%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99)%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'eiq-sample-apps'%20%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%A7%8B%E7%AF%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%3A%20%5B'eiq-sample-apps'%5D%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'fsl-image-qt5'%20%E3%81%AB%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%A7%8B%E7%AF%89%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%3A%20%5B'fsl-image-qt5'%2C%20'eiq-sample-apps'%5D%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%EF%BC%9A2%E3%81%A4%E3%81%AEERROR%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E9%9D%9E%E3%82%BC%E3%83%AD%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81eIQ%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎11-26-2019 06:41 AM
更新者:
