Deploying the eIQ Sample Apps to an i.MX8 board
After setting up an Yocto build environment as described in the L4.19.35_1.0.0 BSP Yocto Project User's Guide, apply the attached patch to the meta-fsl-bsp-release layer:
<yocto_dir>/sources/meta-fsl-bsp-release$ git am eiq-sample-apps-Add-recipe.patch
To include the applications in the image, add the following line to local.conf:
IMAGE_INSTALL_append += "eiq-sample-apps"
This will include all applications from the eIQ Sample Apps repository to the built image.
标记 (2)
附件
评论
Hello:
           I encounter a error when applied the attached patch.
ERROR: Nothing RPROVIDES 'eiq-sample-apps' (but /home/duxy/fsl-arm-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-sdk/dynamic-layers/qt5-layer/recipes-fsl/images/fsl-image-qt5.bb RDEPENDS on or otherwise requires it)
NOTE: Runtime target 'eiq-sample-apps' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['eiq-sample-apps']
ERROR: Required build target 'fsl-image-qt5' has no buildable providers.
Missing or unbuildable dependency chain was: ['fsl-image-qt5', 'eiq-sample-apps']
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
      how to resolve it?    Before applied the patch, I have compiled the eIQ image successfully.
Hi coindu‌,
Could you please confirm that the patch was successfully applied? Does the eiq-sample-apps folder exists in meta-fsl-bsp-release/imx/meta-ml/recipes-apps/eiq-sample-apps? What BSP release are you using?
Thanks!
Vanessa
fsl-arm-yocto-bsp/sources/meta-fsl-bsp-release$ git log
commit 7a67a5a9f8bb31a50bf6704d6383957c8264c656
Author: Vanessa Maegima <[email protected]>
Date: Tue Oct 1 16:07:22 2019 -0300
eiq-sample-apps: Add recipe
Recipe to deploy all eiq_sample_apps to an iMX8* board.
Signed-off-by: Vanessa Maegima <[email protected]>
commit 8eeb420fad668b733ab95b460895e1c337c66b25
Author: Neena Busireddy <[email protected]>
Date: Fri May 3 10:50:12 2019 -0500
vkmark: Use SHA in SRCREV instead of AUTOREV
Signed-off-by: Neena Busireddy <[email protected]>
I reference 《UM11226.pdf》 to set the environment
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_machinelearning.xml
$: EULA=1 MACHINE=imx8mqevk DISTRO=fsl-imx-xwayland source ./fsl-setup-release.sh -b build-xwayland $: echo "BBLAYERS += \" \${BSPDIR}/sources/meta-imx-machinelearning \"" >> conf/bblayers.conf
meta-imx-machinelearning/recipes-libraries/tensorflow/tensorflow_1.12.0.bb  modify
COMPATIBLE_MACHINE = "(imx8qm|imx8mq|imx8mm)"
bitbake fsl-image-qt5
Could you please modify the COMPATIBLE_MACHINE in the eiq_sample_apps recipe as you did for TensorFlow and let me know how it goes?
My patch applies on top of a newer release L4.19.35 but let's try to make this work on L4.14.98
It do not work to modify COMPATIBLE_MACHINE.
It doesn't matter, I still compile according to the documentation
Please try adding the following line to conf/bblayers.conf:
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-ml "
The Yocto Project User's Guide say that eIQ is integrated in meta-eiq, but this layer doesn't exist.
There is a meta-ml: is ti the same thing?
Philippe
Hi philippemidol-monnet‌,
Yes, you are correct. I will ask for this to be updated.
Thanks for reporting.
Vanessa
%3CLINGO-SUB%20id%3D%22lingo-sub-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E5%BC%80%E5%8F%91%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8C%89%E7%85%A7%20L4.19.35_1.0.0%20BSP%20Yocto%20%E9%A1%B9%E7%9B%AE%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E8%AE%BE%E7%BD%AE%20Yocto%20%E6%9E%84%E5%BB%BA%E7%8E%AF%E5%A2%83%E5%90%8E%EF%BC%8C%E5%B0%86%E9%99%84%E5%8A%A0%E7%9A%84%E8%A1%A5%E4%B8%81%E5%BA%94%E7%94%A8%E5%88%B0%3CSTRONG%3Emeta-fsl-bsp-release%3C%2FSTRONG%3E%E5%B1%82%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CYOCTO_DIR%3E%2Fsources%2Fmeta-fsl-bsp-release%24%20git%20am%20eiq-sample-apps-Add-recipe.patch%3C%2FYOCTO_DIR%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A6%81%E5%B0%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%8C%85%E5%90%AB%E5%9C%A8%E5%9B%BE%E5%83%8F%E4%B8%AD%EF%BC%8C%E8%AF%B7%E5%B0%86%E4%BB%A5%E4%B8%8B%E8%A1%8C%E6%B7%BB%E5%8A%A0%E5%88%B0%3CSTRONG%3Elocal.conf%3C%2FSTRONG%3E%20%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EIMAGE_INSTALL_append%20%2B%3D%20%E2%80%9Ceiq-sample-apps%E2%80%9D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E5%B0%86%E5%8C%85%E6%8B%AC%E4%BB%8E%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimxsupport%2Feiq_sample_apps%2Ftree%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EeIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%AD%98%E5%82%A8%E5%BA%93%3C%2FA%3E%E5%88%B0%E6%9E%84%E5%BB%BA%E7%9A%84%E5%9B%BE%E5%83%8F%E7%9A%84%E6%89%80%E6%9C%89%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fphilippemidol-monnet%22%20target%3D%22_blank%22%3Ephilippemidol-monnet%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AF%B9%E3%80%82%E6%88%91%E4%BC%9A%E8%A6%81%E6%B1%82%E6%9B%B4%E6%96%B0%E6%AD%A4%E5%86%85%E5%AE%B9%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%8A%A5%E5%91%8A%E3%80%82%3C%2FP%3E%3CP%3EVanessa%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EYocto%20%E9%A1%B9%E7%9B%AE%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%E8%AF%B4%20eIQ%20%E9%9B%86%E6%88%90%E5%9C%A8%20meta-eiq%20%E4%B8%AD%EF%BC%8C%E4%BD%86%E8%BF%99%E4%B8%80%E5%B1%82%E5%B9%B6%E4%B8%8D%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%9C%89%E4%B8%80%E4%B8%AA%E5%85%83%20ml%EF%BC%9Ati%20%E6%98%AF%E5%90%8C%E4%B8%80%E4%BB%B6%E4%BA%8B%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%8F%B2%E5%88%A9%E6%99%AE%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%B0%86%E4%BB%A5%E4%B8%8B%E8%A1%8C%E6%B7%BB%E5%8A%A0%E5%88%B0%3CEM%3Econf%2Fbblayers.conf%3C%2FEM%3E%20%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3EBBLAYERS%20%2B%3D%E2%80%9C%20%24%7BBSPDIR%7D%20%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-ml%E2%80%9D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BF%AE%E6%94%B9%20COMPATIBLE_MACHINE%20%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%B2%A1%E5%85%B3%E7%B3%BB%EF%BC%8C%E6%88%91%E8%BF%98%E6%98%AF%E6%8C%89%E7%85%A7%E6%96%87%E6%A1%A3%E7%BC%96%E8%AF%91%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%83%8F%E4%BF%AE%E6%94%B9%20TensorFlow%20%E4%B8%80%E6%A0%B7%E4%BF%AE%E6%94%B9%20eiq_sample_apps%20%E9%85%8D%E6%96%B9%E4%B8%AD%E7%9A%84%20COMPATIBLE_MACHINE%EF%BC%8C%E5%B9%B6%E5%91%8A%E8%AF%89%E6%88%91%E8%BF%9B%E5%B1%95%E5%A6%82%E4%BD%95%EF%BC%9F%3C%2FP%3E%3CPRE%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23f6f8fa%3B%20border%3A%200px%3B%20margin%3A%200px%200px%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3ECOMPATIBLE_MACHINE%3C%2FSPAN%3E%20%3D%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23dd1144%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%22(imx8qm%7Cimx8mq%7Cimx8mm)%22%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E7%9A%84%E8%A1%A5%E4%B8%81%E9%80%82%E7%94%A8%E4%BA%8E%E8%BE%83%E6%96%B0%E7%89%88%E6%9C%AC%20L4.19.35%EF%BC%8C%E4%BD%86%E8%AE%A9%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E5%9C%A8%20L4.14.98%20%E4%B8%8A%E8%BF%9B%E8%A1%8C%E6%AD%A4%E6%93%8D%E4%BD%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Efsl-arm-yocto-bsp%2Fsources%2Fmeta-fsl-bsp-release%24%20git%20log%3C%2FP%3E%3CP%3E%E6%8F%90%E4%BA%A4%207a67a5a9f8bb31a50bf6704d6383957c8264c656%3CBR%20%2F%3E%3CSPAN%3E%E4%BD%9C%E8%80%85%EF%BC%9AVanessa%20Maegima%20%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Avanessa.maegima%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evanessa.maegima%40nxp.com%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%E6%97%A5%E6%9C%9F%EF%BC%9A2019%E5%B9%B410%E6%9C%881%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%8C16%3A07%3A22%20-0300%3C%2FP%3E%3CP%3Eeiq-sample-apps%EF%BC%9A%E6%B7%BB%E5%8A%A0%E8%8F%9C%E8%B0%B1%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%B0%86%E6%89%80%E6%9C%89%20eiq_sample_apps%20%E9%83%A8%E7%BD%B2%E5%88%B0%20iMX8*%20%E6%9D%BF%E7%9A%84%E9%85%8D%E6%96%B9%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E7%AD%BE%E5%90%8D%E4%BA%BA%EF%BC%9AVanessa%20Maegima%20%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Avanessa.maegima%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Evanessa.maegima%40nxp.com%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E4%BA%A4%208eeb420fad668b733ab95b460895e1c337c66b25%3CBR%20%2F%3E%3CSPAN%3E%E4%BD%9C%E8%80%85%EF%BC%9ANeena%20Busireddy%20%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aneenareddy.busireddy%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eneenareddy.busireddy%40nxp.com%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%E6%97%A5%E6%9C%9F%EF%BC%9A2019%E5%B9%B45%E6%9C%883%E6%97%A5%E6%98%9F%E6%9C%9F%E4%BA%9410%3A50%3A12%20-0500%3C%2FP%3E%3CP%3Evkmark%EF%BC%9A%E5%9C%A8%20SRCREV%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20SHA%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20AUTOREV%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E7%AD%BE%E5%90%8D%E4%BA%BA%EF%BC%9ANeena%20Busireddy%20%26lt%3B%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aneenareddy.busireddy%40nxp.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eneenareddy.busireddy%40nxp.com%3C%2FA%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20869px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F95238iE5ABE8016CEE8D42%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%82%E8%80%83%E4%BA%86%E3%80%8AUM11226.pdf%E3%80%8B%E8%AE%BE%E7%BD%AE%E7%8E%AF%E5%A2%83%3C%2FP%3E%3CPRE%20style%3D%22color%3A%20%2324292e%3B%20background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3Erepo%20init%20-u%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23990073%3B%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%3C%2FSPAN%3E%20%2F%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23009926%3B%22%3Eimx%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23009926%3B%22%3E%2Fimx%3C%2FSPAN%3E%20-manifest-b%20imx%20-%20linux-sumo%20-m%20imx-%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E%20%3C%2FSPAN%3E4.14.98-2.0.0_machinelearning.xml%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23008080%3B%22%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CPRE%20style%3D%22color%3A%20%2324292e%3B%20background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3E%24%3A%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3EEULA%3C%2FSPAN%3E%20%3D1%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3E%E6%9C%BA%E5%99%A8%3C%2FSPAN%3E%3Dimx8mqevk%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23000080%3B%20font-weight%3A%20normal%3B%22%3E%E5%8F%91%E8%A1%8C%E7%89%88%3C%2FSPAN%3E%3Dfsl-imx-xwayland%20%E6%BA%90.%2Ffsl-setup-release.sh%20-b%20build-xwayland%20%24%3A%20echo%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23dd1144%3B%22%3E%22BBLAYERS%20%2B%3D%20%5C%22%20%5C%20%24%7BBSPDIR%7D%20%2Fsources%2Fmeta-imx-machinelearning%20%5C%22%22%3C%2FSPAN%3E%20%26gt%3B%26gt%3B%20conf%2Fbblayers.conf%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2324292e%3B%22%3Emeta-imx-machinelearning%2Frecipes-libraries%2Ftensorflow%2Ftensorflow_1.12.0.bb%20%E4%BF%AE%E6%94%B9%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20style%3D%22background-color%3A%20%23f6f8fa%3B%20margin-bottom%3A%2016px%3B%20padding%3A%2016px%3B%22%3E%3CCODE%20class%3D%22%22%20style%3D%22color%3A%20%23333333%3B%20background%3A%20transparent%3B%20border%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%3ECOMPATIBLE_MACHINE%3C%2FSPAN%3E%20%3D%20%3CSPAN%20class%3D%22%22%20style%3D%22color%3A%20%23dd1144%3B%22%3E%22(imx8qm%7Cimx8mq%7Cimx8mm)%22%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2324292e%3B%22%3Ebitbake%20fsl-image-qt5%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fcoindu%22%20target%3D%22_blank%22%3Ecoindu%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E7%A1%AE%E8%AE%A4%E8%A1%A5%E4%B8%81%E5%B7%B2%E6%88%90%E5%8A%9F%E5%BA%94%E7%94%A8%EF%BC%9Feiq-sample-apps%20%E6%96%87%E4%BB%B6%E5%A4%B9%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E4%BA%8E%3CEM%3Emeta-fsl-bsp-release%2Fimx%2Fmeta-ml%2Frecipes-apps%2Feiq-sample-apps%20%E4%B8%AD%3C%2FEM%3E%EF%BC%9F%E6%82%A8%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%20BSP%20%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EVanessa%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%86%20eIQ%20%E7%A4%BA%E4%BE%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%A8%E7%BD%B2%E5%88%B0%20i.MX8%20%E6%9D%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E5%BA%94%E7%94%A8%E9%99%84%E5%8A%A0%E7%9A%84%E8%A1%A5%E4%B8%81%E6%97%B6%E6%88%91%E9%81%87%E5%88%B0%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%B2%A1%E6%9C%89%E6%8F%90%E4%BE%9B%E2%80%9Ceiq-sample-apps%E2%80%9D%EF%BC%88%E4%BD%86%2Fhome%2Fduxy%2Ffsl-arm-yocto-bsp%2Fsources%2Fmeta-fsl-bsp-release%2Fimx%2Fmeta-sdk%2Fdynamic-layers%2Fqt5-layer%2Frecipes-fsl%2Fimages%2Ffsl-image-qt5.bb%20%E4%BE%9D%E8%B5%96%E4%BA%8E%E5%AE%83%E6%88%96%E4%BB%A5%E5%85%B6%E4%BB%96%E6%96%B9%E5%BC%8F%E9%9C%80%E8%A6%81%E5%AE%83%EF%BC%89%3CBR%20%2F%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E8%BF%90%E8%A1%8C%E6%97%B6%E7%9B%AE%E6%A0%87%E2%80%9Ceiq-sample-apps%E2%80%9D%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%EF%BC%8C%E5%88%A0%E9%99%A4...%3CBR%20%2F%3E%E7%BC%BA%E5%A4%B1%E6%88%96%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%E7%9A%84%E4%BE%9D%E8%B5%96%E9%93%BE%E4%B8%BA%EF%BC%9A%5B'eiq-sample-apps'%5D%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%89%80%E9%9C%80%E6%9E%84%E5%BB%BA%E7%9B%AE%E6%A0%87%E2%80%9Cfsl-image-qt5%E2%80%9D%E6%B2%A1%E6%9C%89%E5%8F%AF%E6%9E%84%E5%BB%BA%E7%9A%84%E6%8F%90%E4%BE%9B%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%E7%BC%BA%E5%A4%B1%E6%88%96%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%E7%9A%84%E4%BE%9D%E8%B5%96%E9%93%BE%E4%B8%BA%EF%BC%9A%5B'fsl-image-qt5'%EF%BC%8C'eiq-sample-apps'%5D%3C%2FP%3E%3CP%3E%E6%91%98%E8%A6%81%EF%BC%9A%E6%98%BE%E7%A4%BA%E4%BA%862%E6%9D%A1%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%EF%BC%8C%E8%BF%94%E5%9B%9E%E4%BA%86%E9%9D%9E%E9%9B%B6%E9%80%80%E5%87%BA%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%EF%BC%9F%E5%9C%A8%E5%BA%94%E7%94%A8%E8%A1%A5%E4%B8%81%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E7%BC%96%E8%AF%91%E4%BA%86%20eIQ%20%E6%98%A0%E5%83%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎11-26-2019 06:41 AM
更新人:
