RW610 JLink DAP Failing on Zephyr
206件の閲覧回数
jm-streametric
I am working on a custom PCB with an RW610 MCU and running Zephyr RTOS.  Before using Zephyr, I worked with FreeRTOS and the NXP HAL directly.
On that old firmware, I was able to use an external JLink debugger to reset/program the board even while running.  After switching to Zephyr, I can no longer flash while the board is running.  I get the message DAP failed to initialize.
On the custom board I do have a BOOT button which can force the board into ISP boot when powered off/on.  Using this, I can flash my Zephyr code.  However, I lose the ability to debug the code with GDB because when the board is flashed in ISP mode I can't reset it through the JLink.
Failed flash while running:
スポイラ
[2025-11-24T09:36:31.893] [Secure Provisioning] [error] No device id found.
[2025-11-24T09:36:32.392] [Secure Provisioning] [error] No device id found.
[2025-11-24T09:36:32.402] [proc] [info] Cmd: /opt/SEGGER/JLink_V872/JLinkGDBServerCLExe -listprobes USB
[2025-11-24T09:36:32.407] [proc] [info] Cmd: /usr/local/LinkServer_25.9.134/LinkServer probes --json
[2025-11-24T09:36:32.845] [proc] [info] Cmd: /usr/local/mcuxpressoide-24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-11-24T09:36:32.850] [proc] [info] Cmd: /.../.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-11-24T09:36:32.856] [proc] [info] Cmd: /usr/local/mcuxpressoide/ide/tools/bin/arm-none-eabi-gcc --version
[2025-11-24T09:36:32.859] [proc] [info] Cmd: /.../.mcuxpressotools/arm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-11-24T09:36:32.866] [proc] [info] Cmd: cmake -DFORMAT=json -P verify-toolchain.cmake
[2025-11-24T09:36:33.815] [proc] [info] {"ZEPHYR_TOOLCHAIN_VARIANT" : "zephyr", "SDK_VERSION": "0.17.4", "ZEPHYR_SDK_INSTALL_DIR" : "/.../zephyr-sdk-0.17.4"}
[2025-11-24T09:36:33.821] [proc] [info] Cmd: /.../zephyr-sdk-0.17.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-objcopy -I elf32-littlearm -O ihex /.../project/debug/zephyr/zephyr.elf zephyr.hex
[2025-11-24T09:36:33.842] [proc] [info] Cmd: /opt/SEGGER/JLink_V872/JLinkExe -if SWD -speed auto -commanderscript /.../project/script.jlink -device RW610 -SelectEmuBySN 53002466
[2025-11-24T09:36:34.285] [proc] [error] /opt/SEGGER/JLink_V872/JLinkExe exited with code 1
[2025-11-24T09:36:34.285] [proc] [error] SEGGER J-Link Commander V8.72 (Compiled Sep 24 2025 13:39:14)
DLL version V8.72, compiled Sep 24 2025 13:38:10
J-Link Command File read successfully.
Processing script file...
J-Link>ExitOnError 1
J-Link Commander will now exit on Error
J-Link>r
J-Link connection not established yet but required for command.
Connecting to J-Link via USB...O.K.
Firmware: J-Link V13 compiled Sep 17 2025 12:01:59
Hardware version: V13.00
J-Link uptime (since boot): 0d 00h 08m 51s
S/N: 53002466
License(s): GDB
USB speed mode: High speed (480 MBit/s)
VTref=3.322V
Target connection not established yet but required for command.
Device "RW610" selected.
Connecting to target via SWD
InitTarget() start
SWD selected. Executing JTAG -> SWD switching sequence.
Error: Failed to initialize DAP.
InitTarget() end - Took 133ms
Connect failed. Resetting via Reset pin and trying again.
InitTarget() start
Error occurred: Could not connect to the target device.
For troubleshooting steps visit: https://kb.segger.com/J-Link_Troubleshooting
Script processing completed.
Successful flash when I use ISP boot:
スポイラ
[2025-11-24T09:34:03.519] [Secure Provisioning] [error] No device id found.
[2025-11-24T09:34:04.494] [Secure Provisioning] [error] No device id found.
[2025-11-24T09:34:04.503] [proc] [info] Cmd: /opt/SEGGER/JLink_V872/JLinkGDBServerCLExe -listprobes USB
[2025-11-24T09:34:04.507] [proc] [info] Cmd: /usr/local/LinkServer_25.9.134/LinkServer probes --json
[2025-11-24T09:34:04.948] [proc] [info] Cmd: /usr/local/mcuxpressoide-24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-11-24T09:34:04.953] [proc] [info] Cmd: /usr/local/mcuxpressoide/ide/tools/bin/arm-none-eabi-gcc --version
[2025-11-24T09:34:04.959] [proc] [info] Cmd: /.../.mcuxpressotools/arm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-11-24T09:34:04.963] [proc] [info] Cmd: /.../.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-11-24T09:34:04.972] [proc] [info] Cmd: cmake -DFORMAT=json -P verify-toolchain.cmake
[2025-11-24T09:34:06.130] [proc] [info] {"ZEPHYR_TOOLCHAIN_VARIANT" : "zephyr", "SDK_VERSION": "0.17.4", "ZEPHYR_SDK_INSTALL_DIR" : "/.../zephyr-sdk-0.17.4"}
[2025-11-24T09:34:06.136] [proc] [info] Cmd: /.../zephyr-sdk-0.17.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-objcopy -I elf32-littlearm -O ihex /.../project/debug/zephyr/zephyr.elf zephyr.hex
[2025-11-24T09:34:06.157] [proc] [info] Cmd: /opt/SEGGER/JLink_V872/JLinkExe -if SWD -speed auto -commanderscript /.../project/script.jlink -device RW610 -SelectEmuBySN 53002466
[2025-11-24T09:34:20.074] [SEGGER] [info] SEGGER flash operation completed successfully:
J-Link>r
J-Link uptime (since boot): 0d 00h 06m 24s
S/N: 53002466
License(s): GDB
VTref=3.325V
InitTarget() start
DAP initialized successfully.
DMAP_REG_ID: DM-AP IDCODE detected: 0x002A0000
DHCSR: 0xFFFFFFFF
ROM entered ISP command handling loop. Re-enable the debug access.
InitTarget() end - Took 14.0ms
Found SW-DP with ID 0x6BA02477
DPIDR: 0x6BA02477
CoreSight SoC-400 or earlier
Scanning AP map to find all available APs
AP[1]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x84770001, ADDR: 0x00000000)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FD214. Implementer code: 0x41 (ARM)
Feature set: Mainline
Cache: No cache
Found Cortex-M33 r0p4, Little endian.
FPUnit: 8 code (BP) slots and 0 literal slots
Security extension: implemented
Secure debug: enabled
CoreSight components:
ROMTbl[0] @ E00FF000
[0][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
[0][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
[0][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
[0][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
[0][5]: E0041000 CID B105900D PID 002BBD21 DEVARCH 47724A13 DEVTYPE 13 ETM
[0][6]: E0042000 CID B105900D PID 000BBD21 DEVARCH 47701A14 DEVTYPE 14 CSS600-CTI
Memory zones:
Zone: "Default" Description: Default access mode
Cortex-M33 identified.
Reset delay: 0 ms
ResetTarget() start
Reset via SYSRESETREQ and reset pin + halt after bootloader
MSPLIM cleared
ResetTarget() end - Took 128ms
Device specific reset executed.
J-Link>h
PC = 1302B460, CycleCnt = 00000000
R0 = 00000000, R1 = 5AC33CA5, R2 = 00000001, R3 = 5AC33CA5
R4 = 3012F5FC, R5 = 50002E24, R6 = 55AACC33, R7 = 33CCAA55
R8 = 5AA55AA5, R9 = FCF0030F, R10= C33CA55A, R11= 55AACC33
R12= 3012F5FC
SP(R13)= 30125A38, MSP= 30125A38, PSP= 00000000, R14(LR) = 1302B421
XPSR = 01000000: APSR = nzcvq, EPSR = 01000000, IPSR = 000 (NoException)
CFBP = 00000001, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 01
MSPLIM = 00000000
PSPLIM = 00000000
Security extension regs:
MSP_S = 30125A38, MSP_NS = 00000000
MSPLIM_S = 00000000, MSPLIM_NS = 00000000
PSP_S = 00000000, PSP_NS = FFFFFFFC
PSPLIM_S = 00000000, PSPLIM_NS = 00000000
CONTROL_S = 00, FAULTMASK_S = 00, BASEPRI_S = 00, PRIMASK_S = 01
CONTROL_NS = 00, FAULTMASK_NS = 00, BASEPRI_NS = 00, PRIMASK_NS = 00
FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000
FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000
FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000
FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000
FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000
FPSCR= 00000000
J-Link>loadfile /.../project/debug/zephyr/zephyr.hex
'loadfile': Performing implicit reset & halt of MCU.
ResetTarget() start
MSPLIM cleared
ResetTarget() end - Took 117ms
Downloading file [/.../project/debug/zephyr/zephyr.hex]...
J-Link: Flash download: Bank 1 @ 0x18000000: 1 range affected (786432 bytes)
J-Link: Flash download: Total: 13.012s (Prepare: 0.333s, Compare: 2.685s, Erase: 2.979s, Program: 5.531s, Verify: 1.307s, Restore: 0.174s)
J-Link: Flash download: Program speed: 139 KB/s
O.K.
J-Link>qc
Since the flashing worked when using FreeRTOS I suspect I have something in the devicetree or KConfig configured incorrectly.  Is there anything I should look for there?
I am using the MCUXpresso VSCode extension on Linux, flashing Zephyr 4.3.0.
Thank you!
タグ(4)
77件の閲覧回数
jm-streametric
Hello Daniel,
Turns out I was not attentive enough to my PCB's datasheet.  We are using the same pins for both Flexcomm2 and SWD.  I'm not using Flexcomm2 for this code but I accidentally set the status = "okay" flag for the flexcomm2 devicetree node.  Once I set status = "disabled" I was able to program my board without needing to set it into ISP mode.
160件の閲覧回数
DanielRuvalcaba
Are you able to use the J-Link Commander CLI to communicate with the core? (not in VS code)
What example did you use?
Daniel.
78件の閲覧回数
jm-streametric
Hello Daniel,
%3CLINGO-SUB%20id%3D%22lingo-sub-2247462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW610%20JLink%20DAP%E3%81%8CZephyr%E3%81%A7%E6%95%85%E9%9A%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20RW610%20MCU%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%80%81Zephyr%20RTOS%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20PCB%20%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Zephyr%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AF%E3%80%81FreeRTOS%20%E3%81%A8%20NXP%20HAL%20%E3%82%92%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%8F%A4%E3%81%84%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%AF%E3%80%81%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%A7%E3%82%82%E5%A4%96%E9%83%A8%E3%81%AE%20JLink%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%2F%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Zephyr%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82DAP%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%80%81%E9%9B%BB%E6%BA%90%E3%81%AE%E3%82%AA%E3%83%95%2F%E3%82%AA%E3%83%B3%E6%99%82%E3%81%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%BC%B7%E5%88%B6%E7%9A%84%E3%81%AB%20ISP%20%E3%83%96%E3%83%BC%E3%83%88%20CAN%20BOOT%20%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Zephyr%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%20ISP%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%20JLink%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81GDB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CU%3E%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FU%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%8D%E3%82%BF%E3%83%90%E3%83%AC%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E3%83%8F%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%88%E3%81%97%E3%81%A6%E8%AA%AD%E3%82%80%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A31.893%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A32.392%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A32.402%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A32.407%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2FLinkServer_25.%3C%2FSPAN%3E%20%3CSPAN%3E9%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3E134%3C%2FSPAN%3E%20%3CSPAN%3E%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A32.845%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2Fmcuxpressoide-%3C%2FSPAN%3E%3CSPAN%3E24%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E12%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E148%3C%2FSPAN%3E%3CSPAN%3E%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A32.850%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2F.mcuxpressotools%2Farm-%3C%2FSPAN%3E%20%3CSPAN%3Egnu-toolchain-13.2.Rel1-x86_64-arm-none%3C%2FSPAN%3E%20%3CSPAN%3E-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A32.856%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2Fmcuxpressoide%2Fide%2Ftools%2Fbin%2FArm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A32.859%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2F.mcuxpressotools%2Farm-%3C%2FSPAN%3E%20%3CSPAN%3Egnu-toolchain-14.2.rel1-x86_64-arm-none%3C%2FSPAN%3E%20%3CSPAN%3E-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A32.866%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20cmake%20-DFORMAT%3Djson%20-P%3C%2FSPAN%3E%20%3CSPAN%3Everify-toolchain.cmake%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A33.815%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E6%83%85%E5%A0%B1%5D%3C%2FSPAN%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3CSPAN%3E%22ZEPHYR_TOOLCHAIN_VARIANT%22%3C%2FSPAN%3E%3CSPAN%3E%20%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22Zephyr%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%22SDK_VERSION%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%220.17.4%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%22ZEPHYR_SDK_INSTALL_DIR%22%3C%2FSPAN%3E%3CSPAN%3E%20%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%2F...%2Fzephyr-SDK-0.17.4%22%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A33.821%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2FZephyr-%3C%2FSPAN%3E%3CSPAN%3ESDK-0.17%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3CSPAN%3E%2FArm-Zephyr-eabi%2Fbin%2FArm-Zephyr-eabi-objcopy%20-I%20elf32-littlearm%20-O%20ihex%20%2F...%2Fproject%2Fdebug%2FZephyr%2FZephyr.elf%20%3C%2FSPAN%3E%3CSPAN%3EZephyr.hex%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A33.842%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%20-if%20SWD%20-speed%20%E8%BB%8A%E8%BC%89%20-commanderscript%20%2F...%2Fproject%2Fscript.jlink%20-device%20RW610%20-SelectEmuBySN%3C%2FSPAN%3E%20%3CSPAN%3E53002466%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A34.285%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%20%3CSPAN%3E%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%20%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E2025-11-24T09%3A36%3A34.285%3C%2FSPAN%3E%20%3CSPAN%3E%5D%20%5Bproc%5D%3C%2FSPAN%3E%20%3CSPAN%3E%5Berror%5D%3C%2FSPAN%3E%20%3CSPAN%3ESEGGER%20J-Link%20Commander%3C%2FSPAN%3E%20%3CSPAN%3EV8.72%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E2025%E5%B9%B4%3C%2FSPAN%3E9%E6%9C%88%3CSPAN%3E24%E6%97%A5%3C%2FSPAN%3E%3CSPAN%3E13%3A39%3A14%3C%2FSPAN%3E%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EDLL%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3CSPAN%3EV8.72%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E2025%E5%B9%B4%3C%2FSPAN%3E9%E6%9C%88%3CSPAN%3E24%E6%97%A5%3C%2FSPAN%3E%3CSPAN%3E13%3A38%3A10%3C%2FSPAN%3E%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3EJ-Link%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%26gt%3B%E3%82%A8%E3%83%A9%E3%83%BC%E7%99%BA%E7%94%9F%E6%99%82%E3%81%AB%E7%B5%82%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%20Commander%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%E6%99%82%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%26gt%3Br%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%20%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%BE%E3%81%A0%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EUSB%E7%B5%8C%E7%94%B1%E3%81%A7J-Link%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%20%3CSPAN%3EOK%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20J-Link%20V13%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%97%A5%3A%3C%2FSPAN%3E%20%3CSPAN%3E2025%E5%B9%B4%3C%2FSPAN%3E9%E6%9C%88%3CSPAN%3E17%E6%97%A5%3C%2FSPAN%3E%3CSPAN%3E12%3A01%3A59%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%3C%2FSPAN%3E%20%3CSPAN%3EV13.00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%20%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E9%96%93%20(%E8%B5%B7%E5%8B%95%E4%BB%A5%E9%99%8D)%3A%200d%2000h%2008m%2051s%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A%3C%2FSPAN%3E%20%3CSPAN%3E53002466%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%3A%20GDB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EUSB%E9%80%9F%E5%BA%A6%E3%83%A2%E3%83%BC%E3%83%89%EF%BC%9A%E9%AB%98%E9%80%9F%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3E480%3C%2FSPAN%3E%20%3CSPAN%3EMBit%2Fs%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EVTref%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E3.322V%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%BE%E3%81%A0%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FSPAN%3E%3CSPAN%3E%E3%80%8CRW610%E3%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3ESWD%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EInitTarget()%20%E9%96%8B%E5%A7%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESWD%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3E%3A%20DAP%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EInitTarget()%20%E7%B5%82%E4%BA%86%20-%20133%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E3%81%A7%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EInitTarget()%20%E9%96%8B%E5%A7%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESWD%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3E%3A%20DAP%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EInitTarget()%20%E7%B5%82%E4%BA%86%20-%20133%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fkb.segger.com%2FJ-Link_Troubleshooting%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fkb.segger.com%2FJ-Link_Troubleshooting%3C%2FA%3E%3C%2FSPAN%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%5B2025-11-24T09%3A36%3A31.893%5D%20%5B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%5D%20%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%5B2025-11-24T09%3A36%3A32.392%5D%5B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%5D%20%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20ID%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%5B2025-11-24T09%3A36%3A32.402%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkGDBServerCLExe%20-listprobes%20USB%5B2025-11-24T09%3A36%3A32.407%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2FLinkServer_25.9.134%2FLinkServer%20probes%20--json%5B2025-11-24T09%3A36%3A32.845%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2Fmcuxpressoide-24.12.148%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%5B2025-11-24T09%3A36%3A32.850%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2F.mcuxpressotools%2Farm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%5B2025-11-24T09%3A36%3A32.856%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2Fmcuxpressoide%2Fide%2Ftools%2Fbin%2FArm-none-eabi-gcc%20--version%5B2025-11-24T09%3A36%3A32.859%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2F.mcuxpressotools%2Farm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%5B2025-11-24T09%3A36%3A32.866%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20cmake%20-DFORMAT%3Djson%20-P%20verify-toolchain.cmake%5B2025-11-24T09%3A36%3A33.815%5D%5Bproc%5D%20%5B%E6%83%85%E5%A0%B1%5D%20%7B%22ZEPHYR_TOOLCHAIN_VARIANT%22%20%3A%20%22Zephyr%22%2C%20%22SDK_VERSION%22%3A%20%220.17.4%22%2C%20%22ZEPHYR_SDK_INSTALL_DIR%22%20%3A%20%22%2F...%2FZephyr-SDK-0.17.4%22%7D%5B2025-11-24T09%3A36%3A33.821%5D%5Bproc%5D%20%5B%E6%83%85%E5%A0%B1%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2Fzephyr-sdk-0.17.4%2FArm-Zephyr-eabi%2Fbin%2FArm-Zephyr-eabi-objcopy%20-I%20elf32-littlearm%20-O%20ihex%20%2F...%2Fproject%2Fdebug%2FZephyr%2FZephyr.elf%20Zephyr.hex%5B2025-11-24T09%3A36%3A33.842%5D%20%5Bproc%5D%20%5B%E6%83%85%E5%A0%B1%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%20-if%20SWD%20-speed%20%E8%BB%8A%E8%BC%89%20-commanderscript%20%2F...%2Fproject%2Fscript.jlink%20-device%20RW610%20-SelectEmuBySN%2053002466%5B2025-11-24T09%3A36%3A34.285%5D%5Bproc%5D%20%5Berror%5D%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%20%E3%81%8C%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%5B2025-11-24T09%3A36%3A34.285%5D%5Bproc%5D%20%5Berror%5D%20SEGGER%20J-Link%20Commander%20V8.72%20(2025%E5%B9%B49%E6%9C%8824%E6%97%A5%2013%3A39%3A14%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB)DLL%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3V8.72%E3%80%812025%E5%B9%B49%E6%9C%8824%E6%97%A5%2013%3A38%3A10%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%ABJ-Link%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E4%B8%AD...J-Link%26gt%3BExitOnError%201J-Link%20Commander%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E7%99%BA%E7%94%9F%E6%99%82%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82J-Link%26gt%3BrJ-Link%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%BE%E3%81%A0%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82USB%E7%B5%8C%E7%94%B1%E3%81%A7J-Link%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...OK%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20J-Link%20V13%202025%E5%B9%B49%E6%9C%8817%E6%97%A5%2012%3A01%3A59%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%20V13.00J-Link%E7%A8%BC%E5%83%8D%E6%99%82%E9%96%93%20(%E8%B5%B7%E5%8B%95%E4%BB%A5%E9%99%8D)%3A%200d%2000h%2008m%2051sS%2FN%3A%2053002466%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%3A%20GDBUSB%E9%80%9F%E5%BA%A6%E3%83%A2%E3%83%BC%E3%83%89%3A%20%E9%AB%98%E9%80%9F%20(480%20MBit%2Fs)VTref%3D3.322VTarget%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%BE%E3%81%A0%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8CRW610%E3%80%8D%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SWDInitTarget()%20startSWD%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%3A%20DAP%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82InitTarget()%20%E7%B5%82%E4%BA%86%20-%20133%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%80%81%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82InitTarget()%20startSWD%20%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%3A%20DAP%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82InitTarget()%20%E7%B5%82%E4%BA%86%20-%20133%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fkb.segger.com%2FJ-Link_TroubleshootingScript%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fkb.segger.com%2FJ-Link_TroubleshootingScript%3C%2FA%3E%20%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CU%3EISP%20%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%88%90%E5%8A%9F%3A%3C%2FU%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%8D%E3%82%BF%E3%83%90%E3%83%AC%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E3%83%8F%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%88%E3%81%97%E3%81%A6%E8%AA%AD%E3%82%80%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CP%3E%5B2025-11-24T09%3A34%3A03.519%5D%20%5B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%5D%20%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20ID%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%5B2025-11-24T09%3A34%3A04.494%5D%20%5B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%5D%20%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%5B2025-11-24T09%3A34%3A04.503%5D%20%5Bproc%5D%20%5Binfo%5D%20Cmd%3A%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkGDBServerCLExe%20-listprobes%20USB%3CBR%20%2F%3E%20%5B2025-11-24T09%3A34%3A04.507%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2FLinkServer_25.9.134%2FLinkServer%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%20--json%3CBR%20%2F%3E%20%5B2025-11-24T09%3A34%3A04.948%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2Fmcuxpressoide-24.12.148%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%3CBR%20%2F%3E%20%5B2025-11-24T09%3A34%3A04.953%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2Fmcuxpressoide%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%3CBR%20%2F%3E%20%5B2025-11-24T09%3A34%3A04.959%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2F.mcuxpressotools%2Farm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%3CBR%20%2F%3E%20%5B2025-11-24T09%3A34%3A04.963%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2F.mcuxpressotools%2Farm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%3CBR%20%2F%3E%20%5B2025-11-24T09%3A34%3A04.972%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20cmake%20-DFORMAT%3Djson%20-P%20verify-toolchain.cmake%3CBR%20%2F%3E%5B2025-11-24T09%3A34%3A06.130%5D%20%5Bproc%5D%20%5B%E6%83%85%E5%A0%B1%5D%20%7B%22ZEPHYR_TOOLCHAIN_VARIANT%22%20%3A%20%22Zephyr%22%2C%20%22SDK_VERSION%22%3A%20%220.17.4%22%2C%20%22ZEPHYR_SDK_INSTALL_DIR%22%20%3A%20%22%2F...%2Fzephyr-sdk-0.17.4%22%7D%3C%2FP%3E%3CP%3E%5B2025-11-24T09%3A34%3A06.136%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2FZephyr-sdk-0.17.4%2FArm-Zephyr-eabi%2Fbin%2FArm-Zephyr-eabi-objcopy%20-I%20elf32-littlearm%20-O%20ihex%20%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.elf%20zephyr.hex%3CBR%20%2F%3E%5B2025-11-24T09%3A34%3A06.157%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%20-if%20SWD%20-speed%20%E8%BB%8A%E8%BC%89%20-commanderscript%20%2F...%2Fproject%2Fscript.jlink%20-device%20RW610%20-SelectEmuBySN%2053002466%3CBR%20%2F%3E%20%5B2025-11-24T09%3A34%3A20.074%5D%20%5BSEGGER%5D%20%5Binfo%5D%20SEGGER%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%93%8D%E4%BD%9C%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20SEGGER%20J-Link%20Commander%20V8.72%20(2025%E5%B9%B49%E6%9C%8824%E6%97%A5%2013%3A39%3A14%20%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB)%3CBR%20%2F%3E%20DLL%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3V8.72%E3%80%812025%E5%B9%B49%E6%9C%8824%E6%97%A513%3A38%3A10%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EJ-Link%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB...%3CBR%20%2F%3EJ-Link%26gt%3B%E3%82%A8%E3%83%A9%E3%83%BC%E7%99%BA%E7%94%9F%E6%99%82%E3%81%AB%E7%B5%82%E4%BA%86%201%3CBR%20%2F%3EJ-Link%20Commander%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E6%99%82%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EJ-Link%26gt%3Br%3CBR%20%2F%3EJ-Link%20%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%BE%E3%81%A0%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3EUSB%E7%B5%8C%E7%94%B1%E3%81%A7J-Link%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...OK%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20J-Link%20V13%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E6%97%A5%3A%202025%E5%B9%B49%E6%9C%8817%E6%97%A5%2012%3A01%3A59%3CBR%20%2F%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%20V13.00%3CBR%20%2F%3E%20J-Link%20%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E9%96%93%20(%E8%B5%B7%E5%8B%95%E4%BB%A5%E9%99%8D)%3A%200d%2000h%2006m%2024s%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E7%95%AA%E5%8F%B7%3A%2053002466%3CBR%20%2F%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%3A%20GDB%3CBR%20%2F%3E%20USB%E9%80%9F%E5%BA%A6%E3%83%A2%E3%83%BC%E3%83%89%3A%20%E9%AB%98%E9%80%9F%20(480%20MBit%2Fs)%3CBR%20%2F%3E%20VTref%3D3.325V%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%BE%E3%81%A0%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8CRW610%E3%80%8D%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ESWD%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3EInitTarget()%20%E9%96%8B%E5%A7%8B%3CBR%20%2F%3ESWD%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDAP%20%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EDMAP_REG_ID%3A%20DM-AP%20IDCODE%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%200x002A0000%3CBR%20%2F%3E%20DHCSR%3A%200xFFFFFFFF%3CBR%20%2F%3E%20ROM%20%E3%81%8C%20ISP%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E5%87%A6%E7%90%86%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EInitTarget()%20%E7%B5%82%E4%BA%86%20-%2014.0ms%20%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EID%200x6BA02477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x6BA02477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEAP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3EAP%5B1%5D%3A%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E7%AB%AF%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81AP%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001%2C%20ADDR%3A%200x00000000)%3CBR%20%2F%3E%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BAHB-AP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3EAP%5B0%5D%3A%20%E3%82%B3%E3%82%A2%E3%82%92%E7%99%BA%E8%A6%8B%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20ROM%E3%83%99%E3%83%BC%E3%82%B9%3A%200xE00FF000%3CBR%20%2F%3E%20CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%200x410FD214%E3%80%82%E5%AE%9F%E8%A3%85%E8%80%85%E3%82%B3%E3%83%BC%E3%83%89%3A%200x41%20(ARM)%3CBR%20%2F%3E%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%3CBR%20%2F%3E%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AA%E3%81%97%3CBR%20%2F%3ECortex-M33%20r0p4%E3%80%81%E3%83%AA%E3%83%88%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EFPUnit%3A%208%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%20(BP)%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%A8%200%20%E3%81%A4%E3%81%AE%E3%83%AA%E3%83%86%E3%83%A9%E3%83%AB%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%3CBR%20%2F%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E6%8B%A1%E5%BC%B5%3A%20%E5%AE%9F%E8%A3%85%E6%B8%88%E3%81%BF%3CBR%20%2F%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E6%9C%89%E5%8A%B9%3CBR%20%2F%3ECoreSight%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%3A%3CBR%20%2F%3E%20ROMTbl%5B0%5D%20%40%20E00FF000%3CBR%20%2F%3E%20%5B0%5D%5B0%5D%3A%20E000E000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047702A04%20DEVTYPE%2000%20Cortex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ortex-M33%20%E3%81%8C%E7%89%B9%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E9%81%85%E5%BB%B6%3A%200%20%E3%83%9F%E3%83%AA%E7%A7%92%3CBR%20%2F%3EResetTarget()%20%E9%96%8B%E5%A7%8B%3CBR%20%2F%3ESYSRESETREQ%E3%81%A8%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%2B%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E5%BE%8C%E3%81%AE%E5%81%9C%E6%AD%A2%3CBR%20%2F%3EROM%20%E3%81%8C%20ISP%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E5%87%A6%E7%90%86%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EMSPLIM%E3%82%AF%E3%83%AA%E3%82%A2%3CBR%20%2F%3EResetTarget()%20%E7%B5%82%E4%BA%86%20-%20128%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EJ-Link%26gt%3Bh%3CBR%20%2F%3E%20PC%20%3D%201302B460%E3%80%81%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20%3D%2000000000%3CBR%20%2F%3E%20R0%20%3D%2000000000%E3%80%81R1%20%3D%205AC33CA5%E3%80%81R2%20%3D%2000000001%E3%80%81R3%20%3D%205AC33CA5%3CBR%20%2F%3E%20R4%20%3D%203012F5FC%E3%80%81R5%20%3D%2050002E24%E3%80%81R6%20%3D%2055AACC33%E3%80%81R7%20%3D%2033CCAA55%3CBR%20%2F%3E%20R8%20%3D%205AA55AA5%E3%80%81R9%20%3D%20FCF0030F%E3%80%81R10%20%3D%20C33CA55A%E3%80%81R11%20%3D%2055AACC33%3CBR%20%2F%3E%20R12%3D%203012F5FC%3CBR%20%2F%3E%20SP(R13)%3D%2030125A38%E3%80%81MSP%3D%2030125A38%E3%80%81PSP%3D%2000000000%E3%80%81R14(LR)%20%3D%201302B421%3CBR%20%2F%3E%20XPSR%20%3D%2001000000%3A%20APSR%20%3D%20nzcvq%E3%80%81EPSR%20%3D%2001000000%E3%80%81IPSR%20%3D%20000%20(%E4%BE%8B%E5%A4%96%E3%81%AA%E3%81%97)%3CBR%20%2F%3E%20CFBP%20%3D%2000000001%E3%80%81CONTROL%20%3D%2000%E3%80%81FAULTMASK%20%3D%2000%E3%80%81BASEPRI%20%3D%2000%E3%80%81PRIMASK%20%3D%2001%3CBR%20%2F%3E%20MSPLIM%20%3D%2000000000%3CBR%20%2F%3E%20PSPLIM%20%3D%2000000000%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E6%8B%A1%E5%BC%B5%E8%A6%8F%E5%89%87%3A%3CBR%20%2F%3E%20MSP_S%20%3D%2030125A38%E3%80%81MSP_NS%20%3D%2000000000%3CBR%20%2F%3E%20MSPLIM_S%20%3D%2000000000%E3%80%81MSPLIM_NS%20%3D%2000000000%3CBR%20%2F%3E%20PSP_S%20%3D%2000000000%E3%80%81PSP_NS%20%3D%20FFFFFFFC%3CBR%20%2F%3E%20PSPLIM_S%20%3D%2000000000%E3%80%81PSPLIM_NS%20%3D%2000000000%3CBR%20%2F%3E%20CONTROL_S%20%3D%2000%E3%80%81FAULTMASK_S%20%3D%2000%E3%80%81BASEPRI_S%20%3D%2000%E3%80%81PRIMASK_S%20%3D%2001%3CBR%20%2F%3E%20CONTROL_NS%20%3D%2000%E3%80%81FAULTMASK_NS%20%3D%2000%E3%80%81BASEPRI_NS%20%3D%2000%E3%80%81PRIMASK_NS%20%3D%2000%3C%2FP%3E%3CP%3EFPS0%20%3D%2000000000%E3%80%81FPS1%20%3D%2000000000%E3%80%81FPS2%20%3D%2000000000%E3%80%81FPS3%20%3D%2000000000%3CBR%20%2F%3E%20FPS4%20%3D%2000000000%E3%80%81FPS5%20%3D%2000000000%E3%80%81FPS6%20%3D%2000000000%E3%80%81FPS7%20%3D%2000000000%3CBR%20%2F%3E%20FPS8%20%3D%2000000000%E3%80%81FPS9%20%3D%2000000000%E3%80%81FPS10%20%3D%2000000000%E3%80%81FPS11%20%3D%2000000000%3CBR%20%2F%3E%20FPS12%3D%2000000000%E3%80%81FPS13%3D%2000000000%E3%80%81FPS14%3D%2000000000%E3%80%81FPS15%3D%2000000000%3CBR%20%2F%3E%20FPS16%3D%2000000000%E3%80%81FPS17%3D%2000000000%E3%80%81FPS18%3D%2000000000%E3%80%81FPS19%3D%2000000000%3CBR%20%2F%3E%20FPS20%3D%2000000000%E3%80%81FPS21%3D%2000000000%E3%80%81FPS22%3D%2000000000%E3%80%81FPS23%3D%2000000000%3CBR%20%2F%3E%20FPS24%3D%2000000000%E3%80%81FPS25%3D%2000000000%E3%80%81FPS26%3D%2000000000%E3%80%81FPS27%3D%2000000000%3CBR%20%2F%3E%20FPS28%3D%2000000000%E3%80%81FPS29%3D%2000000000%E3%80%81FPS30%3D%2000000000%E3%80%81FPS31%3D%2000000000%3CBR%20%2F%3E%20FPSCR%3D%2000000000%3CBR%20%2F%3E%20J-Link%26gt%3B%E3%83%AD%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.hex%3CBR%20%2F%3E'loadfile'%3A%20MCU%20%E3%81%AE%E6%9A%97%E9%BB%99%E7%9A%84%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E5%81%9C%E6%AD%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20ResetTarget()%20%E9%96%8B%E5%A7%8B%3CBR%20%2F%3ESYSRESETREQ%E3%81%A8%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%2B%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E5%BE%8C%E3%81%AE%E5%81%9C%E6%AD%A2%3CBR%20%2F%3EROM%20%E3%81%8C%20ISP%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E5%87%A6%E7%90%86%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EMSPLIM%E3%82%AF%E3%83%AA%E3%82%A2%3CBR%20%2F%3EResetTarget()%20%E7%B5%82%E4%BA%86%20-%20117%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%5B%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.hex%5D%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20J-Link%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%20%E3%83%90%E3%83%B3%E3%82%AF%201%20%40%200x18000000%3A%20%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%82%8B%E7%AF%84%E5%9B%B2%201%20(786432%20%E3%83%90%E3%82%A4%E3%83%88)%3CBR%20%2F%3E%20J-Link%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%20%E5%90%88%E8%A8%88%3A%2013.012%20%E7%A7%92%20(%E6%BA%96%E5%82%99%3A%200.333%20%E7%A7%92%E3%80%81%E6%AF%94%E8%BC%83%3A%202.685%20%E7%A7%92%E3%80%81%E6%B6%88%E5%8E%BB%3A%202.979%20%E7%A7%92%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3A%205.531%20%E7%A7%92%E3%80%81%E6%A4%9C%E8%A8%BC%3A%201.307%20%E7%A7%92%E3%80%81%E5%BE%A9%E5%85%83%3A%200.174%20%E7%A7%92)%3CBR%20%2F%3E%20J-Link%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E9%80%9F%E5%BA%A6%3A%20139%20KB%2F%E7%A7%92%3CBR%20%2F%3E%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EJ-Link%26gt%3Bqc%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%5B2025-11-24T09%3A34%3A03.519%5D%20%5B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%5D%20%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9ID%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%5B2025-11-24T09%3A34%3A04.494%5D%5B%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%5D%20%5B%E3%82%A8%E3%83%A9%E3%83%BC%5D%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20ID%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%5B2025-11-24T09%3A34%3A04.503%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkGDBServerCLExe%20-listprobes%20USB%5B2025-11-24T09%3A34%3A04.507%5D%20%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2FLinkServer_25.9.134%2FLinkServer%20probes%20--json%5B2025-11-24T09%3A34%3A04.948%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2Fmcuxpressoide-24.12.148%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%5B2025-11-24T09%3A34%3A04.953%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fusr%2Flocal%2Fmcuxpressoide%2Fide%2Ftools%2Fbin%2FArm-none-eabi-gcc%20--version%5B2025-11-24T09%3A34%3A04.959%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2F.mcuxpressotools%2Farm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%5B2025-11-24T09%3A34%3A04.963%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2F.mcuxpressotools%2Farm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-gcc%20--version%5B2025-11-24T09%3A34%3A04.972%5D%5Bproc%5D%20%5Binfo%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20cmake%20-DFORMAT%3Djson%20-P%20verify-toolchain.cmake%5B2025-11-24T09%3A34%3A06.130%5D%5Bproc%5D%20%5B%E6%83%85%E5%A0%B1%5D%20%7B%22ZEPHYR_TOOLCHAIN_VARIANT%22%20%3A%20%22Zephyr%22%2C%20%22SDK_VERSION%22%3A%20%220.17.4%22%2C%20%22ZEPHYR_SDK_INSTALL_DIR%22%20%3A%20%22%2F...%2Fzephyr-sdk-0.17.4%22%7D%5B2025-11-24T09%3A34%3A06.136%5D%5Bproc%5D%20%5B%E6%83%85%E5%A0%B1%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2F...%2FZephyr-sdk-0.17.4%2FArm-zephyr-eabi%2Fbin%2FArm-zephyr-eabi-objcopy%20-I%20elf32-littlearm%20-O%20ihex%20%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.elf%20zephyr.hex%5B2025-11-24T09%3A34%3A06.157%5D%20%5Bproc%5D%20%5B%E6%83%85%E5%A0%B1%5D%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3A%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%20-if%20SWD%20-speed%20%E8%BB%8A%E8%BC%89%20-commanderscript%20%2F...%2Fproject%2Fscript.jlink%20-device%20RW610%20-SelectEmuBySN%2053002466%5B2025-11-24T09%3A34%3A20.074%5D%5BSEGGER%5D%20%5Binfo%5D%20SEGGER%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%93%8D%E4%BD%9C%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3ASEGGER%20J-Link%20Commander%20V8.72%20(2025%E5%B9%B49%E6%9C%8824%E6%97%A5%2013%3A39%3A14%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB)DLL%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3V8.72%E3%80%812025%E5%B9%B49%E6%9C%8824%E6%97%A5%2013%3A38%3A10%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%ABJ-Link%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...J-Link%26gt%3BExitOnError%201J-Link%20Commander%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E6%99%82%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99J-Link%26gt%3BrJ-Link%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%BE%E3%81%A0%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82USB%E7%B5%8C%E7%94%B1%E3%81%A7J-Link%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...OK%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20J-Link%20V13%202025%E5%B9%B49%E6%9C%8817%E6%97%A5%2012%3A01%3A59%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%20V13.00J-Link%E7%A8%BC%E5%83%8D%E6%99%82%E9%96%93%20(%E8%B5%B7%E5%8B%95%E4%BB%A5%E9%99%8D)%3A%200d%2000h%2006m%2024sS%2FN%3A%2053002466%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%3A%20GDBUSB%E9%80%9F%E5%BA%A6%E3%83%A2%E3%83%BC%E3%83%89%3A%20%E9%AB%98%E9%80%9F%20(480%20MBit%2Fs)VTref%3D3.325VTarget%E6%8E%A5%E7%B6%9A%E3%81%AF%E3%81%BE%E3%81%A0%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8CRW610%E3%80%8D%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SWDInitTarget()%20startSWD%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82JTAG%20-%26gt%3B%20SWD%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82DAP%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82DMAP_REG_ID%3A%20DM-AP%20IDCODE%20%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%200x002A0000DHCSR%3A%200xFFFFFFFFROM%20%E3%81%8C%20ISP%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E5%87%A6%E7%90%86%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82InitTarget()%20%E7%B5%82%E4%BA%86%20-%2014.0%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ID%200x6BA02477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82IDR%3A%200x6BA02477CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%E3%80%82%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20AP%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82AP%5B1%5D%3A%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81AP%20%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82AP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001%E3%80%81ADDR%3A%200x00000000)%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20AHB-AP%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82AP%5B0%5D%3A%20%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82AP%5B0%5D%3A%20AHB-AP%20ROM%20%E3%83%99%E3%83%BC%E3%82%B9%3A%200xE00FF000CPUID%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%200x410FD214%E3%80%82%E5%AE%9F%E8%A3%85%E3%82%B3%E3%83%BC%E3%83%89%3A%200x41%20(ARM)%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%3A%20%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AA%E3%81%97Cortex-M33%20r0p4%E3%80%81%E3%83%AA%E3%83%88%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%80%82FPUnit%3A%208%20%E3%82%B3%E3%83%BC%E3%83%89%20(BP)%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%A8%200%20%E3%83%AA%E3%83%86%E3%83%A9%E3%83%AB%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E6%8B%A1%E5%BC%B5%3A%20%E5%AE%9F%E8%A3%85%E6%B8%88%E3%81%BF%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E6%9C%89%E5%8A%B9CoreSight%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%3AROMTbl%5B0%5D%20%40%20E00FF000%5B0%5D%5B0%5D%3A%20E000E000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047702A04%20DEVTYPE%2000%20Cortex-M33%5B0%5D%5B1%5D%3A%20E0001000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A02%20DEVTYPE%2000%20DWT%5B0%5D%5B2%5D%3A%20E0002000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A03%20DEVTYPE%2000%20FPB%5B0%5D%5B3%5D%3A%20E0000000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A01%20DEVTYPE%2043%20ITM%5B0%5D%5B5%5D%3A%20E0041000%20CID%20B105900D%20PID%20002BBD21%20DEVARCH%2047724A13%20DEVTYPE%2013%20ETM%5B0%5D%5B6%5D%3A%20E0042000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A14%20DEVTYPE%2014%20CSS600-CTIMemory%E3%82%BE%E3%83%BC%E3%83%B3%3A%E3%82%BE%E3%83%BC%E3%83%B3%3A%20%22Default%22%E8%AA%AC%E6%98%8E%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89Cortex-M33%E3%81%8C%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E9%81%85%E5%BB%B6%3A%200%20msResetTarget()%20startSYSRESETREQ%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%2B%E5%81%9C%E6%AD%A2%E5%BE%8C%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80ROM%E3%81%8CISP%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E5%87%A6%E7%90%86%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MSPLIM%20clearedResetTarget()%20%E7%B5%82%E4%BA%86%20-%20128%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82J-Link%26gt%3BhPC%20%3D%201302B460%E3%80%81CycleCnt%20%3D%2000000000R0%20%3D%2000000000%E3%80%81R1%20%3D%205AC33CA5%E3%80%81R2%20%3D%2000000001%E3%80%81R3%20%3D%205AC33CA5R4%20%3D%203012F5FC%E3%80%81R5%20%3D%2050002E24%E3%80%81R6%20%3D%2055AACC33%E3%80%81R7%20%3D%2033CCAA55R8%20%3D%205AA55AA5%E3%80%81R9%20%3D%20FCF0030F%E3%80%81R10%20%3D%20C33CA55A%E3%80%81R11%20%3D%2055AACC33R12%20%3D%203012F5FCSP(R13)%3D%2030125A38%E3%80%81MSP%20%3D%2030125A38%E3%80%81PSP%3D%2000000000%E3%80%81R14(LR)%20%3D%201302B421XPSR%20%3D%2001000000%3A%20APSR%20%3D%20nzcvq%E3%80%81EPSR%20%3D%2001000000%E3%80%81IPSR%20%3D%20000%20(%E4%BE%8B%E5%A4%96%E3%81%AA%E3%81%97)CFBP%20%3D%2000000001%E3%80%81CONTROL%20%3D%2000%E3%80%81FAULTMASK%20%3D%2000%E3%80%81BASEPRI%20%3D%2000%E3%80%81PRIMASK%20%3D%2001MSPLIM%20%3D%2000000000PSPLIM%20%3D%2000000000%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E6%8B%A1%E5%BC%B5%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3AMSP_S%20%3D%2030125A38%E3%80%81MSP_NS%20%3D%2000000000MSPLIM_S%20%3D%2000000000%E3%80%81MSPLIM_NS%20%3D%2000000000PSP_S%20%3D%2000000000%E3%80%81PSP_NS%20%3D%20FFFFFFFCPSPLIM_S%20%3D%2000000000%E3%80%81PSPLIM_NS%20%3D%2000000000CONTROL_S%20%3D%2000%E3%80%81FAULTMASK_S%20%3D%2000%E3%80%81BASEPRI_S%20%3D%2000%E3%80%81PRIMASK_S%20%3D%2001CONTROL_NS%20%3D%2000%E3%80%81FAULTMASK_NS%20%3D%2000%E3%80%81BASEPRI_NS%20%3D%2000%E3%80%81PRIMASK_NS%20%3D%2000FPS0%20%3D%2000000000%E3%80%81FPS1%20%3D%2000000000%E3%80%81FPS2%20%3D%2000000000%E3%80%81FPS3%20%3D%2000000000FPS4%20%3D%2000000000%E3%80%81FPS5%20%3D%2000000000%E3%80%81FPS6%20%3D%2000000000%E3%80%81FPS7%20%3D%2000000000FPS8%20%3D%2000000000%E3%80%81%20FPS9%20%3D%2000000000%E3%80%81FPS10%3D%2000000000%E3%80%81FPS11%3D%2000000000FPS12%3D%2000000000%E3%80%81FPS13%3D%2000000000%E3%80%81FPS14%3D%2000000000%E3%80%81FPS15%3D%2000000000FPS16%3D%2000000000%E3%80%81FPS17%3D%2000000000%E3%80%81FPS18%3D%2000000000%E3%80%81FPS19%3D%2000000000FPS20%3D%2000000000%E3%80%81FPS21%3D%2000000000%E3%80%81FPS22%3D%2000000000%E3%80%81FPS23%3D%2000000000FPS24%3D%2000000000%E3%80%81FPS25%3D%2000000000%E3%80%81FPS26%3D%2000000000%E3%80%81FPS27%3D%2000000000FPS28%3D%2000000000%E3%80%81FPS29%3D%2000000000%E3%80%81FPS30%3D%2000000000%E3%80%81FPS31%3D%2000000000FPSCR%3D%2000000000J-Link%26gt%3Bloadfile%20%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.hex'loadfile'%3ASYSRESETREQ%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%20MCU.ResetTarget()%20startReset%20%E3%81%AE%E6%9A%97%E9%BB%99%E7%9A%84%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E5%81%9C%E6%AD%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%20ROM%20%E3%81%8C%20ISP%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E5%87%A6%E7%90%86%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%9F%E5%BE%8C%E3%81%AB%E3%83%94%E3%83%B3%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E5%86%8D%E5%BA%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MSPLIM%20%E3%81%8C%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9FResetTarget()%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20117%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%5B%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.hex%5D%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...J-Link%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%20%E3%83%90%E3%83%B3%E3%82%AF%201%20%40%200x18000000%3A%201%20%E7%AF%84%E5%9B%B2%E3%81%8C%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%20(786432%20%E3%83%90%E3%82%A4%E3%83%88)J-Link%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%20%E5%90%88%E8%A8%88%3A%2013.012%20%E7%A7%92%20(%E6%BA%96%E5%82%99%3A%200.333%20%E7%A7%92%E3%80%81%E6%AF%94%E8%BC%83%3A%202.685%20%E7%A7%92%E3%80%81%E6%B6%88%E5%8E%BB%3A%202.979%20%E7%A7%92%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3A%205.531%20%E7%A7%92%E3%80%81%E6%A4%9C%E8%A8%BC%3A%201.307%20%E7%A7%92%E3%80%81%E5%BE%A9%E5%85%83%3A%200.174%20%E7%A7%92)J-Link%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E9%80%9F%E5%BA%A6%3A%20139%20KB%2F%E7%A7%92O.KJ-Link%26gt%3Bqc%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3EFreeRTOS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%20KConfig%20%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E4%BD%95%E3%81%8B%E6%B3%A8%E7%9B%AE%E3%81%99%E3%81%B9%E3%81%8D%E7%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%20Linux%20%E4%B8%8A%E3%81%A7%20MCUXpresso%20VSCode%20%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81Zephyr%204.3.0%20%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2247462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E8%A3%BD%E5%93%81%3A%20WiFi%20RW6XX%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW610%20JLink%20DAP%20Failing%20on%20Zephyr%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EJ-Link%20Commander%20CLI%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%82%A2%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%EF%BC%88VS%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%BE%8B%E3%82%92%E4%BD%BF%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW610%20JLink%20DAP%20Failing%20on%20Zephyr%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E%E7%B5%90%E5%B1%80%E3%80%81%E7%A7%81%E3%81%AF%20PCB%20%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E5%8D%81%E5%88%86%E6%B3%A8%E6%84%8F%E3%82%92%E6%89%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E5%88%A4%E6%98%8E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Flexcomm2%20%E3%81%A8%20SWD%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AB%E5%90%8C%E3%81%98%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%20Flexcomm2%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E8%AA%A4%E3%81%A3%E3%81%A6%20flexcomm2%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%3CSTRONG%3Estatus%20%3D%20%22okay%22%3C%2FSTRONG%3E%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSTRONG%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E3%80%8C%E7%84%A1%E5%8A%B9%E3%80%8D%E3%81%AB%3C%2FSTRONG%3E%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%20ISP%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
