RW610 JLink DAP Failing on Zephyr
686 次查看
jm-streametric
I am working on a custom PCB with an RW610 MCU and running Zephyr RTOS.  Before using Zephyr, I worked with FreeRTOS and the NXP HAL directly.
On that old firmware, I was able to use an external JLink debugger to reset/program the board even while running.  After switching to Zephyr, I can no longer flash while the board is running.  I get the message DAP failed to initialize.
On the custom board I do have a BOOT button which can force the board into ISP boot when powered off/on.  Using this, I can flash my Zephyr code.  However, I lose the ability to debug the code with GDB because when the board is flashed in ISP mode I can't reset it through the JLink.
Failed flash while running:
破坏者
[2025-11-24T09:36:31.893] [Secure Provisioning] [error] No device id found.
[2025-11-24T09:36:32.392] [Secure Provisioning] [error] No device id found.
[2025-11-24T09:36:32.402] [proc] [info] Cmd: /opt/SEGGER/JLink_V872/JLinkGDBServerCLExe -listprobes USB
[2025-11-24T09:36:32.407] [proc] [info] Cmd: /usr/local/LinkServer_25.9.134/LinkServer probes --json
[2025-11-24T09:36:32.845] [proc] [info] Cmd: /usr/local/mcuxpressoide-24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-11-24T09:36:32.850] [proc] [info] Cmd: /.../.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-11-24T09:36:32.856] [proc] [info] Cmd: /usr/local/mcuxpressoide/ide/tools/bin/arm-none-eabi-gcc --version
[2025-11-24T09:36:32.859] [proc] [info] Cmd: /.../.mcuxpressotools/arm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-11-24T09:36:32.866] [proc] [info] Cmd: cmake -DFORMAT=json -P verify-toolchain.cmake
[2025-11-24T09:36:33.815] [proc] [info] {"ZEPHYR_TOOLCHAIN_VARIANT" : "zephyr", "SDK_VERSION": "0.17.4", "ZEPHYR_SDK_INSTALL_DIR" : "/.../zephyr-sdk-0.17.4"}
[2025-11-24T09:36:33.821] [proc] [info] Cmd: /.../zephyr-sdk-0.17.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-objcopy -I elf32-littlearm -O ihex /.../project/debug/zephyr/zephyr.elf zephyr.hex
[2025-11-24T09:36:33.842] [proc] [info] Cmd: /opt/SEGGER/JLink_V872/JLinkExe -if SWD -speed auto -commanderscript /.../project/script.jlink -device RW610 -SelectEmuBySN 53002466
[2025-11-24T09:36:34.285] [proc] [error] /opt/SEGGER/JLink_V872/JLinkExe exited with code 1
[2025-11-24T09:36:34.285] [proc] [error] SEGGER J-Link Commander V8.72 (Compiled Sep 24 2025 13:39:14)
DLL version V8.72, compiled Sep 24 2025 13:38:10
J-Link Command File read successfully.
Processing script file...
J-Link>ExitOnError 1
J-Link Commander will now exit on Error
J-Link>r
J-Link connection not established yet but required for command.
Connecting to J-Link via USB...O.K.
Firmware: J-Link V13 compiled Sep 17 2025 12:01:59
Hardware version: V13.00
J-Link uptime (since boot): 0d 00h 08m 51s
S/N: 53002466
License(s): GDB
USB speed mode: High speed (480 MBit/s)
VTref=3.322V
Target connection not established yet but required for command.
Device "RW610" selected.
Connecting to target via SWD
InitTarget() start
SWD selected. Executing JTAG -> SWD switching sequence.
Error: Failed to initialize DAP.
InitTarget() end - Took 133ms
Connect failed. Resetting via Reset pin and trying again.
InitTarget() start
Error occurred: Could not connect to the target device.
For troubleshooting steps visit: https://kb.segger.com/J-Link_Troubleshooting
Script processing completed.
Successful flash when I use ISP boot:
破坏者
[2025-11-24T09:34:03.519] [Secure Provisioning] [error] No device id found.
[2025-11-24T09:34:04.494] [Secure Provisioning] [error] No device id found.
[2025-11-24T09:34:04.503] [proc] [info] Cmd: /opt/SEGGER/JLink_V872/JLinkGDBServerCLExe -listprobes USB
[2025-11-24T09:34:04.507] [proc] [info] Cmd: /usr/local/LinkServer_25.9.134/LinkServer probes --json
[2025-11-24T09:34:04.948] [proc] [info] Cmd: /usr/local/mcuxpressoide-24.12.148/ide/tools/bin/arm-none-eabi-gcc --version
[2025-11-24T09:34:04.953] [proc] [info] Cmd: /usr/local/mcuxpressoide/ide/tools/bin/arm-none-eabi-gcc --version
[2025-11-24T09:34:04.959] [proc] [info] Cmd: /.../.mcuxpressotools/arm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-11-24T09:34:04.963] [proc] [info] Cmd: /.../.mcuxpressotools/arm-gnu-toolchain-13.2.Rel1-x86_64-arm-none-eabi/bin/arm-none-eabi-gcc --version
[2025-11-24T09:34:04.972] [proc] [info] Cmd: cmake -DFORMAT=json -P verify-toolchain.cmake
[2025-11-24T09:34:06.130] [proc] [info] {"ZEPHYR_TOOLCHAIN_VARIANT" : "zephyr", "SDK_VERSION": "0.17.4", "ZEPHYR_SDK_INSTALL_DIR" : "/.../zephyr-sdk-0.17.4"}
[2025-11-24T09:34:06.136] [proc] [info] Cmd: /.../zephyr-sdk-0.17.4/arm-zephyr-eabi/bin/arm-zephyr-eabi-objcopy -I elf32-littlearm -O ihex /.../project/debug/zephyr/zephyr.elf zephyr.hex
[2025-11-24T09:34:06.157] [proc] [info] Cmd: /opt/SEGGER/JLink_V872/JLinkExe -if SWD -speed auto -commanderscript /.../project/script.jlink -device RW610 -SelectEmuBySN 53002466
[2025-11-24T09:34:20.074] [SEGGER] [info] SEGGER flash operation completed successfully:
J-Link>r
J-Link uptime (since boot): 0d 00h 06m 24s
S/N: 53002466
License(s): GDB
VTref=3.325V
InitTarget() start
DAP initialized successfully.
DMAP_REG_ID: DM-AP IDCODE detected: 0x002A0000
DHCSR: 0xFFFFFFFF
ROM entered ISP command handling loop. Re-enable the debug access.
InitTarget() end - Took 14.0ms
Found SW-DP with ID 0x6BA02477
DPIDR: 0x6BA02477
CoreSight SoC-400 or earlier
Scanning AP map to find all available APs
AP[1]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x84770001, ADDR: 0x00000000)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FD214. Implementer code: 0x41 (ARM)
Feature set: Mainline
Cache: No cache
Found Cortex-M33 r0p4, Little endian.
FPUnit: 8 code (BP) slots and 0 literal slots
Security extension: implemented
Secure debug: enabled
CoreSight components:
ROMTbl[0] @ E00FF000
[0][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
[0][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
[0][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
[0][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
[0][5]: E0041000 CID B105900D PID 002BBD21 DEVARCH 47724A13 DEVTYPE 13 ETM
[0][6]: E0042000 CID B105900D PID 000BBD21 DEVARCH 47701A14 DEVTYPE 14 CSS600-CTI
Memory zones:
Zone: "Default" Description: Default access mode
Cortex-M33 identified.
Reset delay: 0 ms
ResetTarget() start
Reset via SYSRESETREQ and reset pin + halt after bootloader
MSPLIM cleared
ResetTarget() end - Took 128ms
Device specific reset executed.
J-Link>h
PC = 1302B460, CycleCnt = 00000000
R0 = 00000000, R1 = 5AC33CA5, R2 = 00000001, R3 = 5AC33CA5
R4 = 3012F5FC, R5 = 50002E24, R6 = 55AACC33, R7 = 33CCAA55
R8 = 5AA55AA5, R9 = FCF0030F, R10= C33CA55A, R11= 55AACC33
R12= 3012F5FC
SP(R13)= 30125A38, MSP= 30125A38, PSP= 00000000, R14(LR) = 1302B421
XPSR = 01000000: APSR = nzcvq, EPSR = 01000000, IPSR = 000 (NoException)
CFBP = 00000001, CONTROL = 00, FAULTMASK = 00, BASEPRI = 00, PRIMASK = 01
MSPLIM = 00000000
PSPLIM = 00000000
Security extension regs:
MSP_S = 30125A38, MSP_NS = 00000000
MSPLIM_S = 00000000, MSPLIM_NS = 00000000
PSP_S = 00000000, PSP_NS = FFFFFFFC
PSPLIM_S = 00000000, PSPLIM_NS = 00000000
CONTROL_S = 00, FAULTMASK_S = 00, BASEPRI_S = 00, PRIMASK_S = 01
CONTROL_NS = 00, FAULTMASK_NS = 00, BASEPRI_NS = 00, PRIMASK_NS = 00
FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000
FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000
FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000
FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000
FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000
FPSCR= 00000000
J-Link>loadfile /.../project/debug/zephyr/zephyr.hex
'loadfile': Performing implicit reset & halt of MCU.
ResetTarget() start
MSPLIM cleared
ResetTarget() end - Took 117ms
Downloading file [/.../project/debug/zephyr/zephyr.hex]...
J-Link: Flash download: Bank 1 @ 0x18000000: 1 range affected (786432 bytes)
J-Link: Flash download: Total: 13.012s (Prepare: 0.333s, Compare: 2.685s, Erase: 2.979s, Program: 5.531s, Verify: 1.307s, Restore: 0.174s)
J-Link: Flash download: Program speed: 139 KB/s
O.K.
J-Link>qc
Since the flashing worked when using FreeRTOS I suspect I have something in the devicetree or KConfig configured incorrectly.  Is there anything I should look for there?
I am using the MCUXpresso VSCode extension on Linux, flashing Zephyr 4.3.0.
Thank you!
标记 (4)
557 次查看
jm-streametric
Hello Daniel,
Turns out I was not attentive enough to my PCB's datasheet.  We are using the same pins for both Flexcomm2 and SWD.  I'm not using Flexcomm2 for this code but I accidentally set the status = "okay" flag for the flexcomm2 devicetree node.  Once I set status = "disabled" I was able to program my board without needing to set it into ISP mode.
640 次查看
DanielRuvalcaba
Are you able to use the J-Link Commander CLI to communicate with the core? (not in VS code)
What example did you use?
Daniel.
558 次查看
jm-streametric
Hello Daniel,
%3CLINGO-SUB%20id%3D%22lingo-sub-2247462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW610%20JLink%20DAP%20%E5%9C%A8%20Zephyr%20%E4%B8%8A%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20RW610%20MCU%20%E5%AE%9A%E5%88%B6%20PCB%EF%BC%8C%E5%B9%B6%E8%BF%90%E8%A1%8C%20Zephyr%20%E5%AE%9E%E6%97%B6%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E3%80%82%20%E5%9C%A8%E4%BD%BF%E7%94%A8%20Zephyr%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%20FreeRTOS%20%E5%92%8C%20NXP%20HAL%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E9%82%A3%E4%B8%AA%E6%97%A7%E5%9B%BA%E4%BB%B6%E4%B8%8A%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E6%88%91%E4%B9%9F%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%20jLink%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%AF%B9%E6%9D%BF%E8%BF%9B%E8%A1%8C%20RESET%2F%E7%BC%96%E7%A8%8B%E3%80%82%E5%88%87%E6%8D%A2%E5%88%B0%20Zephyr%20%E5%90%8E%EF%BC%8C%E6%9D%BF%E8%BF%90%E8%A1%8C%E6%97%B6%E6%88%91%E6%97%A0%E6%B3%95%E5%86%8D%E9%97%AA%E5%85%89%E4%BA%86%E3%80%82%E6%88%91%E6%94%B6%E5%88%B0%20DAP%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E4%B8%8A%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%90%AF%E5%8A%A8%E6%8C%89%E9%92%AE%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%85%B3%E6%9C%BA%2F%E5%BC%80%E6%9C%BA%E6%97%B6%E5%BC%BA%E5%88%B6%E6%9D%BF%E8%BF%9B%E5%85%A5%20ISP%20%E5%90%AF%E5%8A%A8%E3%80%82%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E9%97%AA%E7%83%81%E6%88%91%E7%9A%84%20Zephyr%20%E4%BB%A3%E7%A0%81%E3%80%82%20%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E5%A4%B1%E5%8E%BB%E4%BA%86%E4%BD%BF%E7%94%A8GDB%E8%B0%83%E8%AF%95%E4%BB%A3%E7%A0%81%E7%9A%84%E8%83%BD%E5%8A%9B%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%BD%93%E6%9D%BF%E5%9C%A8ISP%E6%A8%A1%E5%BC%8F%E4%B8%8B%E9%97%AA%E5%AD%98%E6%97%B6%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87JLink%E5%B0%86%E5%85%B6RESET%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CU%3E%E8%BF%90%E8%A1%8C%E6%97%B6%E9%97%AA%E5%85%89%E7%81%AF%E6%95%85%E9%9A%9C%EF%BC%9A%3C%2FU%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-11-24T%2009%3A36%3A31.893%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5B%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5B%E9%94%99%E8%AF%AF%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E6%9C%AA%E6%89%BE%E5%88%B0%20%E8%AE%BE%E5%A4%87%20ID%20%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-11-24T%2009%3A36%3A32.392%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5B%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5B%E9%94%99%E8%AF%AF%5D%3C%2FSPAN%3E%3CSPAN%3E%20%E6%9C%AA%E6%89%BE%E5%88%B0%20%E8%AE%BE%E5%A4%87%20ID%20%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A32.402%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkGDBServerCLExe%20-listprobes%20USB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A32.407%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3ECmd%EF%BC%9A%2Fusr%2Flocal%2FLinkServer_25.%3C%2FSPAN%3E%3CSPAN%3E9%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E134%3C%2FSPAN%3E%3CSPAN%3E%2FLinkServer%20probes%20--json%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-11-24T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A36%3A32.845%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%EF%BC%9A%2Fusr%2Flocal%2Fmcuxpressoide-24%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E12%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20148%3C%2FSPAN%3E%3CSPAN%3E%20%2Fide%2Ftools%2Fbin%2Farm%20-none-eab%20i-gcc--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-11-24T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A36%3A32.850%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2F..%2F.%2F.mcuxpressotools%2Farm-GNU-Toolchain-13.2.rel1-x8%3C%2FSPAN%3E%3CSPAN%3E%206_64-arm-none-eabi-g%3C%2FSPAN%3E%3CSPAN%3E%20cc--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-11-24T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A36%3A32.856%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2Fusr%2Flocal%2Fmcuxpressoide%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A32.859%3C%2FSPAN%3E%3CSPAN%3E%5D%20%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2F...%2F.mcuxpressotools%2FArm-%3C%2FSPAN%3E%3CSPAN%3Egnu-toolchain-14.2.rel1-x86_64-Arm-none%3C%2FSPAN%3E%3CSPAN%3E-eabi%2Fbin%2FArm-none-eabi-gcc%20--version%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A32.866%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5Binfo%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3E%E5%91%BD%E4%BB%A4%EF%BC%9A%20cmake%20-DFORMAT%3Djson%20-P%20%3C%2FSPAN%3E%3CSPAN%3Everify-toolchain.cmake%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A33.815%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%5D%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E4%BF%A1%E6%81%AF%EF%BC%BD%3C%2FSPAN%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3CSPAN%3E%22zephyr_toolchain_variant%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%E6%B3%BD%E6%B3%95%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%22SDK_VERSION%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%220.17.4%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%22zephyr_sdk_install_dir%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%2F...%2Fzephyr-sdk-0.17.4%22%3C%2FSPAN%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-11-24T%2009%3A36%3A33.8%3C%2FSPAN%3E%3CSPAN%3E%2021%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5B%E4%BF%A1%E6%81%AF%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2F...%20%2Fzephyr-sdk-0.17%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E4%3C%2FSPAN%3E%3CSPAN%3E%20%2Farm-zephyr-eabi%2Fbin%2Farm-zephyr-eabi-objcopy-I%20elf32-littlearm-O%20ihex%20%2F...%20%2Fproject%2Fdebug%2Fzephyr.elf%3C%2FSPAN%3E%3CSPAN%3E%20zephyr.hex%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E%202025-11-24T%3C%2FSPAN%3E%3CSPAN%3E%2009%3A36%3A33.842%5D%20%5Bproc%5D%3C%2FSPAN%3E%3CSPAN%3E%20%5Binfo%5D%3C%2FSPAN%3E%3CSPAN%3E%20Cmd%3A%20%2Fopt%2Fsegger%2Fjlink_v87%202%2Fjlinkexe-if%20SWD-sepeed%20auto-commanderscript%20%2F...%20%2Fproject%2Fscript.jlink-device%20RW610-selecteMubysn%3C%2FSPAN%3E%3CSPAN%3E%2053002466%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A34.285%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%EF%BC%BD%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E9%94%99%E8%AF%AF%5D%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%3C%2FSPAN%3E%3CSPAN%3E%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%20%E5%B7%B2%E9%80%80%E5%87%BA%EF%BC%8C%E4%BB%A3%E7%A0%81%E4%B8%BA%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%5B%3C%2FSPAN%3E%3CSPAN%3E2025-11-24T09%3A36%3A34.285%3C%2FSPAN%3E%3CSPAN%3E%5D%5Bproc%EF%BC%BD%20%3C%2FSPAN%3E%3CSPAN%3E%5B%E9%94%99%E8%AF%AF%5D%3C%2FSPAN%3E%3CSPAN%3E%E8%B5%9B%E6%A0%BC%20J-Link%20Commander%20%3C%2FSPAN%3E%3CSPAN%3EV8.72%3C%2FSPAN%3E%3CSPAN%3E(9%E6%9C%88%E7%BC%96%E8%AF%91%20%3C%2FSPAN%3E%3CSPAN%3E24%3C%2FSPAN%3E%20%3CSPAN%3E2025%3C%2FSPAN%3E%20%3CSPAN%3E13%3A39%3A14%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EDLL%20%E7%89%88%E6%9C%AC%20%3C%2FSPAN%3E%3CSPAN%3EV8.72%3C%2FSPAN%3E%3CSPAN%3E%E7%BC%96%E8%AF%91%E6%97%A5%E6%9C%9F%20%3C%2FSPAN%3E%3CSPAN%3E24%3C%2FSPAN%3E%20%3CSPAN%3E2025%3C%2FSPAN%3E%20%3CSPAN%3E13%3A38%3A10%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E6%88%90%E5%8A%9F%E8%AF%BB%E5%8F%96%20J-Link%20%E5%91%BD%E4%BB%A4%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%A4%84%E7%90%86%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6...%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%26gt%3BExitOnError%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%20Commander%20%E7%8E%B0%E5%9C%A8%E4%BC%9A%E5%9C%A8%20%3C%2FSPAN%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%26gt%3Br%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%20%E8%BF%9E%E6%8E%A5%E5%B0%9A%E6%9C%AA%E5%BB%BA%E7%AB%8B%EF%BC%8C%E4%BD%86%E5%91%BD%E4%BB%A4%E9%9C%80%E8%A6%81%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20J-Link...%3C%2FSPAN%3E%3CSPAN%3E%E5%A5%BD%E7%9A%84%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9B%BA%E4%BB%B6%EF%BC%9A%E5%B7%B2%E7%BC%96%E8%AF%91%20J-Link%20V13%209%20%E6%9C%88%20%3C%2FSPAN%3E%3CSPAN%3E17%3C%2FSPAN%3E%20%3CSPAN%3E2025%3C%2FSPAN%3E%20%3CSPAN%3E12%3A01%3A59%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3EV13.00%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EJ-Link%20%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E6%97%B6%E9%97%B4%EF%BC%88%E8%87%AA%E5%90%AF%E5%8A%A8%E4%BB%A5%E6%9D%A5%EF%BC%89%EF%BC%9A0d%2000h%2008m%2051s%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ES%2FN%EF%BC%9A%20%3C%2FSPAN%3E%3CSPAN%3E53002466%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%8E%88%E6%9D%83%E8%AE%B8%E5%8F%AF%EF%BC%9A%E8%AE%B8%E5%8F%AF%E8%AF%81%EF%BC%9A%20GDB%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EUSB%20%E9%80%9F%E5%BA%A6%E6%A8%A1%E5%BC%8F%EF%BC%9A%E9%AB%98%E9%80%9F%20(%3C%2FSPAN%3E%3CSPAN%3E480%3C%2FSPAN%3E%3CSPAN%3EMBit%2Fs)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EVTref%3D%3C%2FSPAN%3E%3CSPAN%3E3%3C%2FSPAN%3E%3CSPAN%3E.322V%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%9B%AE%E6%A0%87%E8%BF%9E%E6%8E%A5%E5%B0%9A%E6%9C%AA%E5%BB%BA%E7%AB%8B%EF%BC%8C%E4%BD%86%E5%91%BD%E4%BB%A4%E9%9C%80%E8%A6%81%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%20%3CSPAN%3E%22%20RW610%20%22%3C%2FSPAN%3E%20%3CSPAN%3E%E5%B7%B2%E9%80%89%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E9%80%9A%E8%BF%87%20SWD%20%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EInitTarget()%20%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%80%89%E6%8B%A9%E4%BA%86%E7%A4%BE%E7%BD%B2%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%3CSPAN%3E%3ADAP%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EInitTarget()%20%E7%BB%93%E6%9D%9F%20-%20%E8%80%97%E6%97%B6%20133ms%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%E3%80%82%E9%80%9A%E8%BF%87%20RESET%20%E5%AF%86%E7%A0%81%20RESET%20%E5%B9%B6%E9%87%8D%E8%AF%95%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EInitTarget()%20%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%80%89%E6%8B%A9%E4%BA%86%E7%A4%BE%E7%BD%B2%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E9%94%99%E8%AF%AF%3C%2FSPAN%3E%3CSPAN%3E%3ADAP%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EInitTarget()%20%E7%BB%93%E6%9D%9F%20-%20%E8%80%97%E6%97%B6%20133ms%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%87%BA%E7%8E%B0%40%40%3C%2FSPAN%3E%3CSPAN%3E%20%E9%94%99%E8%AF%AF%20%EF%BC%9A%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%89%E5%85%B3%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E6%AD%A5%E9%AA%A4%EF%BC%8C%E8%AF%B7%E8%AE%BF%E9%97%AE%20%3C%2FSPAN%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fkb.segger.com%2FJ-Link_Troubleshooting%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fkb.segger.com%2FJ-Link_Troubleshooting%3C%2FA%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%E8%84%9A%E6%9C%AC%E5%A4%84%E7%90%86%E5%B7%B2%E5%AE%8C%E6%88%90%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%5B2025-11-24T%2009%3A36%3A31.893%5D%20%5B%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%5D%20%5B%E9%94%99%E8%AF%AF%5D%20%E6%9C%AA%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%20ID%E3%80%82%5B2025-11-24T%2009%3A36%3A32.392%5D%5B%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%5D%20%5B%E9%94%99%E8%AF%AF%5D%20%E6%9C%AA%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%20ID%E3%80%82%5B2025-11-24T%2009%3A36%3A32.402%5D%5Bproc%5D%20%5Binfo%5D%20Cmd%EF%BC%9A%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkGDBServerCLExe%20-listprobes%20USB%5B2025-11-24T09%3A36%3A32.407%5D%20%5Bproc%5D%20%5Binfo%5D%20Cmd%EF%BC%9A%2Fusr%2Flocal%2FLinkServer_25.9.134%2FLinkServer%20probes%20--json%5B2025-11-24T09%3A36%3A32.845%5D%5Bproc%5D%20%5Binfo%5D%20Cmd%EF%BC%9A%2Fusr%2Flocal%2Fmcuxpressoide-24.12.148%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%5B2025-11-24T09%3A36%3A32.850%5D%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2F...%2F.mcuxpressoTools%2Farm-GNU-Toolchain-13.2.rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-GCC--%E7%89%88%E6%9C%AC%20%5B2025-11-24T%2009%3A36%3A32.856%5D%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2Fusr%2Flocal%2Fmcuxpressoide%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc--version%20%5B2025-11-24T%2009%3A36%3A32.859%5D%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20cmd%3A%20%2F...%2F.mcuxpressotools%2Farm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-gcc--%E7%89%88%E6%9C%AC%20%5B2025-11-24T%2009%3A36%3A32.866%5D%5Bproc%5D%20%5Binfo%5D%20%E6%8C%87%E4%BB%A4%EF%BC%9Acmake%20-DFORMAT%3Djson%20-P%20verify-toolchain.cmake%5B2025-11-24T09%3A36%3A33.815%5D%5Bproc%5D%20%5Binfo%5D%20%7B%22ZEPHYR_TOOLCHAIN_VARIANT%22%3A%22zephyr%22%2C%22SDK_VERSION%22%3A%220.17.4%22%2C%22ZEPHYR_SDK_INSTALL_DIR%22%3A%22%2F...%2Fzephyr-sdk-0.17.4%22%7D%5B2025-11-24T09%3A36%3A33.821%5D%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2F...%2Fzephyr-sdk-0.17.4%2Farm-zephyr-eabi%2Fbin%2Farm-zephyr-eabi-objcopy-I%20elf32-littlearm-O%20ihex%20%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.elf%20zephyr.hex%20%5B2025-11-24T%2009%3A36%3A33.842%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2Fopt%2Fsegger%2Fjlink_v872%2Fjlinkexe-if%20swd-speed%20auto-commanderscript%20%2F...%2Fproject%2Fscript.jlink-%E8%AE%BE%E5%A4%87%20RW610-selectemubysn%2053002466%20%5B2025-11-24T%2009%3A36%3A34.285%5D%5Bproc%5D%20%5Berror%5D%20%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkExe%20%E4%BB%A5%E4%BB%A3%E7%A0%81%201%20%E9%80%80%E5%87%BA%5B2025-11-24T09%3A36%3A34.285%5D%5Bproc%5D%20%5B%E9%94%99%E8%AF%AF%5D%20SEGGER%20J-Link%20Commander%20V8.72%EF%BC%882025%20%E5%B9%B4%209%20%E6%9C%88%2024%20%E6%97%A5%E7%BC%96%E8%AF%91%2013%3A39%3A14%EF%BC%89DLL%20%E7%89%88%E6%9C%AC%20V8.72%EF%BC%8C2025%20%E5%B9%B4%209%20%E6%9C%88%2024%20%E6%97%A5%E7%BC%96%E8%AF%91%2013%3A38%3A10%20J-Link%20%E5%91%BD%E4%BB%A4%E6%96%87%E4%BB%B6%E8%AF%BB%E5%8F%96%E6%88%90%E5%8A%9F%E3%80%82%E5%A4%84%E7%90%86%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6...%20J-Link%20%26gt%3B%20exitonError%201J-Link%20%E7%8E%B0%E5%9C%A8%E5%B0%86%E5%9B%A0%E9%94%99%E8%AF%AF%E9%80%80%E5%87%BA%20%26gt%3B%20RJ-Link%20%E8%BF%9E%E6%8E%A5%E5%B0%9A%E6%9C%AA%E5%BB%BA%E7%AB%8B%E4%BD%86%E5%91%BD%E4%BB%A4%E9%9C%80%E8%A6%81%E8%BF%9E%E6%8E%A5%E3%80%82%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20J-Link...%20O.K.%E5%9B%BA%E4%BB%B6%EF%BC%9AJ-Link%20V13%20%E4%BA%8E%202025%20%E5%B9%B4%209%20%E6%9C%88%2017%20%E6%97%A5%E7%BC%96%E8%AF%91%2012%3A01%3A59%20%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9AV13.00J-Link%20%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E6%97%B6%E9%97%B4%EF%BC%88%E8%87%AA%E5%90%AF%E5%8A%A8%E4%BB%A5%E6%9D%A5%EF%BC%89%EF%BC%9A0d%2000h%2008m%2051SS%2FN%EF%BC%9A53002466%E8%AE%B8%E5%8F%AF%E8%AF%81%EF%BC%9AGDBUSB%20%E9%80%9F%E5%BA%A6%E6%A8%A1%E5%BC%8F%EF%BC%9A%E9%AB%98%E9%80%9F%20(480%20Mbit%2Fs)%20vtref%3D3.322vTarget%E5%B0%9A%E6%9C%AA%E5%BB%BA%E7%AB%8B%E8%BF%9E%E6%8E%A5%E4%BD%86%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20Command.%E8%AE%BE%E5%A4%87%20%22%20RW610%20%22%20%E5%B7%B2%E9%80%89%E6%8B%A9%E3%80%82%E9%80%9A%E8%BF%87%20swdinitTarget%20()%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E5%B7%B2%E9%80%89%E6%8B%A9%20startSWD%E3%80%82Executing%20JTAG%20-%26gt%3B%20SWD%20switching%20sequence.Error%EF%BC%9AFailed%20to%20initialize%20DAP.InitTarget()%20end%20-%20Took%20133msConnect%20failed.%E9%80%9A%E8%BF%87%20RESET%20%E5%AF%86%E7%A0%81%E8%BF%9B%E8%A1%8C%20RESET%20%E5%B9%B6%E9%87%8D%E8%AF%95%E3%80%82%E5%B7%B2%E9%80%89%E6%8B%A9%20initTarget%20()%20startsWD%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%88%9D%E5%A7%8B%E5%8C%96%20dap.initTarget%20()%20%E7%AB%AF%E2%80%94%E2%80%94Took%20133msError%20%E5%87%BA%E7%8E%B0%EF%BC%9A%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E8%AE%BE%E5%A4%87%E3%80%82%E6%9C%89%E5%85%B3%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E6%AD%A5%E9%AA%A4%EF%BC%8C%E8%AF%B7%E8%AE%BF%E9%97%AE%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fkb.segger.com%2FJ-Link_TroubleshootingScript%E5%A4%84%E7%90%86%E5%AE%8C%E6%AF%95%E3%80%82%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fkb.segger.com%2FJ-Link_TroubleshootingScript%E5%A4%84%E7%90%86%E5%AE%8C%E6%AF%95%E3%80%82%3C%2FA%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CU%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20ISP%20%E5%90%AF%E5%8A%A8%E6%97%B6%E6%88%90%E5%8A%9F%E5%88%B7%E6%9C%BA%EF%BC%9A%3C%2FU%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CP%3E%5B2025-11-24T%2009%3A34%3A03.519%5D%20%5B%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%5D%20%5B%E9%94%99%E8%AF%AF%5D%20%E6%9C%AA%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%20ID%E3%80%82%3CBR%20%2F%3E%5B2025-11-24T%2009%3A34%3A04.494%5D%20%5B%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%5D%20%5B%E9%94%99%E8%AF%AF%5D%20%E6%9C%AA%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%20ID%E3%80%82%3CBR%20%2F%3E%5B2025-11-24T%2009%3A34%3A04.503%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%EF%BC%9A%2Fopt%2Fsegger%2Fjlink_v872%2FjlinkgdbserverClexe-listprobes%20USB%20%5B2025-11-24T%2009%3A34%3A04.507%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%EF%BC%9A%2Fusr%2Flocal%2FLink_v872%2FjlinkgdbserverClexe-listprobes%20USB%20%5B2025-11-24T%2009%3A34%3A04.507%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%EF%BC%9A%2Fusr%2Flocal%2FLink_Link_v872%2FlinT%2009%3A34%3A04.948%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%EF%BC%9A%2Fusr%2Flocal%2Fmcuxpressoide-24.12.148%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc--%E7%89%88%E6%9C%AC%20%3CBR%20%2F%3E%20%5B2025-11-24T%2009%3A34%3A04.953%5D%20%5Bproc%5D%20%5Binfo%5D%20Cmd%EF%BC%9A%2Fusr%2Flocal%2Fmcuxpressoide%2Fide%2Fide%2Ftools%2Fide%2Ftools%2Fbins%2Ftools%2Fbins%2Ftools%20%2Farm-none-eabi-gcc--version%20%5B2025-11-24T%2009%3A34%3A04.959%5D%20%5Bproc%5D%20%5Binfo%5D%20Cmd%3A%20%2F..%2F.mcuxpressotools%2Farm-gnu-toolchain-14.2.rel1-x86_64-arm-none-%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3Eeabi%2Fbin%2Farm-none-eabi-gcc--version%20%5B2025-11-24T%2009%3A34%3A04.963%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2F...%2F.mcuxpressoTools%2Farm-GNU-Toolchain-13.2.rel1-x86_64-arm-none-eabi-GCC--%E7%89%88%E6%9C%AC%20%3CBR%20%2F%3E%20%5B2025-11-24T%2009%3A34%3A04.972%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%EF%BC%9Acmake-dformat%3DJSON-P%20verify-toolchain.cmake%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%5B2025-11-24T09%3A34%3A06.130%5D%20%5Bproc%5D%20%5Binfo%5D%20%7B%22ZEPHYR_TOOLCHAIN_VARIANT%22%3A%22zephyr%22%2C%22SDK_VERSION%22%3A%220.17.4%22%2C%22ZEPHYR_SDK_INSTALL_DIR%22%3A%22%2F...%2Fzephyr-sdk-0.17.4%22%7D%3C%2FP%3E%3CP%3E%5B2025-11-24T%2009%3A34%3A06.136%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2F...%2Fzephyr-sdk-0.17.4%2Farm-zephyr-eabi%2Fbin%2Farm-zephyr-eabi-objcopy-I%20elf32-littlearm-O%20ihex%20%2F...%2Fproject%2Fdebug%2Fzephyr.elf%20zephyr.hex%20%3CBR%20%2F%3E%5B2025-11-24T%2009%3A34%3A06.157%5D%20%5Bproc%5D%20%5Binfo%5D%20Cmd%3A%20%2Fopt%2Fsegger%2Fjlink_v872%2Fjlinkexe-if%20SWD-sepeed%20auto-commanderscript%20%2F...%2Fproject%2Fscript.jlink-%E8%AE%BE%E5%A4%87%20RW610-selecteMubysn%2053002466%20%3CBR%20%2F%3E%20%5B2025-11-24T%2009%3A34%3A20.074%5D%20%5BSEGGER%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20SEGGER%20%E9%97%AA%E5%AD%98%E6%93%8D%E4%BD%9C%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%EF%BC%9ASEGGER%20J-Link%20Commander%20V8.72%EF%BC%882025%20%E5%B9%B4%209%20%E6%9C%88%2024%20%E6%97%A5%E7%BC%96%E8%AF%91%2013%3A39%3A14%EF%BC%89DLL%20%E7%89%88%E6%9C%AC%20V8.72%EF%BC%8C2025%20%E5%B9%B4%209%20%E6%9C%88%2024%20%E6%97%A5%2013%3A38%3A10%20%E7%BC%96%E8%AF%91%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%88%90%E5%8A%9F%E8%AF%BB%E5%8F%96%20J-Link%20%E5%91%BD%E4%BB%A4%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E5%A4%84%E7%90%86%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6...%3CBR%20%2F%3EJ-Link%26gt%3BExitOnError%201%3CBR%20%2F%3EJ-Link%20Commander%20%E7%8E%B0%E5%9C%A8%E5%B0%86%E5%9C%A8%E5%87%BA%E9%94%99%E6%97%B6%E9%80%80%E5%87%BA%3CBR%20%2F%3EJ-Link%26gt%3Br%3CBR%20%2F%3EJ-Link%20%E8%BF%9E%E6%8E%A5%E5%B0%9A%E6%9C%AA%E5%BB%BA%E7%AB%8B%EF%BC%8C%E4%BD%86%E5%91%BD%E4%BB%A4%E9%9C%80%E8%A6%81%E3%80%82%3CBR%20%2F%3E%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%20J-Link...%20%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E5%9B%BA%E4%BB%B6%EF%BC%9AJ-Link%20V13%20%E7%BC%96%E8%AF%91%202025%20%E5%B9%B4%209%20%E6%9C%88%2017%20%E6%97%A5%2012%3A01%3A59%20%3CBR%20%2F%3E%20%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9AV13.00%20%3CBR%20%2F%3E%20J-Link%20%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E6%97%B6%E9%97%B4%EF%BC%88%E8%87%AA%E5%90%AF%E5%8A%A8%E4%BB%A5%E6%9D%A5%EF%BC%89%EF%BC%9A0d%2000h%2006m%2024s%20S%20%3CBR%20%2F%3E%20%2FN%EF%BC%9A530024%20%3CBR%20%2F%3E%2066%20%E8%AE%B8%E5%8F%AF%E8%AF%81%EF%BC%9AGDB%20USB%20%E9%80%9F%E5%BA%A6%E6%A8%A1%E5%BC%8F%EF%BC%9A%E9%AB%98%E9%80%9F%EF%BC%88480%20Mbit%2Fs%EF%BC%89vtref%3D3.325V%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E7%9B%AE%E6%A0%87%E8%BF%9E%E6%8E%A5%E5%B0%9A%E6%9C%AA%E5%BB%BA%E7%AB%8B%EF%BC%8C%E4%BD%86%E5%91%BD%E4%BB%A4%E9%9C%80%E8%A6%81%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%20%22%20RW610%20%22%20%E5%B7%B2%E9%80%89%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E9%80%9A%E8%BF%87%20SWD%20%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%3CBR%20%2F%3EInitTarget()%20%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E9%80%89%E6%8B%A9%20SWD%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82%3CBR%20%2F%3EDAP%20%E5%88%9D%E5%A7%8B%E5%8C%96%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3EDMAP_REG_ID%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%20DM-AP%20IDCODE%EF%BC%9A0x002A0000%3CBR%20%2F%3EDHCSR%EF%BC%9A0xFFFFFFFF%3CBR%20%2F%3EROM%20%E8%BF%9B%E5%85%A5%20ISP%20%E5%91%BD%E4%BB%A4%E5%A4%84%E7%90%86%E5%BE%AA%E7%8E%AF%E3%80%82%E9%87%8D%E6%96%B0%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%E8%AE%BF%E9%97%AE%E3%80%82%3CBR%20%2F%3EInitTarget()%20end%20-%20Took%2014.0ms%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20ID%20%E4%B8%BA%200x6BA02477%20%E7%9A%84%20SW-DP%3CBR%20%2F%3EDPIDR%3A%200x6BA02477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E6%89%AB%E6%8F%8F%20AP%20%E5%9C%B0%E5%9B%BE%E4%BB%A5%E6%9F%A5%E6%89%BE%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%20AP%3CBR%20%2F%3EAP%5B1%5D%EF%BC%9A%E7%94%B1%E4%BA%8E%E5%B7%B2%E5%88%B0%E8%BE%BE%20AP%20%E5%9C%B0%E5%9B%BE%E7%9A%84%E5%B0%BD%E5%A4%B4%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%81%9C%E6%AD%A2%20AP%20%E6%89%AB%E6%8F%8F%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%200x84770001%2C%20ADDR%3A%200x00000000)%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E9%81%8D%E5%8E%86%20AP%20%E6%98%A0%E5%B0%84%E4%BB%A5%E6%9F%A5%E6%89%BE%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%20AHB-AP%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E6%89%BE%E5%88%B0%E5%86%85%E6%A0%B8%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20ROM%20base%EF%BC%9A0xE00FF000%3CBR%20%2F%3ECPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A0x410FD214.%E5%AE%9E%E7%8E%B0%E8%80%85%E4%BB%A3%E7%A0%81%EF%BC%9A0x41%20(ARM)%20%3CBR%20%2F%3E%20%E5%8A%9F%E8%83%BD%E9%9B%86%EF%BC%9A%E4%B8%BB%E7%BA%BF%3CBR%20%2F%3E%E7%BC%93%E5%AD%98%EF%BC%9A%E6%9C%AA%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%E7%BC%93%E5%AD%98%20Cortex-M33%20r0p4%EF%BC%8C%E5%B0%8F%E7%AB%AF%E8%8A%82%E5%BA%8F%E3%80%82%3CBR%20%2F%3EFPUnit%EF%BC%9A8%20%E4%B8%AA%E4%BB%A3%E7%A0%81%20(BP)%20%E6%8F%92%E6%A7%BD%E5%92%8C%200%20%E4%B8%AA%E6%96%87%E5%AD%97%E6%8F%92%E6%A7%BD%3CBR%20%2F%3E%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E6%89%A9%E5%B1%95%EF%BC%9A%E5%B7%B2%E5%AE%9E%E7%8E%B0%3CBR%20%2F%3E%E5%AE%89%E5%85%A8%E8%B0%83%E8%AF%95%EF%BC%9A%E5%90%AF%E7%94%A8%20%3CBR%20%2F%3E%20CoreSIGHT%20%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3EromTBL%20%5B0%5D%20%40%20E00FF000%20%5B0%5D%20%3CBR%20%2F%3E%20%5B0%5D%EF%BC%9AE000E000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047702A04%20DEVTYPE%2000%20Cortex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ortex-M33%E3%80%82%3CBR%20%2F%3E%E9%87%8D%E7%BD%AE%E5%BB%B6%E8%BF%9F%EF%BC%9A0%20ms%20res%20%3CBR%20%2F%3E%20etTarget%20()%20%E9%80%9A%E8%BF%87%20SYSRESETREQ%20%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E9%87%8D%E7%BD%AE%E5%B9%B6%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%20ROM%20%E8%BF%9B%E5%85%A5%20ISP%20%E5%91%BD%E4%BB%A4%E5%A4%84%E7%90%86%E5%9B%9E%E8%B7%AF%E5%90%8E%E9%87%8D%E7%BD%AE%E5%BC%95%3CBR%20%2F%3E%E8%84%9A%20%2B%20%E6%9A%82%E5%81%9C%E3%80%82%E9%87%8D%E6%96%B0%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%E8%AE%BF%E9%97%AE%E3%80%82%3CBR%20%2F%3EMSPLIM%20%E5%B7%B2%E6%B8%85%E9%99%A4%20%3CBR%20%2F%3E%20RESETTarget%20()%20%E7%BB%93%E6%9D%9F-%E8%8A%B1%E4%BA%86%20128%20%3CBR%20%2F%3E%20%E6%AF%AB%E7%A7%92%E6%89%A7%E8%A1%8C%E4%BA%86%E8%AE%BE%E5%A4%87%E7%89%B9%E5%AE%9A%E7%9A%84%20RESET%E3%80%82%3CBR%20%2F%3EJ-Link%26gt%3Bh%3CBR%20%2F%3EPC%20%3D%201302B460%EF%BC%8CCycleCnt%20%3D%2000000000%3CBR%20%2F%3ER0%20%3D%2000000000%EF%BC%8CR1%20%3D%205AC33CA5%EF%BC%8CR2%20%3D%2000000001%EF%BC%8CR3%20%3D%205AC33CA5%3CBR%20%2F%3ER4%20%3D%203012F5FC%EF%BC%8CR5%20%3D%2050002E24%EF%BC%8CR6%20%3D%2055AACC33%E3%80%81R7%20%3D%2033ccaa55%3CBR%20%2F%3ER8%20%3D%205aa55aa5%2C%20R9%20%3D%20FCF0030F%2C%20R10%3D%20C33CA55A%2C%20R11%3D%2055AACC33%3CBR%20%2F%3ER12%3D%203012F5FC%3CBR%20%2F%3ESP(R13)%3D%2030125A38%2C%20MSP%3D%2030125A38%2C%20PSP%3D%2000000000%2C%20R14(LR)%20%3D%201302B421%3CBR%20%2F%3EXPSR%20%3D%2001000000%EF%BC%9AAPSR%20%3D%20nzcvq%EF%BC%8CEPSR%20%3D%2001000000%EF%BC%8CIPSR%20%3D%20000%EF%BC%88%E6%97%A0%E5%BC%82%E5%B8%B8%EF%BC%89%3CBR%20%2F%3ECFBP%20%3D%2000000001%EF%BC%8CCONTROL%20%3D%2000%EF%BC%8CFAULTMASK%20%3D%2000%EF%BC%8CBASEPRI%20%3D%2000%EF%BC%8CPRIMASK%20%3D%2001%3CBR%20%2F%3EMSPLIM%20%3D%2000000000%3CBR%20%2F%3EPSPLIM%20%3D%2000000000%3C%2FP%3E%3CP%3E%E5%AE%89%E5%85%A8%E6%89%A9%E5%B1%95%E8%A7%84%E5%88%99%EF%BC%9A%3CBR%20%2F%3EMSP_S%20%3D%2030125A38%EF%BC%8CMSP_NS%20%3D%2000000000%20MSPL%20%3CBR%20%2F%3E%20IM_S%20%3D%2000000000%EF%BC%8CMSPLIM_NS%20%3D%2000000000%20PSP_S%20%3D%2000000000%EF%BC%8CPSP_NS%20%3D%20FFFFFC%20PSPLIM_S%20%3D%2000000000%EF%BC%8C%3CBR%20%2F%3EPSPLIM_NS%20%3D%2000000000%20CONTROL_S%20%3D%2000%EF%BC%8CBASEPRI_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2000%20_S%20%3D%2001%20CONTROL_NS%20%3D%2000%EF%BC%8CF%20%3CBR%20%2F%3E%20AULTMASK_NS%20%3D%2000%EF%BC%8CBASEPRI_NS%20%3D%2000%EF%BC%8CPRIMASK_NS%20%3D%2000%EF%BC%8CPRIMASK_NS%20%3D%2000%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EFPS0%3D%2000000000%2C%20FPS1%3D%2000000000%2C%20FPS2%3D%2000000000%2C%20FPS3%3D%2000000000%3CBR%20%2F%3EFPS4%3D%2000000000%2C%20FPS5%3D%2000000000%2C%20FPS6%3D%2000000000%2C%20FPS7%3D%2000000000%3CBR%20%2F%3EFPS8%3D%2000000000%2C%20FPS9%3D%2000000000%2C%20FPS10%3D%2000000000%2C%20FPS11%3D%2000000000%3CBR%20%2F%3EFPS12%3D%2000000000%2C%20FPS13%3D%2000000000%2C%20FPS14%3D%2000000000%2C%20FPS15%3D%2000000000%3CBR%20%2F%3EFPS16%3D%2000000000%E3%80%81FPS17%3D%2000000000%2C%20FPS18%3D%2000000000%2C%20FPS19%3D%2000000000%3CBR%20%2F%3EFPS20%3D%2000000000%2C%20FPS21%3D%2000000000%2C%20FPS22%3D%2000000000%2C%20FPS23%3D%2000000000%3CBR%20%2F%3EFPS24%3D%2000000000%2C%20FPS25%3D%2000000000%2C%20FPS26%3D%2000000000%2C%20FPS27%3D%2000000000%3CBR%20%2F%3EFPS28%3D%2000000000%2C%20FPS29%3D%2000000000%2C%20FPS30%3D%2000000000%2C%20FPS31%3D%2000000000%3CBR%20%2F%3EFPSCR%3D%2000000000%3CBR%20%2F%3EJ-Link%26gt%3Bloadfile%20%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.hex%3CBR%20%2F%3E'loadfile'%EF%BC%9A%E6%89%A7%E8%A1%8C%E9%9A%90%E5%BC%8F%20RESET%20%26amp%3B%20%E6%9A%82%E5%81%9C%20MCU%E3%80%82%3CBR%20%2F%3ERESETTarget%20()%20%E9%80%9A%E8%BF%87%20SYSRESETREQ%20%E5%90%AF%E5%8A%A8%3CBR%20%2F%3ERESET%20%E5%B9%B6%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%20ROM%20%E8%BF%9B%E5%85%A5%20ISP%20%E5%91%BD%E4%BB%A4%E5%A4%84%E7%90%86%E5%9B%9E%E8%B7%AF%E5%90%8E%20RESET%20%E5%BC%95%3CBR%20%2F%3E%E8%84%9A%20%2B%20%E6%9A%82%E5%81%9C%E3%80%82%E9%87%8D%E6%96%B0%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%E8%AE%BF%E9%97%AE%E3%80%82%3CBR%20%2F%3EMSPLIM%20%E5%B7%B2%E6%B8%85%E9%99%A4%20%3CBR%20%2F%3E%20resetTarget%20()%20%E7%BB%93%E6%9D%9F-%E8%8A%B1%E4%BA%86%20117%20%3CBR%20%2F%3E%20%E6%AF%AB%E7%A7%92%E6%89%A7%E8%A1%8C%E4%BA%86%E8%AE%BE%E5%A4%87%E7%89%B9%E5%AE%9A%E7%9A%84RESET%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E4%B8%8B%E8%BD%BD%E6%96%87%E4%BB%B6%20%5B%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.hex%5D...%3CBR%20%2F%3EJ-Link%EF%BC%9AFlash%20%E4%B8%8B%E8%BD%BD%EF%BC%9ABank%201%20%40%200x18000000%EF%BC%9A1%20%E4%B8%AA%E8%8C%83%E5%9B%B4%E5%8F%97%E5%BD%B1%E5%93%8D%EF%BC%88786432%20%E5%AD%97%E8%8A%82%EF%BC%89%3CBR%20%2F%3EJ-Link%EF%BC%9AFlash%20%E4%B8%8B%E8%BD%BD%EF%BC%9A%E6%80%BB%E8%AE%A1%EF%BC%9A13.012%20%E7%A7%92%EF%BC%88%E5%87%86%E5%A4%87%EF%BC%9A0.333%20%E7%A7%92%EF%BC%8C%E6%AF%94%E8%BE%83%EF%BC%9A2.685%20%E7%A7%92%EF%BC%8C%E6%93%A6%E9%99%A4%EF%BC%9A2.979%20%E7%A7%92%EF%BC%8C%E7%A8%8B%E5%BA%8F%EF%BC%9A5.531%20%E7%A7%92%EF%BC%8C%E9%AA%8C%E8%AF%81%EF%BC%9A1.307%20%E7%A7%92%EF%BC%8C%E6%81%A2%E5%A4%8D%EF%BC%9A0.174%20%E7%A7%92%EF%BC%89J-Link%EF%BC%9AFlash%20%E4%B8%8B%E8%BD%BD%EF%BC%9A%E7%A8%8B%E5%BA%8F%E9%80%9F%E5%BA%A6%EF%BC%9A139%20Kb%2Fs%20O.K%E3%80%82J-Link%20%26gt%3B%20qc%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E8%84%9A%E6%9C%AC%E5%A4%84%E7%90%86%E5%B7%B2%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%5B2025-11-24T%2009%3A34%3A03.519%5D%20%5B%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%5D%20%5B%E9%94%99%E8%AF%AF%5D%20%E6%9C%AA%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%20ID%E3%80%82%5B2025-11-24T%2009%3A34%3A04.494%5D%5B%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%5D%20%5B%E9%94%99%E8%AF%AF%5D%20%E6%9C%AA%E6%89%BE%E5%88%B0%E8%AE%BE%E5%A4%87%20ID%E3%80%82%5B2025-11-24T%2009%3A34%3A04.503%5D%5Bproc%5D%20%5Binfo%5D%20Cmd%EF%BC%9A%2Fopt%2FSEGGER%2FJLink_V872%2FJLinkGDBServerCLExe%20-listprobes%20USB%5B2025-11-24T09%3A34%3A04.507%5D%20%5Bproc%5D%20%5Binfo%5D%20Cmd%EF%BC%9A%2Fusr%2Flocal%2FLinkServer_25.9.134%2FLinkServer%20probes%20--json%5B2025-11-24T09%3A34%3A04.948%5D%5Bproc%5D%20%5Binfo%5D%20Cmd%EF%BC%9A%2Fusr%2Flocal%2Fmcuxpressoide-24.12.148%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc%20--version%5B2025-11-24T09%3A34%3A04.953%5D%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2Fusr%2Flocal%2Fmcuxpressoide%2Fide%2Ftools%2Fbin%2Farm-none-eabi-gcc--version%20%5B2025-11-24T%2009%3A34%3A04.959%5D%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20cmd%3A%20%2F...%2F.mcuxpressotools%2Farm-gnu-toolchain-14.2.rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-gcc--%E7%89%88%E6%9C%AC%20%5B2025-11-24T%2009%3A34%3A04.963%5D%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2F...%2F.mcuxpressoTools%2Farm-GNU-Toolchain-13.2.rel1-x86_64-arm-none-eabi%2Fbin%2Farm-none-eabi-GCC--%E7%89%88%E6%9C%AC%20%5B2025-11-24T%2009%3A34%3A04.972%5D%5Bproc%5D%20%5Binfo%5D%20Cmd%3A%20cmake%20-DFORMAT%3Djson%20-P%20verify-toolchain.cmake%5B2025-11-24T09%3A34%3A06.130%5D%5Bproc%5D%20%5Binfo%5D%20%7B%22ZEPHYR_TOOLCHAIN_VARIANT%22%3A%22zephyr%22%2C%22SDK_VERSION%22%3A%220.17.4%22%2C%22ZEPHYR_SDK_INSTALL_DIR%22%3A%22%2F...%2Fzephyr-sdk-0.17.4%22%7D%5B2025-11-24T09%3A34%3A06.136%5D%E3%80%82%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2F...%2Fzephyr-sdk-0.17.4%2Farm-zephyr-eabi%2Fbin%2Farm-zephyr-eabi-objcopy-I%20elf32-littlearm-O%20ihex%20%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.elf%20zephyr.hex%20%5B2025-11-24T%2009%3A34%3A06.157%5D%20%5Bproc%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20Cmd%3A%20%2Fopt%2Fsegger%2Fjlink_v872%2Fjlinkexe-if%20swd-speed%20auto-commanderscript%20%2F...%2Fproject%2Fscript.jlink-%E8%AE%BE%E5%A4%87%20RW610-selectemubysn%2053002466%20%5B2025-11-24T%2009%3A34%3A20.074%5D%5BSEGGER%5D%20%5B%E4%BF%A1%E6%81%AF%5D%20SEGGER%20%E9%97%AA%E5%AD%98%E6%93%8D%E4%BD%9C%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%EF%BC%9ASEGGER%20J-Link%20Commander%20V8.72%EF%BC%882025%20%E5%B9%B4%209%20%E6%9C%88%2024%20%E6%97%A5%E7%BC%96%E8%AF%91%2013%3A39%3A14%EF%BC%89DLL%20%E7%89%88%E6%9C%AC%20V8.72%EF%BC%8C%E7%BC%96%E8%AF%91%E6%88%90%E5%8A%9F%202025%20%E5%B9%B4%209%20%E6%9C%88%2024%20%E6%97%A5%2013%3A38%3A10%20J-Link%20%E5%91%BD%E4%BB%A4%E6%96%87%E4%BB%B6%E8%AF%BB%E5%8F%96%E6%88%90%E5%8A%9F%E3%80%82%E5%A4%84%E7%90%86%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6...%20J-Link%20%26gt%3B%20ExitonError%201J-Link%20Commander%20%E7%8E%B0%E5%9C%A8%E5%B0%86%E5%9C%A8%E5%87%BA%E9%94%99%20J-Link%20%E6%97%B6%E9%80%80%E5%87%BA%20%26gt%3B%20RJ-Link%20%E8%BF%9E%E6%8E%A5%E5%B0%9A%E6%9C%AA%E5%BB%BA%E7%AB%8B%EF%BC%8C%E4%BD%86%E5%91%BD%E4%BB%A4%E9%9C%80%E8%A6%81%E8%BF%9E%E6%8E%A5%E9%80%9A%E8%BF%87%20USB%20%E8%BF%9E%E6%8E%A5%E7%9A%84%20J-Link...%20O.K.%E5%9B%BA%E4%BB%B6%EF%BC%9AJ-Link%20V13%20%E4%BA%8E%202025%20%E5%B9%B4%209%20%E6%9C%88%2017%20%E6%97%A5%E7%BC%96%E8%AF%91%2012%3A01%3A59%20%E7%A1%AC%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9AV13.00J-Link%20%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E6%97%B6%E9%97%B4%EF%BC%88%E8%87%AA%E5%90%AF%E5%8A%A8)%EF%BC%9A0d%2000h%2006m%2024ss%2FN%EF%BC%9A53002466%E8%AE%B8%E5%8F%AF%E8%AF%81%EF%BC%9AGDBUSB%20%E9%80%9F%E5%BA%A6%E6%A8%A1%E5%BC%8F%EF%BC%9A%E9%AB%98%E9%80%9F%20(480%20Mbit%2Fs)%20vtref%3D3.325vTarget%E5%B0%9A%E6%9C%AA%E5%BB%BA%E7%AB%8B%E8%BF%9E%E6%8E%A5%E4%BD%86%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20Command.%E8%AE%BE%E5%A4%87%20%22%20RW610%20%22%20%E5%B7%B2%E9%80%89%E6%8B%A9%E3%80%82%E9%80%9A%E8%BF%87%20swdinitTarget%20()%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E5%B7%B2%E9%80%89%E6%8B%A9%20startSWD%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82DAP%20%E6%88%90%E5%8A%9F%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82DMAP_REG_ID%EF%BC%9A%E6%A3%80%E6%B5%8B%E5%88%B0%20DM-AP%20IDCODE%EF%BC%9A0x002A0000DHCSR%EF%BC%9A0xFFFFFFFFROM%20%E8%BF%9B%E5%85%A5%20ISP%20%E5%91%BD%E4%BB%A4%E5%A4%84%E7%90%86%E5%BE%AA%E7%8E%AF%E3%80%82%E9%87%8D%E6%96%B0%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%E8%AE%BF%E9%97%AE%E3%80%82InitTarget()%20end%20-%20%E8%80%97%E6%97%B6%2014.0msFound%20SW-DP%20with%20ID%200x6BA02477DPIDR%3A%200x6BA02477CoreSight%20SoC-400%20or%20earlierScanning%20AP%20map%20to%20find%20all%20available%20APsAP%5B1%5D%EF%BC%9A%E7%94%B1%E4%BA%8E%E5%B7%B2%E5%88%B0%E8%BE%BE%20AP%20%E5%9C%B0%E5%9B%BE%E7%9A%84%E5%B0%BD%E5%A4%B4%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%81%9C%E6%AD%A2%20AP%20%E6%89%AB%E6%8F%8FAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%200x84770001%2C%20ADDR%3A%200x00000000)Iterating%20through%20AP%20map%20to%20find%20AHB-AP%20to%20useAP%5B0%5D%EF%BC%9A%E6%89%BE%E5%88%B0%E6%A0%B8%E5%BF%83AP%5B0%5D%EF%BC%9AAHB-AP%20ROM%20base%EF%BC%9A0xE00FF000CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A0x410FD214%E3%80%82%E5%AE%9E%E7%8E%B0%E8%80%85%E4%BB%A3%E7%A0%81%EF%BC%9A0x41%20(Arm)%20%E5%8A%9F%E8%83%BD%E9%9B%86%EF%BC%9AMainlineCache%EF%BC%9A%E6%89%BE%E4%B8%8D%E5%88%B0%E7%BC%93%E5%AD%98%20Cortex-M33%20r0p4%EF%BC%8CLittle%20Endian.fpUnit%EF%BC%9A8%20%E4%B8%AA%E4%BB%A3%E7%A0%81%20(BP)%20%E6%8F%92%E6%A7%BD%E5%92%8C%200%20%E4%B8%AA%E5%AD%97%E9%9D%A2%E6%8F%92%E6%A7%BD%E5%AE%89%E5%85%A8%E6%89%A9%E5%B1%95%EF%BC%9A%E5%B7%B2%E5%AE%9E%E7%8E%B0%E5%AE%89%E5%85%A8%E8%B0%83%E8%AF%95%EF%BC%9AenabledCoreSight%20%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%9Aromtbl%20%5B0%5D%20%40%20E00FF000%20%5B0%5D%20%5B0%5D%EF%BC%9AE000E000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047702A04%20DEVTYPE%2000%20Cortype%2000%20Tex-M33%20%5B0%5D%20%5B1%5D%EF%BC%9AE0001000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A02%20DEVTYPE%2000%20DWT%20%5B0%5D%20%5B2%5D%EF%BC%9AE0002000%20CID%20B105900D%20PID%20PID%20PID%20DEVARCH%20DEVTYPE%2000%20FPB%20%5B0%5D%20%5B3%5D%EF%BC%9A000BBD21%2047701A03%20E0000000%20B105900D%20000BBD21%2047701A01%20E0041000%20B105900D%20PID%20002BBD21%20DEVARCH%2047724A13%20DEVTYPE%2013%20ETM%20%5B0%5D%20%5B6%5D%EF%BC%9AE0042000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A14%20DEVTYPE%2014%20css600-ctiMemory%20%E5%8C%BA%E5%9F%9F%EF%BC%9A%22%20%E9%BB%98%E8%AE%A4%20%22%20%E6%8F%8F%E8%BF%B0%EF%BC%9A%E5%B7%B2%E8%AF%86%E5%88%AB%E9%BB%98%E8%AE%A4%E8%AE%BF%E9%97%AE%E6%A8%A1%E5%BC%8F%20decortex-M33%E3%80%82RESET%20%E5%BB%B6%E8%BF%9F%EF%BC%9A0%20msResetTarget%20()%20%E9%80%9A%E8%BF%87%20SYSRESETREQ%20%E5%90%AF%E5%8A%A8%20RESET%20%E5%B9%B6%E5%9C%A8%20bootloaderROM%20%E8%BF%9B%E5%85%A5%E4%BA%92%E8%81%94%E7%BD%91%E6%9C%8D%E5%8A%A1%E6%8F%90%E4%BE%9B%E5%95%86%E5%91%BD%E4%BB%A4%E5%A4%84%E7%90%86%E5%9B%9E%E8%B7%AF%E5%90%8E%20RESET%20%E5%BC%95%E8%84%9A%20%2B%20%E5%81%9C%E6%AD%A2%E3%80%82%E9%87%8D%E6%96%B0%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%20Access.msplim%20clearedResetTarget%20()%20%E7%AB%AF%E2%80%94%E2%80%94%E6%89%A7%E8%A1%8C%E4%BA%86%20128msDevice%20%E7%89%B9%E5%AE%9A%E7%9A%84%20RESET%E3%80%82J-Link%20%26gt%3B%20hPC%20%3D%201302B460%EF%BC%8CcycleCnt%20%3D%2000000000R0%20%3D%2000000000%EF%BC%8CR1%20%3D%205AC33CA5%EF%BC%8CR2%20%3D%2000000001%EF%BC%8CR3%20%3D%203012F5FC%EF%BC%8CR5%20%3D%2050002E24%EF%BC%8CR6%20%3D%2055AACC33%EF%BC%8CR7%20%3D%2033CCAA55R8%20%3D%EF%BC%8C5AA55AA5%20AAACC33R12%3D%EF%BC%88R13%EF%BC%89%3D%EF%BC%8CMSP%3D%EF%BC%8CPSP%3D%2000000000%EF%BC%8CR14%EF%BC%88LR%EF%BC%89%3D%20%3D%2001000000%EF%BC%9AAPSR%20%3D%20nzcvq%EF%BC%8CEPSR%20%3D%2001000000%EF%BC%8CIPSR%20%3D%20000%EF%BC%88%E6%97%A0%E5%BC%82%E5%B8%B8%EF%BC%89CFBP%20%3D%2000000001%EF%BC%8C%E6%8E%A7%E5%88%B6%20%3D%2000%EF%BC%8C%E6%95%85%E9%9A%9C%E6%8E%A9%E7%A0%81%20%3D%2000%EF%BC%8CBASEPRI%20%3D%2000%EF%BC%8CBASEPRI%20%3D%2000%EF%BC%8C5AC33CA5R4%20FCF0030F%20C33CA55A%203012F5FCSP%2030125A38%2030125A38%201302B421XPSRPRIMASK%20%3D%2001MSPLIM%20%3D%2000000000PSLIM%20%3D%2000000000%E5%AE%89%E5%85%A8%E6%89%A9%E5%B1%95%E8%A7%84%E5%88%99%EF%BC%9AMSP_S%20%3D%2030125A38%EF%BC%8CMSP_NS%20%3D%2000000000MSPLIM_S%20%3D%2000000000%EF%BC%8CMSPLIM_NS%20%3D%2000000000PSP_S%20%3D%2000000000%EF%BC%8CPSPLIM_NS%20%3D%2000000000CONTROL_S%20%3D%2000%EF%BC%8CFAULTMASK_S%20%3D%2000%20_S%20%3D%2000%EF%BC%8CBASEPRI_S%20%3D%2000%EF%BC%8CPRIMASK_S%20%3D%2001CONTROL_NS%20%3D%2000%EF%BC%8CFAULTMASK_NS%20%3D%2000%EF%BC%8CBASEPRI_NS%20%3D%2000%EF%BC%8CPRIMASK_NS%20%3D%2000FPS0%20%3D%2000000000%EF%BC%8CFPS1%20%3D%2000000000%EF%BC%8CFPS1%20%3D%2000000000%EF%BC%8CFPS1%20%3D%2000000000%EF%BC%8CFPS1%20%3D%2000000000%EF%BC%8CFPS2%20%3D%2000000000%EF%BC%8CFPS3%20%3D%2000000000FPS4%20%3D%2000000000%EF%BC%8CFPS5%20%3D%2000000000%EF%BC%8CFPS6%20%3D%2000000000%EF%BC%8CFPS7%20%3D%2000000000FPS8%20%3D%2000000000%EF%BC%8CFPS9%20%3D%2000000000%EF%BC%8CFPS10%3D%2000000000%EF%BC%8CFPS11%3D%2000000000FPS12%3D%2000000000FPS12%3D%2000000000%EF%BC%8CFPS13%3D%2000000000%EF%BC%8CFPS14%3D%2000000000%EF%BC%8CFPS15%3D%2000000000FPS16%3D%2000000000%EF%BC%8CFPS17%3D%2000000000%EF%BC%8CFPS18%3D%2000000000%EF%BC%8CFPS19%3D%2000000000FPS20%3D%2000000000%EF%BC%8CFPS21%3D%2000000000%EF%BC%8CFPS22%3D%2000000000%EF%BC%8CFPS23%3D%2000000000FPS24%3D%2000000000%EF%BC%8CFPS26%3D%2000000000%EF%BC%8CFPS27%3D%2000000000FPS28%3D%2000000000%EF%BC%8CFPS29%3D%2000000000%EF%BC%8CFPS30%3D%2000000000%EF%BC%8CFPS31%3D%2000000000FPSCR%3D%2000000000FPSCR%3D%2000000000J-Link%20%26gt%3B%20%E5%8A%A0%E8%BD%BD%E6%96%87%E4%BB%B6%20%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.hex%20'%E5%8A%A0%E8%BD%BD%E6%96%87%E4%BB%B6'%EF%BC%9A%E9%80%9A%E8%BF%87%20SYSRESETREQ%20%E9%9A%90%E5%BC%8F%20RESET%20%26amp%3B%20%E6%9A%82%E5%81%9C%20mcu.resetTarget%20()%20startReset%20%E5%B9%B6%E5%9C%A8%20bootLoaderROM%20%E8%BF%9B%E5%85%A5%20ISP%20%E5%91%BD%E4%BB%A4%E5%A4%84%E7%90%86%E5%9B%9E%E8%B7%AF%E5%90%8E%20RESET%20%E5%BC%95%E8%84%9A%20%2B%20%E6%9A%82%E5%81%9C%E3%80%82%E9%87%8D%E6%96%B0%E5%90%AF%E7%94%A8%E8%B0%83%E8%AF%95%20Access.msplim%20clearedRESETTarget%20()%20%E7%BB%93%E6%9D%9F-%E5%B7%B2%E6%89%A7%E8%A1%8C%20117msDevice%20%E7%89%B9%E5%AE%9A%E7%9A%84%20RESET%E3%80%82%E6%AD%A3%E5%9C%A8%E4%B8%8B%E8%BD%BD%E6%96%87%E4%BB%B6%20%5B%2F...%2Fproject%2Fdebug%2Fzephyr%2Fzephyr.hex%5D...%20J-Link%EF%BC%9AFlash%20%E4%B8%8B%E8%BD%BD%EF%BC%9ABank%201%20%40%200x18000000%EF%BC%9A1%20%E4%B8%AA%E8%8C%83%E5%9B%B4%E5%8F%97%E5%BD%B1%E5%93%8D%EF%BC%88786432%20%E5%AD%97%E8%8A%82%EF%BC%89J-Link%EF%BC%9AFlash%20%E4%B8%8B%E8%BD%BD%EF%BC%9A%E6%80%BB%E8%AE%A1%EF%BC%9A13.012%20%E7%A7%92%EF%BC%88%E5%87%86%E5%A4%87%EF%BC%9A0.333%20%E7%A7%92%EF%BC%8C%E6%AF%94%E8%BE%83%EF%BC%9A2.685%E7%A7%92%EF%BC%8C%E6%93%A6%E9%99%A4%EF%BC%9A2.979%20%E7%A7%92%EF%BC%8C%E7%A8%8B%E5%BA%8F%EF%BC%9A5.531%20%E7%A7%92%EF%BC%8C%E9%AA%8C%E8%AF%81%EF%BC%9A1.307%20%E7%A7%92%EF%BC%8C%E6%81%A2%E5%A4%8D%EF%BC%9A0.174%20%E7%A7%92%EF%BC%89J-Link%3A%20Flash%20%E4%B8%8B%E8%BD%BD%EF%BC%9A%E7%A8%8B%E5%BA%8F%E9%80%9F%E5%BA%A6%EF%BC%9A139%20Kb%2Fso.k.j-Link%20%26gt%3B%20QCScript%20%E5%A4%84%E7%90%86%E5%B7%B2%E5%AE%8C%E6%88%90%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E7%94%B1%E4%BA%8E%E4%BD%BF%E7%94%A8%20FreeRTOS%20%E6%97%B6%E9%97%AA%E5%AD%98%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%88%91%E6%80%80%E7%96%91%E6%98%AF%20devicetree%20%E6%88%96%20KConfig%20%E4%B8%AD%E7%9A%84%E6%9F%90%E4%BA%9B%E9%85%8D%E7%BD%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%20%E6%9C%89%E4%BB%80%E4%B9%88%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E7%9A%84%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E5%9C%A8%20Linux%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20MCUXpresso%20VSCode%20%E6%89%A9%E5%B1%95%EF%BC%8C%E9%97%AA%E5%AD%98%20Zephyr%204.3.0%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2247462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E4%BA%A7%E5%93%81%EF%BC%9AWiFi%20RW6XX%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW610%20JLink%20DAP%20Failing%20on%20Zephyr%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248510%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E4%BD%BF%E7%94%A8%20J-Link%20Commander%20CLI%20%E4%B8%8E%E6%A0%B8%E5%BF%83%E9%80%9A%E4%BF%A1%E5%90%97%EF%BC%9F(%E4%B8%8D%E5%9C%A8%20VS%20%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E7%94%A8%E4%BA%86%E4%BB%80%E4%B9%88%E4%BE%8B%E5%AD%90%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3EDaniel%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RW610%20JLink%20DAP%20Failing%20on%20Zephyr%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%E3%80%81%3C%2FP%3E%3CP%3E%E5%8E%9F%E6%9D%A5%E6%98%AF%E6%88%91%E5%AF%B9%20PCB%20%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%8D%E5%A4%9F%E4%BB%94%E7%BB%86%E3%80%82%20%E6%88%91%E4%BB%AC%E5%AF%B9%20Flexcomm2%20%E5%92%8C%20SWD%20%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E5%BC%95%E8%84%9A%E3%80%82%20%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%E4%B8%AD%E4%BD%BF%E7%94%A8%20Flexcomm2%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E5%B0%8F%E5%BF%83%E4%B8%BA%20flexcomm2%20devicetree%20%E8%8A%82%E7%82%B9%E8%AE%BE%E7%BD%AE%E4%BA%86%3CSTRONG%3Estatus%20%3D%22okay%22%3C%2FSTRONG%3E%E6%A0%87%E5%BF%97%E3%80%82%20%E4%B8%80%E6%97%A6%E6%88%91%E8%AE%BE%E7%BD%AE%E4%BA%86%3CSTRONG%3E%E7%8A%B6%E6%80%81%20%3D%20%22%20%E5%B7%B2%E7%A6%81%E7%94%A8%20%22%3C%2FSTRONG%3E%20%E6%88%91%E5%B0%B1%E8%83%BD%E5%AF%B9%E6%88%91%E7%9A%84%E6%9D%BF%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%20ISP%20%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
