PN7642 C101 Debug mode entering error
2,607 次查看
artem_pn
Hello!
I`m using PN7642EV/C101. On my custom board (I haven`t found DevKit for this version of IC) I can not enter debug mode. I`m using MCU Link to load and debug FW. During the connection sequence I have next log:
Reconnected to existing LinkServer process.
============= SCRIPT: PN7642_connect.scp =============
PN7642 Connect Script
Connecting to Probe Index = 1
This probe = 1
This TAP = 0
This core = 0
DpID = 6BA02477
Breakpoints before reset
Number of FPBs: 8
FPB:0 COMP: 0x00208131 (0x00208130)
FPB:1 COMP: 0x20003003 (0x20003002)
FPB:2 COMP: 0x00000000 (not in use)
FPB:3 COMP: 0x00000000 (not in use)
FPB:4 COMP: 0x00000000 (not in use)
FPB:5 COMP: 0x00000000 (not in use)
FPB:6 COMP: 0x00000000 (not in use)
FPB:7 COMP: 0x00000000 (not in use)
Sending CMSYSRESETREQ
Error: Wire Ack Fault - target connected?
DpID = 6BA02477
Registers after reset
R0 : 00000000
R1 : 00208130
R2 : 00208130
R3 : 00208130
R4 : 00208130
R5 : 00208130
R6 : 00208130
R7 : 00208130
R8 : 00208130
R9 : 00208130
R10 : 00208130
R11 : 00208130
R12 : 00208130
SP : 20008000
LR : FEFFFFFF
PC : 00208130
PSR : 01000000
MSP : 20008000
PSP : 00000000
CFBP: 00000000
============= END SCRIPT =============================
Probe Firmware: MCU-LINK r0FF CMSIS-DAP V0.078 (NXP Semiconductors)
Serial Number: KJKL4QM3ADBKP
VID:PID: 1FC9:0143
USB Path: \\?\hid#vid_1fc9&pid_0143&mi_00#7&1db5e7dc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
Using memory from core 0 after searching for a good core
debug interface type = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
processor type = Cortex-M33 (CPU ID 00000D21) on DAP AP 0
number of h/w breakpoints = 8
number of flash patches = 0
number of h/w watchpoints = 4
Probe(0): Connected&Reset. DpID: 6BA02477. CpuID: 00000D21. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FE000: CID B105100D PID 0000080000 ROM (type 0x1)
ROM 1 E00FF000: CID B105100D PID 04000BB4C9 ROM (type 0x1)
ROM 2 E000E000: CID B105900D PID 04000BBD21 CSt ARM ARMv8-M type 0x0 Misc - Undefined
ROM 2 E0001000: CID B105900D PID 04000BBD21 CSt ARM DWTv2 type 0x0 Misc - Undefined
ROM 2 E0002000: CID B105900D PID 04000BBD21 CSt ARM FPBv2 type 0x0 Misc - Undefined
ROM 2 E0000000: CID B105900D PID 04000BBD21 CSt ARM ITMv2 type 0x43 Trace Source - Bus
ROM 2 E0041000: CID B105900D PID 04002BBD21 CSt ARM ETMv4.0 type 0x13 Trace Source - Core
ROM 2 E0042000: CID B105900D PID 04000BBD21 CSt ARM CTIv2 type 0x14 Debug Control - Trigger, e.g. ECT
ROM 1 E0045000: CID B105900D PID 04004BB907 CSt ETB type 0x21 Trace Sink - ETB
ROM 1 E0044000: CID B105900D PID 04002BB909 CSt type 0x22 Trace Link - Filter
ROM 1 E0046000: CID B105900D PID 04005BB906 CSt type 0x14 Debug Control - Trigger, e.g. ECT
NXP: PN7642
DAP stride is 1024 bytes (256 words)
Inspected v.2 On-chip Flash Memory PN7642.cfx
Image 'PN7642 Flash Apr 5 2024 18:22:54'
( 65) Chip Setup Complete
Connected: was_reset=false. was_stopped=true
Awaiting telnet connection to port 3330 ...
GDB nonstop mode enabled
FreeRTOS stack backtrace is disabled
Opening flash driver PN7642.cfx
VECTRESET requested, but not supported on ARMv8-M CPUs. Using SOFTRESET instead.
Using SOFT reset to run the flash driver
Flash device supported (180KB = 360*512 at 0x208000)
Writing 150608 bytes to address 0x00208000 in Flash
Sectors written: 0, unchanged: 295, total: 295
Erased/Wrote sector 0-294 with 150608 bytes in 155msec
Closing flash driver PN7642.cfx
Flash Write Done
Opening flash driver PN7642.cfx (already resident)
Writing 1540 bytes to address 0x00233000 in Flash
Sectors written: 0, unchanged: 4, total: 4
Erased/Wrote sector 344-347 with 1540 bytes in 26msec
Flash Write Done
Flash Program Summary: 152146 bytes in 0.18 seconds (816.37 KB/sec)
============= SCRIPT: PN7642_reset.scp =============
PN7642 Reset Script
Number of FPBs: 8
DpID = 6BA02477
Registers after CMSYSRESETREQ
R0 : 00000000
R1 : 00208130
R2 : 00208130
R3 : 00208130
R4 : 00208130
R5 : 00208130
R6 : 00208130
R7 : 00208130
R8 : 00208130
R9 : 00208130
R10 : 00208130
R11 : 00208130
R12 : 00208130
SP : 20008000
LR : FEFFFFFF
PC : 00208130
PSR : 01000000
MSP : 20008000
PSP : 00000000
CFBP: 00000000
DpID = 6BA02477
After PN76_Sys_Hal_SoftReset(1)
Error: Could not read registers (0x05)
state - running or following reset request - re-read of state failed - rc Nn(05). Wire ACK Fault in DAP access
following reset read of core registers failed - Ep(08). Cannot access core regs when target running.
Target error from Commit Flash write: Ep(08). Cannot access core regs when target running.
GDB stub (C:\nxp\LinkServer_1.5.30\binaries\crt_emu_cm_redlink) terminating - GDB protocol problem: Pipe has been closed by GDB.
What can be the reason of such behavior?
Thanks in advance!
Artem
标记 (1)
2,555 次查看
danielchen
Hi Artem:
The error message is : Target marked as not debuggable.    I would suggest you refer to below link,  this issue was discussed.
02: Failed on connect: Ep(01). Target marked as not debuggable - NXP Community
you can try other debug probe, like MCU link pro.
4 回复数
2,576 次查看
artem_pn
Hi Daniel, thank you for response. I updated version of my MCU Link (not pro), anyway it is useful but unfortunately didn`t help. Another bad symptom is that when I configure debugger in such a way
and trying to to run debug sequence, I got this message:
Is there something you know can be the possible reason?
Thanks in advance!
Artem
2,556 次查看
danielchen
Hi Artem:
2,510 次查看
artem_pn
Thank you, Daniel!
Artem
标记 (1)
2,588 次查看
danielchen
Are you using MCU Link pro?
I would suggest you update the firmware for the MCU LINK pro and try it again.
Getting Started with the MCU-Link Pro | NXP Semiconductors
Regads
%3CLINGO-SUB%20id%3D%22lingo-sub-1969238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7642%20C101%20%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E8%BF%9B%E5%85%A5%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20PN7642EV%2FC101%E3%80%82%E5%9C%A8%E6%88%91%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E4%B8%8A%EF%BC%88%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E6%AD%A4%E7%89%88%E6%9C%AC%20IC%20%E7%9A%84%20DevKit%EF%BC%89%E6%88%91%E6%97%A0%E6%B3%95%E8%BF%9B%E5%85%A5%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20MCU%20Link%20%E6%9D%A5%E5%8A%A0%E8%BD%BD%E5%92%8C%E8%B0%83%E8%AF%95%20FW%E3%80%82%E5%9C%A8%E8%BF%9E%E6%8E%A5%E5%BA%8F%E5%88%97%E4%B8%AD%E6%88%91%E6%9C%89%E4%B8%8B%E4%B8%80%E4%B8%AA%E6%97%A5%E5%BF%97%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%8E%B0%E6%9C%89%E7%9A%84%20LinkServer%20%E8%BF%9B%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E8%84%9A%E6%9C%AC%EF%BC%9APN7642_connect.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20PN7642%20%E8%BF%9E%E6%8E%A5%E8%84%9A%E6%9C%AC%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%8E%A2%E6%B5%8B%E5%99%A8%E7%B4%A2%E5%BC%95%20%3D%201%3CBR%20%2F%3E%E6%AD%A4%E6%8E%A2%E6%B5%8B%20%3D%201%3CBR%20%2F%3E%E6%AD%A4%20TAP%20%3D%200%3CBR%20%2F%3E%E6%AD%A4%E6%A0%B8%E5%BF%83%20%3D%200%3CBR%20%2F%3E%20DpID%20%3D%206BA02477%3CBR%20%2F%3E%E9%87%8D%E7%BD%AE%E5%89%8D%E7%9A%84%E6%96%AD%E7%82%B9%3CBR%20%2F%3EFPB%E6%95%B0%E9%87%8F%EF%BC%9A8%3CBR%20%2F%3E%20FPB%3A0%20COMP%EF%BC%9A0x00208131%EF%BC%880x00208130%EF%BC%89%3CBR%20%2F%3E%20FPB%3A1%20COMP%EF%BC%9A0x20003003%EF%BC%880x20003002%EF%BC%89%3CBR%20%2F%3E%20FPB%3A2%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A3%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A4%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A5%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A6%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A7%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%E5%8F%91%E9%80%81%20CMSYSRESETREQ%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E7%BA%BF%E8%B7%AF%E7%A1%AE%E8%AE%A4%E6%95%85%E9%9A%9C%20-%20%E7%9B%AE%E6%A0%87%E5%B7%B2%E8%BF%9E%E6%8E%A5%EF%BC%9F%3CBR%20%2F%3EDpID%20%3D%206BA02477%3CBR%20%2F%3E%E5%A4%8D%E4%BD%8D%E5%90%8E%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3ER0%EF%BC%9A00000000%3CBR%20%2F%3E%20R1%EF%BC%9A00208130%3CBR%20%2F%3E%20R2%EF%BC%9A00208130%3CBR%20%2F%3E%20R3%EF%BC%9A00208130%3CBR%20%2F%3E%20R4%EF%BC%9A00208130%3CBR%20%2F%3E%20R5%20%3A%2000208130%3CBR%20%2F%3E%20R6%EF%BC%9A00208130%3CBR%20%2F%3E%20R7%EF%BC%9A00208130%3CBR%20%2F%3E%20R8%EF%BC%9A00208130%3CBR%20%2F%3E%20R9%20%3A%2000208130%3CBR%20%2F%3E%20R10%EF%BC%9A00208130%3CBR%20%2F%3E%20R11%20%3A%2000208130%3CBR%20%2F%3E%20R12%20%3A%2000208130%3CBR%20%2F%3E%E6%9C%8D%E5%8A%A1%E5%8F%B7%EF%BC%9A20008000%3CBR%20%2F%3E%20LR%20%EF%BC%9A%20FEFFFFFF%3CBR%20%2F%3E%E7%94%B5%E8%84%91%EF%BC%9A00208130%3CBR%20%2F%3E%E5%8E%8B%E6%8E%A7%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A01000000%3CBR%20%2F%3E%20MSP%20%EF%BC%9A20008000%3CBR%20%2F%3E%20PSP%20%EF%BC%9A00000000%3CBR%20%2F%3E%20CFBP%EF%BC%9A00000000%3CBR%20%2F%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E8%84%9A%E6%9C%AC%E7%BB%93%E6%9D%9F%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E6%8E%A2%E9%92%88%E5%9B%BA%E4%BB%B6%EF%BC%9AMCU-LINK%20r0FF%20CMSIS-DAP%20V0.078%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%89%3CBR%20%2F%3E%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9AKJKL4QM3ADBKP%3CBR%20%2F%3E%E8%A7%86%E9%A2%91ID%EF%BC%9APID%EF%BC%9A1FC9%EF%BC%9A0143%3CBR%20%2F%3E%20USB%20%E8%B7%AF%E5%BE%84%EF%BC%9A%5C%5C%3F%5Chid%23vid_1fc9%26amp%3Bpid_0143%26amp%3Bmi_00%237%26amp%3B1db5e7dc%26amp%3B0%26amp%3B0000%23%7B4d1e55b2-f16f-11cf-88cb-001111000030%7D%3CBR%20%2F%3E%E6%90%9C%E7%B4%A2%E5%88%B0%E5%90%88%E9%80%82%E7%9A%84%E6%A0%B8%E5%BF%83%E5%90%8E%E4%BD%BF%E7%94%A8%E6%A0%B8%E5%BF%83%200%20%E7%9A%84%E5%86%85%E5%AD%98%3CBR%20%2F%3E%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%20%3D%20CoreSight%20DP%EF%BC%88DAP%20DP%20ID%206BA02477%EF%BC%89%E9%80%9A%E8%BF%87%20SWD%20TAP%200%3CBR%20%2F%3E%E5%A4%84%E7%90%86%E5%99%A8%E7%B1%BB%E5%9E%8B%20%3D%20Cortex-M33%EF%BC%88CPU%20ID%2000000D21%EF%BC%89%E5%9C%A8%20DAP%20AP%200%20%E4%B8%8A%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E6%96%AD%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%208%3CBR%20%2F%3E%E9%97%AA%E5%AD%98%E8%A1%A5%E4%B8%81%E6%95%B0%E9%87%8F%20%3D%200%3CBR%20%2F%3E%E7%A1%AC%E4%BB%B6%E7%9B%91%E6%B5%8B%E7%82%B9%E6%95%B0%E9%87%8F%20%3D%204%3CBR%20%2F%3E%E6%8E%A2%E6%B5%8B%E5%99%A8(0)%EF%BC%9A%E5%B7%B2%E8%BF%9E%E6%8E%A5%E5%B9%B6%E9%87%8D%E7%BD%AE%E3%80%82DpID%EF%BC%9A6BA02477%E3%80%82CPUID%EF%BC%9A00000D21%E3%80%82%E4%BF%A1%E6%81%AF%EF%BC%9A%3CNONE%3E%3CBR%20%2F%3E%20%E8%B0%83%E8%AF%95%E5%8D%8F%E8%AE%AE%EF%BC%9ASWD%E3%80%82RTCK%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%E7%9F%A2%E9%87%8F%E6%8D%95%E8%8E%B7%EF%BC%9A%E5%B7%B2%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3ECoreSight%20%E8%B0%83%E8%AF%95%20ROM%20%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%9A%3CBR%20%2F%3E%20RBASE%20E00FE000%EF%BC%9ACID%20B105100D%20PID%200000080000%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3CBR%20%2F%3E%20ROM%201%20E00FF000%EF%BC%9ACID%20B105100D%20PID%2004000BB4C9%20ROM%EF%BC%88%E7%B1%BB%E5%9E%8B%200x1%EF%BC%89%3CBR%20%2F%3E%20ROM%202%20E000E000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0001000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0002000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20%E7%B1%BB%E5%9E%8B%200x0%20%E6%9D%82%E9%A1%B9%20-%20%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3EROM%202%20E0000000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E7%B1%BB%E5%9E%8B%200x43%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%80%BB%E7%BA%BF%3CBR%20%2F%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20%E7%B1%BB%E5%9E%8B%200x13%20%E8%B7%9F%E8%B8%AA%E6%BA%90%20-%20%E6%A0%B8%E5%BF%83%3CBR%20%2F%3EROM%202%20E0042000%EF%BC%9ACID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E7%B1%BB%E5%9E%8B%200x14%20%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%20-%20%E8%A7%A6%E5%8F%91%E5%99%A8%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%B5%E4%BC%91%E5%85%8B%E6%B2%BB%E7%96%97%3CBR%20%2F%3EROM%201%20E0045000%EF%BC%9ACID%20B105900D%20PID%2004004BB907%20CSt%20ETB%20%E7%B1%BB%E5%9E%8B%200x21%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20ETB%3CBR%20%2F%3E%20ROM%201%20E0045000%EF%BC%9ACID%20B105900D%20PID%2004004BB907%20CSt%20ETB%20%E7%B1%BB%E5%9E%8B%200x21%20%E8%B7%9F%E8%B8%AA%E6%8E%A5%E6%94%B6%E5%99%A8%20-%20ETB%3CBR%20%2F%3E%20ROM%201%20E0044000%EF%BC%9ACID%20B105900D%20PID%2004002BB909%20CSt%20%E7%B1%BB%E5%9E%8B%200x22%20%E8%B7%9F%E8%B8%AA%E9%93%BE%E6%8E%A5%20-%20%E8%BF%87%E6%BB%A4%E5%99%A8%3CBR%20%2F%3EROM%201%20E0046000%EF%BC%9ACID%20B105900D%20PID%2004005BB906%20CSt%20%E7%B1%BB%E5%9E%8B%200x14%20%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%20-%20%E8%A7%A6%E5%8F%91%E5%99%A8%EF%BC%8C%E4%BE%8B%E5%A6%82%E7%94%B5%E4%BC%91%E5%85%8B%E6%B2%BB%E7%96%97%3CBR%20%2F%3E%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%9APN7642%3CBR%20%2F%3E%20DAP%20%E6%AD%A5%E5%B9%85%E4%B8%BA%201024%20%E5%AD%97%E8%8A%82%EF%BC%88256%20%E4%B8%AA%E5%AD%97%EF%BC%89%3CBR%20%2F%3E%E5%B7%B2%E6%A3%80%E6%9F%A5%20v.2%20%E7%89%87%E4%B8%8A%E9%97%AA%E5%AD%98%20PN7642.cfx%3CBR%20%2F%3E%E5%9B%BE%E7%89%87%E2%80%9CPN7642%20Flash%202024%20%E5%B9%B4%204%20%E6%9C%88%205%20%E6%97%A5%2018%3A22%3A54%E2%80%9D%3CBR%20%2F%3E%20%EF%BC%8865%EF%BC%89%E8%8A%AF%E7%89%87%E8%AE%BE%E7%BD%AE%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%E5%B7%B2%E8%BF%9E%E6%8E%A5%EF%BC%9Awas_reset%3Dfalse%E3%80%82was_stopped%3Dtrue%3CBR%20%2F%3E%E7%AD%89%E5%BE%85%20telnet%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%AB%AF%E5%8F%A3%203330%20...%3CBR%20%2F%3E%E5%B7%B2%E5%90%AF%E7%94%A8%20GDB%20%E4%B8%8D%E5%81%9C%E6%AD%A2%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3EFreeRTOS%20%E5%A0%86%E6%A0%88%E5%9B%9E%E6%BA%AF%E5%B7%B2%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20PN7642.cfx%3CBR%20%2F%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E6%94%AF%E6%8C%81%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%EF%BC%88180KB%20%3D%20360*512%EF%BC%8C%E4%BD%8D%E4%BA%8E%200x208000%EF%BC%89%3CBR%20%2F%3E%E5%90%91%20Flash%20%E4%B8%AD%E7%9A%84%E5%9C%B0%E5%9D%80%200x00208000%20%E5%86%99%E5%85%A5%20150608%20%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%E5%86%99%E5%85%A5%E6%89%87%E5%8C%BA%EF%BC%9A0%EF%BC%8C%E6%9C%AA%E6%9B%B4%E6%94%B9%E6%89%87%E5%8C%BA%EF%BC%9A295%EF%BC%8C%E6%80%BB%E8%AE%A1%EF%BC%9A295%3CBR%20%2F%3E%E5%9C%A8%20155%20%E6%AF%AB%E7%A7%92%E5%86%85%E6%93%A6%E9%99%A4%2F%E5%86%99%E5%85%A5%E6%89%87%E5%8C%BA%200-294%EF%BC%8C%E5%85%B1%20150608%20%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20PN7642.cfx%3CBR%20%2F%3EFlash%E5%86%99%E5%85%A5%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%E6%89%93%E5%BC%80%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20PN7642.cfx%EF%BC%88%E5%B7%B2%E9%A9%BB%E7%95%99%EF%BC%89%3CBR%20%2F%3E%E5%B7%B2%E8%AF%B7%E6%B1%82%20VECTRESET%EF%BC%8C%E4%BD%86%20ARMv8-M%20CPU%20%E4%B8%8D%E6%94%AF%E6%8C%81%E3%80%82%E6%94%B9%E7%94%A8%20SOFTRESET%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E8%BD%AF%E5%A4%8D%E4%BD%8D%E8%BF%90%E8%A1%8C%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%E6%94%AF%E6%8C%81%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%EF%BC%88180KB%20%3D%20360*512%EF%BC%8C%E4%BD%8D%E4%BA%8E%200x208000%EF%BC%89%3CBR%20%2F%3E%E5%90%91%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E5%9C%B0%E5%9D%80%200x00233000%20%E5%86%99%E5%85%A5%201540%20%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%E5%86%99%E5%85%A5%E7%9A%84%E6%89%87%E5%8C%BA%EF%BC%9A0%EF%BC%8C%E6%9C%AA%E6%9B%B4%E6%94%B9%E7%9A%84%E6%89%87%E5%8C%BA%EF%BC%9A4%EF%BC%8C%E6%80%BB%E8%AE%A1%EF%BC%9A4%3CBR%20%2F%3E%E5%9C%A8%2026%20%E6%AF%AB%E7%A7%92%E5%86%85%E6%93%A6%E9%99%A4%2F%E5%86%99%E5%85%A5%E6%89%87%E5%8C%BA%20344-347%EF%BC%8C%E5%85%B1%201540%20%E5%AD%97%E8%8A%82%3CBR%20%2F%3E%E5%85%B3%E9%97%AD%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20PN7642.cfx%3CBR%20%2F%3EFlash%E5%86%99%E5%85%A5%E5%AE%8C%E6%88%90%3CBR%20%2F%3EFlash%20%E7%A8%8B%E5%BA%8F%E6%91%98%E8%A6%81%EF%BC%9A0.18%20%E7%A7%92%E5%86%85%20152146%20%E5%AD%97%E8%8A%82%EF%BC%88816.37%20KB%2F%E7%A7%92%EF%BC%89%3CBR%20%2F%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E8%84%9A%E6%9C%AC%EF%BC%9APN7642_reset.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20PN7642%20%E9%87%8D%E7%BD%AE%E8%84%9A%E6%9C%AC%3CBR%20%2F%3E%E9%87%8D%E7%BD%AE%E5%89%8D%E7%9A%84%E6%96%AD%E7%82%B9%3CBR%20%2F%3EFPB%E6%95%B0%E9%87%8F%EF%BC%9A8%3CBR%20%2F%3E%20FPB%3A0%20COMP%EF%BC%9A0x00208131%EF%BC%880x00208130%EF%BC%89%3CBR%20%2F%3E%20FPB%3A1%20COMP%EF%BC%9A0x20003003%EF%BC%880x20003002%EF%BC%89%3CBR%20%2F%3E%20FPB%3A2%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A3%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A4%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A5%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A6%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%20FPB%3A7%20COMP%EF%BC%9A0x00000000%EF%BC%88%E6%9C%AA%E4%BD%BF%E7%94%A8%EF%BC%89%3CBR%20%2F%3E%E5%8F%91%E9%80%81%20CMSYSRESETREQ%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E7%BA%BF%E8%B7%AF%E7%A1%AE%E8%AE%A4%E6%95%85%E9%9A%9C%20-%20%E7%9B%AE%E6%A0%87%E5%B7%B2%E8%BF%9E%E6%8E%A5%EF%BC%9F%3CBR%20%2F%3EDpID%20%3D%206BA02477%3CBR%20%2F%3E%20CMSYSRESETREQ%20%E4%B9%8B%E5%90%8E%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3ER0%EF%BC%9A00000000%3CBR%20%2F%3E%20R1%EF%BC%9A00208130%3CBR%20%2F%3E%20R2%EF%BC%9A00208130%3CBR%20%2F%3E%20R3%EF%BC%9A00208130%3CBR%20%2F%3E%20R4%EF%BC%9A00208130%3CBR%20%2F%3E%20R5%20%3A%2000208130%3CBR%20%2F%3E%20R6%EF%BC%9A00208130%3CBR%20%2F%3E%20R7%EF%BC%9A00208130%3CBR%20%2F%3E%20R8%EF%BC%9A00208130%3CBR%20%2F%3E%20R9%20%3A%2000208130%3CBR%20%2F%3E%20R10%EF%BC%9A00208130%3CBR%20%2F%3E%20R11%20%3A%2000208130%3CBR%20%2F%3E%20R12%20%3A%2000208130%3CBR%20%2F%3E%E6%9C%8D%E5%8A%A1%E5%8F%B7%EF%BC%9A20008000%3CBR%20%2F%3E%20LR%20%EF%BC%9A%20FEFFFFFF%3CBR%20%2F%3E%E7%94%B5%E8%84%91%EF%BC%9A00208130%3CBR%20%2F%3E%E5%8E%8B%E6%8E%A7%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A01000000%3CBR%20%2F%3E%20MSP%20%EF%BC%9A20008000%3CBR%20%2F%3E%20PSP%20%EF%BC%9A00000000%3CBR%20%2F%3E%20CFBP%EF%BC%9A00000000%3CBR%20%2F%3E%20DpID%20%3D%206BA02477%3CBR%20%2F%3E%20PN76_Sys_Hal_SoftReset(1)%E4%B9%8B%E5%90%8E%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x05%EF%BC%89%3CBR%20%2F%3E%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20%E8%84%9A%E6%9C%AC%E7%BB%93%E6%9D%9F%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%20-%20%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%88%96%E9%81%B5%E5%BE%AA%E5%A4%8D%E4%BD%8D%E8%AF%B7%E6%B1%82%20-%20%E9%87%8D%E6%96%B0%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E5%A4%B1%E8%B4%A5%20-%20rc%20Nn(05)%E3%80%82DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E7%BA%BF%E8%B7%AF%20ACK%20%E6%95%85%E9%9A%9C%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%20-%20%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%88%96%E9%81%B5%E5%BE%AA%E5%A4%8D%E4%BD%8D%E8%AF%B7%E6%B1%82%20-%20%E9%87%8D%E6%96%B0%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E5%A4%B1%E8%B4%A5%20-%20rc%20Nn(05)%E3%80%82DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E7%BA%BF%E8%B7%AF%20ACK%20%E6%95%85%E9%9A%9C%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%20-%20%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%88%96%E9%81%B5%E5%BE%AA%E5%A4%8D%E4%BD%8D%E8%AF%B7%E6%B1%82%20-%20%E9%87%8D%E6%96%B0%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E5%A4%B1%E8%B4%A5%20-%20rc%20Nn(05)%E3%80%82DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E7%BA%BF%E8%B7%AF%20ACK%20%E6%95%85%E9%9A%9C%3CBR%20%2F%3E%E9%87%8D%E7%BD%AE%E5%90%8E%E8%AF%BB%E5%8F%96%E6%A0%B8%E5%BF%83%E5%AF%84%E5%AD%98%E5%99%A8%E5%A4%B1%E8%B4%A5%20-%20Ep(08)%E3%80%82%E7%9B%AE%E6%A0%87%E8%BF%90%E8%A1%8C%E6%97%B6%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E6%A0%B8%E5%BF%83%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CBR%20%2F%3E%E6%8F%90%E4%BA%A4%20Flash%20%E5%86%99%E5%85%A5%E6%97%B6%E7%9A%84%E7%9B%AE%E6%A0%87%E9%94%99%E8%AF%AF%EF%BC%9AEp(08)%E3%80%82%E7%9B%AE%E6%A0%87%E8%BF%90%E8%A1%8C%E6%97%B6%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E6%A0%B8%E5%BF%83%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3CBR%20%2F%3EGDB%20stub%EF%BC%88C%3A%5Cnxp%5CLinkServer_1.5.30%5Cbinaries%5Ccrt_emu_cm_redlink%EF%BC%89%E7%BB%88%E6%AD%A2%20-%20GDB%20%E5%8D%8F%E8%AE%AE%E9%97%AE%E9%A2%98%EF%BC%9A%E7%AE%A1%E9%81%93%E5%B7%B2%E8%A2%AB%20GDB%20%E5%85%B3%E9%97%AD%E3%80%82%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%20-%20%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%88%96%E9%81%B5%E5%BE%AA%E5%A4%8D%E4%BD%8D%E8%AF%B7%E6%B1%82%20-%20%E9%87%8D%E6%96%B0%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E5%A4%B1%E8%B4%A5%20-%20rc%20Nn(05)%E3%80%82DAP%20%E8%AE%BF%E9%97%AE%E4%B8%AD%E7%9A%84%E7%BA%BF%E8%B7%AF%20ACK%20%E6%95%85%E9%9A%9C%3C%2FNONE%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1973470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APN7642%20C101%20%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E8%BF%9B%E5%85%A5%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%EF%BC%81%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APN7642%20C101%20%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E8%BF%9B%E5%85%A5%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Artem%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E6%98%AF%EF%BC%9A%E7%9B%AE%E6%A0%87%E6%A0%87%E8%AE%B0%E4%B8%BA%E4%B8%8D%E5%8F%AF%E8%B0%83%E8%AF%95%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%8C%E5%85%B6%E4%B8%AD%E8%AE%A8%E8%AE%BA%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPCXpresso-IDE-FAQs%2F02-Failed-on-connect-Ep-01-Target-marked-as-not-debuggable%2Ftd-p%2F467619%22%20target%3D%22_blank%22%3E02%EF%BC%9A%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%9AEp(01)%E3%80%82%E7%9B%AE%E6%A0%87%E6%A0%87%E8%AE%B0%E4%B8%BA%E4%B8%8D%E5%8F%AF%E8%B0%83%E8%AF%95%20-%20NXP%20%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%85%B6%E4%BB%96%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%EF%BC%8C%E4%BE%8B%E5%A6%82%20MCU%20link%20pro%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1970296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APN7642%20C101%20%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E8%BF%9B%E5%85%A5%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E6%9B%B4%E6%96%B0%E4%BA%86%E6%88%91%E7%9A%84%20MCU%20Link%EF%BC%88%E4%B8%8D%E6%98%AF%E4%B8%93%E4%B8%9A%E7%89%88%EF%BC%89%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%8C%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%E5%AE%83%E5%BE%88%E6%9C%89%E7%94%A8%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E6%B2%A1%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%E5%8F%A6%E4%B8%80%E4%B8%AA%E4%B8%8D%E5%A5%BD%E7%9A%84%E7%97%87%E7%8A%B6%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E4%BB%A5%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E9%85%8D%E7%BD%AE%E8%B0%83%E8%AF%95%E5%99%A8%E6%97%B6%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22artem_pn_0-1728500285678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22artem_pn_0-1728500285678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303819iFD267B0DAC305A49%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22artem_pn_0-1728500285678.png%22%20alt%3D%22artem_pn_0-1728500285678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%B9%B6%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%E8%B0%83%E8%AF%95%E5%BA%8F%E5%88%97%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E6%AD%A4%E6%B6%88%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22artem_pn_1-1728500579387.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22artem_pn_1-1728500579387.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303822iEE0FD2796CEEA122%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22artem_pn_1-1728500579387.png%22%20alt%3D%22artem_pn_1-1728500579387.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E7%9F%A5%E9%81%93%E6%9C%89%E4%BB%80%E4%B9%88%E5%8F%AF%E8%83%BD%E7%9A%84%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E8%87%B4%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1969533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9APN7642%20C101%20%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E8%BF%9B%E5%85%A5%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%20MCU%20Link%20pro%20%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E6%9B%B4%E6%96%B0%20MCU%20LINK%20pro%20%E7%9A%84%E5%9B%BA%E4%BB%B6%E5%B9%B6%E9%87%8D%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-mcu-link-pro%3AGS-MCU-LINK-PRO%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMCU-Link%20Pro%20%E5%85%A5%E9%97%A8%20%7C%20NXP%20%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegads%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E
