PN7642 C101 Debug mode entering error
artem_pn
Hello!
I`m using PN7642EV/C101. On my custom board (I haven`t found DevKit for this version of IC) I can not enter debug mode. I`m using MCU Link to load and debug FW. During the connection sequence I have next log:
Reconnected to existing LinkServer process.
============= SCRIPT: PN7642_connect.scp =============
PN7642 Connect Script
Connecting to Probe Index = 1
This probe = 1
This TAP = 0
This core = 0
DpID = 6BA02477
Breakpoints before reset
Number of FPBs: 8
FPB:0 COMP: 0x00208131 (0x00208130)
FPB:1 COMP: 0x20003003 (0x20003002)
FPB:2 COMP: 0x00000000 (not in use)
FPB:3 COMP: 0x00000000 (not in use)
FPB:4 COMP: 0x00000000 (not in use)
FPB:5 COMP: 0x00000000 (not in use)
FPB:6 COMP: 0x00000000 (not in use)
FPB:7 COMP: 0x00000000 (not in use)
Sending CMSYSRESETREQ
Error: Wire Ack Fault - target connected?
DpID = 6BA02477
Registers after reset
R0 : 00000000
R1 : 00208130
R2 : 00208130
R3 : 00208130
R4 : 00208130
R5 : 00208130
R6 : 00208130
R7 : 00208130
R8 : 00208130
R9 : 00208130
R10 : 00208130
R11 : 00208130
R12 : 00208130
SP : 20008000
LR : FEFFFFFF
PC : 00208130
PSR : 01000000
MSP : 20008000
PSP : 00000000
CFBP: 00000000
============= END SCRIPT =============================
Probe Firmware: MCU-LINK r0FF CMSIS-DAP V0.078 (NXP Semiconductors)
Serial Number: KJKL4QM3ADBKP
VID:PID: 1FC9:0143
USB Path: \\?\hid#vid_1fc9&pid_0143&mi_00#7&1db5e7dc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
Using memory from core 0 after searching for a good core
debug interface type = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
processor type = Cortex-M33 (CPU ID 00000D21) on DAP AP 0
number of h/w breakpoints = 8
number of flash patches = 0
number of h/w watchpoints = 4
Probe(0): Connected&Reset. DpID: 6BA02477. CpuID: 00000D21. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FE000: CID B105100D PID 0000080000 ROM (type 0x1)
ROM 1 E00FF000: CID B105100D PID 04000BB4C9 ROM (type 0x1)
ROM 2 E000E000: CID B105900D PID 04000BBD21 CSt ARM ARMv8-M type 0x0 Misc - Undefined
ROM 2 E0001000: CID B105900D PID 04000BBD21 CSt ARM DWTv2 type 0x0 Misc - Undefined
ROM 2 E0002000: CID B105900D PID 04000BBD21 CSt ARM FPBv2 type 0x0 Misc - Undefined
ROM 2 E0000000: CID B105900D PID 04000BBD21 CSt ARM ITMv2 type 0x43 Trace Source - Bus
ROM 2 E0041000: CID B105900D PID 04002BBD21 CSt ARM ETMv4.0 type 0x13 Trace Source - Core
ROM 2 E0042000: CID B105900D PID 04000BBD21 CSt ARM CTIv2 type 0x14 Debug Control - Trigger, e.g. ECT
ROM 1 E0045000: CID B105900D PID 04004BB907 CSt ETB type 0x21 Trace Sink - ETB
ROM 1 E0044000: CID B105900D PID 04002BB909 CSt type 0x22 Trace Link - Filter
ROM 1 E0046000: CID B105900D PID 04005BB906 CSt type 0x14 Debug Control - Trigger, e.g. ECT
NXP: PN7642
DAP stride is 1024 bytes (256 words)
Inspected v.2 On-chip Flash Memory PN7642.cfx
Image 'PN7642 Flash Apr 5 2024 18:22:54'
( 65) Chip Setup Complete
Connected: was_reset=false. was_stopped=true
Awaiting telnet connection to port 3330 ...
GDB nonstop mode enabled
FreeRTOS stack backtrace is disabled
Opening flash driver PN7642.cfx
VECTRESET requested, but not supported on ARMv8-M CPUs. Using SOFTRESET instead.
Using SOFT reset to run the flash driver
Flash device supported (180KB = 360*512 at 0x208000)
Writing 150608 bytes to address 0x00208000 in Flash
Sectors written: 0, unchanged: 295, total: 295
Erased/Wrote sector 0-294 with 150608 bytes in 155msec
Closing flash driver PN7642.cfx
Flash Write Done
Opening flash driver PN7642.cfx (already resident)
Writing 1540 bytes to address 0x00233000 in Flash
Sectors written: 0, unchanged: 4, total: 4
Erased/Wrote sector 344-347 with 1540 bytes in 26msec
Flash Write Done
Flash Program Summary: 152146 bytes in 0.18 seconds (816.37 KB/sec)
============= SCRIPT: PN7642_reset.scp =============
PN7642 Reset Script
Number of FPBs: 8
DpID = 6BA02477
Registers after CMSYSRESETREQ
R0 : 00000000
R1 : 00208130
R2 : 00208130
R3 : 00208130
R4 : 00208130
R5 : 00208130
R6 : 00208130
R7 : 00208130
R8 : 00208130
R9 : 00208130
R10 : 00208130
R11 : 00208130
R12 : 00208130
SP : 20008000
LR : FEFFFFFF
PC : 00208130
PSR : 01000000
MSP : 20008000
PSP : 00000000
CFBP: 00000000
DpID = 6BA02477
After PN76_Sys_Hal_SoftReset(1)
Error: Could not read registers (0x05)
state - running or following reset request - re-read of state failed - rc Nn(05). Wire ACK Fault in DAP access
following reset read of core registers failed - Ep(08). Cannot access core regs when target running.
Target error from Commit Flash write: Ep(08). Cannot access core regs when target running.
GDB stub (C:\nxp\LinkServer_1.5.30\binaries\crt_emu_cm_redlink) terminating - GDB protocol problem: Pipe has been closed by GDB.
What can be the reason of such behavior?
Thanks in advance!
Artem
danielchen
Hi Artem:
The error message is : Target marked as not debuggable.    I would suggest you refer to below link,  this issue was discussed.
02: Failed on connect: Ep(01). Target marked as not debuggable - NXP Community
you can try other debug probe, like MCU link pro.
artem_pn
Hi Daniel, thank you for response. I updated version of my MCU Link (not pro), anyway it is useful but unfortunately didn`t help. Another bad symptom is that when I configure debugger in such a way
and trying to to run debug sequence, I got this message:
Is there something you know can be the possible reason?
Thanks in advance!
Artem
danielchen
Hi Artem:
artem_pn
Thank you, Daniel!
Artem
danielchen
Are you using MCU Link pro?
I would suggest you update the firmware for the MCU LINK pro and try it again.
Getting Started with the MCU-Link Pro | NXP Semiconductors
Regads
%3CLINGO-SUB%20id%3D%22lingo-sub-1969238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7642%20C101%20Debug%20mode%20entering%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello!%26nbsp%3B%3C%2FP%3E%3CP%3EI%60m%20using%20PN7642EV%2FC101.%20On%20my%20custom%20board%20(I%20haven%60t%20found%20DevKit%20for%20this%20version%20of%20IC)%20I%20can%20not%20enter%20debug%20mode.%20I%60m%20using%20MCU%20Link%20to%20load%20and%20debug%20FW.%20During%20the%20connection%20sequence%20I%20have%20next%20log%3A%26nbsp%3B%3C%2FP%3E%3CP%3EReconnected%20to%20existing%20LinkServer%20process.%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20PN7642_connect.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EPN7642%20Connect%20Script%3CBR%20%2F%3EConnecting%20to%20Probe%20Index%20%3D%201%3CBR%20%2F%3EThis%20probe%20%3D%201%3CBR%20%2F%3EThis%20TAP%20%3D%200%3CBR%20%2F%3EThis%20core%20%3D%200%3CBR%20%2F%3EDpID%20%3D%206BA02477%3CBR%20%2F%3EBreakpoints%20before%20reset%3CBR%20%2F%3ENumber%20of%20FPBs%3A%208%3CBR%20%2F%3EFPB%3A0%20COMP%3A%200x00208131%20(0x00208130)%3CBR%20%2F%3EFPB%3A1%20COMP%3A%200x20003003%20(0x20003002)%3CBR%20%2F%3EFPB%3A2%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A3%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A4%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A5%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A6%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A7%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3ESending%20CMSYSRESETREQ%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EDpID%20%3D%206BA02477%3CBR%20%2F%3ERegisters%20after%20reset%3CBR%20%2F%3ER0%20%3A%2000000000%3CBR%20%2F%3ER1%20%3A%2000208130%3CBR%20%2F%3ER2%20%3A%2000208130%3CBR%20%2F%3ER3%20%3A%2000208130%3CBR%20%2F%3ER4%20%3A%2000208130%3CBR%20%2F%3ER5%20%3A%2000208130%3CBR%20%2F%3ER6%20%3A%2000208130%3CBR%20%2F%3ER7%20%3A%2000208130%3CBR%20%2F%3ER8%20%3A%2000208130%3CBR%20%2F%3ER9%20%3A%2000208130%3CBR%20%2F%3ER10%20%3A%2000208130%3CBR%20%2F%3ER11%20%3A%2000208130%3CBR%20%2F%3ER12%20%3A%2000208130%3CBR%20%2F%3ESP%20%3A%2020008000%3CBR%20%2F%3ELR%20%3A%20FEFFFFFF%3CBR%20%2F%3EPC%20%3A%2000208130%3CBR%20%2F%3EPSR%20%3A%2001000000%3CBR%20%2F%3EMSP%20%3A%2020008000%3CBR%20%2F%3EPSP%20%3A%2000000000%3CBR%20%2F%3ECFBP%3A%2000000000%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EProbe%20Firmware%3A%20MCU-LINK%20r0FF%20CMSIS-DAP%20V0.078%20(NXP%20Semiconductors)%3CBR%20%2F%3ESerial%20Number%3A%20KJKL4QM3ADBKP%3CBR%20%2F%3EVID%3APID%3A%201FC9%3A0143%3CBR%20%2F%3EUSB%20Path%3A%20%5C%5C%3F%5Chid%23vid_1fc9%26amp%3Bpid_0143%26amp%3Bmi_00%237%26amp%3B1db5e7dc%26amp%3B0%26amp%3B0000%23%7B4d1e55b2-f16f-11cf-88cb-001111000030%7D%3CBR%20%2F%3EUsing%20memory%20from%20core%200%20after%20searching%20for%20a%20good%20core%3CBR%20%2F%3Edebug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%200%3CBR%20%2F%3Eprocessor%20type%20%3D%20Cortex-M33%20(CPU%20ID%2000000D21)%20on%20DAP%20AP%200%3CBR%20%2F%3Enumber%20of%20h%2Fw%20breakpoints%20%3D%208%3CBR%20%2F%3Enumber%20of%20flash%20patches%20%3D%200%3CBR%20%2F%3Enumber%20of%20h%2Fw%20watchpoints%20%3D%204%3CBR%20%2F%3EProbe(0)%3A%20Connected%26amp%3BReset.%20DpID%3A%206BA02477.%20CpuID%3A%2000000D21.%20Info%3A%20%3CNONE%3E%3CBR%20%2F%3EDebug%20protocol%3A%20SWD.%20RTCK%3A%20Disabled.%20Vector%20catch%3A%20Disabled.%3CBR%20%2F%3EContent%20of%20CoreSight%20Debug%20ROM(s)%3A%3CBR%20%2F%3ERBASE%20E00FE000%3A%20CID%20B105100D%20PID%200000080000%20ROM%20(type%200x1)%3CBR%20%2F%3EROM%201%20E00FF000%3A%20CID%20B105100D%20PID%2004000BB4C9%20ROM%20(type%200x1)%3CBR%20%2F%3EROM%202%20E000E000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20type%200x0%20Misc%20-%20Undefined%3CBR%20%2F%3EROM%202%20E0001000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20type%200x0%20Misc%20-%20Undefined%3CBR%20%2F%3EROM%202%20E0002000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20type%200x0%20Misc%20-%20Undefined%3CBR%20%2F%3EROM%202%20E0000000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20type%200x43%20Trace%20Source%20-%20Bus%3CBR%20%2F%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20type%200x13%20Trace%20Source%20-%20Core%3CBR%20%2F%3EROM%202%20E0042000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20type%200x14%20Debug%20Control%20-%20Trigger%2C%20e.g.%20ECT%3CBR%20%2F%3EROM%201%20E0045000%3A%20CID%20B105900D%20PID%2004004BB907%20CSt%20ETB%20type%200x21%20Trace%20Sink%20-%20ETB%3CBR%20%2F%3EROM%201%20E0045000%3A%20CID%20B105900D%20PID%2004004BB907%20CSt%20ETB%20type%200x21%20Trace%20Sink%20-%20ETB%3CBR%20%2F%3EROM%201%20E0044000%3A%20CID%20B105900D%20PID%2004002BB909%20CSt%20type%200x22%20Trace%20Link%20-%20Filter%3CBR%20%2F%3EROM%201%20E0046000%3A%20CID%20B105900D%20PID%2004005BB906%20CSt%20type%200x14%20Debug%20Control%20-%20Trigger%2C%20e.g.%20ECT%3CBR%20%2F%3ENXP%3A%20PN7642%3CBR%20%2F%3EDAP%20stride%20is%201024%20bytes%20(256%20words)%3CBR%20%2F%3EInspected%20v.2%20On-chip%20Flash%20Memory%20PN7642.cfx%3CBR%20%2F%3EImage%20'PN7642%20Flash%20Apr%205%202024%2018%3A22%3A54'%3CBR%20%2F%3E(%2065)%20Chip%20Setup%20Complete%3CBR%20%2F%3EConnected%3A%20was_reset%3Dfalse.%20was_stopped%3Dtrue%3CBR%20%2F%3EAwaiting%20telnet%20connection%20to%20port%203330%20...%3CBR%20%2F%3EGDB%20nonstop%20mode%20enabled%3CBR%20%2F%3EFreeRTOS%20stack%20backtrace%20is%20disabled%3CBR%20%2F%3EOpening%20flash%20driver%20PN7642.cfx%3CBR%20%2F%3EVECTRESET%20requested%2C%20but%20not%20supported%20on%20ARMv8-M%20CPUs.%20Using%20SOFTRESET%20instead.%3CBR%20%2F%3EUsing%20SOFT%20reset%20to%20run%20the%20flash%20driver%3CBR%20%2F%3EFlash%20device%20supported%20(180KB%20%3D%20360*512%20at%200x208000)%3CBR%20%2F%3EWriting%20150608%20bytes%20to%20address%200x00208000%20in%20Flash%3CBR%20%2F%3ESectors%20written%3A%200%2C%20unchanged%3A%20295%2C%20total%3A%20295%3CBR%20%2F%3EErased%2FWrote%20sector%200-294%20with%20150608%20bytes%20in%20155msec%3CBR%20%2F%3EClosing%20flash%20driver%20PN7642.cfx%3CBR%20%2F%3EFlash%20Write%20Done%3CBR%20%2F%3EOpening%20flash%20driver%20PN7642.cfx%20(already%20resident)%3CBR%20%2F%3EVECTRESET%20requested%2C%20but%20not%20supported%20on%20ARMv8-M%20CPUs.%20Using%20SOFTRESET%20instead.%3CBR%20%2F%3EUsing%20SOFT%20reset%20to%20run%20the%20flash%20driver%3CBR%20%2F%3EFlash%20device%20supported%20(180KB%20%3D%20360*512%20at%200x208000)%3CBR%20%2F%3EWriting%201540%20bytes%20to%20address%200x00233000%20in%20Flash%3CBR%20%2F%3ESectors%20written%3A%200%2C%20unchanged%3A%204%2C%20total%3A%204%3CBR%20%2F%3EErased%2FWrote%20sector%20344-347%20with%201540%20bytes%20in%2026msec%3CBR%20%2F%3EClosing%20flash%20driver%20PN7642.cfx%3CBR%20%2F%3EFlash%20Write%20Done%3CBR%20%2F%3EFlash%20Program%20Summary%3A%20152146%20bytes%20in%200.18%20seconds%20(816.37%20KB%2Fsec)%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20PN7642_reset.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EPN7642%20Reset%20Script%3CBR%20%2F%3EBreakpoints%20before%20reset%3CBR%20%2F%3ENumber%20of%20FPBs%3A%208%3CBR%20%2F%3EFPB%3A0%20COMP%3A%200x00208131%20(0x00208130)%3CBR%20%2F%3EFPB%3A1%20COMP%3A%200x20003003%20(0x20003002)%3CBR%20%2F%3EFPB%3A2%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A3%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A4%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A5%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A6%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3EFPB%3A7%20COMP%3A%200x00000000%20(not%20in%20use)%3CBR%20%2F%3ESending%20CMSYSRESETREQ%3CBR%20%2F%3EError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%3CBR%20%2F%3EDpID%20%3D%206BA02477%3CBR%20%2F%3ERegisters%20after%20CMSYSRESETREQ%3CBR%20%2F%3ER0%20%3A%2000000000%3CBR%20%2F%3ER1%20%3A%2000208130%3CBR%20%2F%3ER2%20%3A%2000208130%3CBR%20%2F%3ER3%20%3A%2000208130%3CBR%20%2F%3ER4%20%3A%2000208130%3CBR%20%2F%3ER5%20%3A%2000208130%3CBR%20%2F%3ER6%20%3A%2000208130%3CBR%20%2F%3ER7%20%3A%2000208130%3CBR%20%2F%3ER8%20%3A%2000208130%3CBR%20%2F%3ER9%20%3A%2000208130%3CBR%20%2F%3ER10%20%3A%2000208130%3CBR%20%2F%3ER11%20%3A%2000208130%3CBR%20%2F%3ER12%20%3A%2000208130%3CBR%20%2F%3ESP%20%3A%2020008000%3CBR%20%2F%3ELR%20%3A%20FEFFFFFF%3CBR%20%2F%3EPC%20%3A%2000208130%3CBR%20%2F%3EPSR%20%3A%2001000000%3CBR%20%2F%3EMSP%20%3A%2020008000%3CBR%20%2F%3EPSP%20%3A%2000000000%3CBR%20%2F%3ECFBP%3A%2000000000%3CBR%20%2F%3EDpID%20%3D%206BA02477%3CBR%20%2F%3EAfter%20PN76_Sys_Hal_SoftReset(1)%3CBR%20%2F%3EError%3A%20Could%20not%20read%20registers%20(0x05)%3CBR%20%2F%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3Estate%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%3CBR%20%2F%3Estate%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%3CBR%20%2F%3Estate%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%3CBR%20%2F%3Efollowing%20reset%20read%20of%20core%20registers%20failed%20-%20Ep(08).%20Cannot%20access%20core%20regs%20when%20target%20running.%3CBR%20%2F%3ETarget%20error%20from%20Commit%20Flash%20write%3A%20Ep(08).%20Cannot%20access%20core%20regs%20when%20target%20running.%3CBR%20%2F%3EGDB%20stub%20(C%3A%5Cnxp%5CLinkServer_1.5.30%5Cbinaries%5Ccrt_emu_cm_redlink)%20terminating%20-%20GDB%20protocol%20problem%3A%20Pipe%20has%20been%20closed%20by%20GDB.%3CBR%20%2F%3Estate%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FNONE%3E%3C%2FP%3E%3CP%3EWhat%20can%20be%20the%20reason%20of%20such%20behavior%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance!%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1973470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7642%20C101%20Debug%20mode%20entering%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%2C%20Daniel!%26nbsp%3B%3C%2FP%3E%3CP%3EBest%20regards%2C%26nbsp%3B%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1971792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7642%20C101%20Debug%20mode%20entering%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1971792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Artem%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20error%20message%20is%20%3A%20Target%20marked%20as%20not%20debuggable.%26nbsp%3B%20%26nbsp%3B%20I%20would%20suggest%20you%20refer%20to%20below%20link%2C%26nbsp%3B%20this%20issue%20was%20discussed.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPCXpresso-IDE-FAQs%2F02-Failed-on-connect-Ep-01-Target-marked-as-not-debuggable%2Ftd-p%2F467619%22%20target%3D%22_blank%22%3E02%3A%20Failed%20on%20connect%3A%20Ep(01).%20Target%20marked%20as%20not%20debuggable%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eyou%20can%20try%20other%20debug%20probe%2C%20like%20MCU%20link%20pro.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1970296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7642%20C101%20Debug%20mode%20entering%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1970296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Daniel%2C%20thank%20you%20for%20response.%20I%20updated%20version%20of%20my%20MCU%20Link%20(not%20pro)%2C%20anyway%20it%20is%20useful%20but%20unfortunately%20didn%60t%20help.%20Another%20bad%20symptom%20is%20that%20when%20I%20configure%20debugger%20in%20such%20a%20way%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22artem_pn_0-1728500285678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22artem_pn_0-1728500285678.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303819iFD267B0DAC305A49%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22artem_pn_0-1728500285678.png%22%20alt%3D%22artem_pn_0-1728500285678.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eand%20trying%20to%20to%20run%20debug%20sequence%2C%20I%20got%20this%20message%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22artem_pn_1-1728500579387.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22artem_pn_1-1728500579387.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F303822iEE0FD2796CEEA122%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22artem_pn_1-1728500579387.png%22%20alt%3D%22artem_pn_1-1728500579387.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIs%20there%20something%20you%20know%20can%20be%20the%20possible%20reason%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance!%26nbsp%3B%3C%2FP%3E%3CP%3EArtem%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1969533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PN7642%20C101%20Debug%20mode%20entering%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1969533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%0A%3CP%3EAre%20you%20using%20MCU%20Link%20pro%3F%3C%2FP%3E%0A%3CP%3EI%20would%20suggest%20you%20update%20the%20firmware%20for%20the%20MCU%20LINK%20pro%20and%20try%20it%20again.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-mcu-link-pro%3AGS-MCU-LINK-PRO%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EGetting%20Started%20with%20the%20MCU-Link%20Pro%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegads%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E
