FRDM-KW40Z Zigbee PRO stack
2,357件の閲覧回数
jooyounhong
I am using FRDM-KW40Z dev board, and trying to implement Zigbee pro stack.
Should I follow the beekit documentation even though it's not referring to our board? If I should, then is it possible to implement beekit with IAR IDE?
Or should I implement it myself with zigbee pro stack documentation on top of MyWirelessApp Demo (FRDM-KW40Z Getting Started tutorial) file?
Thanks.
ラベル(2)
1,917件の閲覧回数
EarlOrlando
Senior Contributor II
The KW40Z/KW20Z codebases do not include ZigBee stack support. They only have IEEE 802.15.4 MAC/PHY libraries.
Also, please take a look into this thread, I think that you will found useful information there.
Re: Router example for KW40Z/KW20Z
Earl.
