QN902x access 2.4GHz RF/phyical layer possible ?
2,016 次查看
tobiasike
is it possible to access the 2.4GHz physical layer interface from the user application/firmware without bluetooth stack ?
are there some application nodes etc. documents  about whats possible when doing so?
best regards.
tobias
标签 (2)
标记 (3)
1 回复
1,751 次查看
EarlOrlando
Senior Contributor II
Hello!
Thank you for your interest in NXP products.
We are happy to support you through our communities, unfortunately we temporarily have a community structure with two parallel systems which has probably not guided you correctly.
Be ensured we are working on fixing the navigation and the offering as soon as we can.
In the meantime, please re-post your question into the monitored space for this product line:
https://nxpcommunity.force.com/community/CommunityForumQuestionList?category=ZigBee
You may find the following page helpful for navigating to the right spaces:
http://www.nxp.com/support/communities:COMMUNITIES
We apologize for the inconvenience,
The NXP Technical Support Team
