Hi, @Lizardkomodo
Actually I haven't resolved all of the errors on my side.
But there are two ways you can try:
1. According to the errors, copy the needed files from SDK directory to where it requests. I believe you have downloaded our SDK from our website and also imported it to MCUXpresso IDE. You can find where is your SDK, unzip it, and find the needed files by searching the name of related files. But as our experience, directly import the whole edgefast bluetooth middleware to another separate demo example will encounter a lot of errors. And to resolve these compile errors might take a lot of your time.
2. Do not directly import the whole middleware, but only import what you need and add requested files.
This way might be a better way for whom isn't very familiar with the whole code structure.
Why don't you use our default Demo example and do some customized based on it?
Actually it has been out our support, to import some middleware to some demo examples. It is customization part of customers.
Christine.
