Android SDK Incomplete response Exception
1,920 次查看
melaghil
Hello team ,
We are encountering the following exception frequently when using #AndroidSDK with #DESFire EV3 8k card
com.nxp.nfclib.exceptions.InvalidResponseLengthException: Incomplete response
at com.nxp.nfclib.desfire.DESFireEV1.readRecords(:2827)
at com.nxp.nfclib.desfire.DESFireEV2.readRecords(:2026)
We would appreciate your assistance with the following:
  1. What are the possible causes or scenarios that could trigger this InvalidResponseLengthException?
  2. How can we properly handle this exception in our application without requiring the card to be formatted?
Thank you for your support.
标记 (1)
1,877 次查看
KaiLi
Hello @melaghil
What did you do to trigger such an exception?
Generally, the standard process for accessing an EV3 card is as follows: Get and Select the existing application ID(AID) and file ID (FID), then authenticate. After successful authentication, you can read and write the data in the file.
1,873 次查看
melaghil
Hello @KaiLi
     1. What did you do to trigger such an exception?
       Trying to read card records
      2. Generally, the standard process for accessing an EV3 card is as follows: Get and Select  the existing application ID(AID) and file ID (FID), then authenticate. After successful
           but now i got this exception after successful authentication
1,840 次查看
KaiLi
Hello @melaghil
Could you share your code with us? Let us check if there is something happens.
