how to modify the parameters of DDR.
1,801 次查看
muaxi8
T4080 custom board uses granular DDR, may I ask where to modify the parameters of DDR.
1,783 次查看
yipingwang
You need to modify board/freescale/t4rdb/ddr.h in u-boot source code.
You could refer to this document for reference.
https://community.nxp.com/t5/Qonverge-Knowledge-Base/DDR-Controller-Configuration-on-LS2085-LS2080-B...
1,749 次查看
muaxi8
How to determine the value of the red box below。
1,730 次查看
yipingwang
If you use CodeWarrior TAP Ethernet connection, please enter IP address of the CodeWarrior TAP.
If you use CodeWarrior TAP USB connection, no need to fill this box.
