How to enable TCL 8.6, Python 2.7.18 and SSHv2 (OpenSSH_7.6p1) in T1040RDB
Suraj_Prakash
   I want to have the additional software features on the T1040rdb which are mentioned below:
         1. TCL 8.6
         2. Python 2.7.18
         3. SSHv2 (OpenSSH_7.6p1)
Please suggest how to enable those features.
yipingwang
Please delete "python-subprocess" in sources/meta-openembedded/meta-oe/recipes-benchmark/libhugetlbfs/libhugetlbfs_git.bb.
Please add the following in sources/poky/meta/recipes-devtools/python/python_2.7.18.b.
RDEPENDS_remove += "python-re python-contextlib python-netclient"
Then run the following command.
$ bitbake libhugetlbfs -c cleansstate
$ bitbake python -c cleansstate
$ bitbake fsl-image-core
yipingwang
I assume that your are using QorIQ Linux SDK 2.0
1. TCL 8.6.4 recipe is integrated in SDK 2.0, you could use it directly.
2. Only python 2.7.9 recipes are integrated in SDK 2.0, if your want to use python 2.7.18, you need to created recipes for version 2.7.18 based on 2.7.9 recipes. You could refer to the attached example.
You could back up folder sources/poky/meta/recipes-devtools/python/ to other place, then extract the attached file to folder sources/poky/meta/recipes-devtools/. You could refer to python_2.7.18.bb file, which is modified based on python_2.7.9.bb.
3. Openssh_7.1p1 recipe is integrated in SDK 2.0, you could download openssh_7.6p1.bb recipe from http://cgit.openembedded.org/openembedded-core/tree/meta/recipes-connectivity/openssh?h=sumo, please save the recipe openssh_7.6p1.bb and content in openssh folder in sources/poky/meta/recipes-connectivity/openssh/ in SDK 2.0.
4. Please add "tcl, python and openssh" in variable IMAGE_INSTALL_append in sources/meta-freescale/recipes-fsl/images/fsl-image-core.bb, then run "bitbake fsl-image-core" to regenerate rootfs filesystem.
Suraj_Prakash
     I got the following error when trying to add the packages.Please suggest the solution
WARNING: Host distribution "Ubuntu-16.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |#######################################################################################################| ETA: 00:00:00
Loaded 3202 entries from dependency cache.
NOTE: Error during finalise of /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh_7.6p1.bb
ERROR: ExpansionError during parsing /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh_7.6p1.bb: Failure expanding variable do_install: ExpansionError: Failure expanding variable do_install, expression was autotools_do_install
if [ "${@bb.utils.filter('DISTRO_FEATURES', 'pam', d)}" ]; then
install -D -m 0644 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/sshd /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/pam.d/sshd
sed -i -e 's:#UsePAM no:UsePAM yes:' /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config
fi
if [ "${@bb.utils.filter('DISTRO_FEATURES', 'x11', d)}" ]; then
sed -i -e 's:#X11Forwarding no:X11Forwarding yes:' /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config
fi
install -d /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/init.d
install -m 0755 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/init /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/init.d/sshd
rm -f /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/usr/bin/slogin /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/usr/share/Ssh.bin
rmdir /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/var/run/sshd /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/var/run /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/var
install -d /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image//etc/default/volatiles
install -m 644 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/volatiles.99_sshd /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image//etc/default/volatiles/99_sshd
install -m 0755 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/openssh-7.6p1/contrib/ssh-copy-id /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/usr/bin
# Create config files for read-only rootfs
install -d /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh
install -m 644 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config_readonly
sed -i '/HostKey/d' /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config_readonly
echo "HostKey /var/run/ssh/ssh_host_rsa_key" >> /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config_readonly
echo "HostKey /var/run/ssh/ssh_host_dsa_key" >> /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config_readonly
echo "HostKey /var/run/ssh/ssh_host_ecdsa_key" >> /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config_readonly
echo "HostKey /var/run/ssh/ssh_host_ed25519_key" >> /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/etc/ssh/sshd_config_readonly
install -d /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/lib/systemd/system
install -c -m 0644 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/sshd.socket /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/lib/systemd/system
install -c -m 0644 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/sshd@.service /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/lib/systemd/system
install -c -m 0644 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/sshdgenkeys.service /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/lib/systemd/system
sed -i -e 's,@BASE_BINDIR@,/bin,g' \
-e 's,@SBINDIR@,/usr/sbin,g' \
-e 's,@BINDIR@,/usr/bin,g' \
-e 's,@LIBEXECDIR@,/usr/lib64/openssh/openssh,g' \
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/lib/systemd/system/sshd.socket /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/lib/systemd/system/*.service
sed -i -e 's,@LIBEXECDIR@,/usr/lib64/openssh/openssh,g' \
install -D -m 0755 /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/sshd_check_keys /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/image/usr/lib64/openssh/openssh/sshd_check_keys
which triggered exception AttributeError: 'module' object has no attribute 'filter'
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
yipingwang
Please modify the following section in do_install_append in sources/poky/meta/recipes-connectivity/openssh/openssh_7.6p1.bb
install -D -m 0644 ${WORKDIR}/sshd ${D}${sysconfdir}/pam.d/sshd
sed -i -e 's:#UsePAM no:UsePAM yes:' ${D}${sysconfdir}/ssh/sshd_config
fi
sed -i -e 's:#X11Forwarding no:X11Forwarding yes:' ${D}${sysconfdir}/ssh/sshd_config
fi
Modify to:
if [ "${@bb.utils.contains('DISTRO_FEATURES', 'pam', 'pam', '', d)}" = "pam" ]; then
fi
if [ "${@bb.utils.contains('DISTRO_FEATURES', 'x11', 'x11', '', d)}" = "x11" ]; then
fi
Suraj_Prakash
      After following the suggestions given by you i am getting the  errors mentioned here.Please suggest a solution
$bitbake fsl-image-core
Loading cache: 100% |####################################################################################################################################| ETA: 00:00:00
Loaded 6068 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
ERROR: Nothing PROVIDES 'openssl10' (but /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh_7.6p1.bb DEPENDS on or otherwise requires it). Close matches:
openssl
openssh
NOTE: Runtime target 'openssh' is unbuildable, removing...
Missing or unbuildable dependency chain was: ['openssh', 'openssl10']
ERROR: Required build target 'fsl-image-core' has no buildable providers.
Missing or unbuildable dependency chain was: ['fsl-image-core', 'openssh', 'openssl10']
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
yipingwang
In recipe sources/poky/meta/recipes-connectivity/openssh/openssh_7.6p1.bb, please do the following modification.
DEPENDS = "zlib openssl10"
Modify to
DEPENDS = "zlib openssl"
Suraj_Prakash
       Thanks for your timely replies.
I having few more errors as follows. Please suggest a solution. Thanks in advance
WARNING: Unable to get checksum for lib32-openssh SRC_URI entry fix-potential-signed-overflow-in-pointer-arithmatic.patch: file could not be found | ETA: --:--:--
WARNING: Unable to get checksum for lib32-openssh SRC_URI entry sshd_check_keys: file could not be found
WARNING: Unable to get checksum for lib32-openssh SRC_URI entry disable-ciphers-not-supported-by-OpenSSL-DES.patch: file could not be found
WARNING: Unable to get checksum for openssh SRC_URI entry fix-potential-signed-overflow-in-pointer-arithmatic.patch: file could not be found
WARNING: Unable to get checksum for openssh SRC_URI entry sshd_check_keys: file could not be found
WARNING: Unable to get checksum for openssh SRC_URI entry disable-ciphers-not-supported-by-OpenSSL-DES.patch: file could not be found
Parsing recipes: 100% |##################################################################################################################################| Time: 00:00:00
Parsing of 2690 .bb files complete (2689 cached, 1 parsed). 6067 targets, 701 skipped, 0 masked, 0 errors.
Build Configuration:
BB_VERSION = "1.28.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-16.04"
TARGET_SYS = "powerpc64-fsl-linux"
MACHINE = "t1040d4rdb-64b"
DISTRO = "fsl-qoriq"
DISTRO_VERSION = "2.0"
TUNE_FEATURES = "m64 fpu-hard e5500"
TARGET_FPU = "hard"
meta
meta-yocto
meta-yocto-bsp = "HEAD:9a211a4a2c1bfcb292dc97d8dcac149bca9e3f1b"
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-xfce = "HEAD:dc5634968b270dde250690609f0015f881db81f2"
meta-freescale = "HEAD:7facbdb726e2dda0515e084c2066a4b8dd99c6d2"
meta-freescale-internal = "HEAD:4829293f807e35a1111e79763294fc8b98b97810"
meta-freescale-extra = "HEAD:bee911b027e0480b034674d0ddee3fcb06d2e985"
meta-virtualization = "HEAD:042425c1d98bdd7e44a62789bd03b375045266f5"
meta-java = "HEAD:8b776ac68f9af4596be3824152bcf0bc6b67fa1d"
meta-openstack
meta-openstack-aio-deploy
meta-openstack-compute-deploy
meta-openstack-compute-test-config
meta-openstack-controller-deploy
meta-openstack-controller-test-config
meta-openstack-qemu
meta-openstack-swift-deploy
meta-cloud-services = "HEAD:d8bc0d92d0f741e2ea1e6d3d9bc6b7a091d03cfb"
meta-security = "HEAD:f9367e71f923fc7d2fb600208e2b97535ea41777"
meta-nxp-npi-1701 = "jethro-sdk-v2.0-ga-1701:11975eebce9096a3567d00ba2067a2dbd2ed4d5c"
NOTE: Preparing RunQueue
WARNING: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-kernel/linux/linux-qoriq_4.1.bb.do_compile is tainted from a forced run
NOTE: Checking sstate mirror object availability (for 114 objects)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Command Error: exit status: 1 Output:
Applying patch multilib.patch
patching file configure.ac
Hunk #1 succeeded at 736 (offset -22 lines).
patching file Include/pythonrun.h
patching file Lib/distutils/command/install.py
patching file Lib/distutils/sysconfig.py
patching file Lib/pydoc.py
Hunk #1 FAILED at 375.
1 out of 1 hunk FAILED -- rejects in file Lib/pydoc.py
patching file Lib/site.py
Hunk #1 FAILED at 288.
1 out of 1 hunk FAILED -- rejects in file Lib/site.py
patching file Lib/sysconfig.py
patching file Lib/test/test_dl.py
patching file Lib/test/test_site.py
Hunk #1 FAILED at 252.
1 out of 1 hunk FAILED -- rejects in file Lib/test/test_site.py
patching file Lib/trace.py
patching file Makefile.pre.in
Hunk #1 succeeded at 87 (offset -4 lines).
Hunk #2 succeeded at 107 (offset -4 lines).
Hunk #3 succeeded at 598 (offset -48 lines).
Hunk #4 succeeded at 641 with fuzz 1 (offset -54 lines).
patching file Modules/getpath.c
Hunk #1 succeeded at 121 with fuzz 1 (offset 21 lines).
Hunk #2 succeeded at 136 (offset 21 lines).
patching file Python/getplatform.c
patching file Python/sysmodule.c
Patch multilib.patch does not apply (enforce with -f)
ERROR: Function failed: patch_do_patch
ERROR: Logfile of failure stored in: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/python/2.7.9-r1/temp/log.do_patch.16301
ERROR: Task 481 (/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/python/python_2.7.9.bb, do_patch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1102 tasks of which 1092 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 8 WARNING messages shown.
yipingwang
Please refer to the following steps to backup the original python recipe folder and use python.tar.gz in the attachment in my previous reply to replace it.
/backup/b25805/QorIQ-SDK-V2.0-20160527-yocto/sources $ mv poky/meta/recipes-devtools/python .
/backup/b25805/QorIQ-SDK-V2.0-20160527-yocto/sources$ cd poky/meta/recipes-devtools/
/backup/b25805/QorIQ-SDK-V2.0-20160527-yocto/sources$ tar -xzvf ~/python.tar.gz
Suraj_Prakash
      I have followed the procedure which you have sent earlier and i am facing the following errors.
Loading cache: 100% |####################################################################################################################################################| ETA: 00:00:00
Parsing recipes: 100% |##################################################################################################################################################| Time: 00:00:00
Parsing of 2689 .bb files complete (2686 cached, 3 parsed). 6064 targets, 701 skipped, 0 masked, 0 errors.
NOTE: preferred version 2.7.9 of python not available (for item python)
NOTE: versions of python available: 2.7.18
NOTE: preferred version 2.7.9 of python not available (for item python-subprocess)
NOTE: preferred version 2.7.9 of python not available (for item python-datetime)
NOTE: preferred version 2.7.9 of python not available (for item python-json)
NOTE: preferred version 2.7.9 of python not available (for item python-2to3)
NOTE: preferred version 2.7.9 of python not available (for item python-argparse)
NOTE: preferred version 2.7.9 of python not available (for item python-audio)
NOTE: preferred version 2.7.9 of python not available (for item python-bsddb)
NOTE: preferred version 2.7.9 of python not available (for item python-codecs)
NOTE: preferred version 2.7.9 of python not available (for item python-compile)
NOTE: preferred version 2.7.9 of python not available (for item python-compiler)
NOTE: preferred version 2.7.9 of python not available (for item python-compression)
NOTE: preferred version 2.7.9 of python not available (for item python-contextlib)
NOTE: preferred version 2.7.9 of python not available (for item python-core)
NOTE: preferred version 2.7.9 of python not available (for item python-crypt)
NOTE: preferred version 2.7.9 of python not available (for item python-ctypes)
NOTE: preferred version 2.7.9 of python not available (for item python-curses)
NOTE: preferred version 2.7.9 of python not available (for item python-db)
NOTE: preferred version 2.7.9 of python not available (for item python-debugger)
NOTE: preferred version 2.7.9 of python not available (for item python-difflib)
NOTE: preferred version 2.7.9 of python not available (for item python-distutils)
NOTE: preferred version 2.7.9 of python not available (for item python-doctest)
NOTE: preferred version 2.7.9 of python not available (for item python-elementtree)
NOTE: preferred version 2.7.9 of python not available (for item python-email)
NOTE: preferred version 2.7.9 of python not available (for item python-fcntl)
NOTE: preferred version 2.7.9 of python not available (for item python-gdbm)
NOTE: preferred version 2.7.9 of python not available (for item python-hotshot)
NOTE: preferred version 2.7.9 of python not available (for item python-html)
NOTE: preferred version 2.7.9 of python not available (for item python-idle)
NOTE: preferred version 2.7.9 of python not available (for item python-image)
NOTE: preferred version 2.7.9 of python not available (for item python-importlib)
NOTE: preferred version 2.7.9 of python not available (for item python-io)
NOTE: preferred version 2.7.9 of python not available (for item python-lang)
NOTE: preferred version 2.7.9 of python not available (for item python-logging)
NOTE: preferred version 2.7.9 of python not available (for item python-mailbox)
NOTE: preferred version 2.7.9 of python not available (for item python-math)
NOTE: preferred version 2.7.9 of python not available (for item python-mime)
NOTE: preferred version 2.7.9 of python not available (for item python-mmap)
NOTE: preferred version 2.7.9 of python not available (for item python-multiprocessing)
NOTE: preferred version 2.7.9 of python not available (for item python-netclient)
NOTE: preferred version 2.7.9 of python not available (for item python-netserver)
NOTE: preferred version 2.7.9 of python not available (for item python-numbers)
NOTE: preferred version 2.7.9 of python not available (for item python-pickle)
NOTE: preferred version 2.7.9 of python not available (for item python-pkgutil)
NOTE: preferred version 2.7.9 of python not available (for item python-pprint)
NOTE: preferred version 2.7.9 of python not available (for item python-profile)
NOTE: preferred version 2.7.9 of python not available (for item python-pydoc)
NOTE: preferred version 2.7.9 of python not available (for item python-re)
NOTE: preferred version 2.7.9 of python not available (for item python-readline)
NOTE: preferred version 2.7.9 of python not available (for item python-resource)
NOTE: preferred version 2.7.9 of python not available (for item python-robotparser)
NOTE: preferred version 2.7.9 of python not available (for item python-shell)
NOTE: preferred version 2.7.9 of python not available (for item python-smtpd)
NOTE: preferred version 2.7.9 of python not available (for item python-sqlite3)
NOTE: preferred version 2.7.9 of python not available (for item python-sqlite3-tests)
NOTE: preferred version 2.7.9 of python not available (for item python-stringold)
NOTE: preferred version 2.7.9 of python not available (for item python-syslog)
NOTE: preferred version 2.7.9 of python not available (for item python-terminal)
NOTE: preferred version 2.7.9 of python not available (for item python-tests)
NOTE: preferred version 2.7.9 of python not available (for item python-textutils)
NOTE: preferred version 2.7.9 of python not available (for item python-threading)
NOTE: preferred version 2.7.9 of python not available (for item python-tkinter)
NOTE: preferred version 2.7.9 of python not available (for item python-unittest)
NOTE: preferred version 2.7.9 of python not available (for item python-unixadmin)
NOTE: preferred version 2.7.9 of python not available (for item python-xml)
NOTE: preferred version 2.7.9 of python not available (for item python-xmlrpc)
NOTE: preferred version 2.7.9 of python not available (for item python-zlib)
NOTE: preferred version 2.7.9 of python not available (for item python-misc)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-pickle)
NOTE: versions of lib32-python available: 2.7.18
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-crypt)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-shell)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-fcntl)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-stringold)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-logging)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-subprocess)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-math)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-compression)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-textutils)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-io)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-re)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-lang)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-core)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-pprint)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-netclient)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-audio)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-image)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-mime)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-zlib)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-datetime)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-threading)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-sqlite3)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-tkinter)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-codecs)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-distutils)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-difflib)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-contextlib)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-xml)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-netserver)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-ctypes)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-mmap)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-debugger)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-unittest)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-email)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-pkgutil)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-bsddb)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-sqlite3-tests)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-db)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-doctest)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-curses)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-idle)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-misc)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-hotshot)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-json)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-profile)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-pydoc)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-mailbox)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-elementtree)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-gdbm)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-resource)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-compiler)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-xmlrpc)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-html)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-2to3)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-syslog)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-compile)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-tests)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-unixadmin)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-smtpd)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-terminal)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-readline)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-importlib)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-argparse)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-robotparser)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-multiprocessing)
NOTE: preferred version 2.7.9 of lib32-python not available (for item lib32-python-numbers)
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 108 objects)
ERROR: python: md5 data is not matching for file://LICENSE;md5=dff3d00f049545862992d2d097831a13
ERROR: python: The new md5 checksum is 203a6dbc802ee896020a47161e759642
ERROR: python: Check if the license information has changed in /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/python/2.7.18-r1/Python-2.7.18/LICENSE to verify that the LICENSE value "PSFv2" remains valid
ERROR: Licensing Error: LIC_FILES_CHKSUM does not match, please fix
ERROR: Function failed: do_qa_configure
ERROR: Logfile of failure stored in: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/python/2.7.18-r1/temp/log.do_configure.27474
ERROR: Task 485 (/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/python/python_2.7.18.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1501 tasks of which 1478 didn't need to be rerun and 1 failed.
Summary: There were 2 WARNING messages shown.
Summary: There were 5 ERROR messages shown, returning a non-zero exit code.
yipingwang
Please add the following before do_configure_append in sources/poky/meta/recipes-devtools/python/python_2.7.18.bb.
do_qa_configure() {
Suraj_Prakash
I have added the same which you suggested
do_qa_configure() {
do_configure_append() {
rm -f ${S}/Makefile.orig
autoreconf -Wcross --verbose --install --force --exclude=autopoint ../Python-${PV}/Modules/_ctypes/libffi
Even after doing so I am facing the errors given below
Parsing of 2689 .bb files complete (2688 cached, 1 parsed). 6064 targets, 701 skipped, 0 masked, 0 errors.
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 101 objects)
WARNING: Failed to fetch URL file://fix-potential-signed-overflow-in-pointer-arithmatic.patch, attempting MIRRORS if available
ERROR: Fetcher failure: Unable to find file file://fix-potential-signed-overflow-in-pointer-arithmatic.patch anywhere. The paths that were searched were:
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh-7.6p1/fsl-qoriq
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh/fsl-qoriq
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/files/fsl-qoriq
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh-7.6p1/t1040d4rdb-64b
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh/t1040d4rdb-64b
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/files/t1040d4rdb-64b
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh-7.6p1/qoriq
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh/qoriq
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/files/qoriq
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh-7.6p1/qoriq-ppc
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh/qoriq-ppc
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/files/qoriq-ppc
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh-7.6p1/e5500-64b
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh/e5500-64b
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/files/e5500-64b
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh-7.6p1/powerpc64
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh/powerpc64
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/files/powerpc64
/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/downloads
ERROR: Function failed: Fetcher failure for URL: 'file://fix-potential-signed-overflow-in-pointer-arithmatic.patch'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/openssh/7.6p1-r0/temp/log.do_fetch.7530
ERROR: Task 497 (/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-connectivity/openssh/openssh_7.6p1.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1831 tasks of which 1816 didn't need to be rerun and 1 failed.
Summary: There were 3 WARNING messages shown.
yipingwang
You didn't download the patch folder for openssh 7.6.1.
Please go to folder sources/poky/meta/recipes-connectivity/openssh
$ mv openssh openssh_bak
$ tar -xzvf openssh.tar.gz
Suraj_Prakash
        Thanks for the suggestion.It worked but i have few more errors..Please provide a solution.Thanks in advance
Loading cache: 100% |#####################################################################################################################################################| ETA: 00:00:00
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 53 objects)
ERROR: Function failed: py_package_preprocess (log file is located at /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/python/2.7.18-r1/temp/log.do_package.14446)
ERROR: Logfile of failure stored in: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/python/2.7.18-r1/temp/log.do_package.14446
Log data follows:
| DEBUG: Executing python function sstate_task_prefunc
| DEBUG: Python function sstate_task_prefunc finished
| DEBUG: Executing python function do_package
| DEBUG: Executing python function package_get_auto_pr
| DEBUG: Python function package_get_auto_pr finished
| DEBUG: Executing python function perform_packagecopy
| DEBUG: Python function perform_packagecopy finished
| DEBUG: SITE files ['endian-big', 'bit-64', 'powerpc-common', 'common-linux', 'common-glibc', 'powerpc-linux', 'powerpc64-linux', 'common']
| DEBUG: Executing shell function py_package_preprocess
| sed: can't read /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/ppc64e5500-fsl-linux/python/2.7.18-r1/package//usr/lib64/python2.7/_sysconfigdata.py: No such file or directory
| WARNING: exit code 2 from a shell command.
| DEBUG: Python function do_package finished
ERROR: Task 491 (/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/meta/recipes-devtools/python/python_2.7.18.bb, do_package) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1480 tasks of which 1476 didn't need to be rerun and 1 failed.
yipingwang
In the function py_package_preprocess in sources/poky/meta/recipes-devtools/python/python_2.7.18.bb, please do the following modification.
# Remove references to buildmachine paths in target Makefile and _sysconfigdata
sed -i -e 's:--sysroot=${STAGING_DIR_TARGET}::g' -e s:'--with-libtool-sysroot=${STAGING_DIR_TARGET}'::g \
${PKGD}/${libdir}/python${PYTHON_MAJMIN}/config/Makefile \
# ${PKGD}/${libdir}/python${PYTHON_MAJMIN}/_sysconfigdata.py
Modify to:
Suraj_Prakash
    Got stuck with new erros.Log for the same is attached
yipingwang
In your log, the compilation fails at building usdpaa-apps, this have no relationship with recipes which we discussed.
In addition, please add the following in python_2.7.18.bb recipe.
PACKAGES += "${PN}-sed"
FILES_${PN}-sed = "/usr/SEDMELIBLEAF/*"
Suraj_Prakash
Hi sir,
        Even after following your suggestion I have been getting the following errors.Please suggest a solution
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 50 objects)
ERROR: oe_runmake failed
ERROR: Function failed: do_configure (log file is located at /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/usdpaa-apps/git-r0/temp/log.do_configure.31151)
ERROR: Logfile of failure stored in: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/usdpaa-apps/git-r0/temp/log.do_configure.31151
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function do_configure
| NOTE: make CC=powerpc64-fsl-linux-gcc -mhard-float -m64 -mcpu=e5500 --sysroot=/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/t1040d4rdb-64b LD=powerpc64-fsl-linux-ld --sysroot=/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/t1040d4rdb-64b AR=powerpc64-fsl-linux-ar ARCH=powerpc64 clean
| ---- clean ----
| make: execvp: ./lib/common/objs_powerpc64/app_refcount_refcount.o: Permission denied
| Makefile:277: recipe for target 'clean' failed
| make: *** [clean] Error 127
ERROR: Task 1681 (/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-dpaa/usdpaa-apps/usdpaa-apps_git.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2408 tasks of which 2397 didn't need to be rerun and 1 failed.
yipingwang
I am not sure why you encountered problem at building usdpaa-apps,
You could remove usdpaa-apps from the rootfs, please delete usdpaa-apps in DPAA_PKGS in sources/meta-freescale/recipes-fsl/packagegroups/packagegroup-fsl-tools-core.bb
DPAA_PKGS = " \
eth-config \
fmc \
usdpaa \
dpa-offload \
hypervisor-partman \
Suraj_Prakash
     Looks like the usdpaa-apps issue got resolved but there is still some issue in python installation.
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 48 objects)
ERROR: Unable to install packages. Command '/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/sysroots/x86_64-linux/usr/bin/smart --log-level=warning --data-dir=/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/fsl-image-core/1.0-r0/rootfs/var/lib/smart install -y lsb@ppc64e5500 net-snmp@ppc64e5500 packagegroup-fsl-mfgtools@all python-core-2.7.18-r1@ppc64e5500 openssh@ppc64e5500 packagegroup-core-ssh-openssh@all tcl@ppc64e5500 udev-extraconf@ppc64e5500 packagegroup-core-boot@t1040d4rdb_64b packagegroup-fsl-benchmark-core@all sqlite3@ppc64e5500 run-postinsts@all udev-rules-qoriq@ppc64e5500 packagegroup-fsl-networking-core@all packagegroup-fsl-tools-core@all libpam@ppc64e5500' returned 1:
Loading cache...
Updating cache... ######################################## [100%]
Computing transaction...error: Can't install python-core-2.7.18-r1@ppc64e5500: no package provides python-re
ERROR: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/fsl-image-core/1.0-r0/temp/log.do_rootfs.14926
ERROR: Task 7 (/home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/recipes-fsl/images/fsl-image-core.bb, do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3349 tasks of which 3224 didn't need to be rerun and 1 failed.
No currently running tasks (3349 of 3350)
yipingwang
Please add the following line in sources/poky/meta/recipes-devtools/python/python_2.7.18.bb
RDEPENDS_remove += "python-re python-contextlib"
Suraj_Prakash
Hi sir,
       Still getting the same error.Please help me fix this
Loading cache: 100% |#################################################################################################################################################| ETA: 00:00:00
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-gnome
meta-networking
meta-perl
meta-python
meta-ruby
meta-filesystems
meta-webserver
meta-openstack
meta-openstack-qemu
NOTE: Checking sstate mirror object availability (for 6 objects)
Loading cache...
ERROR: Logfile of failure stored in: /home/suchita/GCR/v2/QorIQ-SDK-V2.0-20160527-yocto/build_t1040d4rdb-64b/tmp/work/t1040d4rdb_64b-fsl-linux/fsl-image-core/1.0-r0/temp/log.do_rootfs.29446
NOTE: Tasks Summary: Attempted 3349 tasks of which 3336 didn't need to be rerun and 1 failed.
