Vibrations measure
Vibrations measure
maurogatti
Hi, I have to design a device to measure the vibration on the splindle of mechanical machine. I already used the MMA8451 accelerometer to measurement of inclination; for us, could I use it also to measure the vibration? Best regards.
TomasVaverka
Hi Mauro,
The MMA8451Q might be a good choice, but we need more information such as the frequency of vibration, since vibration sensing is limited by an internal filtering in an accelerometer.
Tomas
maurogatti
The  spindle can run at 30000 rpm so the frequency is 500 Hz
%3CLINGO-SUB%20id%3D%22lingo-sub-648071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVibrations%20measure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-648071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I%20have%20to%20design%20a%20device%20to%20measure%20the%20vibration%20on%20the%20splindle%20of%20mechanical%20machine.%20I%20already%20used%20the%20MMA8451%20accelerometer%20to%20measurement%20of%20inclination%3B%20for%20us%2C%20could%20I%20use%20it%20also%20to%20measure%20the%20vibration%3F%20Best%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-648071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-648073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Vibrations%20measure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-648073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20%26nbsp%3Bspindle%20can%20run%20at%2030000%20rpm%20so%20the%20frequency%20is%20500%20Hz%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-648072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Vibrations%20measure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-648072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Mauro%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20MMA8451Q%20might%20be%20a%20good%20choice%2C%20but%20we%20need%20more%20information%20such%20as%20the%20frequency%20of%20vibration%2C%20since%20vibration%20sensing%20is%20limited%20by%20an%20internal%20filtering%20in%20an%20accelerometer.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
