MMA8491Q Accuracy
MMA8491Q Accuracy
2,300件の閲覧回数
marcvandegaar
Hi Everybody,
I am actually evalutating the 3 axis accelerometer MMA8491Q using the XTRINSIC-SENSE evaluation board.
I am disapointed what the accuracy seems to be.
The evaluation board just lays on a table. There are no movements nor vibration at all.
The application just read the 3 coordinates every 500ms. As I look at the results, I see absolute deviations from one reading to the other going upto 50mG (0.05G). I have more or less the same maximum deviations on all 3 axis.
Is that the best accuracy one can expect from this device or is there something I am missing?
Would the MMA8451 be more accurate (its resolution is 4 times higher than the MMA8491Q)?
Thank you for your help
Marc
ラベル(2)
2 返答(返信)
2,059件の閲覧回数
TomasVaverka
Hi Marc,
Your results correspond to ours as you can see in Figure 9 of the AN4296. Unfortunately it is not possible to achieve higher precision with this accelerometer.
Yes, I would recommend using either the MMA8451Q (only I2C) or FXLS8471Q (I2C or SPI). When I selected the lowest possible ODR (1.56Hz), the ±2g range and used both Low Noise (LNOISE bit = 1) and High Resolution (SMODS = 1) modes, the deviation did not exceed 0.5mg!
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
2,059件の閲覧回数
marcvandegaar
Thank you very much Tomas for your answer.
I will evaluate the MMA8451Q.
%3CLINGO-SUB%20id%3D%22lingo-sub-501033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8491Q%20%E7%B2%BE%E5%BA%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-501033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%3CSTRONG%3E%E3%80%81XTRINSIC-SENSE%3C%2FSTRONG%3E%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%203%20%E8%BB%B8%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%3CSTRONG%3EMMA8491Q%3C%2FSTRONG%3E%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A3%E7%A2%BA%E3%81%95%E3%81%8C%E3%81%A9%E3%81%86%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%8C%E6%AE%8B%E5%BF%B5%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E4%B8%8A%E3%81%AB%E7%BD%AE%E3%81%8F%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%E5%8B%95%E3%81%8D%E3%82%82%E6%8C%AF%E5%8B%95%E3%82%82%E5%85%A8%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%20500%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%94%E3%81%A8%E3%81%AB%203%20%E3%81%A4%E3%81%AE%E5%BA%A7%E6%A8%99%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%B5%90%E6%9E%9C%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%811%20%E3%81%A4%E3%81%AE%E6%B8%AC%E5%AE%9A%E5%80%A4%E3%81%8B%E3%82%89%E4%BB%96%E3%81%AE%E6%B8%AC%E5%AE%9A%E5%80%A4%E3%81%BE%E3%81%A7%E3%81%AE%E7%B5%B6%E5%AF%BE%E5%81%8F%E5%B7%AE%E3%81%8C%E6%9C%80%E5%A4%A7%2050mG%20(0.05G)%20%E3%81%AB%E9%81%94%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%823%20%E3%81%A4%E3%81%AE%E8%BB%B8%E3%81%99%E3%81%B9%E3%81%A6%E3%81%A7%E3%80%81%E6%9C%80%E5%A4%A7%E5%81%8F%E5%B7%AE%E3%81%AF%E3%81%BB%E3%81%BC%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%9C%9F%E5%BE%85%E3%81%A7%E3%81%8D%E3%82%8B%E6%9C%80%E9%AB%98%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%BD%95%E3%81%8B%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3EMMA8451%20%E3%81%AE%E6%96%B9%E3%81%8C%E7%B2%BE%E5%BA%A6%E3%81%8C%E9%AB%98%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%20(%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AF%20MMA8491Q%20%E3%81%AE%204%20%E5%80%8D%E3%81%A7%E3%81%99)%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%9E%E3%83%BC%E3%82%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-501033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-501035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8491Q%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-501035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%E3%81%95%E3%82%93%E3%80%81%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMMA8451Q%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-501034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8491Q%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-501034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4296.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4296%3C%2FA%3E%E3%81%AE%E5%9B%B3%209%20%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%81%93%E3%81%AE%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%A7%E3%81%AF%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84%E7%B2%BE%E5%BA%A6%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%81%AF%E3%81%84%E3%80%81%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F2g-4g-8g-low-g-14-bit-digital-accelerometer%3AMMA8451Q%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMMA8451Q%3C%2FA%3E%20%EF%BC%88I%20%3CSUP%3E2%3C%2FSUP%3E%20C%E3%81%AE%E3%81%BF%EF%BC%89%E3%81%BE%E3%81%9F%E3%81%AF%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F2g-4g-8g-low-g-14-bit-digital-accelerometer%3AFXLS8471Q%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFXLS8471Q%3C%2FA%3E%20%EF%BC%88I%20%3CSUP%3E2%3C%2FSUP%3E%20C%E3%81%BE%E3%81%9F%E3%81%AFSPI%EF%BC%89%E3%81%AE%E3%81%94%E4%BD%BF%E7%94%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E5%8F%AF%E8%83%BD%E3%81%AA%E9%99%90%E3%82%8A%E4%BD%8E%E3%81%84ODR%EF%BC%881.56Hz%EF%BC%89%E3%81%A8%C2%B12g%E3%81%AE%E3%83%AC%E3%83%B3%E3%82%B8%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E4%BD%8E%E3%83%8E%E3%82%A4%E3%82%BA%EF%BC%88LNOISE%E3%83%93%E3%83%83%E3%83%88%20%3D%201%EF%BC%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E9%AB%98%E5%88%86%E8%A7%A3%E8%83%BD%EF%BC%88SMODS%20%3D%201%EF%BC%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%A1%E6%96%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%3C%2FSPAN%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E5%81%8F%E5%B7%AE%E3%81%AF0.5mg%E3%82%92%E8%B6%85%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%2011px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E8%BF%BD%E4%BC%B8%3A%20%E7%A7%81%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8C%E8%B3%AA%E5%95%8F%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FEM%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
