MMA8491Q Accuracy
MMA8491Q Accuracy
marcvandegaar
Hi Everybody,
I am actually evalutating the 3 axis accelerometer MMA8491Q using the XTRINSIC-SENSE evaluation board.
I am disapointed what the accuracy seems to be.
The evaluation board just lays on a table. There are no movements nor vibration at all.
The application just read the 3 coordinates every 500ms. As I look at the results, I see absolute deviations from one reading to the other going upto 50mG (0.05G). I have more or less the same maximum deviations on all 3 axis.
Is that the best accuracy one can expect from this device or is there something I am missing?
Would the MMA8451 be more accurate (its resolution is 4 times higher than the MMA8491Q)?
Thank you for your help
Marc
Labels (2)
TomasVaverka
Hi Marc,
Your results correspond to ours as you can see in Figure 9 of the AN4296. Unfortunately it is not possible to achieve higher precision with this accelerometer.
Yes, I would recommend using either the MMA8451Q (only I2C) or FXLS8471Q (I2C or SPI). When I selected the lowest possible ODR (1.56Hz), the ±2g range and used both Low Noise (LNOISE bit = 1) and High Resolution (SMODS = 1) modes, the deviation did not exceed 0.5mg!
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
marcvandegaar
Thank you very much Tomas for your answer.
I will evaluate the MMA8451Q.
%3CLINGO-SUB%20id%3D%22lingo-sub-501033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8491Q%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-501033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Everybody%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20am%20actually%20evalutating%20the%203%20axis%20accelerometer%20%3CSTRONG%3EMMA8491Q%3C%2FSTRONG%3E%20using%20the%20%3CSTRONG%3EXTRINSIC-SENSE%3C%2FSTRONG%3E%20evaluation%20board.%3C%2FP%3E%3CP%3EI%20am%20disapointed%20what%20the%20accuracy%20seems%20to%20be.%3C%2FP%3E%3CP%3EThe%20evaluation%20board%20just%20lays%20on%20a%20table.%20There%20are%20no%20movements%20nor%20vibration%20at%20all.%3C%2FP%3E%3CP%3EThe%20application%20just%20read%20the%203%20coordinates%20every%20500ms.%20As%20I%20look%20at%20the%20results%2C%20I%20see%20absolute%20deviations%20from%20one%20reading%20to%20the%20other%20going%20upto%2050mG%20(0.05G).%20I%20have%20more%20or%20less%20the%20same%20maximum%20deviations%20on%20all%203%20axis.%3C%2FP%3E%3CP%3EIs%20that%20the%20best%20accuracy%20one%20can%20expect%20from%20this%20device%20or%20is%20there%20something%20I%20am%20missing%3F%3C%2FP%3E%3CP%3EWould%20the%20MMA8451%20be%20more%20accurate%20(its%20resolution%20is%204%20times%20higher%20than%20the%20MMA8491Q)%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20help%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMarc%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-501033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ESensing%20Platforms%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-501035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8491Q%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-501035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20very%20much%20Tomas%20for%20your%20answer.%3C%2FP%3E%3CP%3EI%20will%20evaluate%20the%20MMA8451Q.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-501034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8491Q%20Accuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-501034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Marc%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%3EYour%20results%20correspond%20to%20ours%20as%20you%20can%20see%20in%20Figure%209%20of%20the%20%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4296.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4296%3C%2FA%3E.%20Unfortunately%20it%20is%20not%20possible%20to%20achieve%20higher%20precision%20with%20this%20accelerometer.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%3EYes%2C%20I%20would%20recommend%20using%20either%20the%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F2g-4g-8g-low-g-14-bit-digital-accelerometer%3AMMA8451Q%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMMA8451Q%3C%2FA%3E%20(only%20I%3CSUP%3E2%3C%2FSUP%3EC)%20or%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F2g-4g-8g-low-g-14-bit-digital-accelerometer%3AFXLS8471Q%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFXLS8471Q%3C%2FA%3E%20(I%3CSUP%3E2%3C%2FSUP%3EC%20or%20SPI).%20When%20I%20selected%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3Ethe%20lowest%20possible%20ODR%20(1.56Hz)%2C%20the%20%C2%B12g%20range%20and%20used%20b%3C%2FSPAN%3Eoth%20Low%20Noise%20(LNOISE%20bit%20%3D%201)%20and%20High%20Resolution%20(SMODS%20%3D%201)%20modes%2C%20the%20deviation%20did%20not%20exceed%200.5mg!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%2011px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EPS%3A%20If%20my%20answer%20helps%20to%20solve%20your%20question%2C%20please%20mark%20it%20as%20%22Correct%22.%20Thank%20you.%3C%2FEM%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
