Help with MPR121
Help with MPR121
2,177 次查看
Master_col
hallo, my probles is that first i can comunicate with the controller but with other I2C direction that is not on the datasheet. but well that works, what i cant find are the application notes 3893 and 3894 where explain how to configurate the controller. If someone has them or can helpme i wuld be very greatful. thanks for your time and excuse my bad english.
标记 (1)
1,651 次查看
Joshevelle
Senior Contributor I
Hello Christian,
Both questions had been answered in the following post:
MPR121 datasheet and app note give wrong i2c slave address (rev 0, 9/2009)
Josh
1,652 次查看
Joshevelle
Hello Christian,
Josh
