FXLS8471Q - FIFO Fill mode example code
2,314 次查看
andrewneil
here:
https://community.nxp.com/t5/Sensors-Knowledge-Base/FXLS8471Q-FIFO-Fill-mode-example-code/ta-p/11080...
by @TomasVaverka
In the first code block, I think the comment against CTRL_REG4 is wrong (or, at least, misleading):
void FXLS8471Q_Init (void)
  FXLS8471Q_WriteRegister(CTRL_REG1,   0x00); // Standby mode
  FXLS8471Q_WriteRegister(F_SETUP_REG, 0xA0); // FIFO Fill mode, 32 samples
  FXLS8471Q_WriteRegister(CTRL_REG4,   0x40); // Enable FIFO interrupt, push-pull, active low
  FXLS8471Q_WriteRegister(CTRL_REG5,   0x40); // Route the FIFO interrupt to INT1 - PTA5
  FXLS8471Q_WriteRegister(CTRL_REG1,   0x19); // ODR = 100Hz, Active mode
According to the datasheet, CTRL_REG4 contains only interrupt enable bits - not push-pull or active-low controls.
The push-pull and active-low controls are in CTRL_REG3  (the defaults are push-pull & active-low).
2,296 次查看
TomasVaverka
Hello Andrew,
Thank you again for your feedback, you are right, both the output mode (push-pull vs. open-drain) and polarity (active low vs. high) are configurable using bits pp_od and ipol in the CTRL_REG3 register.
I have updated the FXLS8471Q_Init function to make this clear.
  FXLS8471Q_WriteRegister(CTRL_REG3,   0x00); // Push-pull, active low interrupt
BR, Tomas
2,297 次查看
TomasVaverka
Hello Andrew,
BR, Tomas
2,290 次查看
andrewneil
Thanks.
It would be useful to have some samples like this for the FXLS896xAF, please ...
%3CLINGO-SUB%20id%3D%22lingo-sub-1817711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXLS8471Q%20-%20FIFO%20%E5%A1%AB%E5%85%85%E6%A8%A1%E5%BC%8F%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E9%87%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSensors-Knowledge-Base%2FFXLS8471Q-FIFO-Fill-mode-example-code%2Fta-p%2F1108021%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSensors-Knowledge-Base%2FFXLS8471Q-FIFO-Fill-mode-example-code%2Fta-p%2F1108021%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%E4%BD%9C%E8%80%85%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F12216%22%20target%3D%22_blank%22%3E%40TomasVaverka%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E7%AC%AC%E4%B8%80%E4%B8%AA%E4%BB%A3%E7%A0%81%E5%9D%97%E4%B8%AD%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E9%92%88%E5%AF%B9%20CTRL_REG4%20%E7%9A%84%E6%B3%A8%E9%87%8A%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%EF%BC%88%E6%88%96%E8%80%85%E8%87%B3%E5%B0%91%E6%98%AF%E8%AF%AF%E5%AF%BC%E6%80%A7%E7%9A%84%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Evoid%20FXLS8471Q_Init%20(void)%0A%7B%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG1%2C%20%20%200x00)%3B%20%2F%2F%20Standby%20mode%0A%20%20FXLS8471Q_WriteRegister(F_SETUP_REG%2C%200xA0)%3B%20%2F%2F%20FIFO%20Fill%20mode%2C%2032%20samples%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG4%2C%20%20%200x40)%3B%20%2F%2F%20Enable%20FIFO%20interrupt%2C%20push-pull%2C%20active%20low%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG5%2C%20%20%200x40)%3B%20%2F%2F%20Route%20the%20FIFO%20interrupt%20to%20INT1%20-%20PTA5%20%20%20%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG1%2C%20%20%200x19)%3B%20%2F%2F%20ODR%20%3D%20100Hz%2C%20Active%20mode%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%EF%BC%8C%3CSTRONG%3ECTRL%3C%2FSTRONG%3E_REG4%20%E4%BB%85%E5%8C%85%E5%90%AB%E4%B8%AD%E6%96%AD%E4%BD%BF%E8%83%BD%E4%BD%8D%EF%BC%8C%E4%B8%8D%E5%8C%85%E5%90%AB%E6%8E%A8%E6%8C%BD%E6%88%96%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%8E%A7%E5%88%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%8E%A8%E6%8C%BD%E5%92%8C%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E6%8E%A7%E5%88%B6%E5%9C%A8%3CSTRONG%3ECTRL_REG3%3C%2FSTRONG%3E%E4%B8%AD%EF%BC%88%E9%BB%98%E8%AE%A4%E5%80%BC%E4%B8%BA%E6%8E%A8%E6%8C%BD%26amp%3B%20%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%EF%BC%89%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1818662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXLS8471Q%20%20-%20FIFO%20Fill%20mode%20example%20code%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1818662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E8%83%BD%E4%B8%BA%20FXLS896xAF%20%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BA%9B%E8%BF%99%E6%A0%B7%E7%9A%84%E6%A0%B7%E6%9C%AC%EF%BC%8C%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%EF%BC%8C%E8%B0%A2%E8%B0%A2...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1818491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXLS8471Q%20%20-%20FIFO%20Fill%20mode%20example%20code%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1818491%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%AE%89%E5%BE%B7%E9%B2%81%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%EF%BC%8C%E6%82%A8%E8%AF%B4%E5%BE%97%E6%B2%A1%E9%94%99%EF%BC%8C%E8%BE%93%E5%87%BA%E6%A8%A1%E5%BC%8F%EF%BC%88%E6%8E%A8%E6%8C%BD%E4%B8%8E%E5%BC%80%E6%BC%8F%EF%BC%89%E5%92%8C%E6%9E%81%E6%80%A7%EF%BC%88%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E4%B8%8E%E9%AB%98%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%EF%BC%89%E9%83%BD%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20CTRL_REG3%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84%20pp_od%20%E5%92%8C%20ipol%20%E4%BD%8D%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9B%B4%E6%96%B0%E4%BA%86%20FXLS8471Q_Init%20%E5%87%BD%E6%95%B0%EF%BC%8C%E4%BB%A5%E6%98%8E%E7%A1%AE%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Evoid%20FXLS8471Q_Init%20(void)%0A%7B%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG1%2C%20%20%200x00)%3B%20%2F%2F%20Standby%20mode%0A%20%20FXLS8471Q_WriteRegister(F_SETUP_REG%2C%200xA0)%3B%20%2F%2F%20FIFO%20Fill%20mode%2C%2032%20samples%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG3%2C%20%20%200x00)%3B%20%2F%2F%20Push-pull%2C%20active%20low%20interrupt%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG4%2C%20%20%200x40)%3B%20%2F%2F%20Enable%20FIFO%20interrupt%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG5%2C%20%20%200x40)%3B%20%2F%2F%20Route%20the%20FIFO%20interrupt%20to%20INT1%20-%20PTA5%20%20%20%0A%20%20FXLS8471Q_WriteRegister(CTRL_REG1%2C%20%20%200x19)%3B%20%2F%2F%20ODR%20%3D%20100Hz%2C%20Active%20mode%0A%7D%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20Tomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
