SE050: key rotation demo: nxScp03_GP_InitializeUpdate returns 0x6a88
3,793 次查看
mfr64
Hi Kan Li, all,
I fear the discussion at SE050-key-rotation-DoAPDUTxRx-s-Case4-returns-0x6a80 is considered closed. I have still the problem and some more background information would help to solve it.
I have trouble with the key rotation demo se05x_TP_PlatformSCP03keys.c.
Let me give you an update to what I did:
Compilation on Linux using build options SE05X_Auth := PlatfSCP03, SCP := SCP03_SSS. Demos se05x_Get_Info and se05x_minimal work well in SCP03 mode. The GP Initialize Update Command succeeds there.
Within se05x_TP_PlatformSCP03keys I left "#define EX_SSS_BOOT_SKIP_SELECT_APPLET 1" in, I just added debug output to verify I used the same old preprovisioned keys that work on other demos successfully.
Here debug information:
se05x_RotatePlatformSCP03Keys
App:INFO :PlugAndTrust_v02.12.00_20191122
App:INFO :Running ../simw-top_build/raspbian_native_se050_t1oi2c/bin/se05x_RotatePlatformSCP03Keys
App:INFO :If you want to over-ride the selection, use ENV=EX_SSS_BOOT_SSS_PORT or pass in command line arguments.
sss:INFO :atr (Len=35)
00 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 08
01 00 00 00 00 64 00 00 0A 4A 43 4F 50 34 20 41
54 50 4F
scp:DEBUG:FN: nxScp03_AuthenticateChannel
scp:DEBUG: Output: hostChallenge (Len=8)
75 73 B3 26 35 5B 9B 2A
scp:DEBUG:FN: nxScp03_GP_InitializeUpdate
scp:DEBUG:Input:keyVersion 0b
scp:DEBUG: Input: hostChallenge (Len=8)
scp:DEBUG:Sending GP Initialize Update Command !!!
sss:WARN :nxEnsure:'ret == SM_OK' failed. At Line:4843 Function:sss_se05x_TXn
sss:INFO :Output:apduStatus 6a88
sss:INFO :Header: (Len=4)
80 50 0B 00
sss:INFO :Cmdbuf: (Len=8)
sss:INFO :Receivebuf: (Len=2)
6A 88
scp:ERROR:GP_InitializeUpdate Failure on communication Link 6A88
scp:ERROR:nxScp03_GP_InitializeUpdate fails with Status 3C3C0000
sss:ERROR:Could not set SCP03 Secure Channel
App:INFO :OLD_ENC (Len=16)
85 2B 59 62 E9 CC E5 D0 BE 74 6B 83 3B CC 62 87
App:INFO :OLD_MAC (Len=16)
DB 0A A3 19 A4 08 69 6C 8E 10 7A B4 E3 C2 6B 47
App:INFO :OLD_DEK (Len=16)
4C 2F 75 C6 A2 78 A4 AE E5 C9 AF 7C 50 EE A8 0C
Further down I add two more detailed logs of both se05x_RotatePlatformSCP03Keys and se05x_minimal.
Apparently nxScp03_GP_InitializeUpdate is called when the demo starts. But in difference to the earlier mentioned other demos, I get error message 6A 88, which means according to GP spec: "Referenced data not found".
The function "tp_PlatformKeys" of the Rotate Demo is not even called, the error comes before that (ex_sss_entry is after the error).
I understand from other discussion that the boot sequence has to be different when rotating keys, can you confirm that? What is the intended "to be"-effect of EX_SSS_BOOT_SKIP_SELECT_APPLET=1? It would help to know which APDU commands SHOULD be applied for rotating keys.
- Different options than: SE05X_Auth := PlatfSCP03 / SCP := SCP03_SSS ?
- Does the SE050´s Global Platform part require specific keys, different from the provisioned ones for SE050C1 (that work on other demos)?
Kind regards and many many thanks for any suggestion or help,
Markus
_____________________
Here a more deep log file with all traffic going via I2C interface:
pi@raspberrypi:~/SE050-PLUG-TRUST_MW_v02.12.00/simw-top_build/raspbian_native_se050_t1oi2c/bin $ ./se05x_RotatePlatformSCP03Keys
App:INFO :Running ./se05x_RotatePlatformSCP03Keys
smCom:DEBUG:I2CInit: opening /dev/i2c-4
smCom:DEBUG:I2C driver: PEC flag cleared
smCom:DEBUG:I2C driver supports plain i2c-level commands.
smCom:DEBUG:Done with rv = 0d
smCom:DEBUG:TX (axI2CRead): (Len=260)
BC 23 FD 76 08 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 53 8C 28 21 18 4B FD 76 00 00 00 00
58 8D DC 7E 60 8D DC 7E CC 8D DC 7E 1C 20 01 00
B4 8D DC 7E 20 DB FA 76 60 8D DC 7E BC 4A FD 76
05 00 00 00 08 24 FD 76 01 00 00 00 00 00 00 00
01 00 00 00 60 49 FD 76 05 00 00 00 08 24 FD 76
01 00 00 00 00 00 00 00 00 00 00 00 60 49 FD 76
18 4B FD 76 60 49 FD 76 FF FF FF FF 60 23 FD 76
E4 3C BE 76 40 1D FD 76 18 4B FD 76 60 49 FD 76
FF FF FF FF 00 00 00 00 C4 2F BE 76 40 1D FD 76
00 00 00 00 18 18 FB 76 40 1D FD 76 00 8E DC 7E
20 DC BD 76 00 00 00 00 FC 60 06 00 01 00 00 00
C0 F4 FC 76 00 00 00 00 00 00 00 00 00 40 FD 76
14 8E DC 7E 0C 31 FB 76 08 24 FD 76 01 00 00 00
01 00 00 00 00 00 00 00 24 8E DC 7E E4 3C BE 76
00 60 06 00 00 00 00 00 50 33 01 00 00 00 00 00
00 00 00 00
smCom:DEBUG:TX (axI2CWrite) > (Len=5)
5A CF 00 37 7F
smCom:DEBUG:Done with rv = 0c
smCom:DEBUG:TX (axI2CRead): (Len=2)
A5 EF
smCom:DEBUG:TX (axI2CRead): (Len=1)
23
smCom:DEBUG:TX (axI2CRead): (Len=37)
54 50 4F 87 77
smCom:DEBUG:TX (axI2CWrite) > (Len=10)
5A 00 05 00 A4 04 00 00 1E 3C
00 00
00 00
00 00
00 00
00 00
A5 00
14
smCom:DEBUG:TX (axI2CRead): (Len=22)
6F 10 84 08 A0 00 00 01 51 00 00 00 A5 04 9F 65
01 FF 90 00 95 F6
54 50 4F
sss:INFO :SCP03 SSS section
10 22 1B 84 31 0A 14 07
smCom:DEBUG:TX (axI2CWrite) > (Len=18)
5A 40 0D 80 50 0B 00 08 10 22 1B 84 31 0A 14 07
70 FE
00 00
00 00
00 00
Looping about 10seconds (until timeout?), then:
00 00
00 00
00 00
00 00
00 00
00 00
A5 40
02
smCom:DEBUG:TX (axI2CRead): (Len=4)
6A 88 8D 30
sss:WARN :nxEnsure:'ret == SM_OK' failed. At Line:4848 Function:sss_se05x_TXn
80 50 0B 00
09 A1 CE EE D4 84 44 BC
6A 88
sss:DEBUG:FN: sss_symmetric_context_init
sss:DEBUG:Input:algorithm 0a
sss:DEBUG:Input:mode 01
sss:DEBUG:FN: sss_cipher_one_go
sss:DEBUG: Input: IV (Len=0)
sss:DEBUG: Input: srcData (Len=0)
sss:DEBUG:FN: sss_symmetric_context_free
smCom:DEBUG:TX (axI2CWrite) > (Len=80)
5A 00 4B 80 D8 0B 81 46 0B 88 11 10 4D BD 61 CD
46 F4 79 A8 C2 0E CE 1D 10 72 16 8C 03 75 0D 4D
88 11 10 D6 6A EF 4E A7 52 30 7B 42 F3 25 65 39
7E 3A 5F 03 89 1F B6 88 11 10 34 88 2F 97 33 4F
73 EE 15 55 FA 76 E2 52 70 96 03 EE 6D D4 E1 6B
00 00
00 00
A5 00
02
69 82 08 A3
sss:INFO :Output:apduStatus 6982
80 D8 0B 81
sss:INFO :Cmdbuf: (Len=70)
0B 88 11 10 4D BD 61 CD 46 F4 79 A8 C2 0E CE 1D
10 72 16 8C 03 75 0D 4D 88 11 10 D6 6A EF 4E A7
52 30 7B 42 F3 25 65 39 7E 3A 5F 03 89 1F B6 88
11 10 34 88 2F 97 33 4F 73 EE 15 55 FA 76 E2 52
70 96 03 EE 6D D4
69 82
App:INFO :ex_sss Finished
5A C5 00 47 82
A5 E5
00
87 67
_____________
To compare with:
pi@raspberrypi:~/SE050-PLUG-TRUST_MW_v02.12.00/simw-top_build/raspbian_native_se050_t1oi2c/bin/se05x_minimal
App:INFO :Running ./se05x_minimal
BC 33 F8 76 08 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 53 8C 28 21 18 5B F8 76 00 00 00 00
28 0D D3 7E 30 0D D3 7E 9C 0D D3 7E 1C 20 01 00
84 0D D3 7E 20 EB F5 76 30 0D D3 7E BC 5A F8 76
05 00 00 00 08 34 F8 76 01 00 00 00 00 00 00 00
01 00 00 00 60 59 F8 76 05 00 00 00 08 34 F8 76
01 00 00 00 00 00 00 00 00 00 00 00 60 59 F8 76
18 5B F8 76 60 59 F8 76 FF FF FF FF 60 33 F8 76
E4 4C B9 76 40 2D F8 76 18 5B F8 76 60 59 F8 76
FF FF FF FF 00 00 00 00 C4 3F B9 76 40 2D F8 76
00 00 00 00 18 28 F6 76 40 2D F8 76 D0 0D D3 7E
20 EC B8 76 00 00 00 00 FC 50 06 00 01 00 00 00
C0 04 F8 76 00 00 00 00 00 00 00 00 00 50 F8 76
E4 0D D3 7E 0C 41 F6 76 08 34 F8 76 01 00 00 00
01 00 00 00 00 00 00 00 F4 0D D3 7E E4 4C B9 76
00 50 06 00 00 00 00 00 50 33 01 00 00 00 00 00
00 00 00 00
5A CF 00 37 7F
A5 EF
23
54 50 4F 87 77
00 00
00 00
00 00
00 00
A5 00
14
01 FF 90 00 95 F6
smCom:DEBUG:TX (axI2CWrite) > (Len=26)
5A 40 15 00 A4 04 00 0F A0 00 00 03 96 54 53 00
00 00 01 03 00 00 00 00 B8 78
00 00
Waiting short time ...
00 00
A5 40
09
smCom:DEBUG:TX (axI2CRead): (Len=11)
03 01 00 6F FF 01 0B 90 00 1C D9
54 50 4F
7E 38 3E 75 AF B0 2A 3D
5A 00 0D 80 50 0B 00 08 7E 38 3E 75 AF B0 2A 3D
8B D4
00 00
00 00
A5 00
1F
smCom:DEBUG:TX (axI2CRead): (Len=33)
90 03 91 93 10 56 67 99 31 75 0B 03 00 40 82 13
5A 67 A8 6D 12 0B 21 2F 9F 73 74 BC 39 90 00 26
67
sss:INFO :Output:apduStatus 9000
80 50 0B 00
sss:INFO :Receivebuf: (Len=31)
scp:DEBUG: Output: keyDivData (Len=10)
scp:DEBUG: Output: keyInfo (Len=3)
0B 03 00
scp:DEBUG: Output: cardChallenge (Len=8)
40 82 13 5A 67 A8 6D 12
scp:DEBUG: Output: cardCryptoGram (Len=8)
scp:DEBUG:FN: nxScp03_HostLocal_CalculateSessionKeys
scp:DEBUG: Input:hostChallenge (Len=8)
scp:DEBUG: Input:cardChallenge (Len=8)
scp:DEBUG:Set the Derviation data to generate Session ENC key
scp:DEBUG:FN: nxScp03_setDerivationData
scp:DEBUG:Input:ddConstant 04
scp:DEBUG:Input:ddL 80
scp:DEBUG:Input:iCounter 01
scp:DEBUG: Input: keyInfo (Len=16)
7E 38 3E 75 AF B0 2A 3D 40 82 13 5A 67 A8 6D 12
scp:DEBUG:Output: KeyDivData (Len=32)
00 00 00 00 00 00 00 00 00 00 00 04 00 00 80 01
scp:DEBUG:FN: nxScp03_Generate_SessionKey
scp:DEBUG: Input: inData (Len=32)
scp:DEBUG: Output:outSignature (Len=16)
D7 59 11 55 4F 69 51 25 F5 96 7B FE F6 11 79 15
scp:DEBUG: Output:sessionEncKey (Len=16)
scp:DEBUG:Set the Derviation data to generate Session MAC key
scp:DEBUG:Input:ddConstant 06
00 00 00 00 00 00 00 00 00 00 00 06 00 00 80 01
D8 A8 16 B3 C0 BF E0 E2 26 61 9B E0 7A 31 57 EB
scp:DEBUG: Output:sessionMacKey (Len=16)
scp:DEBUG:Set the Derviation data to generate Session RMAC key
scp:DEBUG:Input:ddConstant 07
00 00 00 00 00 00 00 00 00 00 00 07 00 00 80 01
A3 FD F7 3C E2 0F B7 98 89 4D D4 B0 5F 43 B5 4C
scp:DEBUG: Output:sessionRmacKey (Len=16)
scp:DEBUG:FN: nxScp03_HostLocal_VerifyCardCryptogram
scp:DEBUG:Input:ddConstant 00
scp:DEBUG:Input:ddL 40
00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 01
0B 21 2F 9F 73 74 BC 39 EF A1 C9 CE 55 A8 45 32
scp:DEBUG: Output:cardCryptogram (Len=16)
scp:DEBUG:cardCryptoGram (Len=8)
scp:DEBUG:CardCryptogram verified successfully...Calculate HostCryptogram
scp:DEBUG:FN: nxScp03_HostLocal_CalculateHostCryptogram
scp:DEBUG:Input:ddConstant 01
00 00 00 00 00 00 00 00 00 00 00 01 00 00 40 01
12 B3 EE F2 09 E8 02 6A F7 56 B5 50 48 FE 93 AB
scp:DEBUG: Output:hostCryptogram (Len=16)
scp:DEBUG:hostCryptogram (Len=8)
scp:DEBUG:FN: nxScp03_GP_ExternalAuthenticate
scp:DEBUG: Input: hostCryptogram (Len=8)
scp:DEBUG:Calculate the MAC on data
scp:DEBUG: Output: Calculated MAC (Len=8)
F8 73 58 5D CB 80 83 7B
scp:DEBUG:Add calculated MAC Value to cmd Data
scp:DEBUG:Sending GP External Authenticate Command !!!
5A 40 15 84 82 33 00 10 12 B3 EE F2 09 E8 02 6A
F8 73 58 5D CB 80 83 7B F6 1A
00 00
00 00
00 00
00 00
A5 40
02
90 00 B5 B9
84 82 33 00
sss:INFO :Cmdbuf: (Len=16)
12 B3 EE F2 09 E8 02 6A F8 73 58 5D CB 80 83 7B
90 00
scp:DEBUG:Authentication Successful!!!
sss:INFO :SCP03 SSS 1st part ok
APDU:DEBUG:GetFreeMemory []
APDU:DEBUG:kSE05x_TAG_1 [memoryType] = 0x3
smCom:DEBUG:TX (axI2CWrite) > (Len=34)
5A 00 1D 84 04 00 22 18 58 86 85 A6 55 F2 26 D0
88 2B 57 DF 20 C4 EC 33 9E FF CD 2A 71 0D 25 5A
1F 0A
00 00
00 00
00 00
00 00
00 00
00 00
00 00
00 00
A5 00
1A
smCom:DEBUG:TX (axI2CRead): (Len=28)
38 C1 28 A9 AB A2 FB 5B B2 CD 70 71 63 06 5F 85
6A D3 DA 55 4B 7D D0 55 90 00 C7 03
80 04 00 22
sss:INFO :Cmdbuf: (Len=3)
58 86 85
sss:INFO :Receivebuf: (Len=6)
41 02 01 20 90 00
App:INFO :mem=288
5A C5 00 47 82
A5 E5
00
87 67
标记 (3)
3,675 次查看
Kan_Li
Hello @mfr64 ,
The  MW version is too old (02.12.00 as shown in the logs), and on this old version the rotate code selects the ISD instead of the SSD. This bug got fixed since 02.12.01, please try with the latest version. You may refer to the following for more details.
Kan
4 回复数
3,774 次查看
Kan_Li
Hello @mfr64 ,
The demo uses the default Platform SCP keys, and EX_SSS_BOOT_SKIP_SELECT_APPLET is used to skip the APDU command for selecting applet, please kindly refer to the following for more details.
Kan
3,755 次查看
mfr64
Hi Kan,
hmm, I know this information. What I am looking for is so get a bit more information how the key rotation demo SHOULD execute. This could be an example what should be communicated (APDU commands) or what C-functions should be called when. May be somebody at NXP or a customer reading this can provide some tracing data.
Alternatively it would help to know which APDU command is the first one that is wrong in the tracing data I sent earlier.
Thank you in advance,
Markus
3,676 次查看
Kan_Li
Hello @mfr64 ,
Kan
3,669 次查看
mfr64
Hi Kan Li,
I had an copy of v02.12.04, newer than v02.12.00 and it should contain the bug fix as well. Now as I know this version is worth a chance to retry, I did that today with success.
The Key rotation demo works for me, based on v02.12.04 which did not need too much rework to get my code migrated from v02.12.00.
Many thanks!
Markus
