SE050 Transient Object Export
3,696件の閲覧回数
wami
Hi there,
I have seen in the APDU-Guide there is a function and policy that allows export of an transient object using an "randomly generated but persistent stored AES Key" which will be used to encrypt the object before export.
Is there any way to define a "Transport Key" for this? I have the requirement to backup an generated key if the board needs to be replaced at any time.
Any Idea how to make this possible?
Thanks in Advance.
Michael
4 返答(返信)
3,557件の閲覧回数
wami
Yes absolutely.
I want to be able to Import exported objects in other SE050 Chips.
Tanks
Michael
3,557件の閲覧回数
Kan_Li
Hello Michael,
Do you mean you want to set up the "randomly generated but persistent stored AES Key" manually? Please kindly clarify.
Kan
3,557件の閲覧回数
wami
any news on that?
Thanks and BR
Michael
3,557件の閲覧回数
Kan_Li
Hi Michael,
This AES key is automatically internally generated and handled. No user interaction is possible.
Kan
