Denied to read object bases on policy.
671 次查看
WorkerEmbedded
Hello to everyone, i've got a problem!
Anyone can tell me why i can't access to an object where previosly i stored a key successfully with the sss_key_store_set_key function.
Now with the sss_key_store_get_key i recive the following sentences:
sss :WARN :nxEnsure:'ret == SM_OK' failed. At Line:7026 Function:sss_se05x_TXn
hostLib:WARN :Denied to read object EF000033 bases on policy.
sss :WARN :nxEnsure:'status == SM_OK' failed. At Line:4009 Function:sss_se05x_key_store_get_key
657 次查看
Kan_Li
Hi @WorkerEmbedded ,
Maybe due to the secure obj's policy, or you have to authenticate to access this obj. BTW, is it possible to delete this obj with the demo of "Delete and Test Provision"?
Kan
