s32k358 MCU temperature measurement
967 次查看
BillWen
Hi :
I have some problem on measure s32k358 mcu temperature, I also check other post on NXP community, but I can't find the problem, please help us check, thanks.
The following is my ADC setting :
Function code I follow the formula from S32K3RM
I get Mcu temp raw data about 8208, and after ADC 8208* (3300/16384)
and formula from RM then can get MCU temp = 48~49, I think the value is not correct.
Is there any wrong setting in my MCAL or code?
BR, BillWen
801 次查看
Senlent
Hi@BillWen
The TEMPSENSE output can be read by an ADC on demand so that the software can determine the current die temperature. The software should enable the TEMPSENSE by setting ETSCTL[ETS_EN].
Secondly, there are requirements for the ADC sampling time of the temperature sensor; it must be greater than 1.2us. I suggest you use a larger value.
11 回复数
946 次查看
Senlent
Hi@BillWen
First, the calculation process you provided is correct, but I see some obvious errors:
1. The parameter you entered here is 53, which is 0b00110101.
This indicates that the reference voltage is 3.5V, not 3.3V.
So this should be wrong :ADC 8208* (3300/16384)
I've created a simple table based on the calculation formulas provided in the datasheet for your reference.
830 次查看
BillWen
Hi Senlent:
Thanks for your reply.
For the parameter you entered here is 53, which is 0b00110101.
I change the value to 3.3V(51) or 5V(80), I still get the same raw data. I use the same way to get mcu temp just like how I get other ADC value, is it correct? or do I need to use Adc_TempSenseGetTemp function?
BR,BillWen
828 次查看
Senlent
Hi@BillWen
I think that's incorrect, because this should change.
Have you enabled the internal temperature sensor?
It's not mandatory, but our driver already provides an API for calculation.
You can refer to this example.
https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K344-TempSenser-S32DS36-RTD600-500-400-p...
823 次查看
BillWen
Hi Senlent:
As I know is that we can use Adc_TempSenseGetTemp API to get the temperature value after convert, but I also can convert by myself, right? I also check the following post on community. It seems that I still can just get rawdata and use formula from Reference manual to calculate the real temperature value.
https://community.nxp.com/t5/S32K/Reading-the-internal-temperature-of-S32K388-using-TEMPSENSE/m-p/18...
Btw, I also check the example you uploaded, due to the project is based on driver layer not MCAL layer, I think is different process.
BR, BillWen
817 次查看
Senlent
Hi@BillWen
Yes, you can calculate it yourself, but since an API has been provided, there's no need to do it manually.
811 次查看
BillWen
Hi Senlent:
Yes, I know this, but the problem for now is that I can't get right raw data. The real temperature value won't be correct no matter calculate by API or manually if the raw data not correct.
BR, BillWen
809 次查看
Senlent
Hi@BillWen
1. Check if the internal temperature sensor is enabled.
2. Check if the ADC is configured correctly.
If the sampling values ​​of your other ADC channels are correct, there's no reason why the temperature sensor's sampling value shouldn't change at all.
803 次查看
BillWen
Hi Senlent:
I think ADC configuration is correct because I can get correct other ADC value correct like power voltage which according to our project.
Do you know how to check internal temperature sensor is enabled or not?
BR, BillWen
802 次查看
Senlent
Hi@BillWen
794 次查看
BillWen
Hi Senlent:
Thanks for your support, I find the problem.
After I fix my problem, I get the temperature around 35~36, it seems normal I think.
BR, BillWen
786 次查看
Senlent
Hi@BillWen
If this post answers your question, please click the "ACCEPT AS SOLUTION" button.
%3CLINGO-SUB%20id%3D%22lingo-sub-2348950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Es32k358%20MCU%20%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348950%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%B5%8B%E9%87%8F%20s32k358%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E6%B8%A9%E5%BA%A6%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%B9%9F%E6%9F%A5%E7%9C%8B%E4%BA%86%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E7%9A%84%E5%85%B6%E4%BB%96%E5%B8%96%E5%AD%90%EF%BC%8C%E4%BD%86%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E6%A3%80%E6%9F%A5%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%20ADC%20%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_1-1775803665355.png%22%20style%3D%22width%3A%20346px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381925i283AEAEAF3654867%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22BillWen_1-1775803665355.png%22%20alt%3D%22BillWen_1-1775803665355.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_2-1775803680527.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381928iB288B2D812684C73%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22BillWen_2-1775803680527.png%22%20alt%3D%22BillWen_2-1775803680527.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_3-1775803723072.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381929iF0576F95C7C0425C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22BillWen_3-1775803723072.png%22%20alt%3D%22BillWen_3-1775803723072.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8A%9F%E8%83%BD%E4%BB%A3%E7%A0%81%20I%20%E6%8C%89%E7%85%A7%20S32K3RM%20%E7%9A%84%E5%85%AC%E5%BC%8F%E8%AE%A1%E7%AE%97%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22BillWen_0-1775803642764.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381924i996D90A8D2E65C9F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22BillWen_0-1775803642764.png%22%20alt%3D%22BillWen_0-1775803642764.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BE%97%E5%88%B0%E7%9A%84%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E6%B8%A9%E5%BA%A6%E5%8E%9F%E5%A7%8B%E6%95%B0%E6%8D%AE%E7%BA%A6%E4%B8%BA%208208%EF%BC%8CADC%20%E4%B9%8B%E5%90%8E%E4%B8%BA%208208*%EF%BC%883300%2F16384%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%92%8C%20RM%20%E4%B8%AD%E7%9A%84%E5%85%AC%E5%BC%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8F%AF%E4%BB%A5%E5%BE%97%E5%88%B0%20MCU%20%E6%B8%A9%E5%BA%A6%20%3D%2048~49%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%AA%E5%80%BC%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%20MCAL%20%E6%88%96%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E8%AE%BE%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EBR%2C%20BillWen%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2349079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%40BillWen%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E8%AE%A1%E7%AE%97%E8%BF%87%E7%A8%8B%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E4%BD%86%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E6%98%8E%E6%98%BE%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%0A%3CP%3E1.%E8%BF%99%E9%87%8C%E8%BE%93%E5%85%A5%E7%9A%84%E5%8F%82%E6%95%B0%E6%98%AF%2053%EF%BC%8C%E5%8D%B3%200b00110101%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E8%A1%A8%E7%A4%BA%E5%8F%82%E8%80%83%E7%94%B5%E5%8E%8B%E4%B8%BA%203.5V%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%203.3V%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20389px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381971iFF9A0F9B5D72843E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%BF%99%E5%BA%94%E8%AF%A5%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%3CSPAN%3E%EF%BC%9AADC%208208*%20(%3CSTRONG%3E3300%2F16384%3C%2FSTRONG%3E)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E---------------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%A0%B9%E6%8D%AE%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%E8%AE%A1%E7%AE%97%E5%85%AC%E5%BC%8F%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E8%A1%A8%E6%A0%BC%EF%BC%8C%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20515px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381970iB21F82B18D9AF616%2Fimage-dimensions%2F515x239%3Fv%3Dv2%22%20width%3D%22515%22%20height%3D%22239%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20565px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381972iD35E8729EBE46C28%2Fimage-dimensions%2F565x317%3Fv%3Dv2%22%20width%3D%22565%22%20height%3D%22317%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%82%A8%E5%A5%BD%20Senlent%3A%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E9%87%8C%E8%BE%93%E5%85%A5%E7%9A%84%E5%8F%82%E6%95%B0%E6%98%AF%2053%EF%BC%8C%E5%8D%B3%200b00110101%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B0%86%E6%95%B0%E5%80%BC%E6%94%B9%E4%B8%BA%203.3V(51)%20%E6%88%96%205V(80)%EF%BC%8C%E5%BE%97%E5%88%B0%E7%9A%84%E5%8E%9F%E5%A7%8B%E6%95%B0%E6%8D%AE%E4%BB%8D%E7%84%B6%E7%9B%B8%E5%90%8C%E3%80%82%E6%88%91%E7%94%A8%E5%90%8C%E6%A0%B7%E7%9A%84%E6%96%B9%E6%B3%95%E8%8E%B7%E5%8F%96%20mcu%20%E6%B8%A9%E5%BA%A6%EF%BC%8C%E5%B0%B1%E5%83%8F%E8%8E%B7%E5%8F%96%E5%85%B6%E4%BB%96%20ADC%20%E5%80%BC%E4%B8%80%E6%A0%B7%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%E8%BF%98%E6%98%AF%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20Adc_TempSenseGetTemp%20%E5%87%BD%E6%95%B0%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3CBR%20%2F%3EBR%2CBillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%40BillWen%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E1.%E6%A3%80%E6%9F%A5%E5%86%85%E9%83%A8%E6%B8%A9%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%98%AF%E5%90%A6%E5%90%AF%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%E6%A3%80%E6%9F%A5%20ADC%20%E9%85%8D%E7%BD%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E5%85%B6%E4%BB%96%20ADC%20%E9%80%9A%E9%81%93%E7%9A%84%E9%87%87%E6%A0%B7%E5%80%BC%E6%AD%A3%E7%A1%AE%EF%BC%8C%E9%82%A3%E4%B9%88%E6%B8%A9%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E9%87%87%E6%A0%B7%E5%80%BC%E5%B0%B1%E6%B2%A1%E6%9C%89%E7%90%86%E7%94%B1%E4%B8%8D%E5%8F%91%E7%94%9F%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Senlent%3A%3CBR%20%2F%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20Adc_TempSenseGetTemp%20API%20%E6%9D%A5%E8%8E%B7%E5%8F%96%E8%BD%AC%E6%8D%A2%E5%90%8E%E7%9A%84%E6%B8%A9%E5%BA%A6%E5%80%BC%EF%BC%8C%E4%BD%86%E6%88%91%E4%B9%9F%E5%8F%AF%E4%BB%A5%E8%87%AA%E5%B7%B1%E8%BF%9B%E8%A1%8C%E8%BD%AC%E6%8D%A2%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%E6%88%91%E8%BF%98%E6%9F%A5%E7%9C%8B%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%85%B3%E4%BA%8E%E7%A4%BE%E5%8C%BA%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%E7%9C%8B%E6%9D%A5%E6%88%91%E4%BB%8D%E7%84%B6%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%8F%96%E5%8E%9F%E5%A7%8B%E6%95%B0%E6%8D%AE%E5%B9%B6%E4%BD%BF%E7%94%A8%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E5%85%AC%E5%BC%8F%E6%9D%A5%E8%AE%A1%E7%AE%97%E5%AE%9E%E9%99%85%E6%B8%A9%E5%BA%A6%E5%80%BC%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FReading-the-internal-temperature-of-S32K388-using-TEMPSENSE%2Fm-p%2F1847736%2Fhighlight%2Ftrue%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FReading-the-internal-temperature-of-S32K388-using-TEMPSENSE%2Fm-p%2F1847736%2Fhighlight%2Ftrue%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E5%8F%A5%EF%BC%8C%E6%88%91%E8%BF%98%E6%A3%80%E6%9F%A5%E4%BA%86%E4%BD%A0%E4%B8%8A%E4%BC%A0%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%E6%98%AF%E5%9F%BA%E4%BA%8E%E9%A9%B1%E5%8A%A8%E5%B1%82%E8%80%8C%E4%B8%8D%E6%98%AFMCAL%E5%B1%82%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E6%98%AF%E4%B8%8D%E5%90%8C%E7%9A%84%E8%BF%87%E7%A8%8B%E3%80%82%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%3CBR%20%2F%3EBR%E3%80%81BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Senlent%3A%3CBR%20%2F%3E%E6%88%91%E8%AE%A4%E4%B8%BA%20ADC%20%E9%85%8D%E7%BD%AE%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E5%8F%AF%E4%BB%A5%E5%BE%97%E5%88%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%85%B6%E4%BB%96%20ADC%20%E5%80%BC%EF%BC%8C%E5%A6%82%E7%AC%A6%E5%90%88%E6%88%91%E4%BB%AC%E9%A1%B9%E7%9B%AE%E7%9A%84%E7%94%B5%E6%BA%90%E7%94%B5%E5%8E%8B%E3%80%82%3CBR%20%2F%3E%E4%BD%A0%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E6%A3%80%E6%9F%A5%E5%86%85%E9%83%A8%E6%B8%A9%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%98%AF%E5%90%A6%E5%90%AF%E7%94%A8%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3CBR%20%2F%3EBR%2C%20BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350445%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%82%A8%E5%A5%BD%20Senlent%3A%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%8C%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%3CBR%20%2F%3E%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E5%90%8E%EF%BC%8C%E6%B8%A9%E5%BA%A6%E5%9C%A8%2035~36%20%E5%B7%A6%E5%8F%B3%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%3CBR%20%2F%3EBR%E3%80%81BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350424%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40BillWen%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHi%40BillWen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%A8%A1%E6%95%B0%E8%BD%AC%E6%8D%A2%E5%99%A8%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E9%9C%80%E8%A6%81%E8%AF%BB%E5%8F%96%20TEMPSENSE%20%E8%BE%93%E5%87%BA%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%BD%AF%E4%BB%B6%E5%8F%AF%E4%BB%A5%E7%A1%AE%E5%AE%9A%E5%BD%93%E5%89%8D%E7%9A%84%E8%8A%AF%E7%89%87%E6%B8%A9%E5%BA%A6%E3%80%82%E8%BD%AF%E4%BB%B6%E5%BA%94%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%3CSTRONG%3EETSCTL%5BETS_EN%5D%3C%2FSTRONG%3E%20%E5%90%AF%E7%94%A8%20TEMPSENSE%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%85%B6%E6%AC%A1%EF%BC%8C%E5%AF%B9%E6%B8%A9%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%20ADC%20%E9%87%87%E6%A0%B7%E6%97%B6%E9%97%B4%E4%B9%9F%E6%9C%89%E8%A6%81%E6%B1%82%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%A4%A7%E4%BA%8E%201.2us%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E4%BD%BF%E7%94%A8%E6%9B%B4%E5%A4%A7%E7%9A%84%E6%95%B0%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20822px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20822px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20822px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20822px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20822px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20822px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382187i16152EE2484A5494%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350404%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%40BillWen%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%87%AA%E5%B7%B1%E8%AE%A1%E7%AE%97%EF%BC%8C%E4%BD%86%E6%97%A2%E7%84%B6%E5%B7%B2%E7%BB%8F%E6%8F%90%E4%BE%9B%E4%BA%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%EF%BC%8C%E5%B0%B1%E6%B2%A1%E6%9C%89%E5%BF%85%E8%A6%81%E6%89%8B%E5%8A%A8%E8%AE%A1%E7%AE%97%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CSenlent%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E4%BD%86%E7%9B%AE%E5%89%8D%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%8E%9F%E5%A7%8B%E6%95%B0%E6%8D%AE%E3%80%82%E5%A6%82%E6%9E%9C%E5%8E%9F%E5%A7%8B%E6%95%B0%E6%8D%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E6%97%A0%E8%AE%BA%E4%BD%BF%E7%94%A8%20API%20%E8%BF%98%E6%98%AF%E6%89%8B%E5%8A%A8%E8%AE%A1%E7%AE%97%EF%BC%8C%E5%AE%9E%E9%99%85%E6%B8%A9%E5%BA%A6%E5%80%BC%E9%83%BD%E4%B8%8D%E4%BC%9A%E6%AD%A3%E7%A1%AE%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%3CBR%20%2F%3EBR%E3%80%81BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%40BillWen%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%98%AF%E4%B8%8D%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%BA%94%E8%AF%A5%E6%94%B9%E5%8F%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E5%90%A6%E5%90%AF%E7%94%A8%E4%BA%86%E5%86%85%E9%83%A8%E6%B8%A9%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E4%B8%8D%E6%98%AF%E5%BF%85%E9%A1%BB%E7%9A%84%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B7%B2%E7%BB%8F%E6%8F%90%E4%BE%9B%E4%BA%86%E8%AE%A1%E7%AE%97%20API%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K344-TempSenser-S32DS36-RTD600-500-400-p24%2Fta-p%2F2136187%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K344-TempSenser-S32DS36-RTD600-500-400-p24%2Fta-p%2F2136187%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20s32k358%20MCU%20temperature%20measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%40BillWen%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22ACCEPT%20AS%20SOLUTION%22%20%E6%8C%89%E9%92%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
