WDOG ISR
WDOG ISR
1,576件の閲覧回数
Shruthi_C
HI,
I have initialized WDOG with 500ms and Before WDOG  going to RESET,  we have only 128 clock cycles in WDOG ISR,  Can we increase this 128 clock cycles, because I want some things to write on param table before RESET.
Please support on this
Thank You
2 返答(返信)
1,551件の閲覧回数
VaneB
Hi @Shruthi_C
The reset can be delayed by the WDOG 128 BUS_CLK cycles, as you mentioned, but also can have more delay by the RCM up to 512 LPO clock cycles.
Please refer to Example S32K144 WDOG RCM interrupt.
B.R.
VaneB
1,535件の閲覧回数
Shruthi_C
HI,
Thank You so much VaneB
