S32k144 not receive in Logic analyzer
vinmotion
Hello engineers , im new to nxp and i dont know why every example CAN project for s32k144 when i test receive using logic analyzer it get all can error and cannot decode can id or data. hopefully you guys can test the code to check . Thanks a lot
PetrS
I used below PCAN setting
BR, Petr
PetrS
I tested your code on S32K144EVB-Q100 and with PCAN tool connected I see CAN FD message periodically received. Using a debugger no error is detected on FlexCAN module.
In you case error frame is sent, I guess. You can check module MCR/ECR/ESR1 registers to see a state and error detected. If using S32K144EVB-Q100 as well on your side, be sure board is powered by 12V and SBC CAN transceiver is active.
BR, Petr
Lixutong
Hello PetrS
I follow you code, and S32K144EVB-Q100 board is powered by 12V, and PCAN setting is same. but the CAN is seem not woking. The CANH-GND/CANL-GND is 1.3V, is it means the SBC CAN is not active, can you help me?
Lixutong
how to make SBC CAN transceiver active
vinmotion
Thank you sir but im fresher from university and nxp is all new to me , can you please share or screen shot how config pcan view to receive above program .. .
PetrS
BR, Petr
