S32K344 Whiteboard Example Project
21,192 次查看
StephenDu
@S32kUser
The S32K344 Whiteboard (S32K344-WB) is a reference design board for providing quick prototype verification, such as Body Domain Control, Gateway, Passive Entry Passive Start (PEPS), Motor Control, and so on. It Based on the 32-bit Arm® Cortex®-M7 S32K3 MCU in a 257 MPABGA package.
To help customers get familiar with the hardware quickly, a set of example projects are provided based on the Real-Time Drivers(RTD) provided by NXP. With these example projects, you can have an out-of-box experience with the S32K344-WB reference design. You can get this example package from the attachment on this page.
标记 (3)
21,192 次查看
StephenDu
To get more example projects for S32K344-WB, please contact me.
22 回复数
9,666 次查看
ekmas-19
Hi Stephen,
Can you provide an example using half Duplex Lpspi and for Qspi_lp? I would like to see how they are configured and used for the S32K344-WB board.
Preferably for a bare metal application.
Thanks!
9,638 次查看
ekmas-19
Is there an LLD Driver API? I have searched the website, and the S32DS help content. I cannot find one.
There is one for the mcuxpresso drivers, but these are different than what gets generated from RTD libraries with the Eclipse IDE.
18,526 次查看
StephenDu
We have provided a richer sample project. Please take it if you needed.
17,810 次查看
GavinLi1
Thanks for the info!
I have build errors when import the examples, shows at:
Also, I import the EB project, shows error:
Anything else I miss?
The S32DS  version:
S32 Design Studio for S32 Platform
Version: 3.5
Build id: 231128 (Update
Is it ok to compile the examples?
Thanks in advance!
Gavin
17,805 次查看
GavinLi1
I checked that again, it seems the issue for the EB.
I re-installed it and it's ok now. Projects can be built pass.
20,575 次查看
StephenDu
To get more Multi-Core example projects, please switch to the page: S32K324 Multi-Core Example Project based on Whiteboard
21,192 次查看
StephenDu
16,649 次查看
yomna_attia
Could you send me an example for client program, such as SocketTest, for the S32K344 WHITEBOARD?
Thanks in advance,
16,627 次查看
StephenDu
hi, Yomna
Due to this is a third-party software (Not sure the license limitation), please download by yourself. I can only to tell you the name which we are using: Wireshark.
16,618 次查看
yomna_attia
I mean what are the steps to configure the ethernet example for the S32K344 WB to be client (use the Socket example as Client ).
 Thanks in advance .
16,670 次查看
yomna_attia
I tried to reconfigure the LWIP example to be CLient but i faced this lwip_connect function returns error out of memory and i don't know why this happen so if you have a client example working properly could you you sent it to me
Thanks in advance
16,723 次查看
Mossab
would you please send me TCP/IP example that compatible with the mentioned board
16,700 次查看
StephenDu
hi, Mossab
The TCP/IP (LWIP) only has the LLD version, it is included in the S32K344_Whiteboard_Example(LLD)_RTM_1.0.0.zip attached in this page, please download and install it (Above this message).
16,788 次查看
yomna_attia
I want LWIP example
16,754 次查看
StephenDu
hi, Yomna
The LWIP only has the LLD version, it is included in the S32K344_Whiteboard_Example(LLD)_RTM_1.0.0.zip attached in this page, please download and install it (Above this message).
16,751 次查看
yomna_attia
I already checked it and i found the lwip example thank you for your support
I also have another question is this example client or server and what's the configured ip address
20,426 次查看
daich
I use s32k344 now, and i want to get some IAR project.
how to get it? thank you very much!
20,408 次查看
StephenDu
hi,
In the attachment, there is include one IAR example project which located in the IAR folder. You can create your own project based on this example project.
20,489 次查看
savantwxj
Would you help provide the mcal eb project of this S32K344 Whiteboard? I will use it as a starting point of my own mcal eb project based on our own HW board. Thanks!
20,469 次查看
StephenDu
hi, savantwxj In fact, it is there. Please refer to the "Tresos_Project" folder in each example project.
%3CLINGO-SUB%20id%3D%22lingo-sub-1500850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344%20%E7%94%B5%E5%AD%90%E7%99%BD%E6%9D%BF%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1500850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200218%22%20target%3D%22_blank%22%3E%40S32kUser%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fs32k3%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K344%20%E7%99%BD%E6%9D%BF%3C%2FA%3E%20(S32K344-WB)%20%E6%98%AF%E4%B8%80%E6%AC%BE%E7%94%A8%E4%BA%8E%E6%8F%90%E4%BE%9B%E5%BF%AB%E9%80%9F%E5%8E%9F%E5%9E%8B%E9%AA%8C%E8%AF%81%E7%9A%84%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%E6%9D%BF%EF%BC%8C%E4%BE%8B%E5%A6%82%E8%BD%A6%E8%BA%AB%E5%8A%9F%E8%83%BD%E5%9F%9F%E6%8E%A7%E5%88%B6%E3%80%81%E7%BD%91%E5%85%B3%E3%80%81%E8%A2%AB%E5%8A%A8%E8%BF%9B%E5%85%A5%E8%A2%AB%E5%8A%A8%E5%90%AF%E5%8A%A8%20(PEPS)%E3%80%81%E7%94%B5%E6%9C%BA%E6%8E%A7%E5%88%B6%E7%AD%89%E3%80%82%E5%AE%83%E5%9F%BA%E4%BA%8E%2032%20%E4%BD%8D%20Arm%C2%AE%20Cortex%C2%AE-M7%20S32K3%20MCU%EF%BC%8C%E9%87%87%E7%94%A8%20257%20MPABGA%20%E4%BB%A3%E7%A0%81%E5%8C%85%E3%80%82%3CBR%20%2F%3E%E4%B8%BA%E4%BA%86%E5%B8%AE%E5%8A%A9%E5%AE%A2%E6%88%B7%E5%BF%AB%E9%80%9F%E7%86%9F%E6%82%89%E7%A1%AC%E4%BB%B6%EF%BC%8C%E6%A0%B9%E6%8D%AE%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8F%90%E4%BE%9B%E7%9A%84%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2FRTD%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20(RTD)%3C%2FA%3E%20%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%80%E7%BB%84%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E3%80%82%E9%80%9A%E8%BF%87%E8%BF%99%E4%BA%9B%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BA%AB%E5%8F%97%20S32K344-WB%20%E5%8F%82%E8%80%83%E8%AE%BE%E8%AE%A1%E7%9A%84%E5%BC%80%E7%AE%B1%E5%8D%B3%E7%94%A8%E4%BD%93%E9%AA%8C%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%8E%E6%9C%AC%E9%A1%B5%E7%9A%84%E9%99%84%E4%BB%B6%E4%B8%AD%E8%8E%B7%E5%8F%96%E6%AD%A4%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%8C%85%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nxf50137_0-1659597023656.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nxf50137_0-1659597023656.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F189046iACA5AD67AB5E86ED%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nxf50137_0-1659597023656.png%22%20alt%3D%22nxf50137_0-1659597023656.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%98%AF%E5%90%A6%E6%9C%89%20LLD%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20API%EF%BC%9F%E6%88%91%E6%90%9C%E7%B4%A2%E4%BA%86%E7%BD%91%E7%AB%99%E5%92%8C%20S32DS%20%E7%9A%84%E5%B8%AE%E5%8A%A9%E5%86%85%E5%AE%B9%E3%80%82%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E4%B8%80%E4%B8%AA%E7%94%A8%E4%BA%8E%20mcuxpresso%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E8%BF%99%E4%BA%9B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8E%E4%BD%BF%E7%94%A8%20Eclipse%20IDE%20%E4%BB%8E%20RTD%20%E5%BA%93%E7%94%9F%E6%88%90%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2155485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2155485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E6%96%AF%E8%92%82%E8%8A%AC%E3%80%81%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E4%B8%80%E4%B8%AA%E4%BD%BF%E7%94%A8%E5%8D%8A%E5%8F%8C%E5%B7%A5%20Lpspi%20%E5%92%8C%20Qspi_lp%20%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%9F%E6%88%91%E6%83%B3%E7%9C%8B%E7%9C%8B%E5%AE%83%E4%BB%AC%E6%98%AF%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E5%92%8C%E7%94%A8%E4%BA%8E%20S32K344-WB%20%E6%9D%BF%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%A5%BD%E6%98%AF%E8%A3%B8%E6%9C%BA%E5%BA%94%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1878005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1878005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E5%B0%86%20S32K344%20WB%20%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%A4%BA%E4%BE%8B%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%88%E5%B0%86%20Socket%20%E7%A4%BA%E4%BE%8B%E7%94%A8%E4%BD%9C%E5%AE%A2%E6%88%B7%E7%AB%AF%EF%BC%89%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A2%84%E5%85%88%E8%A1%A8%E7%A4%BA%E6%84%9F%E8%B0%A2%20.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%BA%A6%E5%A7%86%E5%A8%9C%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E8%BF%99%E6%98%AF%E4%B8%80%E6%AC%BE%E7%AC%AC%E4%B8%89%E6%96%B9%E8%BD%AF%E4%BB%B6%EF%BC%88%E4%B8%8D%E6%B8%85%E6%A5%9A%E8%AE%B8%E5%8F%AF%E8%AF%81%E9%99%90%E5%88%B6%EF%BC%89%EF%BC%8C%E8%AF%B7%E8%87%AA%E8%A1%8C%E4%B8%8B%E8%BD%BD%E3%80%82%E6%88%91%E5%8F%AA%E8%83%BD%E5%91%8A%E8%AF%89%E4%BD%A0%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%90%8D%E7%A7%B0%EF%BC%9AWireshark.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E7%BB%99%E6%88%91%E5%8F%91%E4%B8%80%E4%B8%AA%3CSPAN%3ES32K344%20WHITEBOARD%20%E7%9A%84%E5%AE%A2%E6%88%B7%E7%AB%AF%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%E7%A4%BA%E4%BE%8B%EF%BC%88%E5%A6%82%20SocketTest%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A2%84%E5%85%88%E8%A1%A8%E7%A4%BA%E6%84%9F%E8%B0%A2%E3%80%81%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1876978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1876978%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%20LWIP%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BD%BF%E5%85%B6%E6%88%90%E4%B8%BA%20CLient%EF%BC%8C%E4%BD%86%E9%81%87%E5%88%B0%E4%BA%86%20lwip_connect%20%E5%87%BD%E6%95%B0%E8%BF%94%E5%9B%9E%E5%86%85%E5%AD%98%E4%B8%8D%E8%B6%B3%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E9%A2%84%E5%85%88%E8%87%B4%E8%B0%A2%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1876629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1876629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E8%8E%AB%E8%90%A8%E5%B8%83%3C%2FP%3E%3CP%3E%3CSPAN%3ETCP%2FIP%20(LWIP)%20%E5%8F%AA%E6%9C%89%20LLD%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%AE%83%E5%8C%85%E5%90%AB%E5%9C%A8%E6%9C%AC%E9%A1%B5%E6%89%80%E9%99%84%E7%9A%84%20S32K344_Whiteboard_Example(LLD)_RTM_1.0.0.zip%20%E4%B8%AD%EF%BC%8C%E8%AF%B7%E4%B8%8B%E8%BD%BD%E5%B9%B6%E5%AE%89%E8%A3%85%EF%BC%88%E5%9C%A8%E6%9C%AC%E6%B6%88%E6%81%AF%E4%B8%8A%E6%96%B9%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1876289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1876289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%E3%80%81%20%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E7%BB%99%E6%88%91%E5%8F%91%E4%B8%AA%E4%B8%8E%E4%B8%8A%E8%BF%B0%E6%9D%BF%E5%85%BC%E5%AE%B9%E7%9A%84%20TCP%2FIP%20%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1875257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%A3%80%E6%9F%A5%E8%BF%87%E4%BA%86%EF%BC%8C%E5%B9%B6%E6%89%BE%E5%88%B0%E4%BA%86%20lwip%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%20%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%99%E4%B8%AA%E7%A4%BA%E4%BE%8B%E6%98%AF%E5%AE%A2%E6%88%B7%E7%AB%AF%E8%BF%98%E6%98%AF%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%8C%E9%85%8D%E7%BD%AE%E7%9A%84%20IP%20%E5%9C%B0%E5%9D%80%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1875250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%BA%A6%E5%A7%86%E5%A8%9C%3C%2FP%3E%3CP%3ELWIP%20%E5%8F%AA%E6%9C%89%20LLD%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%AE%83%E5%8C%85%E5%90%AB%E5%9C%A8%E6%9C%AC%E9%A1%B5%E6%89%80%E9%99%84%E7%9A%84%20S32K344_Whiteboard_Example(LLD)_RTM_1.0.0.zip%20%E4%B8%AD%EF%BC%8C%E8%AF%B7%E4%B8%8B%E8%BD%BD%E5%B9%B6%E5%AE%89%E8%A3%85%EF%BC%88%E5%9C%A8%E6%9C%AC%E6%B6%88%E6%81%AF%E4%B8%8A%E6%96%B9%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1875019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E6%83%B3%E8%A6%81%20LWIP%20%E7%A4%BA%E4%BE%8B%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1783673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1783673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%8F%88%E6%A3%80%E6%9F%A5%E4%BA%86%E4%B8%80%E9%81%8D%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%98%AF%20EB%20%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E4%BA%86%E5%AE%83%EF%BC%8C%E7%8E%B0%E5%9C%A8%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%E9%A1%B9%E7%9B%AE%E5%8F%AF%E4%BB%A5%E6%8C%89%E9%A1%BA%E5%88%A9%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1783668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1783668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%E5%AF%BC%E5%85%A5%E7%A4%BA%E4%BE%8B%E6%97%B6%E5%87%BA%E7%8E%B0%E7%89%88%E6%9C%AC%E9%94%99%E8%AF%AF%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22GavinLi1_0-1704453986437.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22GavinLi1_0-1704453986437.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F256897i2B0DFCA0BB64EF06%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22GavinLi1_0-1704453986437.png%22%20alt%3D%22GavinLi1_0-1704453986437.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E5%AF%BC%E5%85%A5%20EB%20%E9%A1%B9%E7%9B%AE%E6%97%B6%E6%98%BE%E7%A4%BA%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22GavinLi1_1-1704454031885.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22GavinLi1_1-1704454031885.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F256898iE62373142624F6C7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22GavinLi1_1-1704454031885.png%22%20alt%3D%22GavinLi1_1-1704454031885.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%E9%81%97%E6%BC%8F%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3ES32DS%20%E7%89%88%E6%9C%AC%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%80%82%E7%94%A8%E4%BA%8E%20S32%20%E5%B9%B3%E5%8F%B0%E7%9A%84%20S32%20%E8%AE%BE%E8%AE%A1%E5%B7%A5%E4%BD%9C%E5%AE%A4%3CBR%20%2F%3E%E7%89%88%E6%9C%AC%EF%BC%9A3.5%20%3CBR%20%2F%3E%20%E7%89%88%E6%9C%AC%E5%8F%B7%EF%BC%9A231128%EF%BC%88%E6%9B%B4%E6%96%B0%EF%BC%89%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8F%AF%E4%BB%A5%E7%BC%96%E8%AF%91%E7%A4%BA%E4%BE%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1739007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1739007%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%8F%90%E4%BE%9B%E4%BA%86%E6%9B%B4%E4%B8%B0%E5%AF%8C%E7%9A%84%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E3%80%82%E5%A6%82%E6%9C%89%E9%9C%80%E8%A6%81%EF%BC%8C%E8%AF%B7%E6%9C%8D%E7%94%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1530835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1530835%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E9%99%84%E4%BB%B6%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%20IAR%20%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%8D%E4%BA%8E%20IAR%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%AD%A4%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E7%9A%84%E5%9F%BA%E7%A1%80%E4%B8%8A%E5%88%9B%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1529453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1529453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E7%94%A8%E7%9A%84%E6%98%AF%20s32k344%EF%BC%8C%E6%88%91%E6%83%B3%E5%81%9A%E4%B8%80%E4%BA%9B%20IAR%20%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%8E%B7%E5%BE%97%E5%AE%83%EF%BC%9F%20%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1528391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1528391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%BF%99%E4%B9%88%E5%A4%8D%E6%9D%82%E7%9A%84%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E3%80%82%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E4%BB%BB%E4%BD%95%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E9%80%90%E4%B8%AA%E5%AF%BC%E5%85%A5%E6%89%80%E9%9C%80%E7%9A%84%E6%A8%A1%E5%9D%97%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%9C%A8%E6%AD%A4%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1527984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1527984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%86%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E5%AE%8C%E6%95%B4%E7%9A%84%20mcal%20eb%20%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B7%B2%E7%BB%8F%E6%9C%89%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E7%9A%84%E8%AF%9D%EF%BC%8C%E9%87%8C%E9%9D%A2%E7%9A%84%E6%A8%A1%E5%9D%97%E4%BC%9A%E6%9B%B4%E5%A4%9A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1527855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1527855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%97%A8%EF%BC%8Csavantwxj%20%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8C%E5%AE%83%E5%B0%B1%E5%9C%A8%E9%82%A3%E9%87%8C%E3%80%82%E8%AF%B7%E5%8F%82%E8%80%83%E6%AF%8F%E4%B8%AA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%22Tresos_Project%22%20%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1527568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1527568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%8F%90%E4%BE%9B%E8%AF%A5%20S32K344%20%E7%94%B5%E5%AD%90%E7%99%BD%E6%9D%BF%E7%9A%84%20mcal%20eb%20%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%E6%88%91%E5%B0%86%E6%8A%8A%E5%AE%83%E4%BD%9C%E4%B8%BA%E5%9F%BA%E4%BA%8E%E6%88%91%E4%BB%AC%E8%87%AA%E5%B7%B1%E7%9A%84%E7%A1%AC%E4%BB%B6%E6%9D%BF%E7%9A%84%E6%88%91%E8%87%AA%E5%B7%B1%E7%9A%84%20mcal%20eb%20%E9%A1%B9%E7%9B%AE%E7%9A%84%E8%B5%B7%E7%82%B9%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1515431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1515431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%81%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%E7%9A%84%E5%A4%9A%E6%A0%B8%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%8C%E8%AF%B7%E5%88%87%E6%8D%A2%E5%88%B0%E9%A1%B5%E9%9D%A2%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K324-Multi-Core-Example-Project-based-on-Whiteboard%2Fm-p%2F1515429%23M17449%22%20target%3D%22_self%22%3E%E5%9F%BA%E4%BA%8E%E7%99%BD%E6%9D%BF%E7%9A%84%20S32K324%20%E5%A4%9A%E6%A0%B8%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1500852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20Whiteboard%20Example%20Project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1500852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%81%E8%8E%B7%E5%8F%96%E6%9B%B4%E5%A4%9A%3CSPAN%3ES32K344-WB%3C%2FSPAN%3E%E7%9A%84%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%8C%E8%AF%B7%E8%81%94%E7%B3%BB%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
