S32K328 RTC FAIL AFTER WAKEUP
1,611件の閲覧回数
Wade0905
Hello NXP Team,
I have previously developed RTC functionality on the S32K314, and after sleep wake-up it can continue counting time normally.
Now I am porting the project to the S32K328. However, while porting the RTC function, I encountered an issue:
After wake-up, the date (year/month/day) is reset to the default value 1970/1/1. In addition, the time (hours/minutes/seconds) does not preserve the originally configured value, but instead reflects only the elapsed time counted from the RTC start point.
For example, I initialize the RTC to 2026/05/08 05:06:07. After 1 minute of operation, when the MCU wakes up and I read back the RTC time, the date has reverted to 1970/01/01, and the time shows 00:01:00 instead of the expected 05:07:07.
This issue did not occur on the S32K314. What could be the possible causes of this problem?
Thank you.
7 返答(返信)
1,579件の閲覧回数
Julián_AragónM
Hello @Wade0905,
Have you checked RTC clock source? Confirm if SIRC and "Enabled in Standby" options are selected:
Also, keep in mind that RTC counter value will not be reset after wake-up, but it will reset by calling RTC initialization code in main.c. I can see you initialize RTC only after wake-up event. You can try reading reset reason to see if any other type of reset is being issued, and thus, clearing RTC value by mistake.
There is a community post you can refer to: S32K312: RTC- Preserving RTC counter value from getting resets once after every wakeup.
Please compare it to your configuration.
Julián
1,547件の閲覧回数
Wade0905
Hi Julián,
Thanks for your reponse.
Regarding clock source, I select SXOSC which same as our project in S32K314. Please see below picture for you ref.
Regarding init, I only do rtc_app_init() when WAKEUP_REASON != MCU_WAKEUP_REASON which same as our project in S32K314. Please see below picture for you ref.
I believe the counter continues counting during sleep mode, but the date and time are reset.
You can refer to my test results below.
At the first power-on, after rtc_app_init() is completed, the system starts counting from 2026/05/08, 5 hours, 6 minutes, and 7 seconds.
This is transmitted via CAN message 0x521.
  • BYTE 0: Year
  • BYTE 1: Month
  • BYTE 2: Day
  • BYTE 3: Hour
  • BYTE 4: Minute
  • BYTE 5: Second
  • BYTE 7: RESET REASON
After waking up from sleep for five minutes, the counter (CNT) continues counting. However, the year, month, day, hour, minute, and second all start counting from 1970/01/01 00:00:00, instead of continuing from the time set during initialization.
For 0x263, BYTE 2 to BYTE 5 represent the time extracted using Rtc_Ip_ConvertTimeDateToSeconds().
Please check the differences between the S32K328 and S32K314.
Why does the RTC on the S32K328 not retain the previously configured date and time, even though the same settings work correctly on the S32K314?
1,513件の閲覧回数
Julián_AragónM
Are you able to share your project, or the .mex configuration file, so I can inspect the code on my side?
The only reasons I can think of for the RTC not keeping the value are:
  1. Reset reason is other than Wake-Up and value is not kept since reset is non-functional.
  2. Even if reset reason is functional, it may not be wakeup, meaning the RTC is being re-initialized.
You've mentioned that byte 7 shares reset reason, however I cannot see in the images which reset reason is being sent over CAN. MCU_WAKEUP_REASON is declared as 28 inside the Power_Ip_Specific.h, I imagine CAN must send a 28?
If you are using MCAL, make sure the option "GPT Standby Wakeup Support" is enabled: S32K324 RTC value not preserved after sleep.
One thing I can suggest is to do a register dump (through the "Watch Registers" view). This may help you spot any differences between projects. Simply export both S32K328 & S32K314 register values as files, and you can compare them through any program, for example WinMerge.
Julián
1,501件の閲覧回数
Wade0905
Hi Julián,
Reset reason is 0x1C(28). If re-init happened, date and time should be 2026/5/8 05:06:07 which same as I set in rtc_app_init(). Besides, as I mentioned, I can see that the counter (CNT) continues counting, as the seconds value obtained using Rtc_Ip_ConvertTimeDateToSeconds() keeps increasing even after the MCU wakes up from standby mode.
I see the same problem in NXP Community for S32K328.
https://community.nxp.com/t5/S32K/S32K328%E5%86%85%E9%83%A8%E7%9A%84RTC%E6%98%AF%E4%B8%8D%E6%98%AF%E...
The .mex configuration file will be sent to you separately.
The RTC and standby-related code are as follows.
Executed once during initialization; not executed upon wake-up.
rtc_app_main() is executed every 500 ms.
mcu_standby_service() is executed once before entering standby mode.
Wade
1,279件の閲覧回数
Julián_AragónM
Hello @Wade0905,
Sorry for the late reply. Please see some comments below:
1. The .mex you've shared does not include any configuration for RTC. Please check the file and send it again if possible.
2. Actually. Rtc_Ip_Init() function is already standby-wakeup aware, and will skip software reset of the module if RTCC_CNTEN is already set:
Simply enable GPT Standby Wakeup Support:
With this, you can just keep the Rtc_Ip_SetTimeDate() API inside the if instruction:
/* Clear RDSS to prevent automatic wake up after setting RDSS during standby */
resetReason = Power_Ip_GetResetReason();
Rtc_Ip_Init(RTC_INST, &RTC_0_InitConfig_PB);
Rtc_Ip_EnableInterrupt(RTC_INST, RTC_IP_COUNTER_INTERRUPT);
Rtc_Ip_StartCounter(RTC_INST);
if(resetReason != MCU_WAKEUP_REASON)
Rtc_Ip_SetTimeDate(RTC_INST, &Rtc_DateTimeCfg_0);
Date and Time data are software based, while the RTC counter is hardware based. So, if MCU does not execute software to re-calculate year, month, and data after exiting standby, date and time will be showing the same after every wakeup.
I've created a simple example for S32K3X8EVB, as there is no evaluation board for S32K328. It simply configures two GPIO wakeups, and depending on which SW is pressed, either the RTC counter + date will be printed, or MCU will enter standby.
It even prints reset reason (28 for wakeup, 0 for power on reset, etc.), which helps identify whether a functional or destructive reset was done:
Hope it helps.
Julián
1,161件の閲覧回数
Wade0905
Hi Julián,
 .mex will send to you in private message.
I will try to follow and replicate your .mex configuration settings.
However, I noticed that in your test results, the date always starts from 1970/01/01, because the issue I am seeing is also that the date resets and starts counting again from 1970/01/01.
Could you try setting a different date before entering sleep mode and test again?
Thank you.
Wade
1,082件の閲覧回数
Julián_AragónM
Hi @Wade0905,
Thank you for sharing your .mex file. Configuration for POWER and RTC modules seem to be correct.
Yes, as I've mentioned, date and time data are software based, while the RTC counter is hardware based. While the RTC counter keeps counting in standby, actual date and time is still re-calculated at wake up.
You can try creating a "restore RTC context" function or use Standby RAM (kept alive through standby and wake up) to keep the date & time data in place.
There are some standby RAM examples in these community posts:
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2368275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K328%20RTC%E3%81%8C%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%81%AB%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2368275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E5%89%8D%E3%80%81S32K314%E4%B8%8A%E3%81%A7RTC%EF%BC%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%89%E6%A9%9F%E8%83%BD%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%8B%E3%82%89%E5%BE%A9%E5%B8%B0%E3%81%97%E3%81%9F%E5%BE%8C%E3%82%82%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%99%82%E9%96%93%E3%82%92%E8%A8%88%E6%B8%AC%E3%81%97%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92S32K328%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81RTC%E6%A9%9F%E8%83%BD%E3%82%92%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%80%81%E6%97%A5%E4%BB%98%EF%BC%88%E5%B9%B4%2F%E6%9C%88%2F%E6%97%A5%EF%BC%89%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%80%A4%E3%81%AE1970%2F1%2F1%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E6%99%82%E5%88%BB%EF%BC%88%E6%99%82%2F%E5%88%86%2F%E7%A7%92%EF%BC%89%E3%81%AF%E6%9C%80%E5%88%9D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%80%A4%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%9B%E3%81%9A%E3%80%81RTC%E3%81%AE%E9%96%8B%E5%A7%8B%E7%82%B9%E3%81%8B%E3%82%89%E7%B5%8C%E9%81%8E%E3%81%97%E3%81%9F%E6%99%82%E9%96%93%E3%81%AE%E3%81%BF%E3%82%92%E5%8F%8D%E6%98%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81RTC%E3%82%922026%2F05%2F08%2005%3A06%3A07%E3%81%AB%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%821%E5%88%86%E9%96%93%E3%81%AE%E5%8B%95%E4%BD%9C%E5%BE%8C%E3%80%81MCU%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6RTC%E3%81%AE%E6%99%82%E5%88%BB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E6%97%A5%E4%BB%98%E3%81%8C1970%2F01%2F01%E3%81%AB%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%99%82%E5%88%BB%E3%81%AF%E6%9C%9F%E5%BE%85%E3%81%95%E3%82%8C%E3%82%8B05%3A07%3A07%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F00%3A01%3A00%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AFS32K314%E3%81%A7%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RTC%20INIT.jpg%22%20style%3D%22width%3A%20439px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTC%20INIT.jpg%22%20style%3D%22width%3A%20439px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTC%20INIT.jpg%22%20style%3D%22width%3A%20439px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTC%20INIT.jpg%22%20style%3D%22width%3A%20439px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTC%20INIT.jpg%22%20style%3D%22width%3A%20439px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTC%20INIT.jpg%22%20style%3D%22width%3A%20439px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTC%20INIT.jpg%22%20style%3D%22width%3A%20439px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RTC%20INIT.jpg%22%20style%3D%22width%3A%20439px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386156i9C1E667500C818A8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RTC%20INIT.jpg%22%20alt%3D%22RTC%20INIT.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERTC%20INIT.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rtc_Ip_u32ChState.jpg%22%20style%3D%22width%3A%20733px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_u32ChState.jpg%22%20style%3D%22width%3A%20733px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_u32ChState.jpg%22%20style%3D%22width%3A%20733px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_u32ChState.jpg%22%20style%3D%22width%3A%20733px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_u32ChState.jpg%22%20style%3D%22width%3A%20733px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_u32ChState.jpg%22%20style%3D%22width%3A%20733px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_u32ChState.jpg%22%20style%3D%22width%3A%20733px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_u32ChState.jpg%22%20style%3D%22width%3A%20733px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386157i60E84FC632C2C529%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Rtc_Ip_u32ChState.jpg%22%20alt%3D%22Rtc_Ip_u32ChState.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERtc_Ip_u32ChState.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20RTC%20FAIL%20AFTER%20WAKEUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81S32K314%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A8%E5%90%8C%E3%81%98SXOSC%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%94%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E4%B8%8B%E8%A8%98%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SXOSC_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386327i0CA2E1843692CC5A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SXOSC_1.jpg%22%20alt%3D%22SXOSC_1.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESXOSC_1.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SXOSC_2.jpg%22%20style%3D%22width%3A%20340px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_2.jpg%22%20style%3D%22width%3A%20340px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_2.jpg%22%20style%3D%22width%3A%20340px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_2.jpg%22%20style%3D%22width%3A%20340px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_2.jpg%22%20style%3D%22width%3A%20340px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_2.jpg%22%20style%3D%22width%3A%20340px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_2.jpg%22%20style%3D%22width%3A%20340px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SXOSC_2.jpg%22%20style%3D%22width%3A%20340px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386328i3DBBC6CAE150C1B5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SXOSC_2.jpg%22%20alt%3D%22SXOSC_2.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESXOSC_2.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81S32K314%20%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81WAKEUP_REASON%20%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3E!%3D%3C%2FSTRONG%3E%3C%2FFONT%3E%20MCU_WAKEUP_REASON%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%20rtc_app_init()%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E4%B8%8B%E8%A8%98%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386329iB4A1ED53BE354921%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22rtc_app_init.jpg%22%20alt%3D%22rtc_app_init.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ertc_app_init.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E4%B8%AD%E3%82%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AE%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%80%81rtc_app_init()%20%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%202026%2F05%2F08%E3%80%815%20%E6%99%82%E9%96%93%206%20%E5%88%86%207%20%E7%A7%92%E3%81%8B%E3%82%89%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AFCAN%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B80x521%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%90%E3%82%A4%E3%83%880%EF%BC%9A%E5%B9%B4%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%82%A4%E3%83%881%EF%BC%9A%E6%9C%88%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%82%A4%E3%83%882%EF%BC%9A%E6%97%A5%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%82%A4%E3%83%883%EF%BC%9A%E6%99%82%E9%96%93%3C%2FLI%3E%3CLI%3EBYTE%204%3A%20%E5%88%86%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%82%A4%E3%83%885%EF%BC%9A2%E7%95%AA%E7%9B%AE%3C%2FLI%3E%3CLI%3E%E3%83%90%E3%82%A4%E3%83%887%EF%BC%9A%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%90%86%E7%94%B1%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22power%20on.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power%20on.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power%20on.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power%20on.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power%20on.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power%20on.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power%20on.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power%20on.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386330i31140623B5F32AE6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22power%20on.jpg%22%20alt%3D%22power%20on.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Epower%20on.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E5%E5%88%86%E9%96%93%E3%81%AE%E7%9D%A1%E7%9C%A0%E3%81%8B%E3%82%89%E7%9B%AE%E8%A6%9A%E3%82%81%E3%81%9F%E5%BE%8C%E3%82%82%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%EF%BC%88CNT%EF%BC%89%E3%81%AF%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%B9%B4%E3%80%81%E6%9C%88%E3%80%81%E6%97%A5%E3%80%81%E6%99%82%E3%80%81%E5%88%86%E3%80%81%E7%A7%92%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E6%99%82%E5%88%BB%E3%81%8B%E3%82%89%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%811970%2F01%2F01%2000%3A00%3A00%E3%81%8B%E3%82%89%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22wakeup.jpg%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wakeup.jpg%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wakeup.jpg%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wakeup.jpg%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wakeup.jpg%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wakeup.jpg%22%20style%3D%22width%3A%20725px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wakeup.jpg%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wakeup.jpg%22%20style%3D%22width%3A%20725px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386331i67F51EC5EBFEF76F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22wakeup.jpg%22%20alt%3D%22wakeup.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ewakeup.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E0x263%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%83%90%E3%82%A4%E3%83%882%E3%81%8B%E3%82%89%E3%83%90%E3%82%A4%E3%83%885%E3%81%AF%E3%80%81Rtc_Ip_ConvertTimeDateToSeconds()%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%8A%BD%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E6%99%82%E9%96%93%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20style%3D%22width%3A%20488px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20style%3D%22width%3A%20488px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20style%3D%22width%3A%20488px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20style%3D%22width%3A%20488px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20style%3D%22width%3A%20488px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20style%3D%22width%3A%20488px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20style%3D%22width%3A%20488px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20style%3D%22width%3A%20488px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386332i01C37725A505228F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20alt%3D%22Rtc_Ip_ConvertTimeDateToSeconds.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERtc_Ip_ConvertTimeDateToSeconds.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ES32K328%E3%81%A8S32K314%E3%81%AE%E9%81%95%E3%81%84%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3ES32K328%E3%81%AERTC%E3%81%AF%E3%80%81S32K314%E3%81%A7%E3%81%AF%E5%90%8C%E3%81%98%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%80%81%E3%81%AA%E3%81%9C%E4%BB%A5%E5%89%8D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2368933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20RTC%20FAIL%20AFTER%20WAKEUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2368933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255424%22%20target%3D%22_blank%22%3E%40Wade0905%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3ERTC%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9FSIRC%E3%81%A8%E3%80%8C%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E6%99%82%E3%81%AB%E6%9C%89%E5%8A%B9%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_1-1779316332707.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1779316332707.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1779316332707.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1779316332707.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1779316332707.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1779316332707.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1779316332707.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1779316332707.png%22%20style%3D%22width%3A%20415px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386246i0C2756FA97DD99CF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_1-1779316332707.png%22%20alt%3D%22Julin_AragnM_1-1779316332707.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJulin_AragnM_1-1779316332707.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_0-1779316326784.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1779316326784.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1779316326784.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1779316326784.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1779316326784.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1779316326784.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1779316326784.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1779316326784.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386245i8B636E8903855665%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_0-1779316326784.png%22%20alt%3D%22Julin_AragnM_0-1779316326784.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJulin_AragnM_0-1779316326784.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%20%3CSPAN%3ERTC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%AE%E5%80%A4%E3%81%AF%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%81%AB%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81main.c%E3%81%AERTC%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%A7%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E5%BE%8C%E3%81%AB%E3%81%AE%E3%81%BFRTC%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%90%86%E7%94%B1%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%80%81%E4%BB%96%E3%81%AE%E7%A8%AE%E9%A1%9E%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E7%99%BA%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E8%AA%A4%E3%81%A3%E3%81%A6RTC%E3%81%AE%E5%80%A4%E3%81%8C%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-RTC-Preserving-RTC-counter-value-from-getting-resets%2Fta-p%2F2028176%22%20target%3D%22_blank%22%3ES32K312%3A%20RTC%20-%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E3%81%9F%E3%81%B3%E3%81%AB%E4%B8%80%E5%BA%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%ABRTC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E5%80%A4%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%3C%2FA%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%94%E8%87%AA%E8%BA%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20RTC%20FAIL%20AFTER%20WAKEUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372802%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%E3%80%81%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AE.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E5%86%8D%E7%8F%BE%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E9%A0%85%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E6%97%A5%E4%BB%98%E3%81%8C%E5%B8%B8%E3%81%AB1970%2F01%2F01%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A8%E3%81%84%E3%81%86%E3%81%AE%E3%82%82%E3%80%81%E7%A7%81%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%82%E3%80%81%E6%97%A5%E4%BB%98%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%A61970%2F01%2F01%E3%81%8B%E3%82%89%E5%86%8D%E3%81%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E5%A7%8B%E3%82%81%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%E5%88%A5%E3%81%AE%E6%97%A5%E4%BB%98%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20RTC%20FAIL%20AFTER%20WAKEUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CSPAN%3E%E3%80%81%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%E3%81%95%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%90%86%E7%94%B1%E3%81%AF0x1C(28)%E3%81%A7%E3%81%99%E3%80%82%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%3CSPAN%3E%E3%81%AFrtc_app_init()%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F2026%2F5%2F8%2005%3A06%3A07%E3%81%A8%E5%90%8C%E3%81%98%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%89%8D%E8%BF%B0%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81MCU%E3%81%8C%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E5%BE%A9%E5%B8%B0%E3%81%97%E3%81%9F%E5%BE%8C%E3%82%82Rtc_Ip_ConvertTimeDateToSeconds()%E3%81%A7%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E7%A7%92%E6%95%B0%E3%81%AE%E5%80%A4%E3%81%8C%E5%A2%97%E5%8A%A0%E3%81%97%E7%B6%9A%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%EF%BC%88CNT%EF%BC%89%E3%81%8C%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E7%B6%9A%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3ENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E3%82%82S32K328%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K328%25E5%2586%2585%25E9%2583%25A8%25E7%259A%2584RTC%25E6%2598%25AF%25E4%25B8%258D%25E6%2598%25AF%25E4%25B8%258D%25E6%2594%25AF%25E6%258C%2581%25E9%2587%258D%25E5%2590%25AF%25E4%25BF%259D%25E5%25AD%2598%25E6%2597%25B6%25E9%2597%25B4%25E5%258A%259F%25E8%2583%25BD%25E5%2595%258A%2Fm-p%2F2158185%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K328%20%25E5%25%2086%20%2585%25%20E9%20%2583%25%20A8%20%25E7%25%209A%20%2584RTC%25%20E6%20%2598%25%20AF%20%25E4%25%20B8%20%258D%25%20E6%20%2598%25%20AF%20%25E4%25%20B8%20%258D%25%20E6%20%2594%25%20AF%20%25E6%25%208C%20%2581%25%20E9%20%2587%25%208D%20%25E5%25%2090%20%25AF%25%20E4%20%25BF%25%209D%20%25E5%25%20AD%20%2598%25%20E6%20%2597%25%20B6%20%25E9%25%2097%20%25B4%25%20E5%20%258A%25%209F%20%25E8%25%2083%20%25BD%25%20E5%20%2595%25%208A%2Fmp%2F2158511%2Fhighlight%2Ftrue%3Futm_source%3Dchatgpt.com%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E.mex%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%88%A5%E9%80%94%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3ERTC%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E9%96%A2%E9%80%A3%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E5%88%9D%E6%9C%9F%E5%8C%96%E6%99%82%E3%81%AB%E4%B8%80%E5%BA%A6%E3%81%A0%E3%81%91%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%81%AF%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_init.jpg%22%20style%3D%22width%3A%20447px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386436i109ED3FAB91F1408%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22rtc_app_init.jpg%22%20alt%3D%22rtc_app_init.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ertc_app_init.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3Ertc_app_main()%20%E3%81%AF%20500%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%94%E3%81%A8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rtc_app_main.jpg%22%20style%3D%22width%3A%20354px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_main.jpg%22%20style%3D%22width%3A%20354px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_main.jpg%22%20style%3D%22width%3A%20354px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_main.jpg%22%20style%3D%22width%3A%20354px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_main.jpg%22%20style%3D%22width%3A%20354px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rtc_app_main.jpg%22%20style%3D%22width%3A%20354px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386438i7D7759230FBD57F3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22rtc_app_main.jpg%22%20alt%3D%22rtc_app_main.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ertc_app_main.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3Emcu_standby_service()%20%E3%81%AF%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%E4%B8%80%E5%BA%A6%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mcu_standby_service.jpg%22%20style%3D%22width%3A%20460px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mcu_standby_service.jpg%22%20style%3D%22width%3A%20460px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mcu_standby_service.jpg%22%20style%3D%22width%3A%20460px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mcu_standby_service.jpg%22%20style%3D%22width%3A%20460px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mcu_standby_service.jpg%22%20style%3D%22width%3A%20460px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mcu_standby_service.jpg%22%20style%3D%22width%3A%20460px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F386439i02C0522ED5D4FB0A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22mcu_standby_service.jpg%22%20alt%3D%22mcu_standby_service.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Emcu_standby_service.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%89%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20RTC%20FAIL%20AFTER%20WAKEUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372644%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255424%22%20target%3D%22_blank%22%3E%40Wade0905%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AB%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%8E%B2%E8%BC%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%9F.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81RTC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E5%86%8D%E5%BA%A6%E9%80%81%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E5%AE%9F%E9%9A%9B%E3%80%82Rtc_Ip_Init()%20%E9%96%A2%E6%95%B0%E3%81%AF%E6%97%A2%E3%81%AB%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81RTCC_CNTEN%20%E3%81%8C%E6%97%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_0-1780008710327.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1780008710327.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1780008710327.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1780008710327.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_0-1780008710327.png%22%20style%3D%22width%3A%20743px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F387150i96281175B369AD8F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_0-1780008710327.png%22%20alt%3D%22Julin_AragnM_0-1780008710327.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJulin_AragnM_0-1780008710327.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EGPT%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_1-1780008724392.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1780008724392.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1780008724392.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1780008724392.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_1-1780008724392.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F387151i06A4A6D12E413699%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_1-1780008724392.png%22%20alt%3D%22Julin_AragnM_1-1780008724392.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJulin_AragnM_1-1780008724392.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81if%E6%96%87%E3%81%AE%E4%B8%AD%E3%81%ABRtc_Ip_SetTimeDate()%20API%E3%81%A0%E3%81%91%E3%82%92%E6%AE%8B%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F*%20Clear%20RDSS%20to%20prevent%20automatic%20wake%20up%20after%20setting%20RDSS%20during%20standby%20*%2F%0AresetReason%20%3D%20Power_Ip_GetResetReason()%3B%0A%0ARtc_Ip_Init(RTC_INST%2C%20%26amp%3BRTC_0_InitConfig_PB)%3B%0ARtc_Ip_EnableInterrupt(RTC_INST%2C%20RTC_IP_COUNTER_INTERRUPT)%3B%0ARtc_Ip_StartCounter(RTC_INST)%3B%0A%0Aif(resetReason%20!%3D%20MCU_WAKEUP_REASON)%0A%7B%0ARtc_Ip_SetTimeDate(RTC_INST%2C%20%26amp%3BRtc_DateTimeCfg_0)%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81RTC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81MCU%E3%81%8C%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E7%8A%B6%E6%85%8B%E3%81%8B%E3%82%89%E5%BE%A9%E5%B8%B0%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E5%B9%B4%E3%80%81%E6%9C%88%E3%80%81%E6%97%A5%E4%BB%98%E3%82%92%E5%86%8D%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%82%82%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%81%AF%E5%B8%B8%E3%81%AB%E5%90%8C%E3%81%98%E5%80%A4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ES32K328%E7%94%A8%E3%81%AE%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81S32K3X8EVB%E7%94%A8%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E5%8D%98%E7%B4%94%E3%81%AB2%E3%81%A4%E3%81%AEGPIO%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%E6%8A%BC%E3%81%95%E3%82%8C%E3%81%9F%E3%81%8B%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81RTC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%A8%E6%97%A5%E4%BB%98%E3%81%8C%E5%8D%B0%E5%AD%97%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%80%81MCU%E3%81%8C%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E7%8A%B6%E6%85%8B%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%90%86%E7%94%B1%EF%BC%88%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF28%E3%80%81%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF0%E3%81%AA%E3%81%A9%EF%BC%89%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%A9%9F%E8%83%BD%E7%9A%84%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%8B%E3%80%81%E7%A0%B4%E5%A3%8A%E7%9A%84%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%9F%E3%81%AE%E3%81%8B%E3%82%92%E8%AD%98%E5%88%A5%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Julin_AragnM_2-1780009219922.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_2-1780009219922.png%22%20style%3D%22width%3A%20659px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_2-1780009219922.png%22%20style%3D%22width%3A%20659px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_2-1780009219922.png%22%20style%3D%22width%3A%20659px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Julin_AragnM_2-1780009219922.png%22%20style%3D%22width%3A%20659px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F387152iB2C306A7E86E8DC7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Julin_AragnM_2-1780009219922.png%22%20alt%3D%22Julin_AragnM_2-1780009219922.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJulin_AragnM_2-1780009219922.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20RTC%20FAIL%20AFTER%20WAKEUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%0A%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E8%87%AA%E5%88%86%E3%81%AE%E5%81%B4%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%AA%BF%E3%81%B9%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3ERTC%E3%81%8C%E5%80%A4%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%A8%E3%81%97%E3%81%A6%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE2%E7%82%B9%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%90%86%E7%94%B1%E3%81%AF%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E4%BB%A5%E5%A4%96%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E5%80%A4%E3%81%AF%E4%BF%9D%E6%8C%81%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%90%86%E7%94%B1%E3%81%8C%E6%A9%9F%E8%83%BD%E7%9A%84%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFRTC%E3%81%8C%E5%86%8D%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%83%90%E3%82%A4%E3%83%887%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%90%86%E7%94%B1%E3%81%8C%E5%85%B1%E6%9C%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81CAN%E7%B5%8C%E7%94%B1%E3%81%A7%E3%81%A9%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%90%86%E7%94%B1%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E7%94%BB%E5%83%8F%E3%81%8B%E3%82%89%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CSPAN%3EPower_Ip_Specific.h%20%E5%86%85%E3%81%A7%20MCU_WAKEUP_REASON%20%E3%81%8C%2028%20%E3%81%A8%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81CAN%20%E3%81%AF%2028%20%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EMCAL%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8CGPT%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K324-RTC-value-not-preserved-after-sleep%2Fm-p%2F1965805%22%20target%3D%22_blank%22%3ES32K324%20RTC%20%E3%81%AE%E5%80%A4%E3%81%AF%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E5%BE%8C%E3%81%AB%E4%BF%9D%E6%8C%81%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%8C%E6%8F%90%E6%A1%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AE%E4%B8%80%E3%81%A4%E3%81%AF%E3%80%81%EF%BC%88%E3%80%8C%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E7%9B%A3%E8%A6%96%E3%80%8D%E3%83%93%E3%83%A5%E3%83%BC%E3%82%92%E9%80%9A%E3%81%97%E3%81%A6%EF%BC%89%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%80%E3%83%B3%E3%83%97%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E9%96%93%E3%81%AE%E9%81%95%E3%81%84%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82S32K328%E3%81%A8S32K314%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%80%A4%E3%82%92%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81WinMerge%E3%81%AA%E3%81%A9%E3%81%AE%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E6%AF%94%E8%BC%83%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2374160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20RTC%20FAIL%20AFTER%20WAKEUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2374160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%E3%80%81%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E5%86%8D%E7%8F%BE%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E9%A0%85%E7%9B%AE%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E7%B5%90%E6%9E%9C%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E6%97%A5%E4%BB%98%E3%81%8C%E5%B8%B8%E3%81%AB1970%2F01%2F01%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A8%E3%81%84%E3%81%86%E3%81%AE%E3%82%82%E3%80%81%E7%A7%81%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%82%E3%80%81%E6%97%A5%E4%BB%98%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%A61970%2F01%2F01%E3%81%8B%E3%82%89%E5%86%8D%E3%81%B3%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E5%A7%8B%E3%82%81%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%E5%88%A5%E3%81%AE%E6%97%A5%E4%BB%98%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2374647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20RTC%20FAIL%20AFTER%20WAKEUP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2374647%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255424%22%20target%3D%22_blank%22%3E%40Wade0905%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E.mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82POWER%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%A8RTC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%E5%88%A5%E3%81%AE%E6%97%A5%E4%BB%98%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E5%85%88%E3%81%BB%E3%81%A9%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%3CSPAN%3E%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81RTC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%99%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82RTC%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AF%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E7%8A%B6%E6%85%8B%E3%81%A7%E3%82%82%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%82%92%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%81%AF%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E5%86%8D%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81MCU%E3%81%8C%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E7%8A%B6%E6%85%8B%E3%81%8B%E3%82%89%E5%BE%A9%E5%B8%B0%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E5%B9%B4%E3%80%81%E6%9C%88%E3%80%81%E6%97%A5%E4%BB%98%E3%82%92%E5%86%8D%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%82%82%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%81%AF%E5%B8%B8%E3%81%AB%E5%90%8C%E3%81%98%E5%80%A4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%80%8CRTC%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E5%BE%A9%E5%85%83%E3%80%8D%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4RAM%EF%BC%88%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E6%99%82%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E6%99%82%E3%81%AB%E3%82%82%E4%BF%9D%E6%8C%81%E3%81%95%E3%82%8C%E3%82%8B%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%97%A5%E4%BB%98%E3%81%A8%E6%99%82%E5%88%BB%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E6%8A%95%E7%A8%BF%E3%81%AB%E3%81%AF%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4RAM%E3%81%AE%E4%BE%8B%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%8E%B2%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K3-Low-Power-Management-AN-and-demos%2Fta-p%2F1527724%22%20target%3D%22_blank%22%3ES32K3%E3%81%AE%E4%BD%8E%E6%B6%88%E8%B2%BB%E9%9B%BB%E5%8A%9B%E7%AE%A1%E7%90%86AN%E3%81%A8%E3%83%87%E3%83%A2%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD600-MCAL-amp-IP-S32K3-Low-Power-Management-AN-and-demos%2Fta-p%2F1993152%22%20target%3D%22_blank%22%3E%5BRTD600%20MCAL%20%26amp%3B%20IP%5D%20S32K3%20%E4%BD%8E%E6%B6%88%E8%B2%BB%E3%83%91%E3%83%AF%E3%83%BC%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8BAN%E3%81%A8%E3%83%87%E3%83%A2%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
