S32K311 - FlexCAN using FIRC not working
2,802 次查看
geeznxp
I'm trying to implement FlexCAN using FIRC clock mode, but not able to successfully tx and rx CAN data. However, CAN is able to tx and rx when FXOSC is configured. According to the Clock diagram, FlexCAN is using FIRC_CLK (/2) on 24Mhz resulting in 500kbps CAN bit rate. I don't understand what I'm doing wrong.
Please refer to the Clock settings below. I'm attaching code base zip as well.
Please help me run FlexCAN on FIRC.
#s32k3 AUTOMOTIVE-RTD NXPCAN
2,624 次查看
Julián_AragónM
Hi @geeznxp,
I've also tested your SW with PCAN USB correctly, both with 0x240 & 0x420 IDs:
I imagine you are using a custom board, correct? I strongly suggest comparing your design with either S32K31XEVB-Q100 EVB or S32K312EVB-Q172 EVB. Specifically, the CAN interface. You can also refer to S32K3 Hardware Design Guidelines.
Also, please check the terminating resistors. I think the issue is due to bus termination.
Julián
8 回复数
2,705 次查看
Julián_AragónM
Hi @geeznxp, 
I've imported and tested your project. I can see both 014h and 015h IDs being sent correctly when connecting a PCAN-USB analyzer:
However, CAN bit rate is set to 250kbps with 87.5% SP, not 500kbps:
You can calculate the bit rate values for 500kbps using the MPC5xxx/S32Kxx/LPCxxxx: CAN / CAN FD bit timing calculation tool.
Julián
2,684 次查看
geeznxp
I'm receiving BUSHEAVY when the same firmware is tested on PCAN-View resulting in no data reception.
What could be the reason to get BUSHEAVY status ?
2,690 次查看
geeznxp
Thanks for your response.
What hardware module are you using?
2,690 次查看
geeznxp
2,676 次查看
Julián_AragónM
Hi @geeznxp,
I tested your SW in the S32K31XEVB-Q100 Evaluation Board. I connected CAN Rx/Tx to PCAN-USB analyzer and tested with 250kbps.
Can you try one of the available examples from the RTD package?  Or alternatively, these community examples:
As for the PCAN error message "bus heavy", that is a very broad description. Could you confirm if your bus has correct terminating resistors?
Julián
2,653 次查看
geeznxp
Hi Julian,
After referring to the examples you have shared, I have made another program having CAN tx and rx on interrupt with sampling point as 75% and running entirely on FIRC.
But I'm still not able to receive data on CAN. Whereas if a CAN message is sent from PCAN its response is successfully received. But messages are not getting transmitted on the specified interval.
I'm attaching the screenshots as well as zip file. Can you please take a look at it ?
2,625 次查看
Julián_AragónM
Hi @geeznxp,
Julián
2,553 次查看
geeznxp
Hi @Julián_AragónM,
Thanks for your help.
Yes I'm using a custom board to test.
I was successfully able to execute CAN on the above firmware when I changed a few CAN settings attached in the screenshot.
I'm not sure what is the root cause of it, but as of now it is working with BTR 0 = 40h and BTR 1 = 2Bh Sample point 81%.
I would also compare the design with the EVB boards you have linked.
Thanks so much
%3CLINGO-SUB%20id%3D%22lingo-sub-2345081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K311%20-%20%E4%BD%BF%E7%94%A8%20FIRC%20%E7%9A%84%20FlexCAN%20%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%3CSTRONG%3E%E4%BD%BF%E7%94%A8%20FIRC%20%E6%97%B6%E9%92%9F%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%E5%AE%9E%E7%8E%B0%20FlexCAN%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E6%88%90%E5%8A%9F%E6%94%B6%E5%8F%91%20CAN%20%E6%95%B0%E6%8D%AE%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%3CU%3E%E5%9C%A8%E9%85%8D%E7%BD%AE%20FXOSC%20%E6%97%B6%EF%BC%8CCAN%20%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E6%94%B6%E5%8F%91%3C%2FU%3E%E3%80%82%E6%A0%B9%E6%8D%AE%E6%97%B6%E9%92%9F%E5%9B%BE%EF%BC%8CFlexCAN%20%E4%BD%BF%E7%94%A8%2024Mhz%20%E7%9A%84%20FIRC_CLK%20(%2F2)%EF%BC%8CCAN%20%E6%AF%94%E7%89%B9%E7%8E%87%E4%B8%BA%20500kbps%E3%80%82%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E6%88%91%E5%81%9A%E9%94%99%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%E3%80%82%E6%88%91%E8%BF%98%E9%99%84%E4%B8%8A%E4%BA%86%E4%BB%A3%E7%A0%81%E5%9F%BA%E7%A1%80%E5%8E%8B%E7%BC%A9%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E6%88%91%E5%9C%A8%20FIRC%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20FlexCAN%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%23s32k3%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FAUTOMOTIVE-RTD%2Fpd-p%2FAUTOMOTIVE-RTD%22%20class%3D%22lia-product-mention%22%20data-product%3D%222258-1%22%20target%3D%22_blank%22%3EAUTOMOTIVE-RTD%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FNXPCAN%2Fpd-p%2FNXPCAN%22%20class%3D%22lia-product-mention%22%20data-product%3D%222360-1%22%20target%3D%22_blank%22%3ENXPCAN%3C%2FA%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2345818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20-%20FlexCAN%20using%20FIRC%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261352%22%20target%3D%22_blank%22%3E%40geeznxp%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AF%BC%E5%85%A5%E5%B9%B6%E6%B5%8B%E8%AF%95%E4%BA%86%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%E5%9C%A8%E8%BF%9E%E6%8E%A5%20PCAN-USB%20%E5%88%86%E6%9E%90%E4%BB%AA%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%20014h%20%E5%92%8C%20015h%20ID%20%E8%A2%AB%E6%AD%A3%E7%A1%AE%E5%8F%91%E9%80%81%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7078a1.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381368i99D3BEA7E502AAEC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snag_1f7078a1.png%22%20alt%3D%22Snag_1f7078a1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8CCAN%20%E6%AF%94%E7%89%B9%E7%8E%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%20250kbps%EF%BC%8C87.5%25%20SP%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20500kbps%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f7106d7.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381369iDC79EA9B7E9EB917%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snag_1f7106d7.png%22%20alt%3D%22Snag_1f7106d7.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_1f71ac10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381370i1BE144E0BF1DD8C4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snag_1f71ac10.png%22%20alt%3D%22Snag_1f71ac10.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20MPC5xxx%2FS32Kxx%2FLPCxxxx%20%E8%AE%A1%E7%AE%97%20500kbps%20%E7%9A%84%E6%AF%94%E7%89%B9%E7%8E%87%E5%80%BC%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx-Knowledge-Base%2FMPC5xxx-S32Kxx-LPCxxxx-CAN-CAN-FD-bit-timing-calculation%2Fta-p%2F1119319%22%20target%3D%22_blank%22%3E%20%EF%BC%9ACAN%20%2F%20CAN%20FD%20%E6%AF%94%E7%89%B9%E5%AE%9A%E6%97%B6%E8%AE%A1%E7%AE%97%3C%2FA%3E%20%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20-%20FlexCAN%20using%20FIRC%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346175%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%E7%A1%AC%E4%BB%B6%E6%A8%A1%E5%9D%97%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20-%20FlexCAN%20using%20FIRC%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%E7%A1%AC%E4%BB%B6%E6%A8%A1%E5%9D%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20-%20FlexCAN%20using%20FIRC%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%20PCAN-View%20%E4%B8%8A%E6%B5%8B%E8%AF%95%E7%9B%B8%E5%90%8C%E5%9B%BA%E4%BB%B6%E6%97%B6%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%20%22BUSHEAVY%22%EF%BC%8C%E7%BB%93%E6%9E%9C%E6%97%A0%E6%B3%95%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%8E%B7%E5%BE%97%20%22%E5%B8%83%E4%BB%80%E6%80%BB%E7%BB%9F%20%22%E5%9C%B0%E4%BD%8D%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20-%20FlexCAN%20using%20FIRC%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261352%22%20target%3D%22_blank%22%3E%40geeznxp%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32K31XEVB-Q100%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ES32K31XEVB-Q100%20%E8%AF%84%E4%BC%B0%E6%9D%BF%E4%B8%8A%E6%B5%8B%E8%AF%95%E4%BA%86%E4%BD%A0%E7%9A%84%E8%BD%AF%E4%BB%B6%E3%80%82%3C%2FA%3E%E6%88%91%E5%B0%86%20CAN%20Rx%2FTx%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20PCAN-USB%20%E5%88%86%E6%9E%90%E4%BB%AA%EF%BC%8C%E5%B9%B6%E7%94%A8%20250kbps%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E8%AF%95%E8%AF%95%20RTD%20%E4%BB%A3%E7%A0%81%E5%8C%85%EF%BC%8C%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%B8%AD%E7%9A%84%E4%B8%80%E4%B8%AA%E5%8F%AF%E7%94%A8%E7%A4%BA%E4%BE%8B%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%EF%BC%8C%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E8%BF%99%E4%BA%9B%E7%A4%BE%E5%8C%BA%E8%8C%83%E4%BE%8B%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD600-MCAL-amp-IP-S32K3X4EVB-T172-FlexCAN-Example-Interrupt%2Fta-p%2F2142069%22%20target%3D%22_blank%22%3E%5BRTD600%20MCAL%20%26amp%3B%20IP%5D%20S32K3X4EVB%20-%20T172%20FlexCAN%20%E7%A4%BA%E4%BE%8B%EF%BC%88%E4%B8%AD%E6%96%AD%2F%E8%BD%AE%E8%AF%A2%EF%BC%89%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K312-CAN-Transmit-amp-Receive-Using-Polling-mode-DS3%2Fta-p%2F1789191%22%20target%3D%22_blank%22%3E%E7%A4%BA%E4%BE%8B%20S32K312%20CAN%20%E5%8F%91%E9%80%81%E5%92%8C%E6%8E%A5%E6%94%B6%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%BD%AE%E8%AF%A2%E6%A8%A1%E5%BC%8F%20DS3.5%20RTD300%3C%2FA%3E%3C%2FLI%3E%0A%3CLI%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K312-CAN-Transmit-amp-Receive-Using-MB-amp-FIFO-DMA%2Fta-p%2F1789196%22%20target%3D%22_blank%22%3E%E7%A4%BA%E4%BE%8B%20S32K312%20CAN%20%E5%8F%91%E9%80%81%26amp%3B%20%E6%8E%A5%E6%94%B6%E4%BD%BF%E7%94%A8%20MB%26amp%3B%20FIFO%20DMA%20DS3.5%20RTD300%3C%2FA%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E8%87%B3%E4%BA%8E%20%3CSPAN%3EPCAN%20%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%20%22%E6%80%BB%E7%BA%BF%20heavy%20%22%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E5%AE%BD%E6%B3%9B%E7%9A%84%E6%8F%8F%E8%BF%B0%E3%80%82%E4%BD%A0%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E4%BD%A0%E7%9A%84%E6%80%BB%E7%BA%BF%E6%98%AF%E5%90%A6%E6%9C%89%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%BB%88%E7%AB%AF%E7%94%B5%E9%98%BB%3C%2FSPAN%3E%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20-%20FlexCAN%20using%20FIRC%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261352%22%20target%3D%22_blank%22%3E%40geeznxp%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%98%E7%94%A8%20PCAN%20USB%20%E6%AD%A3%E7%A1%AE%E6%B5%8B%E8%AF%95%E4%BA%86%E6%82%A8%E7%9A%84%20SW%EF%BC%8C%E4%B8%A4%E8%80%85%E7%9A%84%20ID%20%E9%83%BD%E6%98%AF%200x240%26amp%3B%200x420%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snag_58433be.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_58433be.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_58433be.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snag_58433be.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381645iA313F05BD3512D9F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Snag_58433be.png%22%20alt%3D%22Snag_58433be.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%83%B3%E4%BD%A0%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%AE%9A%E5%88%B6%E6%9D%BF%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%E6%88%91%E5%BC%BA%E7%83%88%E5%BB%BA%E8%AE%AE%E5%B0%86%E6%82%A8%E7%9A%84%E8%AE%BE%E8%AE%A1%E4%B8%8E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32K31XEVB-Q100%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K31XEVB-Q100%20EVB%3C%2FA%3E%E6%88%96%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FS32K312EVB-Q172%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K312EVB-Q172%20EVB%3C%2FA%3E%20%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%E7%89%B9%E5%88%AB%E6%98%AF%20CAN%20%E6%8E%A5%E5%8F%A3%E3%80%82%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%8F%82%E9%98%85%E3%80%8A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DS32K3_HW-DesignPackage%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K3%20%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%E6%8C%87%E5%8D%97%E3%80%8B%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%E7%BB%88%E7%AB%AF%E7%94%B5%E9%98%BB%E3%80%82%20%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%E7%94%B1%E4%BA%8E%E6%80%BB%E7%BA%BF%E7%BB%88%E6%AD%A2%E9%80%A0%E6%88%90%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20-%20FlexCAN%20using%20FIRC%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346760%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E6%9C%B1%E5%88%A9%E5%AE%89%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%8F%82%E8%80%83%E4%BA%86%E6%82%A8%E5%88%86%E4%BA%AB%E7%9A%84%E7%A4%BA%E4%BE%8B%E5%90%8E%EF%BC%8C%E6%88%91%E5%88%B6%E4%BD%9C%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%9C%A8%E4%B8%AD%E6%96%AD%3CSTRONG%3E%E4%B8%8A%3C%2FSTRONG%3E%E8%BF%9B%E8%A1%8C%20CAN%20tx%20%E5%92%8C%20rx%EF%BC%8C%E9%87%87%E6%A0%B7%E7%82%B9%E4%B8%BA%2075%25%20%EF%BC%8C%E5%AE%8C%E5%85%A8%E5%9C%A8%20FIRC%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E6%8E%A5%E6%94%B6%20CAN%20%E4%B8%8A%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%20%3C%2FSTRONG%3E%3CSTRONG%3E%E8%80%8C%E5%A6%82%E6%9E%9C%E4%BB%8E%20PCAN%20%E5%8F%91%E9%80%81%20CAN%20%E6%8A%A5%E6%96%87%EF%BC%8C%E5%88%99%E4%BC%9A%E6%88%90%E5%8A%9F%E6%94%B6%E5%88%B0%E5%93%8D%E5%BA%94%E3%80%82%E4%BD%86%E6%98%AF%E6%8A%A5%E6%96%87%E5%B9%B6%E6%B2%A1%E6%9C%89%E5%9C%A8%E6%8C%87%E5%AE%9A%E7%9A%84%E6%97%B6%E9%97%B4%E9%97%B4%E9%9A%94%E5%86%85%E5%8F%91%E9%80%81%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E6%88%AA%E5%9B%BE%E5%92%8C%E5%8E%8B%E7%BC%A9%E6%96%87%E4%BB%B6%E3%80%82%E8%AF%B7%E6%82%A8%E7%9C%8B%E4%B8%80%E4%B8%8B%E5%A5%BD%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20-%20FlexCAN%20using%20FIRC%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F200831%22%20target%3D%22_blank%22%3E%40Juli%C3%A1n_Arag%C3%B3nM%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%9B%B4%E6%94%B9%E4%BA%86%E6%88%AA%E5%9B%BE%E4%B8%AD%E7%9A%84%E4%B8%80%E4%BA%9B%20CAN%20%E8%AE%BE%E7%BD%AE%E5%90%8E%EF%BC%8C%E6%88%91%E6%88%90%E5%8A%9F%E5%9C%B0%E5%9C%A8%E4%B8%8A%E8%BF%B0%E5%9B%BA%E4%BB%B6%E4%B8%8A%E6%89%A7%E8%A1%8C%E4%BA%86%20CAN%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E9%97%AE%E9%A2%98%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%8C%E4%BD%86%E7%9B%AE%E5%89%8D%E5%AE%83%E6%98%AF%E5%9C%A8%3CSTRONG%3EBTR%200%20%3D%2040h%20%E5%92%8C%20BTR%201%20%3D%202Bh%20%E9%87%87%E6%A0%B7%E7%82%B9%2081%25%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%B7%A5%E4%BD%9C%3C%2FSTRONG%3E%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E4%BC%9A%E5%B0%86%E8%AF%A5%E8%AE%BE%E8%AE%A1%E4%B8%8E%E6%82%A8%E9%93%BE%E6%8E%A5%E7%9A%84%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
