S32K-PMSM Sensorless FreeMASTER issue
5,357 次查看
bjrajendra
Senior Contributor I
Hello all,
I'm trying to use PMSM SW downloaded from the NXP website. Accordingly I want to use its FreeMaster tool. But When I'm trying open the corresponding FreeMaster control, Im getting the pop-up error stating incorrect file handle was associated with it.
Kindly help in solving this issue.
Thanks in advance,
BJ Rajendranath
标记 (1)
5,191 次查看
danielmartynek
Hi Raju,
Which FreeMaster version are you using?
If an old one, could you please download and use the up-to-date version 2.0.9?
FreeMASTER Run-Time Debugging Tool | NXP
Thank you,
BR, Daniel
5,191 次查看
danielmartynek
I'm not able to reproduce the error.
Did you follow all the steps described in the MTRDEVKSPNK144 Quick Start Guide or here: Getting Started with MTRDEVKSPNK144 | NXP
Is the FreeMaster tool installed?
BR, Daniel
5,189 次查看
bjrajendra
Hi Daniel,
Thanks for your response.
In fact I just opened the FreeMaster Application which was there in the project. I did shown like this.
I'm having a doubt that Do we need to Run the Project to Open this File ?
Thanks & Regards
Raju
5,192 次查看
danielmartynek
Hi Raju,
Thank you,
BR, Daniel
