[S32DS 3.6.1] Example Code disappear !?
1,267 次查看
CY9
餓死抬頭
As the title
I'd install brand new S32DS v3.6.1 on brand new OS.
I CAN *NOT* find any example project out :
What's wrong !??
S32DS-S32PLATFORM S32DS-ARM
14 回复数
1,265 次查看
CY9
After install `S32SDK_S32K1xx_RTM_4.0.2.exe` ,
The situation remains the same.
1,246 次查看
Robin_Shen
If you must use S32K1 SDK RTM 4.0.3, then please install S32K1 SDK RTM 4.0.3 in S32DS v3.4 by refer to the discussion in Where can I find it?S32_SDK_S32K1xx_RTM_4.0.3 .
S32DS v3.4 can be download by click S32 Design Studio – Windows/Linux -> S32 Design Studio IDE -> Previous -> S32 Design Studio for S32 Platform v.3.4 -> S32DS.3.4_b201217_win32.x86_64.exe
It is not recommended to install S32K1 SDK 4.0.x in S32DS v3.5 or v3.6. According to the currently available information, we don’t have any plan to integrate S32SDK S32K1XX 4.0.x into S32DS 3.5 or above version.
For new project development,  I recommend you to use the latest S32K1 RTD in S32DS v3.6.10. The old SDK will not be updated to fix bugs.
Please download Real-Time Drivers for S32K1 -> Automotive SW - S32K1_S32M24x - Real-Time Drivers for Cortex-M -> S32K1_S32M24X Real Time Drivers AUTOSAR R21-11 Version 3.0.0 ->  SW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip
Please refer to the instructions in the video(How To Download, Install and Configure the RTD 5.0.0 with S32 Design Studio 3.6.0) to install the specific version of S32K1 RTD that you need.
And don't forget to install NXP GCC for Arm Embedded Processors v10.2 build 1728
Robin
1,215 次查看
anbn
NXP, please confirm. Is the S32K1 SDK deprecated?
标记 (1)
1,213 次查看
Robin_Shen
It has been replaced by the S32K1 RTD since the last version, S32K1 SDK 4.0.3.
1,209 次查看
anbn
But that doesn't include example code, correct?
1,205 次查看
Robin_Shen
No. If the S32K1 RTD is installed correctly, the examples will be displayed in S32DS v3.6.x.
Here are the examples of S32K1 RTD:
1,195 次查看
anbn
Is it Windows-only? RTDs don't show up when adding the updatesite in Linux.
标记 (1)
1,236 次查看
CY9
Your S32DS report version to OS is 3.6.1 !! not `10` too...
1,234 次查看
CY9
I am trying to abandom uninstall this SHxT version ...
Will NEVER using this version .
Thanks for your comments.
1,239 次查看
CY9
I am using S32DS 3.6.10 ...
I don't know why it's default install path = `C:\NXP\S32DS.3.6.1\` , not `C:...6.10\`
My problem is :
the "Example Project" disappear !!
even already install S32K1_S32M24X Real Time Drivers in this instruction: https://community.nxp.com/t5/S32-SDK/S32K1XX-SD...
1,237 次查看
Robin_Shen
1. You will not see the S32K1 SDK 4.0.x in S32DS v3.6.x under any circumstances. Installing S32SDK_S32K1xx_RTM_4.0.2.exe will not make the SDK example appear in S32DSv3.6.x. If you need the S32K1 SDK, please install it according to my previous answer.
2. If the S32K1 RTD is not installed correctly, the example will also not be visible in S32DS v3.6.x. Please install SW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip according to the method shown in the video I provided earlier.
1,227 次查看
CY9
Because it cause another problem :
My previous project is create by RTM 4.0.2 ,
I can NOT open previous project , even using import function.
The best fastest solotion for me is install previous version + RTM 4.0.2 .
This SHxT waste me too much time on it.
1,224 次查看
Robin_Shen
Then please download S32DSv3.4 and then install SW32K1_S32DS_3.4.1_D2106.zip. This software package can be downloaded from the download page for S32DS.3.4_b201217_win32.x86_64.exe.
The SW32K1_S32DS_3.4.1_D2106.zip file contains the S32 SDK for S32K1xx RTM 4.0.2. For installation instructions, please refer to: S32 Design Studio v3.4 S32K1 Service Pack 1 released!
1,258 次查看
CY9
No RTM !? even already installed !?
Install RTM FAIL !??
cause :
# grep -in "RTM" * .*
PrjXX_LinMaster_144.mex:6: <mcu_data>s32sdk_s32k1xx_rtm_402</mcu_data>
.cproject:7: <stringMacro name="S32_SDK_PATH" type="VALUE_TEXT" value="${eclipse_home}../S32DS/software/S32SDK_S32K1XX_RTM_4.0.2"/>
.cproject:201: <stringMacro name="S32_SDK_PATH" type="VALUE_TEXT" value="${eclipse_home}../S32DS/software/S32SDK_S32K1XX_RTM_4.0.2"/>
.project:321: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/middleware/lin/doxygen/LIN_Stack_Architecture.png</locationURI>
.project:326: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/middleware/lin/doxygen/LIN_Stack_Configuration_Data.png</locationURI>
.project:331: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/middleware/lin/doxygen/lin_stack.dox</locationURI>
.project:336: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/rtos/osif/doxygen/osif.dox</locationURI>
.project:376: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/clock/doxygen/clock_manager.dox</locationURI>
.project:381: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/edma/doxygen/edma_driver.dox</locationURI>
.project:386: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/interrupt/doxygen/interrupt.dox</locationURI>
.project:391: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/lin/doxygen/lin.dox</locationURI>
.project:396: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/lptmr/doxygen/lptmr.dox</locationURI>
.project:401: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/lptmr/doxygen/lptmr_driver.dox</locationURI>
.project:406: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/pins/doxygen/pins.dox</locationURI>
.project:411: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/clock/S32K1xx/doxygen/clock_S32K1xx.dox</locationURI>
.project:417: <value>file:/${eclipse_home}../S32DS/software/S32SDK_S32K1XX_RTM_4.0.2</value>
%3CLINGO-SUB%20id%3D%22lingo-sub-2408295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BS32DS%203.6.1%5D%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E6%B6%88%E5%A4%B1%E4%BA%86%EF%BC%81%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%A5%BF%E6%AD%BB%E5%A4%B4%E5%83%8F%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%A6%82%E6%A0%87%E9%A2%98%E6%89%80%E7%A4%BA%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BC%9A%E5%9C%A8%E5%85%A8%E6%96%B0%E7%9A%84%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%AE%89%E8%A3%85%E5%85%A8%E6%96%B0%E7%9A%84%20S32DS%20v3.6.1%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%80%8E%E4%B9%88%E4%BA%86%20%EF%BC%81%EF%BC%9F%EF%BC%9F%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787706296255.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787706296255.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395320i47095328474EFB0B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787706296255.png%22%20alt%3D%22CY9_0-1787706296255.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787706296255.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32DS-S32PLATFORM%2Fpd-p%2FS32DS-S32PLATFORM%22%20class%3D%22lia-product-mention%22%20data-product%3D%223479-1%22%20target%3D%22_blank%22%3ES32DS-S32%E5%B9%B3%E5%8F%B0%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32DS-ARM%2Fpd-p%2FS32DS-ARM%22%20class%3D%22lia-product-mention%22%20data-product%3D%223477-1%22%20target%3D%22_blank%22%3ES32DS-ARM%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AE%83%E5%8F%AA%E6%94%AF%E6%8C%81Windows%E7%B3%BB%E7%BB%9F%E5%90%97%EF%BC%9F%E5%9C%A8Linux%E7%B3%BB%E7%BB%9F%E4%B8%AD%E6%B7%BB%E5%8A%A0%E6%9B%B4%E6%96%B0%E7%AB%99%E7%82%B9%E6%97%B6%EF%BC%8CRTD%E6%96%87%E4%BB%B6%E4%B8%8D%E4%BC%9A%E6%98%BE%E7%A4%BA%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8D%E3%80%82%E5%A6%82%E6%9E%9C%20S32K1%20RTD%20%E5%AE%89%E8%A3%85%E6%AD%A3%E7%A1%AE%EF%BC%8C%E7%A4%BA%E4%BE%8B%E5%B0%86%E5%9C%A8%20S32DS%20v3.6.x%20%E4%B8%AD%E6%98%BE%E7%A4%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%20S32K1%20RTD%20%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32K1%20RTD%203.0.0.png%22%20style%3D%22width%3A%20810px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32K1%20RTD%203.0.0.png%22%20style%3D%22width%3A%20810px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395355i6154CD95BE6F6470%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32K1%20RTD%203.0.0.png%22%20alt%3D%22S32K1%20RTD%203.0.0.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32K1%20RTD%203.0.0.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%86%E8%BF%99%E4%B8%8D%E5%8C%85%E5%90%AB%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%87%AA%E4%B8%8A%E4%B8%80%E7%89%88%E6%9C%AC%20S32K1%20SDK%204.0.3%20%E8%B5%B7%EF%BC%8C%E5%AE%83%E5%B7%B2%E8%A2%AB%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fautomotive-software-and-tools%2Freal-time-drivers-rtd%3AAUTOMOTIVE-RTD%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K1%20RTD%3C%2FA%3E%E5%8F%96%E4%BB%A3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%8C%E8%AF%B7%E7%A1%AE%E8%AE%A4%E3%80%82%3CSTRONG%3ES32K1%20SDK%20%E6%98%AF%E5%90%A6%E5%B7%B2%E5%BC%83%E7%94%A8%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%84%B6%E5%90%8E%E8%AF%B7%E4%B8%8B%E8%BD%BD%20S32DSv3.4%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AE%89%E8%A3%85%3CSTRONG%3ESW32K1_S32DS_3.4.1_D2106.zip%E3%80%82%3C%2FSTRONG%3E%E5%8F%AF%E4%BB%A5%E4%BB%8E%3CSTRONG%3ES32DS.3.4_b201217_win32.x86_64.exe%3C%2FSTRONG%3E%E7%9A%84%E4%B8%8B%E8%BD%BD%E9%A1%B5%E9%9D%A2%E4%B8%8B%E8%BD%BD%E6%AD%A4%E8%BD%AF%E4%BB%B6%E5%8C%85%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%22%20style%3D%22width%3A%20945px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%22%20style%3D%22width%3A%20945px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395351i89098099C9454559%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%22%20alt%3D%22S32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESW32K1_S32DS_3.4.1_D2106.zip%20%E6%96%87%E4%BB%B6%E5%8C%85%E5%90%AB%3CSTRONG%3ES32K1xx%20RTM%204.0.2%20%E7%9A%84%20S32%20SDK%3C%2FSTRONG%3E%20%E3%80%82%E6%9C%89%E5%85%B3%E5%AE%89%E8%A3%85%E8%AF%B4%E6%98%8E%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FS32-Design-Studio-v3-4-S32K1-Service-Pack-1-released%2Fta-p%2F1299799%22%20target%3D%22_self%22%3ES32%20Design%20Studio%20v3.4%20S32K1%20Service%20Pack%201%20%E5%B7%B2%E5%8F%91%E5%B8%83%EF%BC%81%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BC%9A%E5%BC%95%E5%8F%91%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%B9%8B%E5%89%8D%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%98%AF%E7%94%A8RTM%204.0.2%E5%88%9B%E5%BB%BA%E7%9A%84%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E4%B9%8B%E5%89%8D%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%8D%B3%E4%BD%BF%E4%BD%BF%E7%94%A8%E5%AF%BC%E5%85%A5%E5%8A%9F%E8%83%BD%E4%B9%9F%E4%B8%8D%E8%A1%8C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%9C%80%E5%BF%AB%3CSTRIKE%3E%E6%9C%80%E5%A5%BD%E7%9A%84%3C%2FSTRIKE%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E5%AE%89%E8%A3%85%E4%BB%A5%E5%89%8D%E7%9A%84%E7%89%88%E6%9C%AC%20%2B%20RTM%204.0.2%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E7%A0%B4%E4%BA%8B%E6%B5%AA%E8%B4%B9%E4%BA%86%E6%88%91%E5%A4%AA%E5%A4%9A%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_2-1787708167310.png%22%20style%3D%22width%3A%20605px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_2-1787708167310.png%22%20style%3D%22width%3A%20605px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395324i9C9103E63D57F095%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CY9_2-1787708167310.png%22%20alt%3D%22CY9_2-1787708167310.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_2-1787708167310.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%3CSTRIKE%3E%E5%8D%B8%E8%BD%BD%3C%2FSTRIKE%3E%E8%BF%99%E4%B8%AA%3CSTRONG%3ESHxT%3C%2FSTRONG%3E%E7%89%88%E6%9C%AC%E2%80%A6%E2%80%A6%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%BB%9D%E4%B8%8D%E4%BC%9A%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%AF%84%E8%AE%BA%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E7%9A%84%20S32DS%20%E5%90%91%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E6%8A%A5%E5%91%8A%E7%9A%84%E7%89%88%E6%9C%AC%E6%98%AF%3CU%3E%3CSTRONG%3E3.6.1%3C%2FSTRONG%3E%3C%2FU%3E%20%EF%BC%81%E8%80%8C%E4%B8%8D%E6%98%AF%2010%E2%80%A6%E2%80%A6%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787722320774.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787722320774.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395349iE785EA1FCBCAA167%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787722320774.png%22%20alt%3D%22CY9_0-1787722320774.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787722320774.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_1-1787722371649.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_1-1787722371649.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395350i01465DCE3F381578%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_1-1787722371649.png%22%20alt%3D%22CY9_1-1787722371649.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_1-1787722371649.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.%E5%9C%A8%3CSTRONG%3ES32DS%20v3.6.x%3C%2FSTRONG%3E%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E4%B8%8D%E5%88%B0%3CSTRONG%3ES32K1%20SDK%204.0.x%E3%80%82%3C%2FSTRONG%3E%E5%9C%A8%E4%BB%BB%E4%BD%95%E6%83%85%E5%86%B5%E4%B8%8B%E3%80%82%E5%AE%89%E8%A3%85%3CSTRONG%3ES32SDK_S32K1xx_RTM_4.0.2.exe%3C%2FSTRONG%3E%E4%B8%8D%E4%BC%9A%E4%BD%BF%20SDK%20%E7%A4%BA%E4%BE%8B%E5%87%BA%E7%8E%B0%E5%9C%A8%3CSTRONG%3ES32DSv3.6.x%3C%2FSTRONG%3E%E4%B8%AD%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%20S32K1%20SDK%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%E6%88%91%E4%B9%8B%E5%89%8D%E7%9A%84%E5%9B%9E%E7%AD%94%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%E5%A6%82%E6%9E%9C%20S32K1%20RTD%20%E6%B2%A1%E6%9C%89%E6%AD%A3%E7%A1%AE%E5%AE%89%E8%A3%85%EF%BC%8C%E5%88%99%E8%AF%A5%E7%A4%BA%E4%BE%8B%E5%9C%A8%3CSTRONG%3ES32DS%20v3.6.x%3C%2FSTRONG%3E%E4%B8%AD%E4%B9%9F%E4%B8%8D%E4%BC%9A%E6%98%BE%E7%A4%BA%E3%80%82%E8%AF%B7%E6%8C%89%E7%85%A7%E6%88%91%E4%B9%8B%E5%89%8D%E6%8F%90%E4%BE%9B%E7%9A%84%E8%A7%86%E9%A2%91%E4%B8%AD%E7%9A%84%E6%96%B9%E6%B3%95%E5%AE%89%E8%A3%85%3CSTRONG%3ESW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip%3C%2FSTRONG%3E%20%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20S32DS%203.6.10%20%E7%89%88%E6%9C%AC%E3%80%82...%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E9%BB%98%E8%AE%A4%E5%AE%89%E8%A3%85%E8%B7%AF%E5%BE%84%E6%98%AF%20%60C%3A%5CNXP%5CS32DS.3.6.1%5C%60%E4%B8%8D%E6%98%AF%20%60C%3A...6.10%5C%60%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E2%80%9C%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E2%80%9D%E6%B6%88%E5%A4%B1%E4%BA%86%EF%BC%81%3C%2FP%3E%3CP%3E%E7%94%9A%E8%87%B3%E5%B7%B2%E7%BB%8F%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-SDK%2FS32K1XX-SDK-installation%2Fm-p%2F2073028%2Fhighlight%2Ftrue%23M4041%22%20target%3D%22_blank%22%3E%E6%8C%89%E7%85%A7%E6%AD%A4%E8%AF%B4%E6%98%8E%E5%AE%89%E8%A3%85%E4%BA%86%3CI%3ES32K1_S32M24X%20%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FI%3E%EF%BC%9Ahttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-SDK%2FS32K1XX-SDK-installation%2Fmp%2F2073028%2Fhighlight%2Ftrue%23M4041%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EHI%3C%2FDIV%3E%0A%3CDIV%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20S32K1%20SDK%20RTM%204.0.3%EF%BC%8C%E8%AF%B7%E5%AE%89%E8%A3%85%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32K1%20SDK%20RTM%204.0.3%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%9C%A8%3CSTRONG%3ES32DS%20v3.4%E4%B8%AD%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%E5%8F%82%E8%A7%81%E7%9B%B8%E5%85%B3%E8%AE%A8%E8%AE%BA%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FWhere-can-I-find-it-S32-SDK-S32K1xx-RTM-4-0-3%2Ftd-p%2F1995922%22%20target%3D%22_blank%22%20shape%3D%22rect%22%3E%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E5%AE%83%EF%BC%9FS32_SDK_S32K1xx_RTM_4.0.3%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%3CBR%20%2F%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E7%82%B9%E5%87%BB%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E4%B8%8B%E8%BD%BD%3CSTRONG%3ES32DS%20v3.4%3C%2FSTRONG%3E%20%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DS32DS-3-4%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32%20Design%20Studio%20%E2%80%93%20Windows%2FLinux%3C%2FA%3E%20-%26gt%3B%20S32%20Design%20Studio%20IDE%20-%26gt%3B%20%E4%B8%8A%E4%B8%80%E6%AD%A5%20-%26gt%3B%20S32%20Design%20Studio%20for%20S32%20Platform%20v.3.4%20-%26gt%3B%20%3CEM%3ES32DS.3.4_b201217_win32.x86_64.exe%3C%2FEM%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E4%B8%8D%E5%BB%BA%E8%AE%AE%E5%9C%A8S32DS%20v3.5%E6%88%96v3.6%E4%B8%AD%E5%AE%89%E8%A3%85S32K1%20SDK%204.0.x%E3%80%82%E6%A0%B9%E6%8D%AE%E7%9B%AE%E5%89%8D%E6%8E%8C%E6%8F%A1%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E8%AE%A1%E5%88%92%E9%9B%86%E6%88%90%20S32SDK%20S32K1XX%204.0.x%20%E7%89%88%E6%9C%AC%E3%80%82%E5%8D%87%E7%BA%A7%E5%88%B0%20S32DS%203.5%20%E6%88%96%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E5%AF%B9%E4%BA%8E%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%BC%80%E5%8F%91%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DS32DS-3-6%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32DS%20v3.6.10%3C%2FA%3E%E4%B8%AD%E4%BD%BF%E7%94%A8%E6%9C%80%E6%96%B0%E7%9A%84%20S32K1%20RTD%E3%80%82%E6%97%A7%E7%89%88%20SDK%20%E5%B0%86%E4%B8%8D%E4%BC%9A%E6%9B%B4%E6%96%B0%E4%BB%A5%E4%BF%AE%E5%A4%8D%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%0A%3CDIV%3E%E8%AF%B7%E4%B8%8B%E8%BD%BD%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K1-RTD44-D%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20shape%3D%22rect%22%3E%E9%80%82%E7%94%A8%E4%BA%8E%20S32K1%20%E7%9A%84%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FA%3E-%26gt%3B%20%E6%B1%BD%E8%BD%A6%E8%BD%AF%E4%BB%B6%20-%20S32K1_S32M24x%20-%20%E9%80%82%E7%94%A8%E4%BA%8E%20Cortex-M%20%E7%9A%84%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20-%26gt%3B%20S32K1_S32M24X%20%E5%AE%9E%E6%97%B6%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20AUTOSAR%20R21-11%20%E7%89%88%E6%9C%AC%203.0.0-%26gt%3B%20SW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E8%AF%B7%E5%8F%82%E8%80%83%E8%A7%86%E9%A2%91%EF%BC%88%20%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20S32%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHow-To-Download-Install-and-Configure-the-RTD-5-0-0-with-S32%2Fta-p%2F2015104%22%20target%3D%22_blank%22%3E%20Design%20Studio%203.6.0%20%E4%B8%8B%E8%BD%BD%E3%80%81%E5%AE%89%E8%A3%85%E5%92%8C%E9%85%8D%E7%BD%AE%20RTD%205.0.0%3C%2FA%3E%3CSPAN%3E%20%EF%BC%89%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%20%EF%BC%8C%E5%AE%89%E8%A3%85%E6%82%A8%E9%9C%80%E8%A6%81%E7%9A%84%E7%89%B9%E5%AE%9A%E7%89%88%E6%9C%AC%E7%9A%84%20S32K1%20RTD%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E5%88%AB%E5%BF%98%E4%BA%86%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%89%E8%A3%85%3C%2FSPAN%3E%3CSTRONG%3ENXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20%E7%89%88%E6%9C%AC%201728%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22NXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22NXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388974i395D5BBDF9BA1D68%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22NXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%22%20alt%3D%22NXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ENXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3CBR%20%2F%3ERobin%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3F%3F%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787707907582.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787707907582.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395322i18450C6A33477721%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787707907582.png%22%20alt%3D%22CY9_0-1787707907582.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787707907582.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%B2%A1%E6%9C%89RTM%E7%89%88%E6%9C%AC%EF%BC%81%EF%BC%9F%E5%8D%B3%E4%BD%BF%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%EF%BC%81%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%AE%89%E8%A3%85%20RTM%20%E5%A4%B1%E8%B4%A5%EF%BC%81%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_1-1787708009334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_1-1787708009334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395323i01E38B6238AF9B2F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_1-1787708009334.png%22%20alt%3D%22CY9_1-1787708009334.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_1-1787708009334.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8E%9F%E5%9B%A0%20%EF%BC%9A%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_2-1787708167310.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_2-1787708167310.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395324i9C9103E63D57F095%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_2-1787708167310.png%22%20alt%3D%22CY9_2-1787708167310.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_2-1787708167310.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%60%60%60%3C%2FP%3E%3CP%3E%23%20grep%20-in%20%22RTM%22%20*%20.*%3C%2FP%3E%3CP%3EPrjXX_LinMaster_144.mex%3A6%3A%20%3CMCU_DATA%3Es32sdk_s32k1xx_rtm_402%3C%2FMCU_DATA%3E%3CBR%20%2F%3E%20.cproject%3A7%3A%3CSTRINGMACRO%20name%3D%22S32_SDK_PATH%22%20type%3D%22VALUE_TEXT%22%20value%3D%22%20%24%7Beclipse_home%7D%20..%2FS32DS%2Fsoftware%2FS32SDK_S32K1XX_RTM_4.0.2%22%3E%3C%2FSTRINGMACRO%3E%3CBR%20%2F%3E%20.cproject%3A201%3A%3CSTRINGMACRO%20name%3D%22S32_SDK_PATH%22%20type%3D%22VALUE_TEXT%22%20value%3D%22%20%24%7Beclipse_home%7D%20..%2FS32DS%2Fsoftware%2FS32SDK_S32K1XX_RTM_4.0.2%22%3E%3C%2FSTRINGMACRO%3E%3CBR%20%2F%3E%20.project%3A321%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2F%E4%B8%AD%E9%97%B4%E4%BB%B6%2Flin%2Fdoxygen%2FLIN_Stack_Architecture.png%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A326%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fmiddleware%2Flin%2Fdoxygen%2FLIN_Stack_Configuration_Data.png%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A331%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fmiddleware%2Flin%2Fdoxygen%2Flin_stack.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A336%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Frtos%2Fosif%2Fdoxygen%2Fosif.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E%20.project%3A376%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Fclock%2Fdoxygen%2Fclock_manager.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A381%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Fedma%2Fdoxygen%2Fedma_driver.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A386%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Finterrupt%2Fdoxygen%2Finterrupt.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A391%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Flin%2Fdoxygen%2Flin.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A396%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Flptmr%2Fdoxygen%2Flptmr.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A401%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Flptmr%2Fdoxygen%2Flptmr_driver.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A406%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Fpins%2Fdoxygen%2Fpins.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A411%3A%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Fclock%2FS32K1xx%2Fdoxygen%2Fclock_S32K1xx.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A417%3A%3CVALUE%3Efile%3A%2F%24%7Beclipse_home%7D..%2FS32DS%2Fsoftware%2FS32SDK_S32K1XX_RTM_4.0.2%3C%2FVALUE%3E%3C%2FP%3E%3CP%3E%60%60%60%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AE%89%E8%A3%85%20%60S32SDK_S32K1xx_RTM_4.0.2.exe%60%20%E5%90%8E%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%83%85%E5%86%B5%E4%BE%9D%E6%97%A7%E5%A6%82%E6%AD%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
