[S32DS 3.6.1] Example Code disappear !?
CY9
餓死抬頭
As the title
I'd install brand new S32DS v3.6.1 on brand new OS.
I CAN *NOT* find any example project out :
What's wrong !??
S32DS-S32PLATFORM S32DS-ARM
CY9
After install `S32SDK_S32K1xx_RTM_4.0.2.exe` ,
The situation remains the same.
Robin_Shen
If you must use S32K1 SDK RTM 4.0.3, then please install S32K1 SDK RTM 4.0.3 in S32DS v3.4 by refer to the discussion in Where can I find it?S32_SDK_S32K1xx_RTM_4.0.3 .
S32DS v3.4 can be download by click S32 Design Studio – Windows/Linux -> S32 Design Studio IDE -> Previous -> S32 Design Studio for S32 Platform v.3.4 -> S32DS.3.4_b201217_win32.x86_64.exe
It is not recommended to install S32K1 SDK 4.0.x in S32DS v3.5 or v3.6. According to the currently available information, we don’t have any plan to integrate S32SDK S32K1XX 4.0.x into S32DS 3.5 or above version.
For new project development,  I recommend you to use the latest S32K1 RTD in S32DS v3.6.10. The old SDK will not be updated to fix bugs.
Please download Real-Time Drivers for S32K1 -> Automotive SW - S32K1_S32M24x - Real-Time Drivers for Cortex-M -> S32K1_S32M24X Real Time Drivers AUTOSAR R21-11 Version 3.0.0 ->  SW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip
Please refer to the instructions in the video(How To Download, Install and Configure the RTD 5.0.0 with S32 Design Studio 3.6.0) to install the specific version of S32K1 RTD that you need.
And don't forget to install NXP GCC for Arm Embedded Processors v10.2 build 1728
Robin
anbn
NXP, please confirm. Is the S32K1 SDK deprecated?
Robin_Shen
It has been replaced by the S32K1 RTD since the last version, S32K1 SDK 4.0.3.
anbn
But that doesn't include example code, correct?
Robin_Shen
No. If the S32K1 RTD is installed correctly, the examples will be displayed in S32DS v3.6.x.
Here are the examples of S32K1 RTD:
anbn
Is it Windows-only? RTDs don't show up when adding the updatesite in Linux.
CY9
Your S32DS report version to OS is 3.6.1 !! not `10` too...
CY9
I am trying to abandom uninstall this SHxT version ...
Will NEVER using this version .
Thanks for your comments.
CY9
I am using S32DS 3.6.10 ...
I don't know why it's default install path = `C:\NXP\S32DS.3.6.1\` , not `C:...6.10\`
My problem is :
the "Example Project" disappear !!
even already install S32K1_S32M24X Real Time Drivers in this instruction: https://community.nxp.com/t5/S32-SDK/S32K1XX-SD...
Robin_Shen
1. You will not see the S32K1 SDK 4.0.x in S32DS v3.6.x under any circumstances. Installing S32SDK_S32K1xx_RTM_4.0.2.exe will not make the SDK example appear in S32DSv3.6.x. If you need the S32K1 SDK, please install it according to my previous answer.
2. If the S32K1 RTD is not installed correctly, the example will also not be visible in S32DS v3.6.x. Please install SW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip according to the method shown in the video I provided earlier.
CY9
Because it cause another problem :
My previous project is create by RTM 4.0.2 ,
I can NOT open previous project , even using import function.
The best fastest solotion for me is install previous version + RTM 4.0.2 .
This SHxT waste me too much time on it.
Robin_Shen
Then please download S32DSv3.4 and then install SW32K1_S32DS_3.4.1_D2106.zip. This software package can be downloaded from the download page for S32DS.3.4_b201217_win32.x86_64.exe.
The SW32K1_S32DS_3.4.1_D2106.zip file contains the S32 SDK for S32K1xx RTM 4.0.2. For installation instructions, please refer to: S32 Design Studio v3.4 S32K1 Service Pack 1 released!
CY9
No RTM !? even already installed !?
Install RTM FAIL !??
cause :
# grep -in "RTM" * .*
PrjXX_LinMaster_144.mex:6: <mcu_data>s32sdk_s32k1xx_rtm_402</mcu_data>
.cproject:7: <stringMacro name="S32_SDK_PATH" type="VALUE_TEXT" value="${eclipse_home}../S32DS/software/S32SDK_S32K1XX_RTM_4.0.2"/>
.cproject:201: <stringMacro name="S32_SDK_PATH" type="VALUE_TEXT" value="${eclipse_home}../S32DS/software/S32SDK_S32K1XX_RTM_4.0.2"/>
.project:321: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/middleware/lin/doxygen/LIN_Stack_Architecture.png</locationURI>
.project:326: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/middleware/lin/doxygen/LIN_Stack_Configuration_Data.png</locationURI>
.project:331: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/middleware/lin/doxygen/lin_stack.dox</locationURI>
.project:336: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/rtos/osif/doxygen/osif.dox</locationURI>
.project:376: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/clock/doxygen/clock_manager.dox</locationURI>
.project:381: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/edma/doxygen/edma_driver.dox</locationURI>
.project:386: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/interrupt/doxygen/interrupt.dox</locationURI>
.project:391: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/lin/doxygen/lin.dox</locationURI>
.project:396: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/lptmr/doxygen/lptmr.dox</locationURI>
.project:401: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/lptmr/doxygen/lptmr_driver.dox</locationURI>
.project:406: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/pins/doxygen/pins.dox</locationURI>
.project:411: <locationURI>S32SDK_S32K1XX_RTM_4.0.2/platform/drivers/src/clock/S32K1xx/doxygen/clock_S32K1xx.dox</locationURI>
.project:417: <value>file:/${eclipse_home}../S32DS/software/S32SDK_S32K1XX_RTM_4.0.2</value>
%3CLINGO-SUB%20id%3D%22lingo-sub-2408295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%A4%93%E6%AD%BB%E6%8A%AC%E9%A0%AD%26nbsp%3B%3C%2FP%3E%3CP%3EAs%20the%20title%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI'd%20install%20brand%20new%20S32DS%20v3.6.1%20on%20brand%20new%20OS.%3C%2FP%3E%3CP%3EI%20CAN%20*NOT*%20find%20any%20example%20project%20out%20%3A%26nbsp%3B%3C%2FP%3E%3CP%3EWhat's%20wrong%20!%3F%3F%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787706296255.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787706296255.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395320i47095328474EFB0B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787706296255.png%22%20alt%3D%22CY9_0-1787706296255.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787706296255.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32DS-S32PLATFORM%2Fpd-p%2FS32DS-S32PLATFORM%22%20class%3D%22lia-product-mention%22%20data-product%3D%223479-1%22%20target%3D%22_blank%22%3ES32DS-S32PLATFORM%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32DS-ARM%2Fpd-p%2FS32DS-ARM%22%20class%3D%22lia-product-mention%22%20data-product%3D%223477-1%22%20target%3D%22_blank%22%3ES32DS-ARM%3C%2FA%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408504%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20it%20Windows-only%3F%20RTDs%20don't%20show%20up%20when%20adding%20the%20updatesite%20in%20Linux.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408401%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo.%20If%20the%20S32K1%20RTD%20is%20installed%20correctly%2C%20the%20examples%20will%20be%20displayed%20in%20S32DS%20v3.6.x.%3C%2FP%3E%0A%3CP%3EHere%20are%20the%20examples%20of%20S32K1%20RTD%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32K1%20RTD%203.0.0.png%22%20style%3D%22width%3A%20810px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32K1%20RTD%203.0.0.png%22%20style%3D%22width%3A%20810px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395355i6154CD95BE6F6470%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32K1%20RTD%203.0.0.png%22%20alt%3D%22S32K1%20RTD%203.0.0.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32K1%20RTD%203.0.0.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408398%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBut%20that%20doesn't%20include%20example%20code%2C%20correct%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20has%20been%20replaced%20by%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fautomotive-software-and-tools%2Freal-time-drivers-rtd%3AAUTOMOTIVE-RTD%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32K1%20RTD%3C%2FA%3E%20since%20the%20last%20version%2C%20S32K1%20SDK%204.0.3.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%2C%20please%20confirm.%20Is%20the%26nbsp%3B%3CSTRONG%3ES32K1%20SDK%20deprecated%3F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThen%20please%20download%20S32DSv3.4%20and%20then%20install%26nbsp%3B%3CSTRONG%3ESW32K1_S32DS_3.4.1_D2106.zip.%26nbsp%3B%3C%2FSTRONG%3EThis%20software%20package%20can%20be%20downloaded%20from%20the%20download%20page%20for%20%3CSTRONG%3ES32DS.3.4_b201217_win32.x86_64.exe%3C%2FSTRONG%3E.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%22%20style%3D%22width%3A%20945px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%22%20style%3D%22width%3A%20945px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395351i89098099C9454559%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%22%20alt%3D%22S32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ES32DS%20v3.4%20SW32K1_S32DS_3.4.1_D2106%20S32K1%20SDK%204.0.2.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20SW32K1_S32DS_3.4.1_D2106.zip%20file%20contains%20the%20%3CSTRONG%3ES32%20SDK%20for%20S32K1xx%20RTM%204.0.2%3C%2FSTRONG%3E.%20For%20installation%20instructions%2C%20please%20refer%20to%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FS32-Design-Studio-v3-4-S32K1-Service-Pack-1-released%2Fta-p%2F1299799%22%20target%3D%22_self%22%3ES32%20Design%20Studio%20v3.4%20S32K1%20Service%20Pack%201%20released!%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBecause%20it%20cause%20another%20problem%20%3A%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMy%20previous%20project%20is%20create%20by%20RTM%204.0.2%20%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20can%20NOT%20open%20previous%20project%20%2C%20even%20using%20import%20function.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20best%20%3CSTRIKE%3Efastest%3C%2FSTRIKE%3E%20solotion%20for%20me%20is%20install%20previous%20version%20%2B%20RTM%204.0.2%20.%26nbsp%3B%3C%2FP%3E%3CP%3EThis%20SHxT%20waste%20me%20too%20much%20time%20on%20it.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_2-1787708167310.png%22%20style%3D%22width%3A%20605px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_2-1787708167310.png%22%20style%3D%22width%3A%20605px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395324i9C9103E63D57F095%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CY9_2-1787708167310.png%22%20alt%3D%22CY9_2-1787708167310.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_2-1787708167310.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20trying%20to%20%3CSTRIKE%3Eabandom%3C%2FSTRIKE%3E%20uninstall%20this%20%3CSTRONG%3ESHxT%3C%2FSTRONG%3E%20version%20...%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWill%20NEVER%20using%20this%20version%20.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20for%20your%20comments.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYour%20S32DS%20report%20version%20to%20OS%20is%203.6.%3CU%3E%3CSTRONG%3E1%3C%2FSTRONG%3E%3C%2FU%3E%20!!%20not%20%6010%60%20too...%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787722320774.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787722320774.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395349iE785EA1FCBCAA167%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787722320774.png%22%20alt%3D%22CY9_0-1787722320774.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787722320774.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_1-1787722371649.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_1-1787722371649.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395350i01465DCE3F381578%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_1-1787722371649.png%22%20alt%3D%22CY9_1-1787722371649.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_1-1787722371649.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.%20You%20will%20not%20see%20the%20%3CSTRONG%3ES32K1%20SDK%204.0.x%3C%2FSTRONG%3E%20in%20%3CSTRONG%3ES32DS%20v3.6.x%3C%2FSTRONG%3E%20under%20any%20circumstances.%20Installing%20%3CSTRONG%3ES32SDK_S32K1xx_RTM_4.0.2.exe%3C%2FSTRONG%3E%20will%20not%20make%20the%20SDK%20example%20appear%20in%20%3CSTRONG%3ES32DSv3.6.x%3C%2FSTRONG%3E.%20If%20you%20need%20the%20S32K1%20SDK%2C%20please%20install%20it%20according%20to%20my%20previous%20answer.%3C%2FP%3E%0A%3CP%3E2.%20If%20the%20S32K1%20RTD%20is%20not%20installed%20correctly%2C%20the%20example%20will%20also%20not%20be%20visible%20in%20%3CSTRONG%3ES32DS%20v3.6.x%3C%2FSTRONG%3E.%20Please%20install%20%3CSTRONG%3ESW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip%3C%2FSTRONG%3E%20according%20to%20the%20method%20shown%20in%20the%20video%20I%20provided%20earlier.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20using%20S32DS%203.6.10%20...%3C%2FP%3E%3CP%3EI%20don't%20know%20why%20it's%20default%20install%20path%20%3D%20%60C%3A%5CNXP%5CS32DS.3.6.1%5C%60%20%2C%20not%20%60C%3A...6.10%5C%60%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMy%20problem%20is%20%3A%26nbsp%3B%3C%2FP%3E%3CP%3Ethe%20%22Example%20Project%22%20disappear%20!!%26nbsp%3B%3C%2FP%3E%3CP%3Eeven%20already%20install%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-SDK%2FS32K1XX-SDK-installation%2Fm-p%2F2073028%2Fhighlight%2Ftrue%23M4041%22%20target%3D%22_blank%22%3E%3CI%3ES32K1_S32M24X%20Real%20Time%20Drivers%3C%2FI%3E%20in%20this%20instruction%3A%20https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-SDK%2FS32K1XX-SDK-installation%2Fm-p%2F2073028%2Fhighlight%2Ftrue%23M4041%26nbsp%3B%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EHi%3C%2FDIV%3E%0A%3CDIV%3EIf%20you%20must%20use%20S32K1%20SDK%20RTM%204.0.3%2C%20then%20please%20install%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32K1%20SDK%20RTM%204.0.3%3C%2FSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Ein%20%3CSTRONG%3ES32DS%26nbsp%3Bv3.4%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3Eby%20refer%20to%20the%20discussion%20in%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FWhere-can-I-find-it-S32-SDK-S32K1xx-RTM-4-0-3%2Ftd-p%2F1995922%22%20target%3D%22_blank%22%20shape%3D%22rect%22%3EWhere%20can%20I%20find%20it%3FS32_SDK_S32K1xx_RTM_4.0.3%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E.%3C%2FDIV%3E%0A%3CDIV%3E%3CBR%20%2F%3E%3CSTRONG%3ES32DS%20v3.4%3C%2FSTRONG%3E%20can%20be%20download%20by%20click%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DS32DS-3-4%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32%20Design%20Studio%20%E2%80%93%20Windows%2FLinux%3C%2FA%3E%20-%26gt%3B%20S32%20Design%20Studio%20IDE%20-%26gt%3B%20Previous%20-%26gt%3B%20S32%20Design%20Studio%20for%20S32%20Platform%20v.3.4%20-%26gt%3B%20%3CEM%3ES32DS.3.4_b201217_win32.x86_64.exe%3C%2FEM%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EIt%20is%20not%20recommended%20to%20install%20S32K1%26nbsp%3BSDK%204.0.x%26nbsp%3Bin%20S32DS%26nbsp%3Bv3.5%20or%20v3.6.%26nbsp%3BAccording%20to%20the%20currently%20available%20information%2C%20we%20don%E2%80%99t%20have%20any%20plan%20to%20integrate%20S32SDK%20S32K1XX%204.0.x%20into%20S32DS%203.5%20or%20above%20version.%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3EFor%20new%20project%20development%2C%26nbsp%3B%20I%20recommend%20you%20to%20use%20the%20latest%20S32K1%20RTD%20in%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DS32DS-3-6%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ES32DS%20v3.6.10%3C%2FA%3E.%20The%20old%20SDK%20will%20not%20be%20updated%20to%20fix%20bugs.%3C%2FSPAN%3E%0A%3CDIV%3EPlease%20download%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K1-RTD44-D%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20shape%3D%22rect%22%3EReal-Time%20Drivers%20for%20S32K1%3C%2FA%3E%26nbsp%3B-%26gt%3B%20Automotive%20SW%20-%20S32K1_S32M24x%20-%20Real-Time%20Drivers%20for%20Cortex-M%20-%26gt%3B%20S32K1_S32M24X%20Real%20Time%20Drivers%20AUTOSAR%20R21-11%20Version%203.0.0%20-%26gt%3B%20%26nbsp%3BSW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3EPlease%20refer%20to%20the%20instructions%20in%20the%20video(%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FHow-To-Download-Install-and-Configure-the-RTD-5-0-0-with-S32%2Fta-p%2F2015104%22%20target%3D%22_blank%22%3EHow%20To%20Download%2C%20Install%20and%20Configure%20the%20RTD%205.0.0%20with%20S32%20Design%20Studio%203.6.0%3C%2FA%3E%3CSPAN%3E)%20to%20install%20the%20specific%20version%20of%20S32K1%20RTD%20that%20you%20need.%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3EAnd%20don't%20forget%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Eto%20install%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ENXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22NXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22NXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F388974i395D5BBDF9BA1D68%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22NXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%22%20alt%3D%22NXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ENXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3EBest%20Regards%2C%3CBR%20%2F%3ERobin%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3F%3F%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787707907582.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787707907582.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395322i18450C6A33477721%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787707907582.png%22%20alt%3D%22CY9_0-1787707907582.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787707907582.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ENo%20RTM%20!%3F%20even%20already%20installed%20!%3F%3C%2FP%3E%3CP%3EInstall%20RTM%20FAIL%20!%3F%3F%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_1-1787708009334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_1-1787708009334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395323i01E38B6238AF9B2F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_1-1787708009334.png%22%20alt%3D%22CY9_1-1787708009334.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_1-1787708009334.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ecause%20%3A%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_2-1787708167310.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_2-1787708167310.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395324i9C9103E63D57F095%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_2-1787708167310.png%22%20alt%3D%22CY9_2-1787708167310.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_2-1787708167310.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%60%60%60%26nbsp%3B%3C%2FP%3E%3CP%3E%23%26nbsp%3Bgrep%20-in%20%22RTM%22%20*%20.*%26nbsp%3B%3C%2FP%3E%3CP%3EPrjXX_LinMaster_144.mex%3A6%3A%20%3CMCU_DATA%3Es32sdk_s32k1xx_rtm_402%3C%2FMCU_DATA%3E%3CBR%20%2F%3E.cproject%3A7%3A%20%3CSTRINGMACRO%20name%3D%22S32_SDK_PATH%22%20type%3D%22VALUE_TEXT%22%20value%3D%22%24%7Beclipse_home%7D..%2FS32DS%2Fsoftware%2FS32SDK_S32K1XX_RTM_4.0.2%22%3E%3C%2FSTRINGMACRO%3E%3CBR%20%2F%3E.cproject%3A201%3A%20%3CSTRINGMACRO%20name%3D%22S32_SDK_PATH%22%20type%3D%22VALUE_TEXT%22%20value%3D%22%24%7Beclipse_home%7D..%2FS32DS%2Fsoftware%2FS32SDK_S32K1XX_RTM_4.0.2%22%3E%3C%2FSTRINGMACRO%3E%3CBR%20%2F%3E.project%3A321%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fmiddleware%2Flin%2Fdoxygen%2FLIN_Stack_Architecture.png%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A326%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fmiddleware%2Flin%2Fdoxygen%2FLIN_Stack_Configuration_Data.png%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A331%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fmiddleware%2Flin%2Fdoxygen%2Flin_stack.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A336%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Frtos%2Fosif%2Fdoxygen%2Fosif.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A376%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Fclock%2Fdoxygen%2Fclock_manager.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A381%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Fedma%2Fdoxygen%2Fedma_driver.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A386%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Finterrupt%2Fdoxygen%2Finterrupt.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A391%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Flin%2Fdoxygen%2Flin.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A396%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Flptmr%2Fdoxygen%2Flptmr.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A401%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Flptmr%2Fdoxygen%2Flptmr_driver.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A406%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Fpins%2Fdoxygen%2Fpins.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A411%3A%20%3CLOCATIONURI%3ES32SDK_S32K1XX_RTM_4.0.2%2Fplatform%2Fdrivers%2Fsrc%2Fclock%2FS32K1xx%2Fdoxygen%2Fclock_S32K1xx.dox%3C%2FLOCATIONURI%3E%3CBR%20%2F%3E.project%3A417%3A%20%3CVALUE%3Efile%3A%2F%24%7Beclipse_home%7D..%2FS32DS%2Fsoftware%2FS32SDK_S32K1XX_RTM_4.0.2%3C%2FVALUE%3E%3C%2FP%3E%3CP%3E%60%60%60%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%5BS32DS%203.6.1%5D%20Example%20Code%20disappear%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20install%20%60S32SDK_S32K1xx_RTM_4.0.2.exe%60%20%2C%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20situation%20remains%20the%20same.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
