S32 Design Studio contiguous srec file
2,221 次查看
adria
For S32K116, from the end of the interrupt vector table section until the start of the flash config section, there is a gap of memory unused. This gap is specified with zeros if a raw binary is generated. Instead, if srec file is generated, that space is not specified.
Is it possible to generate the srec file so it specifies all addresses so the whole addresses in the file are contiguous to each other?
Adria
2,171 次查看
dianabatrlova
Hello Adria,
You can use the srec_cat tool for this purpose, see section "FILLING THE BLANKS" in the last link.
Please refer to the links below:
I hope it helps.
Diana
2,172 次查看
dianabatrlova
Hello Adria,
I hope it helps.
Diana
