where is reference of linker file,and so on
已解决
跳至解决方案
4,761 次查看
459021854
if I want to learn the detail grammar, directives and the process of linker file .ld and startup file .s .c    of S32k and so on where can I find the reference documents? thanks, much appreciated
标记 (3)
1 解答
4,622 次查看
lukaszadrapa
Hi Andy,
the documentation can be found in S32 Design Studio installation folder:
c:\NXP\S32DS_ARM_v2.2\S32DS\build_tools\gcc_v6.3\gcc-6.3-arm32-eabi\arm-none-eabi\share\docs\pdf\ld.pdf
Or attached here...
Lukas
在原帖中查看解决方案
2 回复数
4,622 次查看
459021854
thanks.
4,623 次查看
lukaszadrapa
Hi Andy,
Or attached here...
Lukas
