RAM Initialization
RAM Initialization
3,736 次查看
SreejithN
I am using s32k146 in my current project. In that i have a requirement to initialize the RAM except a particular section on every reset other than Power On Reset. (On Power On Reset all data should be initialized) . Is there any wat to do this?
3,687 次查看
VaneB
Hi @SreejithN
The following link is for an example of SRAM retention, which may help clarify how this works on the S32K1.
3,695 次查看
SreejithN
Hi @VaneB
Thanks for your information.
By using SRAM retention, it is possible to save either the entire SRAM_U or SRAM_L data. However, is there any other option to retain only a particular section on reset? For example, can we retain only the data between '0x2000EC00 to 0x2000EFFF' on SRAM_U while initializing all other data?
3,688 次查看
VaneB
Hi @SreejithN
3,726 次查看
VaneB
Hi @SreejithN
Take a look at section 31.3.4 (SRAM retention: power modes and resets) of the S32K1xx Series Reference Manual, Rev. 13.
B.R.
VaneB
