S32K148 RTC external power supply
2,157件の閲覧回数
siva280386
Hi NXP Team,
   In S32K148 Micro, we understand that the RTC module is active in all low power modes. In Our Project , we are planning to remove the power completely to the micro to reduce the overall control board power consumption. Is there possibility a possibility to provide power source to RTC module externally , to let this run still and when the MCU is powered up back, we still see the RTC timer running to know the sleep time of our control system. I remember some high end micros in NXP support different power supply pins to different modules of the micro controller , like ADC , RTC...
   We also read that RTC registers get reset on MCU power on reset. how does this work if incase there is an external power supply support?
Siva
3 返答(返信)
2,128件の閲覧回数
abdullah45
Hi @ VaneB
Please explain if there is an input pin for the VDD supply.
B.R.
2,112件の閲覧回数
VaneB
Hi @abdullah45
I suggest you take a look at Hardware Design Guidelines for S32K1xx.
2,139件の閲覧回数
VaneB
Hi @siva280386
The S32K1 family does not have an external power pin that allows you to keep the RTC active.
This family only has one power domain, VDD (3.3v or 5v).
B.R.
VaneB
