PortPin MSCR error within S32CT
已解决
跳至解决方案
2,283 次查看
beginner100
I'm using S32K311 for my application, trying to configure LPSPI0, but I keep seeing errors in PortPIN MSCR as shown below, please let me know what steps I might be missing.
Configured the following Pins
In Peripherals - Port, although I assign the correct Mscr, the PortPin Mode and Level Value fields are not populated.
Snippet of Problems window
1 解答
2,260 次查看
_Leo_
In S32K311_S32K310_IOMUX.xlsx file (S32K311_IO Signal Table sheet -> B column):
Note: To be able to see the attached documents of the reference manual you have to use a PDF reader such as Adobe Acrobat Reader.
在原帖中查看解决方案
3 回复数
2,268 次查看
_Leo_
Thank you for your interest in our products and for contributing to our community.
PortPin Mscr values are incorrect.
Please use the following values:
We hope this resolves your issue.
2,263 次查看
beginner100
Do you have more information on where these values are available or how to calculate or where to find them, thank you!
2,261 次查看
_Leo_
