PortPin MSCR error within S32CT
beginner100
I'm using S32K311 for my application, trying to configure LPSPI0, but I keep seeing errors in PortPIN MSCR as shown below, please let me know what steps I might be missing.
Configured the following Pins
In Peripherals - Port, although I assign the correct Mscr, the PortPin Mode and Level Value fields are not populated.
Snippet of Problems window
_Leo_
In S32K311_S32K310_IOMUX.xlsx file (S32K311_IO Signal Table sheet -> B column):
Note: To be able to see the attached documents of the reference manual you have to use a PDF reader such as Adobe Acrobat Reader.
_Leo_
Thank you for your interest in our products and for contributing to our community.
PortPin Mscr values are incorrect.
Please use the following values:
We hope this resolves your issue.
beginner100
Do you have more information on where these values are available or how to calculate or where to find them, thank you!
_Leo_
