NVIC Structure missing from S32DS
DanielGMBz
Recently I have started using the S32k144EVB board to get into S32 series of mcus.
While looking at the cookbook examples posted in the github repo, I noticed the struct for NVIC handling was in the S32k144.h file. However, this whole structure is nowhere to be found when creating a new project from scratch with the wizard in both S32DS 3.5.14 and the newer 3.6.0.
It would be highly appreciated if anyone could point out what I am doing wrong.
Thanks in advance.
danielmartynek
Hello @DanielGMBz,
You are right. I'm sorry for the inconvenience.
The NVIC can be found in the header file if the project is created in S32DS 3.4 or 2.2.
Thank you for pointing it out, it has been reported.
