Interrupt based message configuration
AparnaSridharan
Actually I need to create interrupt for function when a receive particular message id. Is there anyway i can do this for S32k144 board with S32ds.
Senlent
Hi@AparnaSridharan
The easiest way is to judge the data you need among all the received data
you can take a look at the revevant registers in the picture below.
I don't know if this register can achieve the function you want,and there is no demo program for your reference,
BR!
      Jim,
AparnaSridharan
Hi @Senlent ,
Actually I need to invoke an interrupt for a function when I receive particular CAN id which will stay continuously in receive function till all the lines in the configuration_function() get completed. For this whether I can use LPUART match register.
Senlent
Hi@AparnaSridharan
       I'm a little confused, your first question is related to uart, I can't understand what your second question has to do with uart? Your second question is simple, FlexCAN can support certain frame transceiving interrupts.
BR!
      Jim,
AparnaSridharan
Hi @Senlent ,
Actually What i need is I need to create a interrupt for a flex_CAN receive function. That interrupt need to be enabled only when particular CAN message id is received. After enabling the interrupt the control need to be there inside the receive function till interrupt is disabled.
