How to handle divide by zero exception in FPU
1,608 次查看
Kiran_Gowda
Hi All,
I'm working on S32k358 .I see the exception bit is set in the FPSCR for division by zero exception but i don't see any exception handler  is being triggered on that. I could see the vdiv.f32 instruction.
Thank you
1,565 次查看
davidtosenovjan
Hi, It apparently should not trigger an exception, it is rather expected to test status register after operation.
1,560 次查看
Kiran_Gowda
Is there any sample code to return value from the divide by zero operation upon checking the status register. Please share
1,520 次查看
davidtosenovjan
Unfortunately I don't have example code to share. I is just needed to test FPSCR register after operation.
