How to check pending interrupts
7,440件の閲覧回数
Sylvia_jiang
Hi Nxp Community,
        I am working on Lpspi+eDMA/PIT/CAN/EEPROM modules on S32K3. It is necessary to check if interrupts are serviced. I don't know Which registers indicate pending interrupts. Is there any solution?
Looking forward to your reply.
BR,
Sylvia
タグ(3)
7,343件の閲覧回数
danielmartynek
Hello @Sylvia_jiang,
That is really application-dependent.
The code you posted clears pending interrupts.
BR, Daniel
7 返答(返信)
7,432件の閲覧回数
danielmartynek
Hi Sylvia,
If there is pending interrupt, the corresponding NVIC_ISPRn and NVIC_ICPRn bit is set.
For more information about NVIC, please refer to ARM®v7-M Architecture Reference Manual.
The S32K3xx NVIC interrupt mapping is specified in the S32K3xx_interrupt_map.xlsx file that is attached to the RM.
7,421件の閲覧回数
Sylvia_jiang
Hi Daniel
       Thank for your prompt reply. I am studying on S32K3XXRM.pdf, Rev.4, 04/2022 which doesn't provide any detail about S32_NVIC ICPR. Could you send me S32K3xx_interrupt_map.xlsx?
BR,
Sylvia
7,409件の閲覧回数
danielmartynek
Hi Sylvia,
Yes, the S32K3xx RM does not provide details about the NVIC.
Refer to the ARMv7-M Architecture Reference Manual
https://developer.arm.com/documentation/ddi0403/latest/
The excel file is attached to the RM.
BR, Daniel
7,405件の閲覧回数
Sylvia_jiang
Hi Daniel,
            ARMv7-M Architecture Reference Manual.pdf has been downloaded successfully. But attachments are null.
7,400件の閲覧回数
danielmartynek
I'm sorry, the excel is attached to the S32K3xx RM because this is vendor specific unlike the description of the registers that can be found in the ARM documentation.
7,348件の閲覧回数
Sylvia_jiang
Hi Daniel
            Thank for your sending me map file and I have downloaded it. I try to use IntCtrl_Ip_GetPending api that is defined in IntCtrl_lp.c to check pending interrupts and use IntCtrl_Ip_ClearPending to clear pending interrupts as below. Is it correct action? Is there any matters I need to pay attention to?
7,344件の閲覧回数
danielmartynek
BR, Daniel
