How to check Flash and RAM utilization?
olimexsmart
I'm using S32 Design Studio for ARM to develop for the S32K146 MCU.
When I build something, how can I check how much Flash and RAM my solution is using, possibly combined with a percentage of the total?
davidtosenovjan
Hi, here you find a solution:
https://community.nxp.com/t5/S32-Design-Studio/How-can-I-check-my-RAM-usage/m-p/811864
Percentages it does not display, you will need to compare with info from linker command file or MAP file.
davidtosenovjan
olimexsmart
Thanks, but doing something simple like ST does?
davidtosenovjan
Unfortunately, such feature is not available.
