How can I check my RAM usage?
5,636 次查看
kbj
I use S32K144 and S32DS.
I want to know RAM usage.
Please let me know.
Thanks and best regards,
Byungju.
标记 (3)
5,418 次查看
jiri_kral
in project properties enable Print size:
You can see size output at the build end:
More details you can find on Erich Styger's blog:
text, data and bss: Code and Data Size Explained | MCU on Eclipse
Hope it helps.
Jiri
5,419 次查看
jiri_kral
Hope it helps.
Jiri
5,418 次查看
kbj
Hi Jiri,
Thanks for your help.
Byungju.
