HSE NVM AES key usage issue
1,375件の閲覧回数
DamonH
I have a porbram of HSE NVM AES key usage.
Here is my test flow,
1. Import AES Key 0
2. Import Public Key(Curve ID : ECC_SEC_SECP256R1)
3. Import AES Key 1
4. Use AES Key 0 & 1 to encrypt test pattern
AES Key 0 encrypt service response HSE_SRV_RSP_OK
AES Key 1 encrypt service response HSE_SRV_RSP_NOT_ALLOWED
AES Key 0 & 1 use same keyelement setting
Looks like point is 'import ecc pub key', but I'm not sure why this happended?
And I switch import timing of these AES keys, result is same.
Encrypt service by the AES key(witch is import after ecc pub key)will response HSE_SRV_RSP_NOT_ALLOWED.
MCU : S32K324
RTD version:RTD S32K3XX 2.0.0.202203311410
HSE FW version: s32k3x4_hse_fw_0.5.0_2.1.0_pb220625
タグ(3)
0 返答(返信)
