Fast Standby Boot Base Address.
4,388件の閲覧回数
aryandis
Have tried to change linker script for fast standby wakeup but always error. Can you please help me how to update linker for fast standby wakeup support.
15 返答(返信)
4,360件の閲覧回数
aryandis
all example are based on standby wakeup no fast stadnby wakeup .Do you have any example for RTD 3.0.0 based with linker updated.?
4,354件の閲覧回数
danielmartynek
Hi @aryandis,
The examples have fast wakeup too.
For instance, S32K344_GPIO_Wkup_S32DS_3_4_RTD_LLD_2_0.zip
include/Wkup.h
src/Wkup.c
Linker:
Any support, information, and technology (“Materials”) provided by NXP are provided AS IS,
without any warranty express or implied, and NXP disclaims all direct and indirect liability
and damages in connection with the Material to the maximum extent permitted by the applicable law.
NXP accepts no liability for any assistance with applications or product design.
Materials may only be used in connection with NXP products.
Any feedback provided to NXP regarding the Materials may be used by NXP without restriction.
4,339件の閲覧回数
aryandis
have configured boot base address 0x00402000 in MCU for standby wakeup and also updating linker with below info.
After adding  KEEP(*(.fast_wkup_boot_vector)) in .pflash getting error mentioned above.
How i can adjust size in this linker.  ?
4,307件の閲覧回数
danielmartynek
HEllo @aryandis,
Can you share the linker file here?
You can adjust the size of each SRAM section as needed, but the total combined size of all sections must not exceed the actual SRAM capacity.
BR, Daniel
4,280件の閲覧回数
aryandis
4,279件の閲覧回数
aryandis
can you lease also share me what configuration i have to do for fast standby wakeup. since i have used some of the reference and have done for fast standby wakeup
4,249件の閲覧回数
danielmartynek
Hello @aryandis,
All the necessary steps are demonstrated in the provided examples.
To enable Fast Wakeup, you must configure the boot address, which sets the entry point after wakeup.
This configuration is done by writing to the DCMRWF5 register, where you specify the base address of your custom vector table in standby SRAM and enable the Fast Wakeup mechanism.
BR, Daniel
4,242件の閲覧回数
aryandis
have done this configuration but still no wakeup is working.
4,238件の閲覧回数
danielmartynek
What about normal wake-up, does it work?
I would recommend that you create a support ticket and share the whole project there privately so that I can test it.
BR, Daniel
4,234件の閲覧回数
aryandis
standby wakeup working but i need for for faststadnby wakeup .
here i have done memory map.
.fast_wakp_boot_vector
0x20400000  0x0c load address 0x00402000
0x20400000    .= ALIGN(0x1000)
4,196件の閲覧回数
danielmartynek
Hello @aryandis,
Please create a support ticket and share you project (privately) so that I can test it.
Thank you
4,130件の閲覧回数
aryandis
have one requirement i want to do GPIO/CAN/RTC wakeup wakeup once it enter in sleep mode (which operating mode have to refer CORE_STADNBY ,STANDBY or FAST STANDBY or something else). after wakeup it should go to ISR and from ISR i can call EcuM_Checkwakeup for wakeup system.
Please guide me with configuration for RTD 3.0.0 .
4,114件の閲覧回数
danielmartynek
Can you please create a new community thread for the last question?
Regarding the fast wake-up, I would need to test your project - ideally through a support ticket.
4,362件の閲覧回数
danielmartynek
Hi @aryandis,
There are several examples demonstrating the use of Fast Wakeup available here:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K3-Low-Power-Management-AN-and-demos/ta-p/152772...
These examples are built using RTD 2.0.0. If you plan to run them, I recommend installing a fresh instance of S32 Design Studio 3.4 with only RTD 2.0.0 added. This helps avoid compatibility issues.
4,312件の閲覧回数
aryandis
%3CLINGO-SUB%20id%3D%22lingo-sub-2180328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%AB%98%E9%80%9F%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%AB%98%E9%80%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%B8%B8%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%AB%98%E9%80%9F%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E5%BE%8C%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%20Thread%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E9%AB%98%E9%80%9F%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E7%90%86%E6%83%B3%E7%9A%84%E3%81%AB%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%81%E4%BB%B6%E3%81%8C%201%20%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%A8%E3%80%81GPIO%2FCAN%2FRTC%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%20(%E3%81%A9%E3%81%AE%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%20CORE_STADNBY%E3%80%81STANDBY%E3%80%81FAST%20STANDBY%20%E3%81%AA%E3%81%A9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B)%E3%80%82%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%81%AF%20ISR%20%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81ISR%20%E3%81%8B%E3%82%89%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E7%94%A8%E3%81%AE%20EcuM_Checkwakeup%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ERTD%203.0.0%20%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248584%22%20target%3D%22_blank%22%3E%40aryandis%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%20(%E9%9D%9E%E5%85%AC%E9%96%8B%E3%81%A7)%20%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81faststadnby%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E.fast_wakp_boot_vector%3C%2FP%3E%3CP%3E0x20400000%200x0c%20%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x00402000%3C%2FP%3E%3CP%3E0x20400000%20.%3D%E6%95%B4%E5%88%97(0x1000)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%80%9A%E5%B8%B8%E3%81%AE%E8%B5%B7%E5%BA%8A%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%81%E3%82%B1%E3%83%83%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%85%A8%E4%BD%93%E3%82%92%E9%9D%9E%E5%85%AC%E9%96%8B%E3%81%A7%E5%85%B1%E6%9C%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248584%22%20target%3D%22_blank%22%3E%40aryandis%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BF%85%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BE%8B%E3%81%A7%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E9%AB%98%E9%80%9F%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%20%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%83%96%E3%83%BC%E3%83%88%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E3%80%81DCMRWF5%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%20SRAM%20%E5%86%85%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%99%E3%82%AF%E3%82%BF%E3%83%BC%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%80%81%E9%AB%98%E9%80%9F%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%20%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1759910594611.png%22%20style%3D%22width%3A%20607px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1759910594611.png%22%20style%3D%22width%3A%20607px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359865i99F702453EFEB103%2Fimage-dimensions%2F607x419%3Fv%3Dv2%22%20width%3D%22607%22%20height%3D%22419%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1759910594611.png%22%20alt%3D%22danielmartynek_0-1759910594611.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1759910594611.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181608%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECAN%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%AB%98%E9%80%9F%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%A7%8B%E6%88%90%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%A7%81%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E9%AB%98%E9%80%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BE%8B%E3%81%8B%E3%82%89%E3%81%AE%E5%8F%82%E7%85%A7%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K312-STANDBY-wake-up-using-RTC-DS3-5-RTD300%2Fta-p%2F1930115%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K312-STANDBY-wake-up-using-RTC-DS3-5-RTD300%2Fta-p%2F1930115%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181160%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248584%22%20target%3D%22_blank%22%3E%40aryandis%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%90%84%20SRAM%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%AA%BF%E6%95%B4CAN%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%90%88%E8%A8%88%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AE%20SRAM%20%E5%AE%B9%E9%87%8F%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E7%94%A8%E3%81%AB%20MCU%20%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x00402000%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%A7%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E.pflash%E3%81%ABKEEP(*(.fast_wkup_boot_vector))%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E5%BE%8C%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22aryandis_0-1759816091235.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22aryandis_0-1759816091235.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359693i896F50F8C01DF90C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22aryandis_0-1759816091235.png%22%20alt%3D%22aryandis_0-1759816091235.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Earyandis_0-1759816091235.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E7%94%A8%E3%81%AB%20MCU%20%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%200x00402000%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%A7%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E.pflash%E3%81%ABKEEP(*(.fast_wkup_boot_vector))%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E5%BE%8C%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%A7%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180450%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248584%22%20target%3D%22_blank%22%3E%40aryandis%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%AB%E3%81%AF%E9%AB%98%E9%80%9F%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81S32K344_GPIO_Wkup_S32DS_3_4_RTD_LLD_2_0.zip%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Einclude%2FWkup.h%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_0-1759740607148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_0-1759740607148.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359578iC4A5BB6EDBF82D7C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22danielmartynek_0-1759740607148.png%22%20alt%3D%22danielmartynek_0-1759740607148.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_0-1759740607148.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSTRONG%3Esrc%2FWkup.c%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_2-1759740826105.png%22%20style%3D%22width%3A%20710px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_2-1759740826105.png%22%20style%3D%22width%3A%20710px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359580i7D38407BFDB90B8D%2Fimage-dimensions%2F710x385%3Fv%3Dv2%22%20width%3D%22710%22%20height%3D%22385%22%20role%3D%22button%22%20title%3D%22danielmartynek_2-1759740826105.png%22%20alt%3D%22danielmartynek_2-1759740826105.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_2-1759740826105.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E3%83%AA%E3%83%B3%E3%82%AB%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielmartynek_3-1759740866663.png%22%20style%3D%22width%3A%20462px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielmartynek_3-1759740866663.png%22%20style%3D%22width%3A%20462px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F359581iD667F1885F7E4E67%2Fimage-dimensions%2F462x377%3Fv%3Dv2%22%20width%3D%22462%22%20height%3D%22377%22%20role%3D%22button%22%20title%3D%22danielmartynek_3-1759740866663.png%22%20alt%3D%22danielmartynek_3-1759740866663.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edanielmartynek_3-1759740866663.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3EAny%20support%2C%20information%2C%20and%20technology%20(%E2%80%9CMaterials%E2%80%9D)%20provided%20by%20NXP%20are%20provided%20AS%20IS%2C%20%3CBR%20%2F%3Ewithout%20any%20warranty%20express%20or%20implied%2C%20and%20NXP%20disclaims%20all%20direct%20and%20indirect%20liability%20%3CBR%20%2F%3Eand%20damages%20in%20connection%20with%20the%20Material%20to%20the%20maximum%20extent%20permitted%20by%20the%20applicable%20law.%20%3CBR%20%2F%3ENXP%20accepts%20no%20liability%20for%20any%20assistance%20with%20applications%20or%20product%20design.%20%3CBR%20%2F%3EMaterials%20may%20only%20be%20used%20in%20connection%20with%20NXP%20products.%20%3CBR%20%2F%3EAny%20feedback%20provided%20to%20NXP%20regarding%20the%20Materials%20may%20be%20used%20by%20NXP%20without%20restriction.%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BE%8B%E3%81%AF%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E9%AB%98%E9%80%9F%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82RTD%203.0.0%E3%81%AE%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Fast%20Standby%20Boot%20Base%20Address.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248584%22%20target%3D%22_blank%22%3E%40aryandis%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81Fast%20Wakeup%20%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%99%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E4%BE%8B%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K3-Low-Power-Management-AN-and-demos%2Fta-p%2F1527724%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K3-Low-Power-Management-AN-and-demos%2Fta-p%2F1527724%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E4%BE%8B%E3%81%AF%E3%80%81RTD%202.0.0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81RTD%202.0.0%20%E3%81%AE%E3%81%BF%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%20S32%20Design%20Studio%203.4%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
