FS26 FAQ: SPI Protocol Configuration is not sync with current FS26 implementation
cuongnguyenphu
Document si849710-FS26 FAQ Frequently Asked Questions(1.0).pdf mentioned about SPI configuration as following:
However, in current implemented code it will get fail if setup SPI configuration like that:
[C:\EB\tresos29\..\..\NXP\S32K3_FS26_R21-11_2.0.0_CD01\eclipse\plugins\Sbc_fs26_TS_T40D34M20I0R0/generate_PB/src/CDD_Sbc_fs26_PBcfg.c (signed):25]:
"The selected SpiChannelRef must has SpiDataWidth equal to 8"
It needs to update the document FS26 FAQ again to sync-up with current implementation code
cuongnguyenphu
Discussed internally
FAQ will be updated later
cuongnguyenphu
TomasVaverka
Discussed internally with the author of the FS26 FAQ document.
The fact is that the FS26 uses a 32-bit SPI, with the following arrangement:
MOSI (Main Out, Secondary In) bits:
• Bit 31: Main or fail-safe registers selection
• Bit 30 to 25: Register address• Bit 24: Read/Write (For reading Bit 24 = 0; For writing Bit 24 = 1)
• Bit 23 to 8: Control bits
• Bit 7 to 0: Cyclic redundant check (CRC)
MISO (Main In, Secondary Out) bits:
• Bit 31-24: General device status
• Bits 23 to 8: Extended device status, or device internal control register content or device flags
BRs, Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-1875152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS26%20FAQ%3A%20SPI%20Protocol%20Configuration%20is%20not%20sync%20with%20current%20FS26%20implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDocument%20%3CSTRONG%3Esi849710-FS26%20FAQ%20Frequently%20Asked%20Questions(1.0).pdf%20%3C%2FSTRONG%3Ementioned%20about%20SPI%20configuration%20as%20following%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cuongnguyenphu_0-1716781666606.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cuongnguyenphu_0-1716781666606.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F280884iED2AF544C50BC74D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cuongnguyenphu_0-1716781666606.png%22%20alt%3D%22cuongnguyenphu_0-1716781666606.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EHowever%2C%20in%20current%20implemented%20code%20it%20will%20get%20fail%20if%20setup%20SPI%20configuration%20like%20that%3A%3CBR%20%2F%3E%5BC%3A%5CEB%5Ctresos29%5C..%5C..%5CNXP%5CS32K3_FS26_R21-11_2.0.0_CD01%5Ceclipse%5Cplugins%5CSbc_fs26_TS_T40D34M20I0R0%2Fgenerate_PB%2Fsrc%2FCDD_Sbc_fs26_PBcfg.c%20(signed)%3A25%5D%3A%3CBR%20%2F%3E%3CSTRONG%3E%22The%20selected%20SpiChannelRef%20must%20has%20SpiDataWidth%20equal%20to%208%22%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3EIt%20needs%20to%20update%20the%20document%20FS26%20FAQ%20again%20to%20sync-up%20with%20current%20implementation%20code%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cuongnguyenphu_1-1716781698779.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cuongnguyenphu_1-1716781698779.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F280885i5A97DD1F0591EECB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cuongnguyenphu_1-1716781698779.png%22%20alt%3D%22cuongnguyenphu_1-1716781698779.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1879708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FS26%20FAQ%3A%20SPI%20Protocol%20Configuration%20is%20not%20sync%20with%20current%20FS26%20implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1879708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDiscussed%20internally%20%26nbsp%3B%3CBR%20%2F%3EFAQ%20will%20be%20updated%20later%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1875347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FS26%20FAQ%3A%20SPI%20Protocol%20Configuration%20is%20not%20sync%20with%20current%20FS26%20implementation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDiscussed%20internally%20with%20the%20author%20of%20the%20FS26%20FAQ%20document.%3C%2FP%3E%0A%3CP%3EThe%20fact%20is%20that%20the%20FS26%20uses%26nbsp%3Ba%2032-bit%20SPI%2C%20with%20the%20following%20arrangement%3A%3C%2FP%3E%0A%3CP%3EMOSI%20(Main%20Out%2C%20Secondary%20In)%20bits%3A%3CBR%20%2F%3E%E2%80%A2%20Bit%2031%3A%20Main%20or%20fail-safe%20registers%20selection%3CBR%20%2F%3E%E2%80%A2%20Bit%2030%20to%2025%3A%20Register%20address%E2%80%A2%20Bit%2024%3A%20Read%2FWrite%20(For%20reading%20Bit%2024%20%3D%200%3B%20For%20writing%20Bit%2024%20%3D%201)%3CBR%20%2F%3E%E2%80%A2%20Bit%2023%20to%208%3A%20Control%20bits%3CBR%20%2F%3E%E2%80%A2%20Bit%207%20to%200%3A%20Cyclic%20redundant%20check%20(CRC)%3C%2FP%3E%0A%3CP%3EMISO%20(Main%20In%2C%20Secondary%20Out)%20bits%3A%3CBR%20%2F%3E%E2%80%A2%20Bit%2031-24%3A%20General%20device%20status%3CBR%20%2F%3E%E2%80%A2%20Bits%2023%20to%208%3A%20Extended%20device%20status%2C%20or%20device%20internal%20control%20register%20content%20or%20device%20flags%26nbsp%3B%3CBR%20%2F%3E%E2%80%A2%20Bit%207%20to%200%3A%20Cyclic%20redundant%20check%20(CRC)%3C%2FP%3E%0A%3CP%3EBRs%2C%20Tomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
