ECC SRAM double-bit error injected triggers hardfault
n00b123
I am using Error inject Module to inject double-bit to SRAM_U, and the all codes about eim or erm are copied from the link:Example S32K14x SRAM ECC Injection - NXP Community The example from the link does not trigger the hardfault and I have made my code identical to the example.So what's wrong with my code?Can anyone do me a favor? Thanks!
danielmartynek
Hi @n00b123,
First of all, you can debug the exception following this document / example:
https://community.nxp.com/t5/S32K-Knowledge-Base/Fault-handling-on-S32K14x/ta-p/1114447
In SRAM_U, there is the stack, so there can be an issue on a function exit.
What S32K1xx part do you have?
If you have S32K11x, in SRAM_U, there is also the copy of the interrupt vector table.
The example you linked disables the copying of the table from PFlash to SRAM.
n00b123
Hi, Thank you for responding, I have compared the example with my code one by one and find the difference in linker files, that my linker files has not defined the __flash_vector_table__ which means the vector table will be copied into SRAM_U, this is the reason causes the bug.
danielmartynek
Hi @n00b123,
%3CLINGO-SUB%20id%3D%22lingo-sub-1881601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EECC%20SRAM%20double-bit%20error%20injected%20triggers%20hardfault%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1881601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20using%20Error%20inject%20Module%20to%20inject%20double-bit%20to%20SRAM_U%2C%20and%20the%20all%20codes%20about%20eim%20or%20erm%20are%20copied%20from%20the%20link%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K14x-SRAM-ECC-Injection%2Fta-p%2F1129181%22%20target%3D%22_blank%22%3EExample%20S32K14x%20SRAM%20ECC%20Injection%20-%20NXP%20Community%3C%2FA%3E%26nbsp%3BThe%20example%20from%20the%20link%20does%20not%20trigger%20the%20hardfault%20and%20I%20have%26nbsp%3B%3CSPAN%3Emade%20my%20code%20identical%20to%20the%20example.So%20what's%20wrong%20with%20my%20code%3FCan%20anyone%20do%20me%20a%20favor%3F%20Thanks!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1884624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20ECC%20SRAM%20double-bit%20error%20injected%20triggers%20hardfault%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1884624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20Thank%20you%20for%20responding%2C%20I%20have%20compared%20the%20example%20with%20my%20code%20one%20by%20one%20and%20find%20the%20difference%20in%20linker%20files%2C%20that%20my%20linker%20files%20has%20not%20defined%20the%20__flash_vector_table__%20which%20means%20the%20vector%20table%20will%20be%20copied%20into%20SRAM_U%2C%20this%20is%20the%20reason%20causes%20the%20bug.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1882696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20ECC%20SRAM%20double-bit%20error%20injected%20triggers%20hardfault%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1882696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233978%22%20target%3D%22_blank%22%3E%40n00b123%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EFirst%20of%20all%2C%20you%20can%20debug%20the%20exception%20following%20this%20document%20%2F%20example%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FFault-handling-on-S32K14x%2Fta-p%2F1114447%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FFault-handling-on-S32K14x%2Fta-p%2F1114447%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIn%20SRAM_U%2C%20there%20is%20the%20stack%2C%20so%20there%20can%20be%20an%20issue%20on%20a%20function%20exit.%3C%2FP%3E%0A%3CP%3EWhat%20S32K1xx%20part%20do%20you%20have%3F%3C%2FP%3E%0A%3CP%3EIf%20you%20have%20S32K11x%2C%20in%20SRAM_U%2C%20there%20is%20also%20the%20copy%20of%20the%20interrupt%20vector%20table.%3C%2FP%3E%0A%3CP%3EThe%20example%20you%20linked%20disables%20the%20copying%20of%20the%20table%20from%20PFlash%20to%20SRAM.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
