Example S32K144 PDB ADC trigger DMA ISR S32DS
* Detailed Description:
* This example shows how to use the back-to-back mode of the PDB to trigger
* sequence of ADC channels conversion. 4 PDB channel pre-triggers/triggers are
* generated upon single PDB SW trigger. The first trigger is started by the PDB,
* no delay is used. Next 3 triggers start after corresponding acknowledgment is
* received from ADC.
* DMA is configured to read the ADC result registers.
* Within DMA major interrupt the new conversion scan is started via PDB SW request.
* Converted data is used to change color of the EVB led based on Trimmer position.
* Test HW:         FRDM-S32K144
* MCU:             PS32K144HFVLL 0N77P
* Fsys:            160MHz
* Debugger:        S32DS
* Target:          internal_FLASH
附件
评论
Is DMA triggered after each of 4 channels conversion is completed or after all four conversions?
Never mind. I figure it out.
the DMA function does not work corrcetly in my S32 DS enviroment?
Hello  , the sample can not run normal ,after the  DMA0  Clock enabled   it will stop at  :
DefaultISR:
     b DefaultISR
could you give some help for this
I am also same symptom , it was stop at below DMA0 Clock enable line.
PCC->PCCn[PCC_DMA0_INDEX] |= PCC_PCCn_CGC_MASK;          // CGC=1: Clock enabled for DMA0
I had the same problem.
If you use this project then comment the enable clock line of the DMA.
//PCC->PCCn[PCC_DMA0_INDEX] |= PCC_PCCn_CGC_MASK;          // CGC=1: Clock enabled for DMA0
If you make a new project then you will need to enable the clock with a other code line. To enable the DMA clock write:
SIM->PLATCGC |= SIM_PLATCGC_CGCDMA_MASK;                                    //Enable clock DMA
To let the project work do you still need to change the register of the DMAMUX_CHCFG. This needs to be:
DMAMUX->CHCFG[0] |= DMAMUX_CHCFG_SOURCE(42);        // ADC0 COCO is the source of the DMA0 channel
Hello, I am trying to get my ADC results from R[0] assigned to a variable by using DMA. This code is not working for me.
Can you please tell me where can I find the  list of sources for the DMAMUX_CHCFG? In other words, where did you find the source number is 42?
I found it in the attached file (DMA Interrupt mapping) from the Reference manual.
Thanks! I want to use this code in a new project. I followed your instructions, but while building the project using this code, I get an error in IRQs_Init() method. Without this, the DMA doesn't work. Basically, I want to read analog signals from 2 different pins and transfer the ADC result to an array/variable via DMA. Is there a fix for this?
TIA.
In this code is the interrupt line written with FSL_NVIC.
With a new project should it be S32_NVIC.
Then it should work.
Thanks for the help. The code works now, I have 4 ADC channels passing the digital values from ADC result registers to the results array. The values also show up correctly.
I've run into another issue, I wanted to use the DMA in the first place for a faster rate. But it seems like the graph that I could plot WITHOUT using the DMA was better.
As you can see from this thread: https://community.nxp.com/thread/497208
Is there some clocking issue or something? Because I didn't change any codes in my ADC or PDB methods, just using DMA to get the results in the results array.
I don't know how the graph looks now. But it could be that you miss a sample because the PDB is restarted after the DMA is done with the data transfer. But i don't know how to fix this, sorry.
The link of the example is broken: Example-S32K144-PDB-ADC_backtoback-DMA-ISR-v1_0-S32DS.zip
%3CLINGO-SUB%20id%3D%22lingo-sub-1103221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E*********************************************************************************%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A**%20%E6%AD%A4%E7%A4%BA%E4%BE%8B%E6%BC%94%E7%A4%BA%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20PDB%20%E7%9A%84%E8%83%8C%E9%9D%A0%E8%83%8C%E6%A8%A1%E5%BC%8F%E8%A7%A6%E5%8F%91*%20ADC%20%E9%80%9A%E9%81%93%E7%9A%84%E8%BD%AC%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%824%20%E4%B8%AA%20PDB%20%E9%80%9A%E9%81%93%E7%9A%84%E9%A2%84%E8%A7%A6%E5%8F%91%2F%E8%A7%A6%E5%8F%91%E4%BA%8B%E4%BB%B6%E5%9C%A8%E5%8D%95%E4%B8%AA%20PDB%20%E8%BD%AF%E4%BB%B6%E8%A7%A6%E5%8F%91%E6%97%B6%E7%94%9F%E6%88%90%E3%80%82%E7%AC%AC%E4%B8%80%E4%B8%AA%E8%A7%A6%E5%8F%91%E5%99%A8%E7%94%B1%E5%8F%AF%E7%BC%96%E7%A8%8B%E5%BB%B6%E6%97%B6%E6%A8%A1%E5%9D%97(PDB)%E5%90%AF%E5%8A%A8%EF%BC%8C*%20%E4%B8%8D%E4%BD%BF%E7%94%A8%E5%BB%B6%E8%BF%9F%E3%80%82%E6%8E%A5%E4%B8%8B%E6%9D%A5%E7%9A%84%203%20%E4%B8%AA%E8%A7%A6%E5%8F%91%E5%99%A8%E5%9C%A8%E6%94%B6%E5%88%B0%E6%9D%A5%E8%87%AA%20ADC%20%E7%9A%84%E7%9B%B8%E5%BA%94%E7%A1%AE%E8%AE%A4%E5%90%8E%E5%90%AF%E5%8A%A8*%E3%80%82**%20DMA%20%E8%A2%AB%E9%85%8D%E7%BD%AE%E4%B8%BA%E8%AF%BB%E5%8F%96%20ADC%20%E7%BB%93%E6%9E%9C%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82*%20%E5%9C%A8%20DMA%20%E4%B8%BB%E8%A6%81%E4%B8%AD%E6%96%AD%E6%9C%9F%E9%97%B4%EF%BC%8C%E9%80%9A%E8%BF%87%20PDB%20%E8%BD%AF%E4%BB%B6%E8%AF%B7%E6%B1%82%E5%90%AF%E5%8A%A8%E6%96%B0%E7%9A%84%E8%BD%AC%E6%8D%A2%E6%89%AB%E6%8F%8F%E3%80%82**%20%E8%BD%AC%E6%8D%A2%E5%90%8E%E7%9A%84%E6%95%B0%E6%8D%AE%E7%94%A8%E4%BA%8E%E6%A0%B9%E6%8D%AE%E7%94%B5%E4%BD%8D%E5%99%A8%E4%BD%8D%E7%BD%AE%E6%9B%B4%E6%94%B9%20EVB%20LED%20%E7%9A%84%E9%A2%9C%E8%89%B2%E3%80%82**%20------------------------------------------------------------------------------*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AFRDM-S32K144*%20MCU%EF%BC%9APS32K144HFVLL%200N77P*%20Fsys%EF%BC%9A160MHz*%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%9AS32DS*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH*********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A4%BA%E4%BE%8B%E9%93%BE%E6%8E%A5%E5%B7%B2%E5%A4%B1%E6%95%88%EF%BC%9A%20%3CSTRONG%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20data-containerid%3D%2211647%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22339808%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339808%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3EExample-S32K144-PDB-ADC_backtoback-DMA-ISR-v1_0-S32DS.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103233%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E7%8E%B0%E5%9C%A8%E7%9A%84%E5%9B%BE%E8%A1%A8%E6%98%AF%E4%BB%80%E4%B9%88%E6%A0%B7%E5%AD%90%E7%9A%84%E3%80%82%E4%BD%86%E4%B9%9F%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9B%A0%E4%B8%BA%20DMA%20%E5%AE%8C%E6%88%90%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E5%90%8E%20PDB%20%E8%A2%AB%E9%87%8D%E5%90%AF%EF%BC%8C%E5%AF%BC%E8%87%B4%E9%81%97%E6%BC%8F%E4%BA%86%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%E3%80%82%E4%BD%86%E6%98%AF%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E4%BB%A3%E7%A0%81%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E4%BA%86%EF%BC%8C%E6%88%91%E6%9C%894%E4%B8%AAADC%E9%80%9A%E9%81%93%E5%B0%86ADC%E7%BB%93%E6%9E%9C%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84%E6%95%B0%E5%AD%97%E5%80%BC%E4%BC%A0%E9%80%92%E5%88%B0%E7%BB%93%E6%9E%9C%E6%95%B0%E7%BB%84%E4%B8%AD%E3%80%82%E8%BF%99%E4%BA%9B%E5%80%BC%E4%B9%9F%E6%AD%A3%E7%A1%AE%E6%98%BE%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%8E%9F%E6%9C%AC%E6%89%93%E7%AE%97%E4%BD%BF%E7%94%A8%20DMA%20%E6%9D%A5%E6%8F%90%E5%8D%87%E9%80%9F%E5%BA%A6%E3%80%82%E4%BD%86%E7%9C%8B%E8%B5%B7%E6%9D%A5%EF%BC%8C%E4%B8%8D%E4%BD%BF%E7%94%A8%20DMA%20%E7%BB%98%E5%88%B6%E7%9A%84%E5%9B%BE%E8%A1%A8%E6%95%88%E6%9E%9C%E5%8F%8D%E8%80%8C%E6%9B%B4%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%A6%82%E6%82%A8%E4%BB%8E%E6%AD%A4%E7%BA%BF%E7%A8%8B%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%EF%BC%9A%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F497208%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fthread%2F497208%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E6%97%B6%E9%92%9F%E9%97%AE%E9%A2%98%E6%88%96%E8%80%85%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%E5%91%A2%EF%BC%9F%E5%9B%A0%E4%B8%BA%E6%88%91%E6%B2%A1%E6%9C%89%E4%BF%AE%E6%94%B9%20ADC%20%E6%88%96%20PDB%20%E6%96%B9%E6%B3%95%E4%B8%AD%E7%9A%84%E4%BB%BB%E4%BD%95%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%8F%AA%E6%98%AF%E4%BD%BF%E7%94%A8%20DMA%20%E5%B0%86%E7%BB%93%E6%9E%9C%E5%86%99%E5%85%A5%E7%BB%93%E6%9E%9C%E6%95%B0%E7%BB%84%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103231%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E4%B8%AD%E6%96%AD%E8%A1%8C%E6%98%AF%E7%94%A8%20FSL_NVIC%20%E7%BC%96%E5%86%99%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E6%96%B0%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20S32_NVIC%20%E5%91%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%E5%AE%83%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87DMA%E5%B0%86R%5B0%5D%E4%B8%AD%E7%9A%84ADC%E7%BB%93%E6%9E%9C%E8%B5%8B%E5%80%BC%E7%BB%99%E4%B8%80%E4%B8%AA%E5%8F%98%E9%87%8F%E3%80%82%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%E5%AF%B9%E6%88%91%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%91%8A%E8%AF%89%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EDMAMUX_CHCFG%20%E7%9A%84%E6%9D%A5%E6%BA%90%E6%B8%85%E5%8D%95%EF%BC%9F%E6%8D%A2%E5%8F%A5%E8%AF%9D%E8%AF%B4%EF%BC%8C%E6%82%A8%E6%98%AF%E5%9C%A8%E5%93%AA%E9%87%8C%E6%89%BE%E5%88%B0%E6%9D%A5%E6%BA%90%E7%BC%96%E5%8F%B7%E4%B8%BA%2042%20%E7%9A%84%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103225%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E5%BC%82%E5%B8%B8%EF%BC%8C%E5%90%AF%E7%94%A8%3CSPAN%3EDMA0%3C%2FSPAN%3E%E6%97%B6%E9%92%9F%E5%90%8E%EF%BC%8C%E7%A8%8B%E5%BA%8F%E4%BC%9A%E5%8D%A1%E6%AD%BB%E5%9C%A8%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3EDefaultISR%EF%BC%9A%3CBR%20%2F%3E%20%20%20%20b%20DefaultISR%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E5%BF%99%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDMA%20%E5%8A%9F%E8%83%BD%E5%9C%A8%E6%88%91%E7%9A%84%20S32%20DS%20%E7%8E%AF%E5%A2%83%E4%B8%AD%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B2%A1%E5%85%B3%E7%B3%BB%E3%80%82%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20S32K144%20PDB%20ADC%20%E8%A7%A6%E5%8F%91%20DMA%20ISR%20S32DS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EDMA%20%E6%98%AF%E5%9C%A8%E6%AF%8F%E4%B8%AA%E9%80%9A%E9%81%93%E8%BD%AC%E6%8D%A2%E5%AE%8C%E6%88%90%E5%90%8E%E8%A7%A6%E5%8F%91%EF%BC%8C%E8%BF%98%E6%98%AF%E5%9C%A8%E6%89%80%E6%9C%89%E5%9B%9B%E4%B8%AA%E9%80%9A%E9%81%93%E7%9A%84%E8%BD%AC%E6%8D%A2%E5%AE%8C%E6%88%90%E5%90%8E%E8%A7%A6%E5%8F%91%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎10-19-2016 04:35 AM
更新人:
